SHUNTS &
JUMPERS
(2.54 mm) .100" PITCH • SNT/MNT/2SN/SNM/PK/JL SERIES
SNT/MNT
Mates:
TSW, HTSW, MTSW,
HMTSW, TLW, DW, EW,
ZW, HW, TSM, BST, PHT
SNT
100
BODY
COLOR
–BK
Mates:
TMMH, TMM,
MTMM, MMT, TW,
LTMM, ZLTMM, TSH, EHT
= Red
–BL
Mates:
TMS, MTMS, DWM
SPECIFICATIONS
Insulation
is white
Teflon®
= Tin
(14.00)
.550
= Yellow
(6.10)
.240
A
(0.64) .025
DIA REF
(3.18)
.125
(2.54)
.100
(5.08)
.200
Note:
Other Gold plating options available.
SNT
Insulator Material:
Glass Filled Polyester
Contact Material:
Phosphor Bronze
Current Rating (SNT/TSW):
4.3 A per pin
(1 pin powered per row)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(4.32 mm) .170" minimum
Lead Size accepted:
(0.64 mm) .025" SQ
–H
= Handle
(Black Only)
–YW
(6.10)
.240
JL
HANDLE
OPTION
–T
= Blue
SNM
= 10 µ"
(0.25 µm)
Gold
–RD
(2.54)
.100
PLATING
OPTION
–G
= Black
2SN
MNT
NO. OF
POSITIONS
1
02 thru 20
BODY
COLOR
–BK
= Black
PLATING
OPTION
–G
= 10 µ" (0.25 µm) Gold
–T
= Tin
MNT
(5.08)
.200
Same as SNT except:
Current Rating (MNT/TSM):
3.9 A per pin
Working Voltage:
450 VAC
PART NO.
A
JL–100–25–T
(2.54)
.100
JL–250–25–T
(6.35)
.250
JL–400–25–T
(10.16)
.400
Note:
For complete
specifications see
www.samtec.com?JL
(2.54) .100 X No. of Positions
2SN
PK
(6.10)
.240
Same as SNT except:
Insertion Depth:
(2.29 mm) .090" minimum
Lead Size accepted:
(0.51 mm) .020" SQ
Note:
Some lengths, styles and options
are non-standard, non-returnable.
SNM
B
Same as SNT except:
Insertion Depth:
(3.43 mm) .135" minimum
Max Processing Temp:
Not recommended for IR/VP
2SN
SNM
A
PART NO.
(1.27)
.050
(3.99)
.157
(1.02)
.040
(3.30)
.130
A
B
PK–01–06
(0.64)
(5.84)
.025
.230
SQ
PK–01–07
(0.51)
(3.18)
.020
.125
SQ
PART NO.
(4.45)
.175
2SN-BK-G
PART NO.
SNM-100-BK-G
(2.00)
.0787
Insulator Material:
Natural Thermoplastic
Note:
Order per wheel.
6 pins per wheel.
samtec.com?SNT, samtec.com?MNT, samtec.com?2SN or samtec.com?SNM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-221
很抱歉,暂时无法提供与“PK-01-07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 14+15.77876
- 50+13.03410
- 100+10.20481
- 500+6.17851
- 1000+5.82787
- 2000+5.74323
- 国内价格 香港价格
- 1+17.134741+2.21368
