無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。
DATA SHEET
FIBERGLASS CEMENT RESISTORS
Power, Wirewound, Vertical Mount
PSM Series
±5%, ±10%
4W to 17W
Product specification – August 12, 2021 V.0
RoHS compliant & Halogen Free
Through Hole Resistors
Fiberglass Cement Resistors
Product Specification
ORDERING INFORMATION
Part number of the fiberglass cement resistor is identified by the series,
power rating, tolerance, packing, temperature coefficient and resistance
value.
PART NUMBER
APPLICATIONS
Power applications
Home appliance
Industry
PSM
400
J
B
100R
(1)
(2)
(3)
(4)
(5)
(6)
(1) SERIES
PSM series
(2) POWER RATING
400 = 4W
900 = 9W
FEATURES
500 = 5W
11A = 11W
Fiberglass core, high ohmic
7WS = 7 W
17A = 17W
Miniaturization
Axial terminal
Flameproof ceramic case
RoHS compliant and halogen
free
700 = 7W
(3) TOLERANCE
J = ±5%
K = ±10%
(4) PACKAGING
B = Bulk
(5) TEMPERATURE COEFFICIENT OF RESISTANCE
- = Based on spec.
(6) RESISTANCE VALUE
E24 Series
Example:
0R1 = 0.1Ω, 100R = 100Ω, 1K = 1,000Ω
www.yageo.com
Aug. 12, 2021
V.0
2
7
PSM
7
PSM
DIMENSIONS
Unit: mm
Normal
Miniature
L
W
H
ψd
PSM400
20±1.0
7.0±0.5
8.0±0.4
0.8±0.02
PSM500
25±1.0
7.0±0.5
8.0±0.4
0.8±0.02
PSM7WS
25±1.0
9.0±0.4
10.0±0.4
0.8±0.02
PSM700
38±1.0
7.0±0.5
8.0±0.4
0.8±0.02
PSM900
38±1.0
9.0±0.4
10.0±0.4
0.8±0.02
PSM11A
50±1.0
9.0±0.4
10.0±0.4
0.8±0.02
PSM17A
75±1.0
9.0±0.4
10.0±0.4
0.8±0.02
DERATING CURVE
Rated Power (%)
100
80
60
40
275
Ambient Temperature (°C)
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS
PSM400
PSM500
PSM7WS
PSM700
PSM900
PSM11A
PSM17A
Power Rating at 70 °C
4W
5W
7W
7W
9W
11W
17W
Voltage Proof on Insulation
2000V
2000V
2000V
2000V
2000V
2000V
2000V
Maximum Working Voltage
√(P X R)
Resistance Range
0.1Ω ~
2.2KΩ
0.1Ω ~
2.2KΩ
0.1Ω ~
2.5KΩ
0.1Ω ~
3.9KΩ
0.1Ω ~
3.9KΩ
1Ω ~
10KΩ
1Ω ~
10KΩ
Operating Temp. Range
- 55°C to +275°C
Temperature Coefficient
see table I
Note: For resistance value out of above range is by request.
www.yageo.com
Aug. 12, 2021
V.0
3
7
PSM
TABLE I TEMPERATURE COEFFICIENT
TYPE
TEMP. COEFFICIENT ±400 PPM/ °C
TEMP. COEFFICIENT ±100 PPM/ °C
PSM400
≤0.2Ω
≥0.22Ω
PSM500
≤0.3Ω
≥0.33Ω
PSM700
≤0.68Ω
≥0.75Ω
PSM7WS
≤0.3Ω
≥0.33Ω
PSM900
≤0.68Ω
≥0.75Ω
PSM11A
≤1Ω
≥1.1Ω
PSM17A
≤1.6Ω
≥1.8Ω
TEST AND REQUIRMENTS
TEST
TEST METHOD
Short Time Overload
IEC 60115-1 4.13
10 times rated power for 5 sec.
±2.0%+0.05Ω
Voltage Proof on
IEC 60115-1 4.7
In V-Block for 60 sec. test voltage as
No Breakdown
Insulation
PROCEDURE
APPRAISE
above table
IEC 60115-1 4.8
Between -55°C to +155°C
By Type
Insulation Resistance
IEC 60115-1 4.6
>10,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
Marking
coatings and markings
Robustness of
IEC 60115-1 4.16
Terminations
Periodic-pulse Overload
Direct load for 10 Sec. in the direction of
≥50N
the terminal leads
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on,
±2.0%+0.05Ω
25 Sec.off)
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C,90-95% RH for 56 days, loaded
±2.0%+0.05Ω
with 0.1 times RCWV
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV(or Umax., whichever
±3.0%+0.05Ω
less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off)
Temperature Cycling
IEC 60115-1 4.19
-55°C
Room Temp.
±2.0%+0.05Ω
+155°C Room Temp.(5 cycles)
Resistance to Soldering
Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a
±2.0%+0.05Ω
point 3±0.5mm from the body
www.yageo.com
Aug. 12, 2021
V.0
4
7
PSM
Note:
RCWV (Rated Continuous Working Voltage ):
The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following
formula:
V=√(P X R)
or max. working voltage whichever is less
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω)
BULK PACKING
Unit: Piece
Normal
Miniature
PACKAGE
Quantity
PSM400
Bulk
1,000
PSM500
Bulk
1,500
PSM700
Bulk
600
PSM7WS
Bulk
500
PSM900
Bulk
500
PSM11A
Bulk
500
PSM17A
Bulk
500
MARKING
Example:
YAGEO
= Brand
1210
= Date code
7WS
= Power rating
100R
= Resistance
J
= Tolerance
www.yageo.com
Aug. 12, 2021
V.0
5
7
PSM
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 0
Aug.2, 2021
- First issue of this specification
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as
the products itse lf are unchanged. Any product change will be announced by PCN.”
www.yageo.com
Aug. 12, 2021
V.0
6
7
PSM
LEGAL DISCLAIMER
Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors,
inaccuracies or incompleteness contained in any product related information, including but not limited to product
specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or
improvements to product related information at any time and without notice.
Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular
purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo
disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability,
including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties,
including warranties of fitness for a particular purpose, non-infringement and merchantability.
Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s
knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are
neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a
specific customer application or use. They are intended for use only by customers with requisite knowledge and
experience for determining whether Yageo products are the correct products for their application or use. In
addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or
use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective
safeguard measures to ensure that product failure would not result in personal injury or property damage.
Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for
any other application or use in which the failure of Yageo products could result in personal injury or death.
Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at
their own risk and agree to fully indemnify Yageo and hold Yageo harmless.
Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this
content without further notification, as long as products are unchanged. Any product change will be announced by PCN.
www.yageo.com
Aug. 12, 2021
V.0
7
