RF/Microwave Capacitors
RF/Microwave Multilayer Capacitors (MLC)
600F Ultra-Low ESR, High Q, NPO Capacitors
FEATURES
Lowest ESR in Class
Highest Working Voltage in Class - 250 V
Standard EIA Size: 0805
Laser Marking (Optional)
High Self-Resonance Frequencies
600 SERIES OVERVIEW
APPLICATIONS
• Subscriber-based Wireless
Devices
• WiFi (802.11)
• Public Safety Radio
CIRCUIT
APPLICATIONS
EIA Case Size
600
L
0402
600
S
0603
600
F
0805
Tape & Reel
Vertical
Orientation
Tape & Reel
LEAD-FREE COMPATIBLE
COMPONENT
ENVIRONMENTAL CHARACTERISTICS
• Filter Networks
• High Q Frequency
Sources
• Matching Networks
• Tuning, Coupling, Bypass
and DC Blocking
ELECTRICAL SPECIFICATIONS
Temperature
Coefficient (TCC)
0 ± 30 PPM/ºC
Capacitance Range
0.1 pF to 240 pF
Operating Temperature
-55ºC to +125ºC*
Quality Factor
Greater than 2,000 @ 1 MHz
Themal Shock
5 Cycles, -55ºC to 125ºC
Moisture Resistance
Mil-STD-202, Method 106
Life Test
2000 hours at 125ºC at 2X WVDC
Solderability
Solder Coverage > 90% of end
termination
Terminal Strength
4 lbs. typ., 2 lb. min.
Military Approval
DSCC Drawing Number 05001
105 Megohms min. @ 25ºC at
rated WVDC
104 Megohms min. @ 125ºC at
rated WVDC
Working Voltage
(WVDC)
250 V
Dielectric Withstanding
Voltage (DWV)
250% of rated WVDC for 5 seconds
Aging Effects
None
Piezoelectric Effects
None
488
Case Size
PACKAGING OPTIONS
• Cellular Base Stations
• Broadband Wireless
Services
• Satellite
Communications
Insulation
Resistance (IR)
Series
The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available
online at www.kyocera-avx.com/disclaimer/ by reference and should be reviewed in full before placing any order.
TDS-RFM-0014 | Rev 1
– rf microwave products –
CAPACITANCE VALUES
Value
(pF)
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1.2
1.3
1.5
1.6
1.8
2.0
2.2
2.4
2.7
3.0
Cap
Code
0R1
0R2
0R3
0R4
0R5
0R6
0R7
0R8
0R9
1R0
1R1
1R2
1R3
1R5
1R6
1R8
2R0
2R2
2R4
2R7
3R0
Marking
Tolerances
A9
H9
M9
d9
f9
m9
n9
t9
y9
A0
B0
C0
D0
E0
F0
G0
H0
J0
K0
L0
M0
A, B
A, B
A, B, C
A, B, C
A, B, C
A, B, C
A, B, C
A, B, C
A, B, C
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
Value
(pF)
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
15
18
24
27
Cap
Code
3R3
3R6
3R9
4R3
4R7
5R1
5R6
6R2
6R8
7R5
8R2
9R1
100
110
120
150
180
200
220
240
270
Marking
Tolerances
N0
P0
Q0
R0
S0
T0
U0
V0
W0
X0
Y0
Z0
A1
B1
C1
E1
G1
H1
J1
K1
L1
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
A, B, C, D
B, C, J, K
B, C, J, K
B, C, J, K
B, C, J, K
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
Value
(pF)
30
33
36
39
43
47
51
56
62
68
75
82
91
100
110
120
150
180
200
220
240
Cap
Code
300
330
360
390
430
470
510
560
620
680
750
820
910
101
111
121
151
181
201
221
241
Marking
Tolerances
M1
N1
P1
Q1
R1
S1
T1
U1
V1
W1
X1
Y1
Z1
A2
B2
C2
E2
G2
H2
J2
K2
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
F, G, J, K, M
HOW TO ORDER
600
F
100
J
T
250
X**
T
Series
Packaging
Case Size
T = Tape and Reel, 500 pcs
T4K = Tape and Reel, 4000 pcs
TV = Vertical Tape and Reel, 500 pcs
See mechanical dimensions below
Capacitance Code
EIA Capacitance Code in pF.
Third digit = number of zeros or after “R” significant figures
Voltage Rating
Capacitance Tolerance Code
Code
Tol.
A
B
C
Termination Style Code
D
±0.05 pF ±0.1 pF ±0.25 pF ±0.5 pF
F
G
J
K
M
±1%
±2%
±5%
±10%
±20%
The above part number refers to a 600F Series (case size F) 10 pF capacitor, J tolerance (±5%), 250 WVDC, with T termination
(Tin Plated over Nickel Barrier, RoHS Compliant), Laser Marking and Tape and Reel packaging.
T = Tin Plated over Nickel Barrier
(RoHS Compliant)
TN = Tin Plated Non-Magnetic Barrier
W = Tin/Lead Solder Nickel Barrier
**Laser Marking is optional
489
600F Series Data Sheet Condition Description
Capacitors horizontally mounted on 23.3 -mil thick Rogers R0435® softboard 52-mils wide 1/2 oz. Cu traces
FSR = lowest frequency at which S11 response, referenced at capacitor edge, crosses real axis on Smith Chart.
FPR = lowest frequency at which there is a notch in S21 magnitude response.
490
OUTLINE DIMENSIONS
Y
L (0805)
W
L: .079 ± .008 (2.01 ± 0.20)
W: .049 ± .008 (1.24 ± 0.20)
T: .051 max (1.30 max)
Y: .020 ± 0.01 (0.51 ± 0.25)
inches (mm)
T
L
SUGGESTED MOUNTING PAD DIMENSIONS
W
L
T
B
A
B
Case Size L, S, and F
Case Size
A Min.
B Min.
C Min.
D Min.
0402 (1005)
.0275
(0.70)
.0354
(0.90)
.0157
(0.40)
.0866
(2.20)
0603 (1608)
.0393
(1.00)
.0433
(1.10)
.0236
(0.60)
.110
(2.80)
0805 (2012)
.0590
(1.50)
.0512
(1.30)
.0236
(0.60)
.1259
(3.20)
inches (mm)
C
D
DESIGN KITS
Item #
Description
Cap. Value
Range (pF)
DK0032T
600F Series Ultra-low ESR,
High Q Microwave Capacitors
16 different values,
15 pcs. min. per value
0.1 to 2.0
DK0033T
0.1 to 10
Kit 34T
DK0034T
10 to 27
Kit 35T
DK0035T
7 different values,
100 to 240
Kit #
Kit 32T
Kit 33T
RoHS
Compliant
Cap. Value (pF)
Tol. (pF)
0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8,0.9,
1.0, 1.1, 1.2, 1.5...............................................±0.1%
Price
$100.00
1.6, 1.8, 2.0......................................................±0.25%
1.0, 1.2, 1.5, 1.8, 2.0. 2.2, 2.4, 2.7, 3.0, 3.3.....±0.1%
3.9, 4.7, 5.6, 6.8, 8.2........................................±0.25%
$100.00
10.....................................................................±5%
10, 12, 15, 18, 20, 22, 24, 27............................±5%
$100.00
100, 120, 150, 180, 200, 220, 240...................±5
$55.00
For Online Kit Orders, Catalog & Application Notes, Visit: www.avx.com
491
