MMSZ5231B-7-F
MMSZ5231B-7-F
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD123
    DIODE ZENER 5.1V 500MW SOD123
MMSZ5231B-7-F 数据手册
MMSZ5221B - MMSZ5259B 500mW SURFACE MOUNT ZENER DIODE Features Mechanical Data         500mW Power Dissipation General Purpose, Medium Current Ideally Suited for Automated Assembly Processes Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Notes 3 & 4) Qualified to AEC-Q101 Standards for High Reliability Case: SOD123 Case Material: Molded Plastic, “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 1 per J-STD-020 Terminals: Matte Tin Finish Annealed over Alloy 42 Leadframe (Lead Free Plating). Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.01 grams (Approximate)     SOD123 Top View Ordering Information (Note 5) Part Number (Type Number)-7-F* (Type Number)Q-7-F* (Type Number)-13-F* (Type Number)Q-13-F* Qualification Commercial Automotive Commercial Automotive Case SOD123 SOD123 SOD123 SOD123 Packaging 3,000/Tape & Reel 3,000/Tape & Reel 10,000/Tape & Reel 10,000/Tape & Reel *For (Type Number), please see the Electrical Characteristics Table. Example: 6.2V Zener = MMSZ5234B-7-F. Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS) & 2011/65/EU (RoHS 2) compliant. 2. See http://www.diodes.com for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain
MMSZ5231B-7-F
物料型号: - 型号从MMSZ5221B到MMSZ5259B
器件简介: - 500mW表面贴装Zener二极管,适用于一般目的和中等电流,非常适合自动化装配流程。 - 完全符合RoHS指令和AEC-Q101标准,无铅且完全符合环保要求。
引脚分配: - SOD123封装,带有阴极带的阳极二极管。
参数特性: - 正向电压(在10mA电流下)为0.9V。 - 功率耗散在+75°C时为500mW,在+25°C时为370mW。 - 热阻从结到环境空气为338°C/W。 - 工作和储存温度范围为-65°C至+150°C。
功能详解: - 提供详细的电气特性表,包括Zener电压范围、测试电流、最大Zener阻抗和最大反向漏电流等参数。
应用信息: - 这些Zener二极管适用于一般用途,特别是在需要自动化装配和环保合规性的应用中。
封装信息: - 提供了SOD123封装的尺寸和建议的焊盘布局。
MMSZ5231B-7-F 价格&库存
很抱歉,暂时无法提供与“MMSZ5231B-7-F”相匹配的价格&库存,您可以联系我们找货
