DF40HC(3.0)-100DS-0.4V(58) 数据手册
0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors
DF40 Series
Space saving
Space saving
-%edh#!%#)bbe^iX]!*bb]Z^\]i
(#(-bb
9;)%
&-#+bb
■Features
High contact reliability - effective mating length 0.45mm
1. High density mounting
H]dX`VWhdgei^dcg^Wh
In addition to its space saving design, several stack
heights are available and add versatility to any
application. Stack heights : 1.5mm, 2.0mm, 2.5mm,
3.0mm, 3.5mm, and 4.0mm.
%#)*bb
2. Multiple stack height options
*∼)#%bb
Space saving design that has a minimum connector
width, yet still retains a sufficient vacuum area for
easy pick-and-place mounting
Minimum width : 3.38mm
3. High contact reliability
4. Excellent self-aligning range
The use of guide ribs allows 0.33mm of selfalignment on this connector.
5. Reinforced structure with shock absorbing ribs
Both sides of the connector have been reinforced
with the addition of shock absorbing ribs.
6. Solder wicking prevention
Nickel-plated barriers were added to protect the
contact areas from potential solder wicking.
7. Contamination resistant design
When mated, the connector’s design covers the
contacts which help to keep dust and other debris away
from the contacts. The SMT leads are kept very close
to the connector housing which also helps to prevent
shorts caused by debris on the exposed contacts.
8. RoHS compliant
Environment friendly and does not use RoHS
specified prohibited materials.
All materials and substances used to produce these
parts comply with the RoHS standards.
9. High speed signal with noise prevention
AdX`hnhiZb
&%edh#id*%edh#
Stacking height variations
Standard type
Stacking
height
10
12
30
34
40
44
50
60
70
80
90
100
No. of Contacts
Despite its small stature and low profile, the contacts
deliver strong contact forces and an effective mating
length of 0.45mm on the 1.5mm stacking height.
This connector utilizes a locking system that prevents
accidental unmating issues and emits a clear tactile
click to ensure that mating has been completed.
1.5
mm
2.0
mm
2.5
mm
3.0
mm
3.5
mm
4.0
mm
Shielded type
Stacking
height
30
48
70
No. of
Contacts
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
*#%bb
:m^hi^c\
egdYjXih
1.5
mm
3.0
mm
The shielded type can support high speed signal
transmissions with noise prevention.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2022.9
1
DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors
■Product Specifications
Ratings
Rated Current 0.3A
Rated Voltage AC, DC 30V
Items
Operating Temperature Range
-35 to +85℃ (Note 1)
Operating Humidity Range
20 to 80%
Storage Temperature Range
-10 to +60℃ (Note 2)
Storage Humidity Range
40 to 70% (Note 2)
Specifications
Conditions
1. Insulation Resistance
50Mø min
Measured with DC 100V
2. Withstanding Voltage
No flashover or breakdown
Apply AC 100V for 1 minute
3. Contact Resistance
90mø max
Measured with AC 20mV, 1 kHz and 1mA
4. Vibration Resistance
No electrical discontinuity of 1µs or greater
Frequency 10-55 Hz, half amplitude 0.75mm,
3 directions for 2 hours
5. Humidity Resistance
Contact resistance : 90mø max
Insulation resistance : 25mø min
Left at temperature 40 ± 2ç, humidity 90 to 95%,
96 hours
6. Temperature Cycles
Insulation resistance : 50mø min
(-55ç : 30 minutes → 5~35ç : 10 minutes → 85ç : 30
minutes → 5~35ç : 10 minutes) 5 cycles
7. Durability
30 mating cycles
8. Soldering Heat
Resistance
Should be no melting of resin parts that affects
its performance
Reflow : according to the Recommended
Temperature Profile
Hand solder : Soldering iron temperature 350ç,
no more than 3 seconds.
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use. The operating
temperature and humidity range covers the non-energized condition of connectors after board mounting and the
temporary storage conditions during transportation, etc.
■Materials (Standard, non shielded type) / Finish
Product
Receptacle
Header
Component
Insulator
Contact
Insulator
Contact
Materials
LCP
Phosphor bronze
LCP
Phosphor bronze
Finish
Black
Gold plating
Black
Gold plating
UL Regulation
UL94V-0
--------------UL94V-0
Materials
LCP
Finish
Black
Phosphor bronze
Gold plating
LCP
Black
Phosphor bronze
Gold plating
UL Regulation
UL94V-0
----------------------------UL94V-0
■Materials (Shielded type) / Finish
Product
Receptacle
Header
2
Component
Insulator
Contact
Shield plate
Insulator
Contact
Reinforcing metal fitting
■Product Number Structure (Standard, non-shielded type)
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacle
DF40 # − (**) − * DS − 0.4 V (**)
❶
❷
❸
❹
❶ Series Name: DF40
❷ Style
B : With reinforcing metal fitting
HB : With reinforcing metal fitting
(The H denotes a stacking height 2.5mm or above)
C : Without reinforcing metal fitting
HC : Without reinforcing metal fitting
❺
❻
❼
❽
❹ No. of Contacts
❸ Stacking height
Display
Stacking height
None
1.5mm
2.0
2.0mm
2.5
2.5mm
3.0
3.0mm
3.5
3.5mm
4.0
4.0mm
❺ Connector Type
DS : Double row receptacle
❻ Contact Pitch : 0.4mm
❼ Mating direction Shape V : Vertical SMT
❽ Packaging Type
(51) Embossed tape packaging
●Header
DF40 # − * DP − 0.4 V (**)
❶
❷
❸
❹
❶ Series Name : DF40
❺
❻
❼
❸ No. of Contacts
❺ Contact Pitch : 0.4mm
❻ Mating direction V : Vertical SMT
❷ Style
❹ Connector Type
DP : Double row pin header
❼ Packaging Type
■Shielded type
●Receptacle
DF40 GB − (**) − * DS − 0.4 V (**)
❶
❷
❸
❹
❺
❻
❸ Stacking height
❷ Style
GB : With shield
Display
1.5
3.0
❼
❽
❺ Connector Type
Stacking height
1.5mm
3.0mm
❼ Mating direction V : Vertical SMT
❹ No. of Contacts
❽ Packaging Type
●Header
DF40 GB − * DP − 0.4 V (**)
❶
❷
❸
❹
❺
❻
❸ No. of Contacts
❷ Style
❹ Connector Type
GB : With reinforcing metal fitting
(For use with shielded product )
❼
❼ Packaging Type
3
■Receptacle (Stacking height 1.5mm)
A±0.2
B±0.08
3.38±0.2
2.88±0.2
P=0.4±0.05
0.12±0.02
D±0.15
Vacuum pick up area : C±0.2
BRecommended PCB layout
B±0.02
B±0.02
1.5MAX
3.78 +0.05
1.5MAX
3.78 +0.05
1.2±0.02
P=0.4±0.02
P=0.4±0.02
0.2±0.02
0.2±0.02
DF40C(Without reinforcing metal fitting)
DF40B(With reinforcing metal fitting)
■Stacking height 1.5mm
【Specification No.】
(51) : Embossed package 5,000 pcs/reel
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
DF40B-10DS-0.4V(51)
684-4038-8 51
10
4.6
1.6
DF40B-12DS-0.4V(51)
DF40B-30DS-0.4V(51)
DF40B-50DS-0.4V(51)
DF40B-60DS-0.4V(51)
DF40B-80DS-0.4V(51)
DF40C-20DS-0.4V(51)
DF40C-24DS-0.4V(51)
DF40C-30DS-0.4V(51)
DF40C-34DS-0.4V(51)
DF40C-40DS-0.4V(51)
DF40C-50DS-0.4V(51)
DF40C-60DS-0.4V(51)
DF40C-70DS-0.4V(51)
DF40C-80DS-0.4V(51)
DF40C-90DS-0.4V(51)
DF40C-100DS-0.4V(51)
684-4152-3 51
684-4090-8 51
684-4018-0 51
684-4049-4 51
684-4052-9 51
684-4005-9 51
684-4006-1 51
684-4007-4 51
684-4023-0 51
684-4008-7 51
684-4009-0 51
684-4004-6 51
684-4016-5 51
684-4002-0 51
684-4124-8 51
684-4033-4 51
12
30
50
60
80
30
34
40
50
60
70
80
90
100
5.0
8.6
12.6
14.6
18.6
6.6
7.4
8.6
9.4
10.6
12.6
14.6
16.6
18.6
20.6
22.6
2.0
5.6
9.6
11.6
15.6
3.6
4.4
5.6
6.4
7.6
9.6
11.6
13.6
15.6
17.6
19.6
C
D
1.0
1.5
3.2
1.0
1.2
1.5
2.3
1.45
3.2
Note 1 : Please place orders by full reel.
Note 2 : The surface of the 60 to 100 pos. parts have a small, concave section that will not affect the vacuum pick up operation.
Note 3 :
Resist coating area.
Note 4 : This connector is NOT polarized.
4
■Receptacle (Stacking height 2.0mm)
A±0.2
B±0.08
3.38±0.2
2.94±0.2
P=0.4±0.05
0.12±0.02
B±0.02
B±0.02
1.2±0.02
P=0.4±0.02
1.5MAX
1.5MAX
3.78 +0.05
P=0.4±0.02
3.78 +0.05
D±0.15
0.2±0.02
0.2±0.02
■Stacking height 2.0mm
【Specification No.】
(51) : Embossed package 4,000 pcs/reel
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
DF40B(2.0)-12DS-0.4V(51)
684-4150-8 51
12
5.0
2.0
1.0
DF40B(2.0)-80DS-0.4V(51)
684-4128-9 51
80
18.6
15.6
3.2
DF40C(2.0)-20DS-0.4V(51)
684-4040-0 51
3.6
1.0
DF40C(2.0)-24DS-0.4V(51)
684-4021-2 51
24
7.4
4.4
1.2
DF40C(2.0)-30DS-0.4V(51)
684-4058-5 51
30
8.6
5.6
1.5
DF40C(2.0)-40DS-0.4V(51)
684-4042-5 51
40
10.6
7.6
DF40C(2.0)-50DS-0.4V(51)
684-4091-0 51
50
12.6
9.6
DF40C(2.0)-60DS-0.4V(51)
684-4034-7 51
60
14.6
11.6
DF40C(2.0)-70DS-0.4V(51)
684-4147-3 51
70
16.6
13.6
DF40C(2.0)-80DS-0.4V(51)
684-4132-6 51
80
18.6
15.6
D
1.95
3.2
Note 3 :
5
■Receptacle (Stacking height 2.5mm to 4.0mm)
A±0.2
B±0.08
3.38±0.2
2.94±0.2
P=0.4±0.05
0.12±0.02
D±0.15
B±0.02
B±0.02
1.5MAX
3.78 +0.05
0.92MAX
3.78 +0.05
1.2±0.02
P=0.4±0.02
P=0.4±0.02
0.2±0.02
0.2±0.02
DF40HC(Without reinforcing metal fitting)
DF40HB(With reinforcing metal fitting)
■Stacking height 2.5mm
【Specification No.】
(51) : Embossed package 3,000 pcs/reel
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
DF40HB(2.5)-10DS-0.4V(51)
684-4189-3 51
10
4.6
1.6
DF40HC(2.5)-20DS-0.4V(51)
684-4126-3 51
3.6
DF40HC(2.5)-40DS-0.4V(51)
684-4112-9 51
40
10.6
7.6
DF40HC(2.5)-50DS-0.4V(51)
684-4101-2 51
50
12.6
9.6
DF40HC(2.5)-60DS-0.4V(51)
684-4085-8 51
60
14.6
11.6
■Stacking height 3.0mm
C
D
1.0
2.4
3.2
【Specification No.】
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
DF40HC(3.0)-30DS-0.4V(51)
684-4098-0 51
30
8.6
5.6
1.5
DF40HC(3.0)-40DS-0.4V(51)
684-4169-6 51
40
10.6
7.6
DF40HC(3.0)-44DS-0.4V(51)
684-4076-7 51
44
11.4
8.4
DF40HC(3.0)-50DS-0.4V(51)
684-4099-2 51
50
12.6
9.6
DF40HC(3.0)-60DS-0.4V(51)
684-4100-0 51
60
14.6
11.6
DF40HC(3.0)-70DS-0.4V(51)
684-4138-2 51
70
16.6
13.6
DF40HC(3.0)-80DS-0.4V(51)
684-4180-9 51
80
18.6
15.6
DF40HC(3.0)-90DS-0.4V(51)
684-4161-4 51
90
20.6
17.6
DF40HC(3.0)-100DS-0.4V(51)
684-4151-0 51
100
22.6
19.6
3.2
D
2.9
Note 3 :
6
■Stacking height 3.5mm
【Specification No.】
(51) : Embossed package 2,000 pcs/reel
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
DF40HC(3.5)-20DS-0.4V(51)
684-4188-0 51
3.6
1.0
DF40HC(3.5)-30DS-0.4V(51)
684-4136-7 51
30
8.6
5.6
1.5
DF40HC(3.5)-40DS-0.4V(51)
684-4209-9 51
40
10.6
7.6
DF40HC(3.5)-50DS-0.4V(51)
684-4109-4 51
50
12.6
9.6
DF40HC(3.5)-60DS-0.4V(51)
684-4102-5 51
60
14.6
11.6
DF40HC(3.5)-80DS-0.4V(51)
684-4162-7 51
80
18.6
15.6
■Stacking height 4.0mm
D
3.4
3.2
【Specification No.】
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
DF40HB(4.0)-50DS-0.4V(51)
684-4104-0 51
50
12.6
DF40HC(4.0)-50DS-0.4V(51)
684-4215-1 51
50
12.6
DF40HC(4.0)-60DS-0.4V(51)
684-4133-9 51
60
14.6
11.6
DF40HC(4.0)-80DS-0.4V(51)
684-4140-4 51
80
18.6
15.6
DF40HC(4.0)-90DS-0.4V(51)
684-4165-5 51
90
20.6
17.6
C
D
3.2
3.9
9.6
Note 3 :
7
■Receptacle (Stacking height 1.5mm, with shield)
< 30 contact >
3.38±0.3
8.64±0.3
6.48±0.1
5.6±0.08
P=0.4±0.05
0.2±0.02
0.12±0.02
Vacuum pick up area: 1.5±0.2
1.45±0.15
3.12±0.2
< 48 contact >
3.38±0.3
P=0.4±0.05
12.24±0.3
10.08±0.1
9.2±0.08
3.2±0.08
0.2±0.02
0.12±0.02
0.12±0.02
Vacuum pick up area: 3.2±0.2
1.45±0.15
3.12±0.2
0.2±0.02
0.6±0.02
0.28±0.02
2.64−00.05
2.38−00.05
1.5MAX
3.78+00.05
+0.05
4.08+00.05
2.64−00.05
P=0.4±0.02
10.08±0.02
9.2±0.02
3.2±0.02
0.6±0.02
0.6±0.02
0.2±0.02
4.08+00.05
< 48 contact >
6.48±0.02
5.6±0.02
P=0.4±0.02
1.5MAX
2.38−00.05
3.78+00.05
< 30 contact >
0.28±0.02
【Specification No.】
Unit : mm
Part No.
HRS No.
No. of Contacts
Signal contact
Ground contact
DF40GB(1.5)-30DS-0.4V(51)
684-4198-4 51
30
30
4
DF40GB(1.5)-48DS-0.4V(51)
684-4194-3 51
48
40
12
Note 2 :
Note 3 : This connector is NOT polarized.
8
■Receptacle (Stacking height 3.0mm, with shield)
< 48 contact >
3.38±0.3
P=0.4±0.05
12.24±0.3
10.08±0.1
9.2±0.08
3.2±0.08
0.2±0.02
0.12±0.02
0.12±0.02
2.9±0.15
< 70 contact >
16.64±0.3
13.6±0.08
9.2±0.08
3.6±0.08
3.38±0.2
3.68±0.2
3.38±0.3
P=0.4±0.05
0.2±0.02
0.12±0.02
0.12±0.05
2.9±0.15
3.12±0.2
< 70 contact >
14.48±0.02
13.6±0.02
9.2±0.02
3.6±0.02
10.08±0.02
9.2±0.02
0.6±0.02
0.28±0.02
1.5MAX
1.5MAX
0.2±0.02
2.64−00.05
P=0.4±0.02
0.6±0.02
4.08+00.05
3.78+00.05
2.38−00.05
3.2±0.02
0.6±0.02
2.64−00.05
4.08+00.05
P=0.4±0.02
0.2±0.02
0.6±0.02
0.6±0.02
0.6±0.02
4.08+00.05
< 48 contact >
4.08+00.05
3.78+00.05
2.38−00.05
3.12±0.2
0.28±0.02
【Specification No.】
Unit : mm
Part No.
HRS No.
No. of Contacts
Signal contact
Ground contact
DF40GB(3.0)-48DS-0.4V(51)
684-4197-1 51
48
40
12
DF40GB(3.0)-70DS-0.4V(51)
684-4196-9 51
70
54
Note 2 : The surface of the 70 pos. part have a small, concave section that will not affect the vacuum pick up operation.
Note 3 :
9
■Header
A±0.2
B±0.08
1.85±0.2
2.97±0.2
P=0.4±0.05
1.14±0.15
0.15±0.02
7¤%#%'
E2%#)¤%#%'
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
DF40C-10DP-0.4V(51)
684-4035-0 51
10
3.52
1.6
C
DF40C-12DP-0.4V(51)
684-4149-9 51
12
3.92
2.0
DF40C-20DP-0.4V(51)
684-4010-9 51
3.6
DF40C-24DP-0.4V(51)
684-4011-1 51
24
6.32
4.4
1.2
DF40C-30DP-0.4V(51)
684-4012-4 51
30
7.52
5.6
1.5
DF40C-34DP-0.4V(51)
684-4024-3 51
34
8.32
6.4
2.3
DF40C-40DP-0.4V(51)
684-4013-7 51
40
9.52
7.6
DF40C-44DP-0.4V(51)
684-4077-0 51
44
10.32
8.4
DF40C-50DP-0.4V(51)
684-4014-0 51
50
11.52
9.6
DF40C-60DP-0.4V(51)
684-4003-3 51
60
13.52
11.6
DF40C-70DP-0.4V(51)
684-4015-2 51
70
15.52
13.6
DF40C-80DP-0.4V(51)
684-4001-8 51
80
17.52
15.6
DF40C-90DP-0.4V(51)
684-4125-0 51
90
19.52
17.6
DF40C-100DP-0.4V(51)
684-4032-1 51
100
21.52
19.6
1.0
3.2
Note 2 : There are no concave parts on the header side contact part to increase the mating strength for 60 pos. or above.
Note 3 : Use the contacts at the four corners as metal fittings. Do not use them as signal or power contacts.
Note 4 : The surface of the 90 pos and higher parts have a small, concave section that will not affect the vacuum pick up operation.
Note 5 : This connector is NOT polarized.
10
■Header (For use with shielded product)
A±0.3
B±0.1
C±0.08
2.97±0.2
2.02±0.2
1.85±0.2
P=0.4±0.05
1.52±0.2
D+00.05
E−00.05
B±0.02
F−00.05
C±0.02
1.88−00.05
1.02−00.05
2.05−00.05
0.23±0.02
3.32+00.05
0.35±0.02
2.42+00.05
P=0.4±0.02
3.37+00.05
0.08±0.02
1.14±0.15
G±0.2
0.15±0.02
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
DF40GB-30DP-0.4V(51)
684-4200-4 51
30
DF40GB-48DP-0.4V(51)
684-4195-6 51
48
DF40GB-70DP-0.4V(51)
684-4199-7 51
70
15.16
D
E
F
G
7.16
6.67
5.6
10.76
10.27
9.2
8.74
7.32
6.12
1.5
12.34
10.92
9.72
3.2
14.67
13.6
16.74
15.32
14.12
3.2
Note 2 : There are no concave parts of header side contact part to increase the mating strength for 60 pos. or above.
Note 3 :
11
BEmbossed Carrier Tape Dimensions (JIS C 0806 compliant)
Ø1
3
±0
Ø80±1
Ø380±2
A
B±0.1
A±0.3
0°
Ø1.5 holes for
feed mechanism
12
0°
.2
2±0.5
0 .8
1±
F-F
C±0.1
F
2±0.1
Product label
Ø2
1
0.
+ 0
.5
4±0.1
●Reel Condition Dimensions
12
Ø1
1.75±0.1
●Receptacle (Stacking height 1.5mm)
A
G
G
E±0.5
D±1
0.2±0.05
.1
+00
5
0.7
H
R
0.3±0.1
F
G-G
1.65±0.15
H
8±0.1
Unreeling Direction
.1
+0 0
.75
R0
Part No.
A
Unit : mm
B
DF40#-10DS-0.4V(51)
DF40#-12DS-0.4V(51)
DF40#-20DS-0.4V(51)
16
DF40#-30DS-0.4V(51)
DF40#-34DS-0.4V(51)
24
DF40#-50DS-0.4V(51)
DF40#-60DS-0.4V(51)
DF40#-70DS-0.4V(51)
DF40#-80DS-0.4V(51)
DF40#-90DS-0.4V(51)
DF40#-100DS-0.4V(51)
D
E
7.5
21.5
17.5
11.5
29.5
25.5
DF40#-24DS-0.4V(51)
DF40#-40DS-0.4V(51)
C
32
28.4
14.2
37.5
33.5
44
40.4
20.2
49.5
45.5
11.5
29.5
25.5
24
Note 1 : For 10 to 60 contact position parts, the carrier tape only has one row of holes. The carrier for parts with 70 contacts and
above has two rows of holes.
12
1.75±0.1
●Receptacle (Stacking height 2.0mm to 2.5mm)
Ø2
Ø1
3
G
G
E±0.5
D±1
.1
+0 0
Unreeling Direction
5
0.7
J
0.3±0.1
H
J
F±0.15
0.2±0.05
8±0.1
R
G-G
.1
+00
.75
R0
B±0.1
A±0.3
Ø80±1
0°
0°
12
12
C±0.1
0 .8
1±
Ø1.5 holes for
feed mechanism
Ø380±2
.1
+0 0
2±0.5
.2
.5
H
Product label
H-H
±0
Ø1
4±0.1
2±0.1
●Reel Dimensions
Part No.
DF40#(2.0)-12DS-0.4V(51)
DF40#(2.0)-20DS-0.4V(51)
DF40#(2.0)-24DS-0.4V(51)
DF40#(2.0)-30DS-0.4V(51)
DF40#(2.0)-40DS-0.4V(51)
DF40#(2.0)-50DS-0.4V(51)
DF40#(2.0)-60DS-0.4V(51)
DF40#(2.0)-70DS-0.4V(51)
DF40#(2.0)-80DS-0.4V(51)
A
16
24
32
Part No.
DF40H#(2.5)-10DS-0.4V(51)
DF40H#(2.5)-20DS-0.4V(51)
DF40H#(2.5)-40DS-0.4V(51)
DF40H#(2.5)-50DS-0.4V(51)
DF40H#(2.5)-60DS-0.4V(51)
B
28.4
C
D
E
7.5
21.5
17.5
11.5
29.5
25.5
14.2
37.5
33.5
Unit : mm
F
2.2
Unit : mm
A
B
C
D
E
F
16
7.5
21.5
17.5
2.72
24
11.5
29.5
25.5
13
1.75±0.1
●Receptacle (Stacking height 3.0mm to 4.0mm)
Product label
2±0.5
Ø80±1
B±0.1
A±0.3
Ø380±2
0°
12
Ø1.5 holes for
feed mechanism
12
0°
Ø1
3
0 .8
1±
C±0.1
.2
H-H
Ø2
.1
+0 0
.5
H
±0
Ø1
4±0.1
2±0.1
G
G
E±0.5
D±1
.1
+00
J
5
0.7
R
0.4±0.1
H
J
F±0.15
0.2±0.05
8±0.1
G-G
Unreeling Direction
.1
+00
.75
R0
Part No.
DF40H#(3.0)-30DS-0.4V(51)
DF40H#(3.0)-40DS-0.4V(51)
DF40H#(3.0)-44DS-0.4V(51)
DF40H#(3.0)-50DS-0.4V(51)
DF40H#(3.0)-60DS-0.4V(51)
DF40H#(3.0)-70DS-0.4V(51)
DF40H#(3.0)-80DS-0.4V(51)
DF40H#(3.0)-90DS-0.4V(51)
DF40H#(3.0)-100DS-0.4V(51)
A
B
C
D
E
24
11.5
29.5
25.5
32
28.4
14.2
37.5
33.5
44
40.4
20.2
49.5
45.5
24
32
28.4
11.5
14.2
29.5
37.5
25.5
33.5
C
7.5
D
21.5
E
17.5
11.5
29.5
25.5
C
D
E
11.5
29.5
25.5
14.2
20.2
37.5
49.5
33.5
45.5
Part No.
A
B
DF40H#(3.5)-20DS-0.4V(51)
DF40H#(3.5)-30DS-0.4V(51)
DF40H#(3.5)-50DS-0.4V(51)
DF40H#(3.5)-60DS-0.4V(51)
16
24
Part No.
DF40H#(4.0)-50DS-0.4V(51)
DF40H#(4.0)-60DS-0.4V(51)
DF40H#(4.0)-80DS-0.4V(51)
DF40H#(4.0)-90DS-0.4V(51)
A
24
32
44
B
28.4
40.4
Unit : mm
F
3.15
Unit : mm
F
3.72
Unit : mm
F
4.15
14
●Reel Dimensions
Product label
0°
A
B±0.1
A±0.3
0°
12
12
C±0.1
0 .8
1±
E±0.5
G
D±1
H
.1
+00
5
.7
Ø0
0.3±0.1
F
G-G
1.34±0.15
0.2±0.05
H
Unreeling Direction
.1
+0 0
.75
Ø0
A
G
Ø1.5 holes for
feed mechanism
Ø80±1
Ø2
2±0.5
Ø380±2
F-F
.2
.1
+0 0
F
±0
.5
4±0.1
2±0.1
Ø1
3
Ø1
1.75±0.1
●Header
Unit : mm
Part No.
DF40C-10DP-0.4V(51)
DF40C-12DP-0.4V(51)
A
12
16
DF40C-30DP-0.4V(51)
DF40C-34DP-0.4V(51)
24
DF40C-50DP-0.4V(51)
DF40C-60DP-0.4V(51)
DF40C-70DP-0.4V(51)
DF40C-80DP-0.4V(51)
DF40C-90DP-0.4V(51)
D
E
5.5
17.5
13.5
7.5
21.5
17.5
11.5
29.5
25.5
DF40C-40DP-0.4V(51)
DF40C-44DP-0.4V(51)
C
DF40C-20DP-0.4V(51)
DF40C-24DP-0.4V(51)
B
32
28.4
14.2
37.5
33.5
44
40.4
20.2
49.5
45.5
16
7.5
21.5
17.5
11.5
29.5
25.5
24
and above has two rows of holes.
15
BOperating Precautions
1. Recommended Solder Profile
Temperature (ç)
250
250ç
220ç
60 seconds
or below
200
180ç
150 150ç
90 to 120 seconds
100
50
Normal
temperature
100
150
200
250
300
Heating time (sec.)
【Conditions】
1. Peak temperature
2. Heating part
3. Preheating part
4. Number of times
Maximum of 250ç
Minimum of 220ç within 60 seconds
150 to 180ç 90 to 120 seconds
Maximum of 2 cycles
Note 1 : The temperature shows PCB surface temperature near the connector lead part.
2. Recommended hand solder
conditions
Soldering iron temperature 340 ±10ç, solder time no more than 3 seconds
3. Recommended screen thickness:
Opening ratio (pattern area ratio)
Thickness : 0.12mm
Opening ratio : DS side 80% DP side 80%
4. Leaning of PCB
16
Max 0.02mm at the center of connector (using both edges of connector as criteria)
5. Washing
Cleaning/washing is not recommended for this connector. Cleaning agents can
deteriorate the mechanical operation and the environmental resistance of this
connector.
6. Precautions
■ Do not mate or unmate these connectors until they are mounted, failure to follow
this precaution can lead to deformation or damage to these connectors.
■ Provide another form of support to the PCB, this connector was not designed to
be the main form of support.
■ Mating and unmating with excessive force can cause damage.
■ Do not apply excessive amounts of flux as it may cause excess solder and flux
wicking.
■ There may be a slight variance in the color of the molding between production
lots, this variance will not affect the performance of the connector.
■ Refer to the next page for the handling precautions when mating and unmating
the connectors.
■ If the connector becomes disconnected due to impact, a fall or a counterforce to
the FPC, it may be necessary to hold the connector in place with an addition to
the device’s case or other cushioning material to hold the connector in place.
BPrecautions when connector mating
DF40*-*DS-0.4V
DF40*-*DS-0.4V
Prior to mating, locate the guidance ribs and
align the header.
Do not apply excess force to the connector
during mating. Doing so can lead to contact
damage.
Make sure that the connector is parallel to
the other side, it then will drop down slightly.
Continue to press it down until it is fully mated
while maintaining the angle. Do not apply
excessive force as it may damage the contacts.
17
BPrecautions when unmating a connector
9;)%"9H"%#)K
9;)%"9E"%#)K
To unmate this connector, lift evenly across
the header, making sure that each side stays
parallel to each other.
If circumstances prevent the connectors from
staying parallel to each other, then one side
may be lifted as shown in the diagram. This
method is only approved if the connector is
mounted onto an extremely rigid circuit board.
If the board were to warp during this process
it may result in damage to the connector or its
solder joints.
Pitch direction
Corner direction
Do not try to disconnect these connectors by
pulling on one side or a corner, or unmate it
while it is securely mounted onto a rigid FPC.
These actions may lead to deformities and
ultimately a damaged connector.
As shown in the figure to the left, do not unmate
it from the width direction (front to back), it may
damage contacts.
Width direction
18
The contact may peel away if there is
not enough rigidity in FPC.
Receptacle
FPC
When mounting the receptacle side to FPC
which does not have enough rigidity, the contact
may peel away soldered connection.
Header
We recommended to mount the header side to
the FPC.
Header
FPC
We have conducted evaluations on the
requirements needed for FPC rigidity. If you
need to mount the receptacle to the FPC,
contact your local Hirose Rep for this data.
Receptacle
Even when mounting the header side to FPC,
if the rigidity of FPC is low, the connector may
break as shown in the left figure. Please check
the strength and durability of FPC before using.
For the evaluation results of each item and FPC
rigidity, please contact us.
19
MEMO:
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 09/2022. Contents are subject to change without notice for the purpose of improvements.
