LCB Series
Stackpole Electronics, Inc.
Ceramic Housed Current Sensing Resistor with 2 Leads
Resistive Product Solutions
Features:
Fireproof construction
Low temperature coefficient
Low resistance value ceramic encased resistor
All welded termination
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Formed leads possible on some sizes – contact Stackpole
See CB datasheet for performance and environmental
specifications
Electrical Specifications
Power Rating (W)
@ 70ºC
2
3
5
7
10
15
Type / Code
LCBF2
LCB3
LCB5
LCB7
LCB10
LCB15
TCR (ppm/ºC)
(1)
1%
±200
Ohmic Range (Ω) and Tolerance
5%
10%
0.05 - 0.33
0.005 - 0.1
±50 to ±400
0.01 - 0.15
0.01 - 0.2
(1) TCR is value dependent. Please contact Stackpole for specific data.
Max Voltage Rating = √ P*R
Mechanical Specifications
Resistance measured 3/8” from the body
Alternate Configuration Series LCBF:
Type / Code
A
B
C
D
LCBF2
0.709 ± 0.039
18.00 ± 1.00
0.157 ± 0.020
4.00 ± 0.50
0.276 ± 0.020
7.00 ± 0.50
0.031 ± 0.002
0.80 ± 0.05
0.197 + 0.039 / -0.020 inches
5.00 + 1.00 / -0.50
mm
LCB3
0.874 ± 0.031
22.20 ± 0.80
0.311 ± 0.031
7.90 ± 0.80
0.311 ± 0.031
7.90 ± 0.80
0.032 ± 0.002
0.81 ± 0.05
0.374 ± 0.031
9.50 ± 0.80
inches
mm
LCB5
0.874 ± 0.031
22.20 ± 0.80
0.374 ± 0.031
9.50 ± 0.80
0.374 ± 0.031
9.50 ± 0.80
0.032 ± 0.002
0.81 ± 0.05
0.437 ± 0.031
11.10 ± 0.80
inches
mm
LCB7
1.402 ± 0.031
35.60 ± 0.80
0.374 ± 0.031
9.50 ± 0.80
0.374 ± 0.031
9.50 ± 0.80
0.036 ± 0.002
0.91 ± 0.05
0.500 ± 0.031
12.70 ± 0.80
inches
mm
LCB10
1.874 ± 0.031
47.60 ± 0.80
0.374 ± 0.031
9.50 ± 0.80
0.374 ± 0.031
9.50 ± 0.80
0.036 ± 0.002
0.91 ± 0.05
0.500 ± 0.031
12.70 ± 0.80
inches
mm
LCB15
1.874 ± 0.031
47.60 ± 0.80
0.500 ± 0.031
12.70 ± 0.80
0.500 ± 0.031
12.70 ± 0.80
0.036 ± 0.002
0.91 ± 0.05
0.626 ± 0.031
15.90 ± 0.80
inches
mm
Rev Date: 11/30/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
E (LCBF only)
Unit
www.seielect.com
marketing@seielect.com
LCB Series
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
2
www.seielect.com
LCB Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Package /
Standard
Lead-Free Termination
Termination Series RoHS
Composition
Type
Compliant
Description
LCB
Axial
YES
100% Matte Sn
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Jan-06
06/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
L
Product Series
Code
Description
LCB
Standard
LCBF With standoff
C
Power Rating
W
Code
2
2
3
3
5
5
7
7
10
10
15
15
B
3
Tolerance
Code Tol
F
1%
J
5%
K
10%
J
B
Code Description
B
Bulk
3
R
1
Packaging
Resistance Value
Four characters with the
Size
Quantity
multiplier used as the
LCBF2
2000
decimal holder.
LCB3, LCB5
750
LCB7, LCB10, LCB15
250
"L" used as multiplier of 103
for any value under 0.1
ohm.
0.005 ohm = 5L00
0.01 ohm = 10L0
0.1 ohm = R100
www.seielect.com
很抱歉,暂时无法提供与“LCB5JB33L0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 750+4.92680750+0.63782
