SS210SMB
SS210SMB
    BORN(伯恩半导体)
    SMB
    SS210SMB
SS210SMB 数据手册
SS22-210 SERIES SCHOTTKY SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS ROHS FEATURES  Schottky barrier rectifier  Guardring protection  Low forward voltage  Reverse energy tested  High current capability  Extremely low thermal resistance MECHANICAL DATA     Case: SMB molded plastic body 1111 Polarity: Color band denotes cathode end Mounting position: ANY Weight: 0.003 ounces, 0.093 gram MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25oC ambient temperature unless otherwise specified Device marking code SS22 SS23 SS24 SS25 SS26 SS28 SS29 S210 UNITS Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 90 100 V Maximum RMS voltage VRWS 14 21 28 35 42 56 63 70 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 90 100 V Maximum average forward rectified current at TL=90 IF(AV) 2.0 A Peak forward surge current 8.3ms single half-sine-wave IFSM 75 A Maximum instantaneous forward voltage at I FM=2.0A (NOTE1) VF Maximum DC reverse current TJ=25 at rated DC blocking voltage TJ=125 Maximum thermal resistance Operating temperature range Storage temperature range IR R 0.75 0.50 0.85 0.4 0.03 10 5.0 28 JL V mA o C/W TJ -55 ---- +125 o C TSTG -55 ---- +150 o C NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 % Rev 8: Nov 2014 www.born-tw.com Page 1 of 2 SS22-210 SERIES SCHOTTKY SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS 2.0 FIG.2-- PEAK FORWARD SURGE CURRENT Resistive or inductive Load 1.0 P.C.B.MOUNTED ON 0.2X0.2(5.0X5.0mm) COPPERPAD AREAS 0 50 60 70 80 90 100 110 120 130 140 150 160 170 PEAK FORWARD SURGE CURRENT,AMPERES CURRENT,AMPERES FIG.1 -- FORWARD DERATING CURVE LEAD TEMPERATURE 75 T L =100℃ 8.3ms Single Half Sine-Wave (JED E C M ethod) 60 45 30 15 0 1 10 10 0 NUMBER OF CYCLES AT 60Hz FIG.3 -- TYPICAL FORWARD CHARACTERISTICS FIG.4 -- TYPICAL REVERSE CHARACTERISTICS 1 SS 25 ~S S2 SS 6 28 ~S S2 10 10 INSTANTANEOUS REVERSE CURRENT,MICRO AMPERES 100 SS 22~ SS 24 INSTANTANEOUS FORWARD CURRENT,AMPERES ROHS 0.1 0.01 Tj=25oC Pulse Width=300 s 1% Duty Cycle .2 .3 .4 .5 .6 .7 .8 SS28-SS210 1.0 TJ=125℃ 0.1 SS22-SS26 SS28-SS210 0.01 0.001 T J=25℃ SS22-SS26 0.001 0 20 40 60 80 1 00 .9 INSTANTANEOUS FORWARD VOLTAGE,VOLTS Rev 8: Nov 2014 10 www.born-tw.com PERCENT OF RATED PEAK REVERSE VOLTAGE, Page 2 of 2
SS210SMB 价格&库存
很抱歉,暂时无法提供与“SS210SMB”相匹配的价格&库存,您可以联系我们找货
