YFS-20-03-H-05-SB-K
YFS-20-03-H-05-SB-K
    SAMTEC(申泰)
    SMD,P=1.27mm
    PIN:100P 间距:1.27MM 立贴
YFS-20-03-H-05-SB-K 数据手册
REVISION R R "F" REF "G" REF DO NOT SCALE FROM THIS PRINT .035 0.89 REF OPTION -K: KAPTON PAD (SEE FIG 2, SHT 2) -TR: TAPE & REEL (SEE NOTE 17) No OF POSITIONS -20, -30, -40, -50 (PER ROW) C3-A-MV C ((No OF POS -1) x .0500[1.270])) .0020[.051] "B" "B" REF .145 3.68 REF "A" YFS-XX-X3-X-XX-SB-XX "A" PLATING SPECIFICATION -G: GOLD (USE C-XXX-03-G) (SEE NOTE 7) -H: HEAVY GOLD (USE C-XXX-03-H) -E: EXTRA GOLD (USE C-XXX-03-E) (SEE NOTE 7) "A" 02 "B" SOLDER BALLS C1-B,I-XR -SB: SOLDER BALL (USE SDB-030-6337) 37% Pb/63% Sn LEAD STYLE -03: PIN / SOLDERBALLS (USE C-140-03-X, SEE FIG 1) -L3: PIN / SOLDERBALLS (LOW INSERTION FORCE) (USE C-226-03-X) ROW SPECIFICATION -05: FIVE (USE YFSP-XX-01-F) -08: EIGHT (USE YFSP-XX-01-E) -10: TEN (USE YFSP-XX-01-T) -06: SIX (USE YFSP-XX-01-6) (AVAILABLE IN 20 POS ONLY) -03: THREE (USE YFSP-XX-01-3) (AVAILABLE IN 20 POS ONLY) (SEE NOTE 17) 01 YFSP-XX-01-X 09 (PIN # = NO. OF ROWS +1) C-XXX-03-X 'A' C5-B-DC .134±.003 3.41±0.08 .104 2.64 REF .012 0.312 (SEE NOTE 9) SDB-030-XXXX SECTION "B"-"B" 1. C REPRESENTS A CRITICAL DIMENSION. 2. NOTE DELETED. 3. MAXIMUM BURR ALLOWANCE: .0005[0.013] 4. MINIMUM PUSHOUT FORCE: .5 LB. 5. NOTE DELETED. C2-B,I-MV 6. CONTACT TO BE FLUSH .002[0.05]. TO BE MEASURED AT ALL FOUR CORNERS. 7. ONE REEL MINIMUM PLATING REQUIREMENT (85,000 CONTACTS PER REEL) 8. ALL DIMS TO BE SYMMETRICAL ABOUT THE CENTERLINE WITHIN .001[0.03]. 9. .0025[0.064] MAX VARIATION BETWEEN SOLDERBALLS. 10. REFER TO VISUAL INSPECTION BOARD FOR SOLDERBALL APPEARANCE CHECKS. 11. THE DISTANCE FROM THE CENTER OF ANY SOLDERBALL TO THE CENTER OF ANY ADJACENT INNER PEG SHALL BE .025 .005[0.64 0.13]. 12. NOTE DELETED. 13. NOTE DELETED. 14. NOTE DELETED. 15. NOTE DELETED. 16. NO FLASH ALLOWED ON THE PIN TIPS. C4-B-VS 17. IF -TR OPTION IS NOT SPECIFIED, PARTS TO BE PACKAGED IN TRAYS. PARTS WITH -03 ROW SPECIFICATION NOT VALID WITHOUT -TR OPTION. SECTION "A"-"A" .095 2.41 REF R FIG 1 YFS-20-X3-X-08-SB SHOWN R IN-PROCESS WITHOUT SOLDERBALLS SEE NOTE 6 DETAIL 'A' SCALE 5 : 1 SEE NOTE 16 NOTES: CRITICAL DIMENSION INSPECTION INSTRUCTION TABLE ASSEMBLY OPERATION IN-PROCESS INSPECTION FILL C-XXX-XX-X C2, C3 ATTACH SDB-XXX-XXXX C3, C4 REPRESS SOLDER BALL FINISHED GOOD INSPECTION C5 C1, C2, C3, C5 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] MATERIAL: 2 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, COLOR: BLACK CONTACT: PHOS BRONZE F:\DWG\MISC\MKTG\YFS-XX-X3-X-XX-SB-XX-MKT.SLDDRW SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050[1.27] MULTI-ROW SOCKET ASSEMBLY DWG. NO. YFS-XX-X3-X-XX-SB-XX BY: KEVIN B 4/22/99 SHEET 1 OF 2 REVISION R R FIG 2 -K: KAPTON PAD YFS-20-X3-X-08-SB-K SHOWN "E" .139 3.541 "D" .010[0.25] "C" F:\DWG\MISC\MKTG\YFS-XX-X3-X-XX-SB-XX-MKT.SLDDRW PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050[1.27] MULTI-ROW SOCKET ASSEMBLY DWG. NO. YFS-XX-X3-X-XX-SB-XX BY: KEVIN B 4/22/99 SHEET 2 OF 2
YFS-20-03-H-05-SB-K 价格&库存
很抱歉,暂时无法提供与“YFS-20-03-H-05-SB-K”相匹配的价格&库存,您可以联系我们找货
