QTH-090-07-L-D-A
QTH-090-07-L-D-A
    SAMTEC(申泰)
    SMD,P=0.5mm
    间距:0.5MM PIN:180P 公 立贴
QTH-090-07-L-D-A 数据手册
QTH-XXX-XX-X-D-XXX REVISION BL OPTION -LC: LOCKING CLIPS (USE LC-08-TM-01, SEE FIG 2, SHT 2)) -A: ALIGNMENT PINS (USE QTH-30-XX-D-XX-A FOR -01 & -02) (FOR -03 THRU -10 SEE TABLE 6, SHT 3) -K: POLYIMIDE FILM (USE K-DOT-.276-.375-.005) (AVAILABLE ON -01 THRU -04, -09 & -10 ONLY) (SEE FIG 4, SHT 2) -TR: TAPE & REEL (-090 POS MAX) (-060 POS MAX W/ -GP OPTION) (N/A ON -05 THRU -08) (SEE FIG 12, SHT 6) (SEE NOTE 15) -GP: GUIDE POSTS (AVAILABLE ON -01 & -02 ONLY) (USE QTH-30-XX-D-XX-X-GP) (SEE FIG 8, SHT 4) -FL: FRICTION LOCKS (SEE FIG 9, SHT 4) (NOT AVAILABLE WITH -GP) -RT1: RETENTION OPTION (SEE FIG 10, SHT 5) (ONLY AVAILABLE ON -01 LEAD STYLE) (MUST USE -A OPTION) (USE QTH-30-01-D-XX-A-RT1 & T-1R36-01-F) (NOT AVAILABLE WITH -LC, -GP, OR -FL) -L: LATCHING OPTION (SEE FIG 11, SHT 5) (ONLY AVAILABLE ON -01 LEAD STYLE) (USE QTH-30-01-D-XX-L) (NOT AVAILABLE WITH -LC, -GP, -FL, OR -RT1) (-060 POS MAX) -FR: FULL REEL QTY. TAPE & REEL (-090 POS MAX) (-060 POS MAX W/ -GP OPTION) (N/A ON -05 THRU -08) (SEE NOTE 16) No OF POSITIONS -030, -060, -090, *-120, *-150 (PER ROW) * (SEE NOTE 11) DO NOT SCALE FROM THIS PRINT C LEAD STYLE -01: .1680[4.267] -02: .2861[7.264] -03: .4043[10.269] -04: .6001[15.246] -05: .7181[18.240] -06: .8361[21.237] -07: .9542[24.237] -08: 1.1511[29.238] -09: .5224[13.269] -10: .5618[14.269] = SEE TABLE 6, SHT 3 "A" PLATING SPECIFICATION -F: 3 µ'' SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (USE T-1SXX-XX-F & T-1GXX-XX-F) (SEE NOTE 7) -L: 10 µ'' SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (USE T-1SXX-XX-L & T-1GXX-XX-L) -H: 30 µ'' GOLD IN CONTACT AREA, 3 µ'' GOLD ON TAIL (USE T-1SXX-XX-H & T-1GXX-XX-G) -C: 50 µ'' SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (USE T-1SXX-XX-C, T-1GXX-XX-L) .7875 20.003 (TYP) .235 5.97 REF 29 EQ SPCS @ .0197[.500] = .571 14.50 (TYP) 01 .155 3.9 REF (SEE NOTE 12) ROW SPECIFICATION -D: DOUBLE (USE QTH-30-XX-D-XX & QTHH-30-XX-D-XX) 02 .008 0.2 REF .644 16.4 REF .047 1.19 REF "A" QTH-30-XX-D-XX-A "C" REF .038 0.95 REF "A" .745 18.9 REF C .155±.003 3.94±0.08 (SEE NOTE 12) +.003 [0.08] "B" - .002 [0.03] C (SEE NOTE 5 & 8) T-1SXX-XX-X (SEE TABLE 1) T-1G1-XX-X "D" REF C .080 2.03 REF SEE TABLE 3 (SEE NOTE 8) (SEE NOTE 14) .098 2.49 REF (SEE NOTE 10) .015 0.4 REF NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 6 OZ FOR –01 & -02, 8 OZ FOR –03 THRU –10. 3. MINIMUM GROUND PLANE RETENTION: 1 LB. 4. PARTS TO BE MOLDED TO POSITION. 5. MAXIMUM VARIANCE OF .002 [0.05]. APPLIES TO SIGNAL OR GROUNDS INDEPENDENT OF THE GROUND OR SIGNAL PINS RESPECTIVELY. 6. LEAD STYLES -03 THRU -10: TOP BODY (QTH) CANNOT HAVE -A OPTION. 7. -L PLATING CAN BE SUBSTITUTED FOR -F PLATING. 8. GROUND PLANE NOT TO BE INCLUDED IN COPLANARITY. 9. T-1R36 RETENTION TO BODY TO BE 1.0 LBF. 10. CUT OFF BURR NOT TO EXCEED .003 [0.08] IN ANY DIRECTION, BURR PLUS TAB HEIGHT NOT TO EXCEED .006 [0.15]. 11. FOR NEW APPLICATIONS REQUIRING THESE POSITIONS, PLEASE CONTACT SAMTEC INTERCONNECT PROCESSING GROUP. 12. MAXIMUM PIN CAN EXTEND PAST WALL .003 [0.08] 13. AVAILABLE MATING WITH QSH-D-GP,BUT NOT AVAILABLE MATING WITH QSH-D-RA-GP OPTION. 14. GROUND PLANE TO BE .001±.001 ABOVE SEATING PLANE (MAX CONTACT COPLANARITY). 15. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. 16. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED. .035 0.89 REF FIG 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: .031 0.8 REF -A: ALIGNMENT PIN OPTION (STYLE -01 & -02 ONLY) (QTH-090-01-X-D-A SHOWN) * .280 7.11 SECTION "A"-"A" PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP UL94V-0, COLOR: BLACK TERMINAL & GROUND PLANE: PHOS BRONZE F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-XXX-MKT.SLDDRW SHEET SCALE: 1.75:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DOUBLE ROW HS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-XXX BY: DEAN P 09-14-2010 SHEET 1 OF 6 REVISION BL QTH-30-XX-D-XX CL C .055 1.40 LC-08-TM-01 FIG 2 .056 1.42 REF .010 0.25 REF -LC LOCKING CLIP OPTION (QTH-090-01-X-D-LC SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) "D" (SEE TABLE 2, SHT 1) .0800 2.032 QTHH-30-XX-D-XX-A QTH-30-02-D-XX (SEE NOTE 6) FIG 3 -A: ALIGNMENT PIN OPTION (QTH-090-05-X-D-A SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (STYLES -03 THRU -09, SEE TABLE 6, SHT 3) CL .038 1.0 REF .035 0.89 REF "D" REF (SEE TABLE 2, SHT 1) C .080 2.03 REF "R" REF "S"±.020 [0.51] .020±.020 0.51±0.51 C * "T" .276 7.01 PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. FIG 4 -K: POLYIMIDE FILM PAD OPTION (USE K-DOT-.276-.375-.005) F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-XXX-MKT.SLDDRW DO NOT SCALE DRAWING SHEET SCALE: 1.75:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DOUBLE ROW HS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-XXX BY: DEAN P 09-14-2010 SHEET 2 OF 6 REVISION BL DETAIL 'H' SCALE 8 : 1 .003 0.08 MAX TAB HEIGHT .006 0.15 MAX BURR + TAB HEIGHT .155±.003 3.94±0.08 C QTH-30-02-D-XX (SEE NOTE 6) "B" T-1S60-XX-X C .278 7.07 REF 'H' .118 3.00 REF "B" .010 0.25 REF T-1G1-XX-X .055 1.40 C SEE NOTE 10 QTHH-30-01-D-XX .053 1.33 .037 0.94 REF .281 7.14 .0800 2.032 CL .265 6.73 REF FIG 5 (QTH-090-03-X-D-LC SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) SECTION "B"-"B" "D" "C" T-1S60-XX-X C .155±.003 3.94±0.08 T-1S61-XX-X .155±.003 3.94±0.08 C C C (SEE NOTE 5 & 8) "C" QTHH-30-03-D-XX T-1G1-XX-X FIG 6 (QTH-090-05-X-D SHOWN) (SAME AS FIG 5, EXCEPT AS SHOWN) SEE NOTE 10 SECTION "C"-"C" SCALE 1.25 : 1 .600 15.24 REF QTHH-030-04-D-XX "D" T-1G17-XX-X FIG 7 * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 1:0.571429 SEE NOTE 10 SECTION "D"-"D" SCALE 1.25 : 1 (QTH-090-07-X-D SHOWN) (SAME AS FIG 5, EXCEPT AS SHOWN) * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-XXX-MKT.SLDDRW +.003 "E" - .001 [0.08] [0.03] (SEE NOTE 5 & 8) +.003 "E" - .001 [0.08] [0.03] .432 10.97 REF +.003 "E" - .001 [0.08] [0.03] (SEE NOTE 5 & 8) 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DOUBLE ROW HS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-XXX BY: DEAN P 09-14-2010 SHEET 3 OF 6 REVISION BL C "H" "F" REF .233 5.91 REF CL SEE TABLE 8 .125 3.18 REF "G" REF FIG 8 (QTH-090-01-X-D-GP SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (AVAILABLE ON -01 & -02 ONLY) .008 0.20 REF .070 1.78 REF (TYP) .015 0.38 REF .015 0.38 REF QTH-30-XX-D-XX-X-FL 'F' 'E' DETAIL 'E' SCALE 12 : 1 * PROPRIETARY NOTE FIG 9 F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-XXX-MKT.SLDDRW DO NOT SCALE DRAWING SHEET SCALE: 2:1 DETAIL 'F' SCALE 12 : 1 * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. -FL: FRICTION LOCKS (NOT AVAILABLE WITH -GP OPTION) (SAME AS FIG 1, EXCEPT AS SHOWN) .012 0.30 REF 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DOUBLE ROW HS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-XXX BY: DEAN P 09-14-2010 SHEET 4 OF 6 REVISION BL CL QTH-30-01-D-XX-X-RT1 "J" REF C C .069 1.76 REF "K"±.004[0.01] C .190 4.83 .100 2.54 REF T-1R36-01-F (2 PLCS) .070 1.78 REF .062 1.57 REF FIG 10 (QTH-090-01-X-D-A-RT1 SHOWN) (NOT AVAILABLE WITH -LC, -GP, OR -FL OPTIONS) (AVAILABLE ON -01 ONLY) (SAME AS FIG 1, EXCEPT AS SHOWN) "L" REF (* = NOT RELEASED) C "M" CL QTH-30-01-D-XX-L WT-56-01-T .010 0.25 REF (TYP) T-1S39-01-XXX .053±.002 1.35±0.05 C .025 0.64 REF "N" C * FIG 11 L: LATCHING OPTION (QTH-060-01-X-D-L SHOWN) (AVAILABLE ON -01 LEAD STYLE ONLY) (NOT AVAILABLE WITH -LC, -GP, -FL, OR -RT1 OPTIONS) (SAME AS FIG 1, EXCEPT AS SHOWN) PROPRIETARY NOTE SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING .020 0.50 REF 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DOUBLE ROW HS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-XXX BY: DEAN P 09-14-2010 SHEET 5 OF 6 REVISION BL "H" "H" USER DIRECTION OF UNREELING POCKET NOT DETAILED SECTION "H"-"H" SCALE 1.5 : 1 FIG 12 -TR: TAPE & REEL (QTH-090-01-X-D-LC-TR SHOWN) (-090 POS MAX) (-060 POS MAX W/-GP OPTION) (N/A ON -05 THRU -08) (SAME AS FIG 1, EXCEPT AS SHOWN) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DOUBLE ROW HS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-XXX BY: DEAN P 09-14-2010 SHEET 6 OF 6
QTH-090-07-L-D-A
1. 物料型号:文档描述了多种型号的端子组件,包括QTH-30-01-D-XX、QTH-30-02-D-XX等,以及它们的变体,如带定位销(-A)、带锁定夹(-LC)等。
2. 器件简介:文档提供了端子组件的一般描述,包括其设计为双排高密度端子组件,适用于多种应用。
3. 引脚分配:文档中的表格和图示详细说明了不同型号的端子组件的引脚分配和位置。
4. 参数特性:包括端子组件的尺寸、公差、材料等,例如绝缘体材料为LCP,颜色为黑色,端子和接地平面材料为磷青铜。
5. 功能详解:文档提供了端子组件的详细功能描述,包括不同的配置选项,如定位销(-A)、锁定夹(-LC)、摩擦锁(-FL)、导向柱(-GP)等。
6. 应用信息:文档中提到了端子组件的应用信息,但具体的应用场景没有详细说明。
7. 封装信息:提供了端子组件的封装信息,包括不同型号的封装尺寸和设计。
8. 其他:文档中还包含了一些设计注意事项、专利信息和专有声明。
QTH-090-07-L-D-A 价格&库存
很抱歉,暂时无法提供与“QTH-090-07-L-D-A”相匹配的价格&库存,您可以联系我们找货
QTH-090-07-L-D-A
    • 1+266.87880
    • 36+229.11984
    库存:3
    QTH-090-07-L-D-A
    • 1+220.050191+28.38704
    • 10+213.6032210+27.55537
    • 25+208.1156725+26.84746
    • 50+198.0946650+25.55472
    • 100+183.72394100+23.70086
    库存:26
