BZ-S2835ZW9C1-02-3V-UV
    BAIZOU(百洲)
    LED_2.8X3.5MM_SM
BZ-S2835ZW9C1-02-3V-UV 数据手册
深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. 产 品 规 格 书 SPECIFICATION FOR APPROVAL CUSTOMER/客户名称: MODEL NO./产品型号: DESCRIPTON./产品描述: BZ-S2835ZW9C1-02-3V-UV SMD 2835自然白-0.2W-3V 2021-05-20 版本 Edition: A.1 CUSTOMER AUTHORIZED SIGNATURE/客户承认签核 Pleas retun to us oen copy of “SPECIFICATION FOR APPROVAL”With you approved Signature./客户签字确认,盖章后请回传一份承认书我司。 Add:shenzhen baoan district rock street pond avenue macro hair trey Gao Xinyuan 12 5 floor of west side 地址:深圳市宝安区石岩街道塘头大道宏发佳特利高新园12栋5楼西侧 TEL/电话:0755-85255622 FAX/传真:0755-85255672 Http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Features: ■ Applications: 1. 2.8mm*3.5mm*0.75mm SMD-LED Tubular light application 2. The material of the LED dice is InGaN Ideal for back light and indicator 3. Extremely wide viewing angle 4. Suitable for all SMT assembly Various colors and lens types available 5. ROHS compliant Indoor and outdoor display Indoor and outdoor lighting ■ Outline Dimension: ■ Recommended Soldering Pattern: Notes: 1.All dimensions are in millimeters. 2.Tolerance is ±0.1 unless otherwise noted. 3.Specifications are subject to change without notice. 1 http://www.cnbzic.com SHENZHEN HUAHEDA ELECTRONISC CO.LTD 深圳华和达电子有限公司 SHENZHEN HUAHEDA ELECTRONISC CO.LTD 深圳华和达电子有限公司 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Typical Electrical & Optical Characteristics(Ta=25°) Symbol Condition Min Typ Max Unit Forward Voltage VF IF =60mA 3 3.1 3.2 V Reverse Current IR VR =5V --- --- 10 μA TemperatureColor CCT IF =60mA 3800 --- 4200 K Luminous Intensity Iv IF =60mA 17 --- 19 Lm CRI IF =60mA 98 --- --- 2θ1/2 IF =60mA --- 120 --- Items Color Rendering Index View Angle Deg ■ Absolute Maximum Ratings (Ta = 25℃) Symbol Absolute maximum Rating Unit Power Dissipation PD 200 mW Forward Current(DC) IF 60 mA Peak Forward Current IFP 100 mA Reverse Voltage VR 5 V Electrostatic Discharge ESD 2000(HBM) V Operation Temperature Topr ﹣40~﹢85 ℃ Storage Temperature Tstg ﹣40~﹢100 ℃ Items Note :1/10 Duty Cycle,0.1 ms Pulse Width 2 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Unless Otherwise Specified, Ambient Temperature is 25 ℃ 1、Current and Voltage 2、Forward current and the relative strength 3、Ambient temperature and forward current 3 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. 4、Ambient temperature and relative strength 5、Typical represen tative Spatial Radiation Pattern 4 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Reliability Test Number Test Item Test Conditions Sample size Acceptance/ Rejection 1 Reflow Solder Temperature:Max 260 ℃ Time:10S Cycles : 3times 50PCS 0/1 Life Test Temperature=25 ℃±5 ℃ Current=60mA±2mA Cycles:10000H 50PCS 0/1 3 85℃~25℃~-40℃~25℃ Temperature Cycling 30min 5min 30min 5min Cycles:20 50PCS 0/1 4 Hot/cold TemperatureShock 100 ℃±5 ℃ ~-40 ℃±5 ℃ 15 mins 15 mins Cycles:30 50PCS 0/1 5 Low Temperature Storage Temperature:-40 ℃±5 ℃ Cycles:1000H 50PCS 0/1 6 High Temperature Storage Temperature:100 ℃±5 ℃ Cycles:1000H 50PCS 0/1 2 Remarks: Specifications are subject to change without prior notice. 5 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Reflow soldering instructions 1、Reflow soldering is recommended to the use of clean free flux, and in accordance to the reflow curve. Maximum number of soldering is limited 2、When soldering, do not exert pressure during heating process. ■Soldering 1、When manual soldering iron is used, it is recommended to use 20W anti-electro static soldering iron, soldering temperature must be kept below 360℃ / 3 seconds, 1Time soldering only 2、Do not mix different BIN materials on the same board, otherwise it will cause LED color Variation 6 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU ■ Taping Specifications ■ Reel Size SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. (Unit:mm) (Unit:mm) 7 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Humidity Proof packaging Note: Pressure affects the reliability of light emitting diodes. In such circumstances, theassembly of organic silicon encapsulated LED products must comply with the appropriate measures to deal with.Avoid any pressure applied to any part of the LED and use pneumatic nozzle. Otherwise it may lead to reduction inreliability, and impact of its life to the LED 8 http://www.cnbzic.com SHENZHEN HUAHEDA ELECTRONISC CO.LTD 深圳华和达电子有限公司
BZ-S2835ZW9C1-02-3V-UV 价格&库存
很抱歉,暂时无法提供与“BZ-S2835ZW9C1-02-3V-UV”相匹配的价格&库存,您可以联系我们找货
