QFS-026-04.25-L-D-RF1 数据手册
QFS-XXX-XX.XX-XX-D-XX-XXX-XX
REVISION AJ
DO NOT
SCALE FROM
THIS PRINT
C
((No OF POS / 26) x .840[21.34] + .040[1.02] REF
.083 2.10
REF
C
(No OF POS / 26) x .8400[21.336]) - .2150[5.461]
.8400 21.336 (TYP)
C
25 EQ SPACES
@ .0250[0.635]
PACKAGING OPTION
-TR: TAPE & REEL PACKAGING
(-026 & -052 POS'S AVAILABLE IN -04.25
LEAD STYLE WITH ALL OPTIONS)
(-026 THRU -078 AVAILABLE IN -06.25
LEAD STYLE WITH NO END OPTIONS)
(-078 AVAILABLE WITH NO END OPTIONS)
(-104 & -130 NOT AVAILABLE IN -TR)
No OF POSITIONS
-026, -052, -078, -104, *-130
(PER ROW)
.1075 2.731
02
"A"
LEAD STYLE
-04.25 (SEE NOTE 9)
-06.25
PLATING SPECIFICATION
-L: 10µ" SELECTIVE GOLDIN CONTACT AREA,
MATTE TIN ON TAIL (SEE TABLE 7)
(AVAILABLE ON -04.25 LEAD STYLE ONLY)
-H: 30µ" GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL (SEE TABLE 7)
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
(AVAILABLE ON -06.25 LEAD STYLE ONLY)
-SL: 10µ" SELECTIVE GOLD IN CONTACT AREA,
END OPTIONS
-PC4: 4 POWER POS PER END (.062" THICK BOARD)
(SEE FIG 3, SHEET 3)
-PC8: 8 POWER POS PER END (.062" THICK BOARD)
-PT4: 4 POWER POS PER END (.093" THICK BOARD)
-PT8: 8 POWER POS PER END (.093" THICK BOARD)
-RF1: 1 RF POS PER END
(SEE FIG 5, SHEET 4)
-RF2: 2 RF POS PER END
(SEE FIG 6, SHEET 4)
-RT1: 1 RT POS PER END
ROW SPECIFICATION
(SEE FIG 7, SHEET 5)
-D: DOUBLE
(-PXX & -RFX NOT AVAILABLE IN
OPTION
COMBINATION WITH -A OR -GP)
(END OPTION APPLIES TO BOTH
-A: ALIGNMENT PIN
ENDS,
COMBINATIONS ARE
-GP: GUIDE HOLE
NOT AVAILABLE)
(SEE FIG 2, SHEET 2)
(AVAILABLE ON -04.25 LEAD STYLE ONLY) (-PXX & -RFX AVAILABLE IN POS
-026, -052, & -078 ONLY)
-P: PICK AND PLACE PAD
(-RT1 AVAILABLE IN -026, -052,
(USE PPP-51, SEE FIG 4, SHEET 2)
-078, & -104 POS WITH -A
OPTION ONLY)
* = NOT TOOLED
(-PXX, -RFX, & -RT1 AVAILABLE
.320 8.13
REF
.009 0.23 REF
"A"
01
.055 1.40
REF
"N"
REF
C .0040 0.102
.040 1.02 REF
.035 0.89 REF
C .134 3.40
(MEASURED CONTACT
TO CONTACT)
T-1G2X-XX.XX-L
(SEE TABLE 7)
((No OF POS / 26) x .840[21.34]) - .030[0.76] REF
QFSS-26-XX.XX-D-02-A
(SEE TABLE 7)
C "M" .004[0.10]
.002[0.05]
(SEE NOTES 5, 6, & 7)
C
SEE TABLE 1
(SEE NOTE 6)
FIG 1
QFS-052-04.25-X-D-A SHOWN
SEE NOTE 4
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MAXIMUM BURR ALLOWANCE: .0015[0.038]
3. MINIMUM PUSHOUT FORCE: SIGNAL: .5 LB, GROUND: 1 LB, POWER: .5 LB, RF: .5 LB.
4. ALL CONTACTS ON THE -04.25 LEAD STYLE WILL BE SHEARED.
5. MAXIMUM VARIANCE OF .002[0.05].
6. DIMENSION APPLIES TO CONTACTS & GROUND PLANE.
7. GROUND PLANE PRESS HEIGHT MUST BE .003[0.08] LESS THAN THE MAXIMUM HEIGHT
OR .001[0.03] GREATER THAN THE MINIMUM HEIGHT OF THE TERMINAL.
8. PARTS TO BE PACKAGED IN TRAYS.
9. LEADSTYLE -01 MAY BE SUBSTITUTED IN PART CALLOUT FOR -04.25
FOR EXISTING CUSTOMERS ONLY
F:\DWG\MISC\MKTG\QFS-XXX-XX.XX-XX-D-XX-XXX-XX-MKT.SLDDRW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01[0.3]
2
.XXX: .005[0.13]
.XXXX: .0020[0.051]
MATERIAL:
C-XXX-XX.XX-XX
(SEE TABLE 7)
.051 1.30 REF
.320±.006 8.13±0.15
SECTION "A"-"A"
SCALE 5 : 1
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, COLOR: BLACK
CONTACTS & GROUND PLANE:
PHOS BRONZE
SHEET SCALE: 2.25:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
.635mm DOUBLE ROW TERMINAL STRIP
DWG. NO.
BY:
E.L.S.
6/09/2003
SHEET 1 OF 5
REVISION AJ
.002[0.05] MAX
BURR
C
.067±.004 1.70±0.10
.008 0.20
.004[0.10]
"M" .002[0.05]
(SEE NOTE 5)
C-181-04.25-XX
* NOT TOOLED
CONTACT DETAILS
SEE TABLE 1
(SEE NOTE 4)
FIG 2
-GP: GUIDE HOLE OPTION
(QFS-052-04.25-X-D-A-GP SHOWN)
(NOT AVAILABLE WITH -PXX OPTIONS)
IN-PROCESS 1
"B" REF
(SEE TABLE 2)
.253 6.43
REF (2 PLCS)
"A" REF
(SEE TABLE 2)
"B"
"G" = MEASURED SIZE
("G" - .535)/2±.020
"B"
.140 3.56 REF (2 PLCS)
PPP-51
.535 13.59 REF
QFSS-26-04.25-D-XX-A-GP
SECTION "B"-"B"
SCALE 1.75 : 1
.275 6.99
REF
"P"
REF
FIG 4
-P: PICK & PLACE PAD OPTION
PROPRIETARY NOTE
SHEET SCALE: 2.5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY:
E.L.S.
6/09/2003
SHEET 2 OF 5
REVISION AJ
"D" REF
("E" EQ SPACE(S) @ .07874[2.000]) (TYP)
.069 1.76 REF
POWER PIN 2
C
L
02
.100 2.54
"C"
FIG 3
C
L
"C"
QFSS-26-04.25-D-XX-PCX
(SEE TABLE 3)
01
"F" REF (TYP)
POWER COMBO OPTIONS
(QFS-052-04.25-X-D-PC4 SHOWN)
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
(NOT AVAILABLE WITH -A OR -GP OPTION)
(AVAILABLE ON -04.25 LEAD STYLE ONLY, POS -026, -052, -078 ONLY)
POWER PIN 1
POWER PIN 3
C
L
C-79-XX-S
.113 2.87 REF
"Q" C
C
.07874±.0050 2.000±0.127 (TYP)
"R" REF
'F'
C 2 MAX SWAY
"C"
C
3 MAX SWAY C
(EITHER DIRECTION)
C .100 2.54
SECTION "C"-"C"
'D'
.005 MAX BURR
THIS DIRECTION
ONLY, OTHERWISE
SEE NOTE 2
.0190 0.48 REF (TYP)
DETAIL 'D'
SCALE 8 : 1
PROPRIETARY NOTE
SHEET SCALE: 2.5:1
DETAIL 'F'
SCALE 10 : 1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY:
E.L.S.
6/09/2003
SHEET 3 OF 5
REVISION AJ
"H" REF (SEE TABLE 5)
02
"E"
"E"
RF01
01
SUB-GRF1-J-P-H-ST-TH2
.231 5.88
REF
.100 2.54 REF
.085 2.16 (TYP) C
.140 3.56 (TYP) C
.070 1.78 REF
.028 0.70 REF
C
"J"
.140 3.56 REF (TYP) C
.003[0.08] (SEE TABLE 5)
FIG 5
.020 0.50 SQ REF
SECTION "E"-"E"
-RF1 OPTION
(QFS-052-04.25-X-D-RF1 SHOWN)
(SAME AS FIG 3, UNLESS OTHERWISE STATED)
(NOT AVAILABLE WITH -A OR -GP OPTIONS)
(AVAILABLE ON -04.25 LEAD STYLE, POSITIONS -026, -052, & -078 ONLY)
C .250±.002 6.35±0.05
02
FIG 6
-RF2 OPTION
(QFS-052-04.25-X-D-RF2 SHOWN)
(SAME AS FIG 5, UNLESS OTHERWISE STATED)
01
RF02
RF01
PROPRIETARY NOTE
C
"J"
SHEET SCALE: 2.5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY:
E.L.S.
6/09/2003
SHEET 4 OF 5
REVISION AJ
"K" REF (SEE TABLE 6)
02
"F"
"F"
QFSS-26-04.25-D-02-A-RT1
01
C
.082 2.08
REF
"L" (SEE TABLE 6)
2 MAX SWAY
(TYP)
T-1R32-10-F-T
.100 2.54 REF
.062 1.57
REF
C
FLUSH TO
SECTION "F"-"F"
.055 1.40 REF
.002
FIG 7
-RT1 OPTION
(QFS-052-04.25-X-D-A-RT1 SHOWN)
(NOT AVAILABLE WITH -GP OR -RFX OPTIONS)
(AVAILABLE ON -04.25 LEAD STYLE, POSITIONS -026, -052, -078, & -104 WITH -A OPTION ONLY)
PROPRIETARY NOTE
SHEET SCALE: 2.5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY:
E.L.S.
6/09/2003
SHEET 5 OF 5
