BSD5A241V35
BSD5A241V35
    BORN(伯恩)
    SOD-523(SC-79)
    ESD保护 VRWM=24V VBR(Min)=26.7V VC=45V IPP=5A Ppp=280W SOD523
BSD5A241V35 数据手册
BSD5A241V35 ESD Protection Diode »Features ■ 280Watts peak pulse power (tp = 8/20μs) ■ Unidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 5A (8/20μs) »Applications »Mechanical Data ■ Microprocessor based equipment ■ SOD523 package ■ Personal Digital Assistants (PDA’s) ■ Molding compound flammability rating: UL 94V-0 ■ Notebooks, Desktops, and Servers ■ Packaging: Tape and Reel ■ Portable Instrumentation ■ RoHS/WEEE Compliant ■ Pagers Peripherals »Schematic & PIN Configuration SOD-523 Revision 2018 www.born-tw.com 1/4 BSD5A241V35 »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs) PPP 280 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 5 A VESD 30 30 kV ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ »Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM Max Units 24.0 V V VBR IT=1mA 26.7 Reverse Leakage Current IR VRWM=24.0V,T=25℃ Clamping Voltage VC IPP=5A,tp=8/20μs 45 V Junction Capacitance Cj VR = 0V, f = 1MHz 30 pF 0.5 uA »Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP V RW M IR V BR IT I IF Working Peak Reverse Voltage Maximum Reverse Leakage Current @ V RW M VC VBR VRWM IR VF IT Breakdown Voltage @ IT V Test Current IPP Note:. 8/20μs pulsewaveform. Revision 2018 www.born-tw.com 2/4 BSD5A241V35 »Typical Characteristics Figure 1: Peak Pulse Power vs. Pulse Time Figure 2: Power Derating Curve 110 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) 10 280w 8/20µs waveform 1 0.1 0.01 0.1 1 10 100 100 90 80 70 60 50 40 30 20 10 0 1,000 td – Pulse Duration - µs 90 Percent Ipp 80 e-1 50 40 td=Ipp/2 0 5 Revision 2018 10 15 125 150 35 30 25 Test Waveform Para m ters tr=8μ s td=20μ s 20 15 10 5 10 0 100 40 Clamping Voltage–VC (V) 100 20 75 45 Waveform Paramters tr=8µs td=20µs 30 50 Figure 4: Clamping Voltage vs.Ipp 110 60 25 Ambient Temperature - TA (℃) Figure3: Pulse Waveform 70 0 Time (µs) 20 25 30 0 2 www.born-tw.com 4 6 8 10 12 14 16 Peak Pulse Current–IPP (A) 3/4 BSD5A241V35 »Outline Drawing – SOD523 D -X-YE 1 DIMENSIONS 2 SYMBOL b 2x 0.08 (0.0032) X Y A C L HE A b C D E HE L MILLIMETER INCHES MIN MAX MIN MAX 0.50 0.25 0.07 1.10 0.70 1.50 0.15 0.70 0.35 0.20 1.30 0.90 1.70 0.25 0.020 0.010 0.0028 0.043 0.028 0.059 0.006 0.028 0.014 0.0079 0.051 0.035 0.067 0.010 »Marking 1 KR 2 »Ordering information Order code BSD5A241V35 Revision 2018 Package Base qty Delivery mode SOD523 5000 Tape and reel www.born-tw.com 4/4
BSD5A241V35 价格&库存
很抱歉,暂时无法提供与“BSD5A241V35”相匹配的价格&库存,您可以联系我们找货
BSD5A241V35
  • 1+0.29742
  • 100+0.27759
  • 300+0.25777
  • 500+0.23794
  • 2000+0.22802
  • 5000+0.22207
