15+Gbps 0.5mm pitch Stacking Connectors
FX10 Series
Electrical Interface for the OIF 100G Long-Haul DWDM Transmission Module (MSA-100GLH)
■Mechanical Features
● 0.5mm Pitch
● Stacking height : 4 to 8mm (2-piece type)
8 to 13mm (3-piece type)
● Number of Contacts
With ground plate : 80 / 100 / 120 / 140
Without ground plate : 96 / 120 / 144 / 168
3-piece interposer : 120 / 144 /168
FX10A-168P/S-SV(83) assembly is specified for the
host line card - MSA-100GLH electrical connector.
■With GND Plate Type
Ground
plate
● Suited to High-Density Applications
Signal contact
Housing
The 0.5 mm signal contact pitch provides a smaller
overall connector, using less mounting area on the board.
m
5m
● Optional Ground Plate
0.7
mm
Metal fitting
Ground plate and metal
fitting make contact
An alternate style without the ground plate is available.
The space provided by the ground plate removal has
been filled with additional signal contacts.
●Smooth floating with high speed transmission
capability supported by unique 3-piece floating
system
●Multiple connectors are allowed on the same PCB
(Allowable Mis-alignment Range : ± 0.3mm in XY
direction)
mm
0.5
5
0.7
●Floating Interposer
ing
Float
Flo
ati
ng
■Signal Integrity Features
60
115
The insertion-loss-to-crosstalk-ratio (ICR) with
five-aggressor differential FEXT meets the
extrapolated IEEE 802.3ap specification for
15+Gbps.
50
110
40
105
Z (Ohm)
●Insertion-Loss-to-Crosstalk-Ratio(ICR)
ICR (dB)
30
100
●Differential Impedance
85ø configuration and 100ø configuration are
available.
95
10
ICR
ICR spec
4
6
Frequency (GHz)
S(3,3)
8
85
10
■Stack Height
●2-piece type
●With ground plate
Headers
Receptacles
FX10#-*S/*-SV
200
400
600
Time (ps)
800
1000
●Without ground plate
FX10#-xP/x-SV
FX10#–xP/x–SV1
4mm
5mm
Headers
Receptacles
FX10#-*S-SV
FX10#-xP-SV FX10–xP–SV1 FX10#-xP-SV2
4mm
5mm
6mm
FX10#-xP-SV3
FX10#-xP-SV4
7mm
8mm
●3-piece type
Stacking Height
8mm
9mm
10mm
11mm
12mm
13mm
Header (Mating side)
FX10#-xP-SV
FX10#-xP-SV
FX10#-xP-SV1
FX10#-xP-SV2
FX10#-xP-SV3
FX10#-xP-SV4
Interposer
FX10-xIP-xD(Q)-8H
FX10-xIP-xD(Q)-8PH
Header(Fixed side)
FX10#-xP-SV
FX10#-xP-SV1
FX10#-xP-SV1
FX10#-xP-SV1
FX10#-xP-SV1
FX10#-xP-SV1
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
● OIF MSA-100GLH Electrical Interface
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
(H) : Reference dimension
2016.12r
1
FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors
■General Product Specifications (2 piece type)
Rating
Rated
current
Rated
voltage
0.3 A
50 V AC
Item
1. Insulation resistance
2. Voltage resistance
3. Contact resistance
4. Vibration resistance
5. Shock resistance
Operating temperature
range
Operating humidity
range
-55 to 85ç (Note 1)
Relative humidity 95% max
(No condensation)
Requirements
100Mø min
No flashover or breakdown
60mø max
No electrical discontinuity for 1µs or greater
No damage, cracks, or parts looseness
Storage
temperature range
Storage humidity
range
-10 to +60ç
(Note 2)
40 to 70%
(Note 2)
Conditions
Measured at 100 V DC
150 V AC applied for 1 minute
Measured at 100 mA
Frequency : 10 to 55 Hz, amplitude of 0.75 mm
in 3 axis directions, 10 cycles each.
Acceleration of 490 m/s2, 11ms duration, sine
half-wave waveform, for 3 cycles in both directions
of each of the 3 axes
Contact resistance of 70mø max, insulation
resistance of
Temperature of 40ç, humidity of 90 to 95%,
100Mø min, no damage, cracks, or parts
duration 96 h
looseness
7. Temperature cycle Contact resistance of 70mø max, insulation
Temperature : -55ç → 15 to 35ç → 85ç → 15 to 35ç
resistance of
Time : 30 min. → 2 to 3 min. → 30 min. → 2 to 3 min.
for 5 cycles
looseness
8. Mating Cycles
50 times
9. Resistance to
No melting of resin portion which affects
Reflow : At the recommended temperature profile
soldering heat
performance
Soldering iron temperature : 360ç for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term storage refers to unused products kept for a long time prior to board mounting. Operating temperature
and humidity range are applicable to the non-conducting state after board assembly.
Note 3 : Information contained in this catalog represents general requirements for this series. Contact us for the drawings and
specifications for a specific part number shown.
6. Damp heat
(Steady state)
■Materials / Finish
Part
Insulator
Material
LCP
Contacts
Phosphor bronze
Ground plate
Metal fitting
Phosphor bronze
Phosphor bronze
Finish
Beige
Contact Area: Gold plating
Header
Lead Area: Tin plating
Receptacle
Lead Area: Flash plating
Tin plating
Tin plating
Notes
UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FX10 # - * P / * - SV 1 (**)
q
w
r
t
y
u
e
q Series name : FX10
r Connector type
w A : With guide post
P : Header
S : Receptacle
t Mounting style
SV : Straight SMT
y Product height
Blank : Standard
1
: Standard + 1mm
u Packaging options
Blank, (71) : Tray packaging
(21), (91) : Embossed tape packaging
B : Without guide post
e Number of contacts
With ground plate
Signal/Ground : 80/8, 100/10, 120/12,
140/14
Signal : 96, 120, 144, 168
2
■Headers without ground plate
●4mm Stacking Height
A±0.2
(0.6)
5.9±0.3
( 5.7)
D±0.3 2.5±0.2
( 0.5 )
0.2 ±0.05
B±0.3
2-(Ø1)
Guidepost
C±0.1
Unit : mm
HRS No.
570-0041-0 **
570-0042-2 **
570-0043-5 **
570-0044-8 **
570-0141-4 **
570-0142-7 **
570-0143-0 **
570-0144-2 **
570-0059-5 **
570-0056-7 **
570-0302-1 **
570-0060-4 **
570-0057-0 **
570-0304-7 **
570-0061-7 **
570-0058-2 **
570-0306-2 **
570-0051-3 **
570-0052-6 **
570-0053-9 **
570-0054-1 **
570-0151-8 **
570-0152-0 **
570-0153-3 **
570-0154-6 **
570-0303-4 **
570-0305-0 **
570-0063-0 **
570-0307-5 **
A
B
C
23.5
29.5
35.5
41.5
23.5
29.5
35.5
41.5
29.5
35.5
41.5
29.5
35.5
41.5
29.5
35.5
41.5
23.5
29.5
35.5
41.5
23.5
29.5
35.5
41.5
41.5
41.5
35.5
41.5
31.1
37.1
43.1
49.1
31.1
37.1
43.1
49.1
37.1
43.1
49.1
37.1
43.1
49.1
37.1
43.1
49.1
31.1
37.1
43.1
49.1
31.1
37.1
43.1
49.1
49.1
49.1
43.1
49.1
26.4
32.4
38.4
44.4
26.4
32.4
38.4
44.4
32.4
38.4
44.4
32.4
38.4
44.4
32.4
38.4
44.4
D
3.5
4.5
5.25
6.25
7.25
3.5
4.5
5.25
6.25
7.25
E
F
31.5
37.5
43.5
49.5
31.5
37.5
43.5
49.5
37.5
43.5
49.5
37.5
43.5
49.5
37.5
43.5
49.5
31.5
37.5
43.5
49.5
31.5
37.5
43.5
49.5
49.5
49.5
43.5
49.5
28.3
34.3
40.3
46.3
28.3
34.3
40.3
46.3
34.3
40.3
46.3
34.3
40.3
46.3
34.3
40.3
46.3
28.3
34.3
40.3
46.3
28.3
34.3
40.3
46.3
46.3
46.3
40.3
46.3
Remarks
With
guideposts
Without
guideposts
[Specifications number]-**, (**)
(71) : Tray packaging / AuP 0.1µm
(83) : Embossed tape packaging 1RL : 1000pcs / AuP 0.76µm
(85) : Embossed tape packaging 1RL : 250pcs / AuP 0.76µm
(91) : Embossed tape packaging 1RL : 1000pcs / AuP 0.1µm
(93) : Tray packaging / AuP 0.76µm
Note 1: There is no polarity with respect to board mounting for this product.
Note 2: The coplanarity of this product's SMT leads is 0.1mm or less.
Note 3: Please order embossed tape packaged items by the reel.
■Board-to-Board Distance
BRecommended PCB Layout
Dimensions (Metal mask)
HEADER CONNECTOR
FX10A(B)-168P-SV*(83)
1.45±0.05
3
PCB
PCB
RECEPTACLE CONNECTOR
FX10A(B)-168S-SV(83)
6.3+0.1
0.5 ±0.03
1
2 Ø1.1 ±0.05
2 Ø1.2 ±0.05
E +0.1
F -0.1
C ±0.05
A ±0.05
SOLDER
2 B
1 (A)
(1.1):MATING LENGTH
Recommended metal mask thickness : 0.15mm
3.1 +0.1
Part No.
FX10A-96P-SV(**)
FX10A-120P-SV(**)
FX10A-144P-SV(**)
FX10A-168P-SV(**)
FX10A-96P-SV1(**)
FX10A-120P-SV1(**)
FX10A-144P-SV1(**)
FX10A-168P-SV1(**)
FX10A-120P-SV2(**)
FX10A-144P-SV2(**)
FX10A-168P-SV2(**)
FX10A-120P-SV3(**)
FX10A-144P-SV3(**)
FX10A-168P-SV3(**)
FX10A-120P-SV4(**)
FX10A-144P-SV4(**)
FX10A-168P-SV4(**)
FX10B-96P-SV(**)
FX10B-120P-SV(**)
FX10B-144P-SV(**)
FX10B-168P-SV(**)
FX10B-96P-SV1(**)
FX10B-120P-SV1(**)
FX10B-144P-SV1(**)
FX10B-168P-SV1(**)
FX10B-168P-SV2(**)
FX10B-168P-SV3(**)
FX10B-144P-SV4(**)
FX10B-168P-SV4(**)
No. of Contacts
Signal
96
120
144
168
96
120
144
168
120
144
168
120
144
168
120
144
168
96
120
144
168
96
120
144
168
168
168
144
168
0.3±0.03(Land)
0.25±0.03(Metal mask)
Note 1 The cross-hatched area
inside the SMT land
may come into contact with the connector contacts
and thus care should be taken that the pattern
does not extend beyond the SMT land width.
2 Not required in products without guideposts.
FX10A(B)-168P-SV(83)
FX10A(B)-168P-SV1(83)
FX10A(B)-168P-SV2(83)
FX10A(B)-168P-SV3(83)
FX10A(B)-168P-SV4(83)
SOLDER
3
1 (A)
2 B
4
4.3±0.127
5.3±0.127
5
6.0±0.127
6
7
7.0±0.127
8
8.0±0.127
Note 1 Stacking height from lead to lead (reference dimensions)
2 Board-to-board distance
3 Stencil (metal mask) shall be based on Hirose's
recommended aperture and thickness.
3
■Receptacles without ground plate
A±0.2
B±0.3
3.2±0.3
( 7.1 )
0.2 ±0.05
2.5 ±0.2
7.3 ±0.3
( 0.5 )
( 0.6 )
2-(Ø1)
C±0.1
Guidepost
Unit : mm
A
B
C
D
E
FX10A-96S-SV(**)
No. of Contacts
HRS No.
Signal
570-0241-9 **
96
23.5
31.1
26.4
31.5
28.3
FX10A-120S-SV(**)
570-0242-1 **
120
29.5
37.1
32.4
37.5
34.3
FX10A-144S-SV(**)
570-0243-4 **
144
35.5
43.1
38.4
43.5
40.3
FX10A-168S-SV(**)
570-0244-7 **
168
41.5
49.1
44.4
49.5
46.3
FX10B-96S-SV(**)
570-0251-2 **
96
23.5
31.1
26.4
31.5
28.3
Part No.
FX10B-120S-SV(**)
570-0252-5 **
120
29.5
37.1
32.4
37.5
34.3
FX10B-144S-SV(**)
570-0253-8 **
144
35.5
43.1
38.4
43.5
40.3
FX10B-168S-SV(**)
570-0254-0 **
168
41.5
49.1
44.4
49.5
46.3
Remarks
With
guideposts
Without
guideposts
[Specifications number] -✽ ✽, (✽ ✽)
Blank: Tray packaging / AuP 0.1µm
(21) : Embossed tape packaging 1RL : 1000pcs / AuP 0.1µm
(84) : Embossed tape packaging 1RL : 500pcs / AuP 0.76µm
Note 1 : There is no polarity with respect to board mounting for this product.
Note 2 : The coplanarity of this product's SMT leads is 0.1mm or less.
Note 3 : Please order embossed tape packaged items by the reel.
Note 4 : Using multiple connectors between two boards is not recommended.
BRecommended PCB Layout Dimensions (Metal mask)
D +0.1
E -0.1
C±0.05
Ø1.2±0.05 1
A±0.05
1.45±0.05
Note 1 Not required in products without guideposts.
4
7.7 +0.1
0.5±0.03
3.1 +0.1
1 Ø1.1±0.05
0.3±0.03(Land)
■Headers with ground plate
Unit : mm
Part No.
HRS No.
No.of Contacts
A
Signal Ground
80
8
23.5
B
C
D
E
F
FX10A-80P/8-SV(**)
570-0001-5 **
18
31.1 26.4 31.5 28.3
FX10A-100P/10-SV(**)
570-0002-8 **
100
10
29.5
24
37.1 32.4 37.5 34.3
FX10A-120P/12-SV(**)
570-0003-0 **
120
12
35.5
30
43.1 38.4 43.5 40.3
FX10A-140P/14-SV(**)
570-0004-3 **
140
14
41.5
36
49.1 44.4 49.5 46.3
FX10B-80P/8-SV(**)
570-0021-2 **
80
8
23.5
18
31.1
31.5 28.3
FX10B-100P/10-SV(**)
570-0022-5 **
100
10
29.5
24
37.1
37.5 34.3
FX10B-120P/12-SV(**)
570-0023-8 **
120
12
35.5
30
43.1
43.5 40.3
FX10B-140P/14-SV(**)
570-0024-0 **
140
14
41.5
36
49.1
49.5 46.3
Remarks
With
guideposts
Without
guideposts
Note 3 : Please order embossed tape packaged items by the reel. (One reel holds 1,000 pieces.)
Note 4 : Using multiple connectors between identical boards is not recommended.
Note 1 Cross-hatched portions, totaling n places, indicate the ground circuits.
2 Cross-hatched portions, 2 places on both sides, indicate the metal fittings.
3 The cross-hatched area
inside the SMT land may come into contact with the connector contacts
and thus care should be taken that the pattern does not extend beyond the SMT land width.
4 Not required in products without guideposts.
5
●5mm Stacking Height
A±0.2
(0.5)
0.2±0.05
5.9±0.3
(5.7)
2.5±0.2
A
0.5±0.05
(0.75)
(0.75)
(6)
B±0.2
4.5±0.3
C±0.3
(0.6)
2-(Ø1)
D±0.1
Guidepost
Unit : mm
Part No.
HRS No.
No. of Contacts
A
Signal Ground
80
8
23.5
B
C
D
E
F
FX10A-80P/8-SV1(**)
570-0101-0 **
18
31.1 26.4 31.5 28.3
FX10A-100P/10-SV1(**)
570-0102-2 **
100
10
29.5
24
37.1 32.4 37.5 34.3
FX10A-120P/12-SV1(**)
570-0103-5 **
120
12
35.5
30
43.1 38.4 43.5 40.3
FX10A-140P/14-SV1(**)
570-0104-8 **
140
14
41.5
36
49.1 44.4 49.5 46.3
FX10B-80P/8-SV1(**)
570-0121-7 **
80
8
23.5
18
31.1
31.5 28.3
FX10B-100P/10-SV1(**)
570-0122-0 **
100
10
29.5
24
37.1
37.5 34.3
FX10B-120P/12-SV1(**)
570-0123-2 **
120
12
35.5
30
43.1
43.5 40.3
FX10B-140P/14-SV1(**)
570-0124-5 **
140
14
41.5
36
49.1
49.5 46.3
Remarks
With
guideposts
Without
guideposts
6
■Receptacles with ground plate
A±0.2
(0.5)
0.2±0.05
7.3±0.3
(7.1)
2.5±0.2
A
0.5±0.05
(0.75)
(0.75)
(6)
(0.6) 3.2±0.3
B±0.2
C±0.3
2-(Ø1)
Guidepost
D±0.1
Unit : mm
Part No.
HRS No.
No. of Contacts
A
Signal Ground
80
8
23.5
B
C
D
E
F
FX10A-80S/8-SV(**)
570-0201-4 **
18
31.1 26.4 31.5 28.3
FX10A-100S/10-SV(**)
570-0202-7 **
100
10
FX10A-120S/12-SV(**)
570-0203-0 **
120
12
29.5
24
37.1 32.4 37.5 34.3
35.5
30
43.1 38.4 43.5 40.3
FX10A-140S/14-SV(**)
570-0204-2 **
140
14
41.5
36
49.1 44.4 49.5 46.3
FX10B-80S/8-SV(**)
570-0221-1 **
80
8
23.5
18
31.1
31.5 28.3
FX10B-100S/10-SV(**)
570-0222-4 **
100
10
29.5
24
37.1
37.5 34.3
FX10B-120S/12-SV(**)
570-0223-7 **
120
12
35.5
30
43.1
43.5 40.3
FX10B-140S/14-SV(**)
570-0224-0 **
140
14
41.5
36
49.1
49.5 46.3
Remarks
With
guideposts
Without
guideposts
3 Not required in products without guideposts.
7
■General Product Specifications (3 piece type)
Rating
Rated
current
Rated
voltage
0.3A
50V AC
range
Operating humidity
range
-55 to 85ç (Note 1)
(No condensation)
Item
Requirements
1. Insulation resistance 100Mø min
2. Voltage resistance No flashover or breakdown
3. Contact resistance 8mm height : 80mø max
9mm height : 85mø max
10mm height : 90mø max
11mm height : 95mø max
12mm height : 100mø max
13mm height : 105mø max
4. Vibration resistance No electrical discontinuity for 1µs or greater
5. Shock resistance
Storage
temperature range
Storage humidity
range
-10 to +60ç
(Note 2)
40 to 70%
(Note 2)
Conditions
Measured at 100 mA
Frequency : 10 to 55 Hz, amplitude of 0.75mm
Acceleration of 490m/s2, 11ms duration, sine
6. Damp heat
(Steady state)
Contact resistance change : 20 mø or less,
insulation resistance of 100Mø min, no
duration 96 h
7. Temperature cycle Contact resistance change : 20mø or less,
for 5 cycles
8. Mating Cycles
50 times
■Materials / Finish
Part
Insulator
Contacts
Ground bar
Material
LCP
Phosphor bronze
Phosphor bronze
Finish
Black/Gray
Ni plating
FX10 - # IP - 36 DM1 - #H (#)
q
w e
q Series Name : FX10
w Pin count : 120, 144, 168 pins
e Connector type
IP : Interposer
r Number of Diff-pairs
t Signal type
8
D : Diff. 100 ohm
Q : Diff. 85 ohm
(Blank) : Open pin field
r
t y
u
i
y Pin configuration
Blank = Standard (all diff pairs),
M* =Reduced GND pins
u Stacking height
8H : 8 to 10mm
8PH : 11 to 13mm
i Specification suffix #
(Blank) : Ni1.5µm + Au0.1µm
(03)
: Ni1.5µm + Au0.76µm
Notes
UL94V-0
6.76±0.5
A±0.5
6.5±0.5
7.7±0.5
■Interposer (3piece type)
Mating side
(Gray)
Fixed side
(Black)
Unit : mm
Part No.
HRS No.
FX10-168IP-40D-8H(**)
608-0001-3 **
FX10-168IP-40D-8PH(**)
608-0004-1 **
FX10-168IP-52Q-8H(**)
608-0002-6 **
Signal Differential
Singleended
Ground
type
pairs
100ø
40
4
84
85ø
52
8
56
FX10-168IP-52Q-8PH(**)
608-0005-4 **
FX10-168IP-8H(**)
608-0003-9 **
Open
pin field
FX10-168IP-8PH(**)
608-0006-7 **
FX10-144IP-32D-8H(**)
608-0007-0 **
FX10-144IP-32D-8PH(**)
608-0011-7 **
FX10-144IP-44Q-8H(**)
608-0008-2 **
FX10-144IP-44Q-8PH(**)
608-0010-4 **
FX10-144IP-8H(**)
608-0009-5 **
Open
pin field
100ø
85ø
FX10-144IP-8PH(**)
608-0012-0 **
FX10-120IP-28D-8H(**)
608-0013-2 **
FX10-120IP-28D-8PH(**)
608-0014-5 **
FX10-120IP-36Q-8H(**)
608-0015-8 **
FX10-120IP-36Q-8PH(**)
608-0016-0 **
FX10-120IP-8H(**)
608-0017-3 **
Open
FX10-120IP-8PH(**)
608-0018-6 **
pin field
100ø
85ø
32
pins
12
pins
8
48
For 11 to 13mm height
49.1
8
40
For 8 to 10mm height
43.1
60
36
Remarks
68
44
28
A
37.1
Blank : Contact plating Ni1.5µm+Au0.1µm
(03) : Contact plating Ni1.5µm+Au0.76µm
8mm
Header
(Mating side)
FX10#-xP-SV
Stacking height
9mm
FX10#-xP-SV
10mm
FX10#-xP-SV1
11mm
FX10#-xP-SV2
12mm
FX10#-xP-SV3
13mm
FX10#-xP-SV4
Interposer
FX10-xIP-xD(Q)-8H
Header
(Fixed side)
FX10#-xP-SV
FX10#-xP-SV1
FX10#-xP-SV1
FX10#-xP-SV1
FX10-xIP-xD(Q)-8PH
FX10#-xP-SV1
FX10#-xP-SV1
9
■Signal integrity (2 piece type)
● Pin assignment
To match 100 ohm differential impedance and to reduce crosstalk, a staggered GSGSG pin assignment is recommended.
(G=ground and S=signal)
GSGSG
signal
Diff pair
ground
● Impedance
The differential impedance is 100 +/- 10 ohm for FX10 at 30 ps rise time (20% to 80%).
5mm (without GND)
115
115
110
110
105
105
Z (Ohm)
Z (Ohm)
4mm (without GND)
100
95
100
95
90
90
S(3,3)
85
400
600
Time (ps)
800
S(3,3)
85
1000
800
115
115
110
110
105
105
100
100
95
95
90
90
S(3,3)
S(3,3)
85
1000
5mm (with GND)
Z (Ohm)
Z (Ohm)
4mm (with GND)
400
600
Time (ps)
400
600
Time (ps)
800
1000
85
400
600
Time (ps)
800
1000
● Propagation delay
The propagation delay is 62 and 67 ps for FX10 of 4mm and 5mm height (with and without GND), respectively.
10
● Insertion loss
The differential insertion loss crosses 1dB at 10.8 and 9.2GHz for FX10 of 4mm and 5mm height, respectively.
4mm (without GND)
5mm (without GND)
S (dB)
S (dB)
IL
5
10
Frequency (GHz)
15
IL
4mm (with GND)
5
10
Frequency (GHz)
15
5mm (with GND)
S (dB)
IL
10
Frequency (GHz)
15
● Return loss
The differential return loss meets the IEEE 802.3ap specification to 20 + and 13.5 GHz for FX10 of 4mm and 5mm height,
respectively.
4mm (without GND)
5mm (without GND)
RL (dB)
RL (dB)
RL
RL Spec
RL
RL Spec
10
Frequency (GHz)
15
4mm (with GND)
5
10
Frequency (GHz)
15
5mm (with GND)
RL (dB)
RL (dB)
RL
RL Spec
RL
RL Spec
10
Frequency (GHz)
15
10
Frequency (GHz)
15
● Near-end crosstalk (NEXT)
The staggered GSGSG pin assignment results in low differential NEXT between neighboring pairs.
4mm (without GND)
5mm (without GND)
NEXT
S (dB)
S (dB)
NEXT
10
Frequency (GHz)
15
4mm (with GND)
10
Frequency (GHz)
15
5mm (with GND)
S (dB)
NEXT
S (dB)
NEXT
10
Frequency (GHz)
15
10
Frequency (GHz)
15
● Far-end crosstalk (FEXT)
The staggered GSGSG pin assignment results in low differential FEXT between neighboring pairs.
4mm (without GND)
5mm (without GND)
FEXT
S (dB)
S (dB)
FEXT
10
Frequency (GHz)
15
4mm (with GND)
15
5mm (with GND)
FEXT
S (dB)
FEXT
S (dB)
10
Frequency (GHz)
5
10
Frequency (GHz)
15
10
Frequency (GHz)
15
● Insertion-loss-to-crosstalk ratio (ICR)
The insertion-loss-to-crosstalk ratio (ICR) with five-aggressor differential FEXT meets the extrapolated IEEE 802.3ap
specification to 10+ Gbps.
5mm (without GND)
60
50
50
40
40
ICR (dB)
ICR (dB)
4mm (without GND)
60
30
10
ICR
ICR spec
4
6
Frequency (GHz)
8
4mm (with GND)
60
50
50
40
40
30
4
6
Frequency (GHz)
8
10
5mm (with GND)
30
ICR
ICR spec
60
ICR (dB)
ICR (dB)
10
ICR
ICR spec
4
6
Frequency (GHz)
8
10
ICR
ICR spec
4
6
Frequency (GHz)
8
10
13
■Signal integrity (3-piece type)
● Pin assignment
For 100 ohm type interposer, pin assignment shall be GSGSG.
For 85 ohm type interposer, pin assignment shall be GSSG.
1.Differential Impedance
100 Type
2.Differential Impedance
85 Type
3.Open Pin Field Type
(With Ground Bar)
(With Ground Bar)
(No Ground Bar)
Pin Assignment
Pin Assignment
Pin Assignment
Row A
Row A
Row A
Row B
Row B
Row B
Signal Pin
Ground Bar
Dedicated Ground Pin
Differential Pair
● Impedance
● Insertion Loss
8mm (85 ohm type)
8mm (85 ohm type)
105
95
-1
S (dB)
Z (Ohm)
90
85
-2
-3
80
-4
75
IL
70
-5
TDR, Rise-time: 50ps(20-80%)
65
0.9
0.95
1
1.05
1.1
1.15
Time (ns)
1.2
1.25
1.3
● Return Loss
specification to 20+GHz for FX10 of 8mm height.
8mm (85 ohm type)
-10
RL (dB)
-15
-20
-25
-30
-35
-40
RL
RL spec
-45
-50
14
10
Frequency (GHz)
15
10
Frequency (GHz)
15
-10
-20
-20
S (dB)
S (dB)
8mm (85 ohm type)
-30
-40
-40
-50
-50
Sdd(2,5)
Sdd(2,3)
-60
10
15
10
15
Frequency (GHz)
Frequency (GHz)
8mm (85 ohm type)
-10
-10
-20
-20
S(dB)
S(dB)
-30
-40
-40
-50
-50
-60
-60
10
Frequency(GHz)
15
8
10
12
14
Frequency(GHz)
16
18
The insertion-loss-to-crosstalk ratio (ICR) with fiveaggressor differential FEXT meets the extrapolated IEEE
802.3ap specification to 15+Gbps.
8mm (85 ohm type)
60
50
40
ICR (dB)
-30
30
ICR
ICR spec
10
15
Frequency (GHz)
15
BEmbossed Carrier Tape Dimensions
Ø1.5 +0.1
12±0.1
4±0.1
2 ±0.1
1.75±0.1
●Headers
(D)
0.9
(0.4)
Insertion Connector
A
B
C
FX10#-80P/8-SV
20.2 40.4 44
FX10#-100P/10-SV
B±0.1
C±0.3
A±0.1
FX10#-120P/12-SV
34.2 68.4 72
FX10#-96P-SV
20.2 40.4 44
FX10#-144P-SV
Unreeling direction
0.2 ±0.05
1.75±0.1
+0.1
45.5 50.5
FX10#-168P-SV1
( 3.5)
26.2 52.4 56
20.2 40.4 44
59
4.8
26.2 52.4 56
34.2 68.4 72
64
76.5 81.5
45.5 50.5
59
64
76.5 81.5
0.9
B±0.1
C±0.3
Unit : mm
Insertion Connector
A
B
C
E
F
G
FX10#-80S/8-SV
20.2 40.4 44 45.5 50.5
FX10#-100S/10-SV
FX10#-120S/12-SV
(7.6)
(8)
59
64
34.2 68.4 72 76.5 81.5
FX10#-96S-SV
FX10#-144S-SV
0.2 ±0.05
26.2 52.4 56
FX10#-140S/14-SV
FX10#-120S-SV
FX10#-168S-SV
26.2 52.4 56
59
64
Note : There is no polarity with respect to embossed
tape packaging for this product.
+0.05
R0.75 0
(Ø80)
(G)
●Reel Dimensions
Ø13±0.5
370
( 0.4)
A±0.1
Ø1.5
59
330
Note : There is no polarity with respect to embossed tape
●Receptacles
(E)
(F)
16
45.5 50.5
20.2 40.4 44
FX10#-144P-SV1
Unreeling direction
76.5 81.5
FX10#-80P/8-SV1
FX10#-120P-SV1
4±0.1
64
76.5 81.5
FX10#-96P-SV1
12±0.1
3.8
26.2 52.4 56
FX10#-140P/14-SV1 34.2 68.4 72
2 ±0.1
59
34.2 68.4 72
FX10#-120P/12-SV1
+0.05
R0.75 0
Unit : mm
E
F
G
45.5 50.5
FX10#-168P-SV
FX10#-100P/10-SV1
(6.2)
(6.6)
26.2 52.4 56
FX10#-140P/14-SV
FX10#-120P-SV
D
330
BRecommended Temperature Profile
HRS test Conditions
Test board Glass epoxy 161mm∞100mm∞1.6mm thick
Solder method
: Reflow
Solder composition
: Paste,
Metal mask
: 0.15mm thick
Reflow cycles
: 2 cycles
96.5%Sn/3%Ag/0.5%Cu
The temperature profile is based on the above conditions.
In individual applications the actual temperature may vary,
depending on solder paste type,
volume/thickness and board size/thickness. Consult your
solder paste and equipment manufacturer for specific
recommendations.
BWashing Conditions
Organic Solvent Cleaning
Solvent
Room temperature washing Heated washing
IPA (Isopropyl alcohol)
HCFC (Hydrochlorofluorocarbon)
Water Type Cleaning
When using water based cleaning agents (e.g., terpene, alkali saponifiers) make sure the labeling discloses any effect on
metals, platings and plastics. Remove any moisture after cleaning. Residual flux or cleaning agents in the contact areas
may affect the electrical performance.
Cleaning Precautions
Residual flux or cleaning agents in the contact areas may affect the electrical performance. Please make sure a
thorough cleaning operation has been completed.
BConnector Handling Precautions
1. Mating lengths and creepage distance
The effective wipe length for this product is 1.1mm for the signal contact and 1 mm for the ground contact.
Creepage of the header and receptacle during mating should be within 0.5 mm of the fully mated position.
2. PCB support
Note that boards should not be supported solely by the connectors themselves. Support should be in the
form of spacers and screws or other suitable methods to support the boards.
3. Solder repairs
During repair, the flux could wick onto the contact area of the connector and cause reduced contact
reliability. In this case, make sure you understand washing conditions before washing is implemented.
4. Miscellaneous
・Note that excessive twisting while inserting or withdrawing connectors will cause damage.
・Slight color differences on the molded items may be noted. However, these color differences will not
affect the connector's performance.
17
BSpacer
Suggested spacer style is
shown below:
Spacers are required to support the PWB’s and protect the SMT solder joints.
Spacer
Spacer, male-male, M3 thread
The recommended spacer height corresponds to the interposer stacking height as shown in the chart below.
Stacking height
Recommended spacer height
Remark
4mm
4.3 ± 0.127mm
5mm
5.3 ± 0.127mm
6mm
6 ± 0.127mm
7mm
7 ± 0.127mm
8mm
8 ± 0.127mm
8mm
8 ± 0.127mm
9mm
9 ± 0.127mm
10mm
10 ± 0.127mm
11mm
11 ± 0.127mm
12mm
12 ± 0.127mm
13mm
13 ± 0.127mm
2 piece type
3 piece type
◆Recommended spacer location
10-30mm
10-30mm
Four spacers located diagonally are required.
Spacers should be located 10 to 30mm from the
connector to prevent excessive mechanical loading on
the interconnections.
If assembly will be subjected to vibration, spacer should
be located to prevent resonance, and additional spacer
may be required.
■ Interposer installation
Position the interposer directly over the
mounting header. (Interposers have no
polarity.)
Fixed side (black side) of the interposer
shall be mated with the mounting
header (fixed side).
Do not use SV2, SV3, or SV4 headers on
both sides of the interposer. The wiping
length on the mating side becomes
shorter.
Interposer
Mounting header
(Fixed side)
8mm
Header
(Mating side)
FX10#-xP-SV
9mm
FX10#-xP-SV
10mm
FX10#-xP-SV1
FX10#-xP-SV1
11mm
FX10#-xP-SV2
FX10#-xP-SV1
12mm
FX10#-xP-SV3
13mm
FX10#-xP-SV4
Stacking height
18
Mating side
(Mold color: Gray)
Fixed side
(Mold color: Black)
Interposer
FX10-xIP-xD(Q)-8H
FX10-xIP-xD(Q)-8PH
Header
(Fixed side)
FX10#-xP-SV
FX10#-xP-SV1
FX10#-xP-SV1
FX10#-xP-SV1
B Interposer removal
The interposer can be removed from the mounting
header by hand. (No special tools are needed.)
Removal and re-mating of the fixed side can
reduce the extraction force of the fixed side due to
wear. It is recommend to replace the interposer to
a new one once removed.
B Multiple Mating
It is not recommended to use multiple 2-piece FX10 connectors on the same PWB.
FX10 3-piece type has multiple mating capability.
If multiple connectors are used on the same PWB, they must be oriented in the same direction.
It is not recommended to mix orientations.
●Mating tolerance (3-piece type)
Due to the floating interposer, FX10 3-piece type can accept mating tolerances of up to ±0.15mm
tolerance in the X-axis and up to ±0.15mm in the Y-axis.
0.15mm
0.15mm
19
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
Regus La Garenne Colombes,Place de La Belgique,
71 Boulevard National La Garenne Colombes, 92250, France
Phone : +33 (0) 1 7082 3170
Fax : +33 (1) 7082 3101
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
1601, Henderson Metropolitan, NO.300, East Nanjing
Road, Huangpu District, Shanghai, China 200001
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
250, Huimanggongwon-ro, Siheung-si,
Gyeonggi-do, Korea, 15083
Phone : +82-31-496-7000 or 7124
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
10 Anson Road #26-16, International Plaza Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
079903, Singapore
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
MALAYSIA:
PENANG REPRESENTATIVE OFFICE
1-21-01, Suntech @ Penang Cybercity (1164), Lintang
Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia.
Phone : +604-619-2564
Fax : +604-619-2574
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
THAILAND:
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Phone : +66-2-686-1255
Fax : +66-2-686-3433
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 12/2016. Contents are subject to change without notice for the purpose of improvements.
