1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1)
Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF9 Series
■Features
1. Compliant with the VESA FPDI-1 Standard Interface Connector
The 31 and 41 contact connectors comply with the standard connector specification for the flat panel display interface, which
U.S VESA. has selected as FPDI-1.
VESA: Video Electronics Standards Association
FPDI-1: Flat Panel Display Interface
2. Perfect Mis-insertion Prevention
The mating area is designed in a trapezoidal structure, and perfectly prevents the mis-insertion despite the miniature size.
3. Equipped with Easy Lock Mechanism
The easy lock mechanism assures the firm insertion and extraction properties as well as the insertion/extraction feeling touch.
4. Smooth Insertion and Extraction Feeling
The contact is constructed without the material fragible surface in the contact portion, and provides a smooth insertion and
use feeling.
5. Setting Two Type Platings as Standard
Two type platings, tin plated and gold plated, are prepared, and either appropriate plating can be selected under cost and use
conditions.
Structure to Prevent Mis-insertion
Lock Mechanism
A135
DF9 Series●1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1)
■Product Specifications
Rating
Current rating 0.5A
Operating Temperature Range -45 to +125ç (Note 1) Storage Temperature Range -10 to +60ç (Note 2)
Voltage rating150V AC
Operating Humidity Range 40 to 80%
Item
1. Insulation Resistance
Storage Humidity Range 40 to 70%
specification
Condition
500MΩ min.
100V DC
2. Withstanding voltage
No flashover or insulation breakdown.
250V AC/1 minute
3. Contact Resistance
50mΩ max.
100mA
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Contact resistance: 50mΩ max. Insulation resistance: 500MΩ min. 96 hours at temperature of 40ç and humidity of 90% to 95%
6. Temperature Cycle
Contact resistance: 50mΩ max. Insulation resistance: 500MΩ min. (-55ç: 30 minutes 5 to 35ç: 10 minutes 85ç: 30 minutes 5 to 35ç: 10 minutes) 5 cycles
7. Durability (Mating/un-mating) Contact resistance: 50mΩ max:
Tin plating: 30 cycles
8. Resistance to Soldering heat No deformation of components affecting performance.
Gold plating: 100 cycles
Reflow: At the recommended temperature profile
Manual soldering: 380ç for 3 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature
Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during
transportation.
■Material / Finish
Product
Part
Material
Finish
Remarks
Insulator
Polyamide
Beige
UL94V-0
Contact
Phosphor copper
Tin plated or gold plated
Metal fitting
Brass
Tin plating
Receptacle/Header
Note : The gold plated product contact area is plated with gold, and lead plated with tin.
■ Product Number Structure
●Receptacle/Header
DF9
q
q Series Name
# - * S - 1 V (**)
w
e
t
y
u
r Connector Type
: DF9
w Type
S : Receptacle
Fitting Boss
Blank
K
K
A
K
B
K
C
e Number of Contacts
9 to 25,31,41,51
r
P : Header
t Contact Pitch
: 1mm
y Contact Type
V : Straight SMT
u Contact Surface Finish/Packaging Type
(22)(32) : Tin plated, embossed tape packaging
(1000pcs/reel)
(69) : Gold plated, embossed tape packaging
(1000pcs/reel)
A136
■Receptacle
With metal fitting
With boss
[Specific No.] _ **, (**)
Unit: mm
Part No.
HRS No.
No. of Contacts
A
B
3
8.3
9
DF9- 9S-1V (**)
540-0054-0 **
4
9.3
11
DF9-11S-1V (**)
540-0055-2 **
5
10.3
13
DF9-13S-1V (**)
540-0056-5 **
6
11.3
15
DF9-15S-1V (**)
540-0057-8 **
7
12.3
17
DF9-17S-1V (**)
540-0058-0 **
8
13.3
19
DF9-19S-1V (**)
540-0059-3 **
9
14.3
21
DF9-21S-1V (**)
540-0060-2 **
15.3 10
23
DF9-23S-1V (**)
540-0061-5 **
16.3 11
25
DF9-25S-1V (**)
540-0062-8 **
19.3 14
31
DF9-31S-1V (**)
540-0063-0 **
24.3 19
41
DF9-41S-1V (**)
540-0213-1 **
29.3 24
51
DF9-51S-1V (**)
540-0064-3 **
Note 1 : Please order the embossed tape packaging product per reel. (1000 pcs/reel)
Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative.
■Receptacle
Without metal fitting
C
D
E
4
5
6
7
8
9
10
11
12
15
7.1
8.1
9.1
10.1
11.1
12.1
13.1
14.1
15.1
18.1
23.1
28.1
10.1
11.1
12.1
13.1
14.1
15.1
16.1
17.1
18.1
21.1
26.1
31.1
Spec. Spec.
(32) (69)
K
K
K
K
K
K
K
K
K
K
K
_
K
K
K
K
K
K
K
K
K
K
K
K
Remarks
With metal
fitting
With boss
RoHS
YES
With pick and
place tape
With boss
(22): Tin plated, tube packaging
(69): Gold plated, embossed tape packaging
Unit: mm
Part No.
HRS No.
No. of Contacts
A
B
9
3
8.3
DF9A-09S-1V (**)
540-0004-1 **
9.3
11
4
DF9A-11S-1V (**)
540-0005-4 **
13
5
10.3
DF9A-13S-1V (**)
540-0006-7 **
15
6
11.3
DF9A-15S-1V (**)
540-0007-0 **
17
7
12.3
DF9A-17S-1V (**)
540-0008-2 **
19
13.3
8
DF9A-19S-1V (**)
540-0009-5 **
21
14.3
9
DF9A-21S-1V (**)
540-0010-4 **
23
15.3 10
DF9A-23S-1V (**)
540-0011-7 **
16.3 11
25
DF9A-25S-1V (**)
540-0012-0 **
19.3 14
31
DF9A-31S-1V (**)
540-0013-2 **
24.3 19
41
DF9A-41S-1V (**)
540-0222-2 **
29.3 24
51
DF9A-51S-1V (**)
540-0014-5 **
Note 1 : Please order the emboss packaging product per reel. (1000 pcs/reel)
C
D
E
4
5
6
7
8
9
10
11
12
15
7.1
8.1
9.1
10.1
11.1
12.1
13.1
14.1
15.1
18.1
23.1
28.1
_
_
_
_
_
_
_
_
_
_
_
_
Spec. Spec.
(22) (69)
K
K
K
K
K
K
K
K
K
K
K
_
_
_
K
K
_
_
K
_
K
K
K
K
Remarks
Without metal
fitting
With boss
RoHS
YES
With pick and
place tape
A137
■Receptacle
With metal fitting
Without boss
(32): Tin plated, tube packaging
Unit: mm
Part No.
HRS No.
No. of Contacts
A
B
08.3 03
09
DF9B-09S-1V (**)
540-0125-6 **
09.3 04
11
DF9B-11S-1V (**)
540-0126-9 **
10.3 05
13
DF9B-13S-1V (**)
540-0127-1 **
11.3 06
15
DF9B-15S-1V (**)
540-0128-4 **
12.3 07
17
DF9B-17S-1V (**)
540-0129-7 **
13.3 08
19
DF9B-19S-1V (**)
540-0247-3 **
14.3 09
21
DF9B-21S-1V (**)
540-0131-9 **
15.3 10
23
DF9B-23S-1V (**)
540-0132-1 **
16.3 11
25
DF9B-25S-1V (**)
540-0133-4 **
19.3 14
31
DF9B-31S-1V (**)
540-0143-8 **
24.3 19
41
DF9B-41S-1V (**)
540-0216-0 **
29.3 24
51
DF9B-51S-1V (**)
540-0145-3 **
■Header
With metal fitting
C
D
E
04
05
06
07
08
09
10
11
12
15
_
_
_
_
_
_
_
_
_
_
_
_
10.1
11.1
12.1
13.1
14.1
15.1
16.1
17.1
18.1
21.1
26.1
31.1
Spec. Spec.
(32) (69)
K
K
K
K
_
_
K
K
K
K
K
_
K
_
K
K
K
K
K
_
_
K
K
K
Remarks
With metal
fitting
Without boss
RoHS
YES
With pick and
place tape
With boss
Unit: mm
Part No.
HRS No.
No. of Contacts
A
B
08.3 03
09
DF9-09P-1V (**)
540-0066-9 **
09.3 04
11
DF9-11P-1V (**)
540-0067-1 **
10.3 05
13
DF9-13P-1V (**)
540-0068-4 **
11.3 06
15
DF9-15P-1V (**)
540-0069-7 **
12.3 07
17
DF9-17P-1V (**)
540-0070-6 **
13.3 08
19
DF9-19P-1V (**)
540-0071-9 **
14.3 09
21
DF9-21P-1V (**)
540-0072-1 **
15.3 10
23
DF9-23P-1V (**)
540-0073-4 **
16.3 11
25
DF9-25P-1V (**)
540-0074-7 **
19.3 14
31
DF9-31P-1V (**)
540-0075-0 **
24.3 19
41
DF9-41P-1V (**)
540-0214-4 **
29.3 24
51
DF9-51P-1V (**)
540-0088-1 **
A138
C
D
E
04
05
06
07
08
09
10
11
12
15
07.1
08.1
09.1
10.1
11.1
12.1
13.1
14.1
15.1
18.1
23.1
28.1
10.1
11.1
12.1
13.1
14.1
15.1
16.1
17.1
18.1
21.1
26.1
31.1
Spec. Spec.
(32) (69)
K
K
K
K
K
K
K
K
K
K
K
_
K
K
K
K
K
K
K
K
K
K
K
K
Remarks
With metal
fitting
With boss
With pick and
place tape
RoHS
YES
■Header
With boss
(22) : Tin plated, embossed tape packaging
Unit: mm
Part No.
HRS No.
No. of Contacts
A
B
08.3 03
09
DF9A-09P-1V (**)
540-0016-0 **
09.3 04
11
DF9A-11P-1V (**)
540-0017-3 **
10.3 05
13
DF9A-13P-1V (**)
540-0018-6 **
11.3 06
15
DF9A-15P-1V (**)
540-0019-9 **
12.3 07
17
DF9A-17P-1V (**)
540-0020-8 **
13.3 08
19
DF9A-19P-1V (**)
540-0021-0 **
14.3 09
21
DF9A-21P-1V (**)
540-0022-3 **
15.3 10
23
DF9A-23P-1V (**)
540-0023-6 **
16.3 11
25
DF9A-25P-1V (**)
540-0024-9 **
19.3 14
31
DF9A-31P-1V (**)
540-0025-1 **
24.3 19
41
DF9A-41P-1V (**)
540-0223-5 **
29.3 24
51
DF9A-51P-1V (**)
540-0026-4 **
■Header
With metal fitting
C
D
E
04
05
06
07
08
09
10
11
12
15
07.1
08.1
09.1
10.1
11.1
12.1
13.1
14.1
15.1
18.1
23.1
28.1
_
_
_
_
_
_
_
_
_
_
_
_
Spec. Spec.
(22) (69)
K
K
K
K
K
K
K
_
K
K
K
_
_
_
K
K
K
_
K
_
K
K
_
K
Remarks
Without metal
fitting
With boss
RoHS
YES
With pick and
place tape
Without boss
Unit: mm
Part No.
HRS No.
No. of Contacts
A
B
08.3 03
09
DF9B-09P-1V (**)
540-0134-7 **
09.3 04
11
DF9B-11P-1V (**)
540-0135-0 **
10.3 05
13
DF9B-13P-1V (**)
540-0136-2 **
11.3 06
15
DF9B-15P-1V (**)
540-0137-5 **
12.3 07
17
DF9B-17P-1V (**)
540-0138-8 **
13.3 08
19
DF9B-19P-1V (**)
540-0248-6 **
14.3 09
21
DF9B-21P-1V (**)
540-0140-0 **
15.3 10
23
DF9B-23P-1V (**)
540-0141-2 **
16.3 11
25
DF9B-25P-1V (**)
540-0142-5 **
19.3 14
31
DF9B-31P-1V (**)
540-0144-0 **
24.3 19
41
DF9B-41P-1V (**)
540-0221-0 **
29.3 24
51
DF9B-51P-1V (**)
540-0146-6 **
C
D
E
04
05
06
07
08
09
10
11
12
15
_
_
_
_
_
_
_
_
_
_
_
_
10.1
11.1
12.1
13.1
14.1
15.1
16.1
17.1
18.1
21.1
26.1
31.1
Spec. Spec.
(32) (69)
K
K
K
K
K
K
K
K
K
K
K
_
K
K
_
K
K
K
K
_
_
K
K
K
Remarks
With metal
fitting
Without boss
RoHS
YES
With pick and
place tape
A139
BRecommended PCB mounting pattern
Note 1 :
●Without metal fitting, with boss
●Metal fitting, without boss
If the pattern is included in the shaded area and not treated with resist, it could touch the connector contact .
Note 2 : Please refer to each product size pattern for the universal size on the above patterns (A, B, C, D...).
BApplication Pattern
Board
Board
Note 1 : The board to board size 4.3mm in the pattern does not include the soldering paste thickness.
3±
0.2
BEmbossed Carrier Tape Dimensions
Ø80±1
Ø330±1
Ø1
●With metal fitting, with boss
D±0.5
Unreeling direction
(D+4)±1
Unit:mm
Product Type
DF9#-*S/P-1V
Size
No. of Contacts
9 to 21
23 to 31
41, 51
A
24
32
44
Note 1 : The pocket design may vary.
Note 2 : The hole of the carrier tape will be only one side if A is less than 32mm.
A140
B
28.4
40.4
C
11.5
14.2
20.2
D
25.5
33.5
45.5
E
12
12
12
BPrecautions for Use
1. Recommended Temperature Profile (SMT)
Temperature (ç)
250ç
250
220ç
200
60sec max
Soldering
180ç
150
Powered by TCPDF (www.tcpdf.org)
150ç
90~120sec
Preheating
100
50
Room temperature
100
150
200
250
300
Time (sec.)
Note1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided
that there is a return to normal temperature between the first and second cycle.
Note2 : The temperature profile indicates the board surface temperature at the point of contacts
with the connector terminals.
2. Recommended Manual Soldering Condition (SMT)
Soldering iron temperature: 370±10ç, Soldering time: Within 3 seconds
3. Recommended Screen Thickness (SMT)
0.15mm
4. Board Warp(SMT)
Maximum 0.03mm in the connector center area, based on both connector edges.
5. Cleaning Condition
Refer to the "Nylon Connector Use Hand book".
6. Cautions
■ Avoid retaining the board with the connector only, and fix the board by any other means than the connector.
■ Where the board is not mounted, the insertion or extraction will cause damage or deformation in contacts.
■ Excessive scoop insertion or extraction may result in damage.
■ In the manual soldering process, don't carry out flux coating which will cause a flux blister on the connector.
■ The color phase of this product may be slightly different from that of the forming product according to the
manufacturing lot. However, the difference doesn't affect the performance.
A141
