PESD12VS1UB-N
ESD Protection Diode
»Features
350Watts peak pulse power (tp = 8/20μs)
Unidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±8kV contact ±15kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 10A (8/20μs)
»Applications
»Mechanical Data
Microprocessor based equipment
SOD523 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
»Schematic & PIN Configuration
SOD-523
Revision 2018
www.born-tw.com
1/4
PESD12VS1UB-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
350
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
10
A
VESD
15
8
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
Max
Units
12.0
V
VBR
IT=1mA
13.3
V
Reverse Leakage Current
IR
VRWM=12V,T=25℃
1
uA
Clamping Voltage
VC
IPP=10A,tp=8/20μs
35
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
55
pF
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RW M
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RW M
VC VBR VRWM
IR VF
IT
Breakdown Voltage @ IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD12VS1UB-N
»Typical Characteristics
Figure 1: Peak Pulse Power vs. Pulse Time
Figure 2: Power Derating Curve
110
350w 8/20µs waveform
1
0.1
0.01
0.1
1
10
100
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
10
90
80
70
60
50
40
30
td – Pulse Duration - µs
90
Ipp
80
Percent
100
125
150
Test
Waveform
Paramters
tr=8µs
td=20µs
40
Clamping Voltage–VC (V)
100
e-1
50
40
td=Ipp/2
45
Waveform
Paramters
tr=8µs
td=20µs
30
50
Figure 4: Clamping Voltage vs.Ipp
110
60
25
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
70
25
10
5
10
Revision 2018
10
15
Time (µs)
30
4
6
8
10
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
PESD12VS1UB-N
»Outline Drawing – SOD523
D
-X-YE
1
DIMENSIONS
2
SYMBOL
b 2x
0.08 (0.0032)
X
A
b
C
D
E
HE
L
Y
A
C
HE
L
MILLIMETER
INCHES
MIN
MAX
MIN
MAX
0.50
0.25
0.07
1.10
0.70
1.50
0.15
0.70
0.35
0.20
1.30
0.90
1.70
0.25
0.020
0.010
0.0028
0.043
0.028
0.059
0.006
0.028
0.014
0.0079
0.051
0.035
0.067
0.010
»Marking
1
ZM
2
»Ordering information
Order code
PESD12VS1UB-N
Revision 2018
Package
Base qty
Delivery mode
SOD523
5000
Tape and reel
www.born-tw.com
4/4
很抱歉,暂时无法提供与“PESD12VS1UB-N”相匹配的价格&库存,您可以联系我们找货
