FX23-120P-0.5SV15
FX23-120P-0.5SV15
    HRS(广濑)
    CONNHDR0.5MM120POSSMD
FX23-120P-0.5SV15 数据手册
APPLICABLE STANDARD Operating Temperature Range Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. to Storage Temperature Range 105 C (1) Signal Contact:50 V AC Power Contact:200 V AC Signal Contact:0.5 A Power Contact:3.0A Voltage Rating -55 C 2 Current -10 C Storage Humidity Range to 60 C (2) Relative humidity 85% max (Not dewed) Operating Humidity Range SPECIFICATIONS ITEM CONSTRUCTION TEST METHOD General Examination Marking REQUIREMENTS Visually and by measuring instrument. Confirmed visually. QT AT According to drawing. × × × × Signal Contact : 70mΩ MAX. Power Contact : 20mΩ MAX. Signal Contact : 100 MΩMIN. Power Contact : 1000 MΩMIN. × - × - × × × - × - × - × - × - ① Contact Resistance: Signal Contact : 80mΩ MAX. Power Contact : 30mΩ MAX. ② Insulation Resistance: Signal Contact : 100 M MIN. Power Contact : 1000 M MIN. ③ No damage, crack and looseness of parts. ① Contact Resistance: Signal Contact : 80mΩ MAX. Power Contact : 30mΩ MAX. ② No damage, crack and looseness of parts. × - × - × - × - ① No defect such as corrosion which impairs the function of connector. ② Contact Resistance: Signal Contact : 80mΩ MAX. Power Contact : 30mΩ MAX. No deformation of case of excessive looseness of the terminal. × - × - A new uniform coating of solder shall cover a minimum of 95 % of the surface being immersed. × - ELECTRIC CHARACTERISTICS Contact Resistance 100 mA(DC or 1000Hz) Insulation Resistance Signal Contact : 100 V DC. Power Contact : 250 V DC Signal Contact : 150 V AC for 1 min. Power Contact : 600 V AC for 1 min. Voltage Proof No flashover or breakdown. MECHANICAL CHARACTERISTICS Insertion and Withdrawal Forces Mechanical Operation Measured by applicable connector. Vibration Frequency 10 to 55 to 10Hz, approx 5min Single amplitude : 0.75 mm, 10 cycles for 3 axial directions. Shock 490 m/s2 , duration of pulse 11 ms at 3 times for 3 both axial directions. Insertion Force: 54 N MAX. Withdrawal Force: 6 N MIN. ① Contact Resistance: Signal Contact : 80mΩ MAX. Power Contact : 30mΩ MAX. ② No damage, crack and looseness of parts. ① No electrical discontinuity of 1 s. ② No damage, crack and looseness of parts. 100 times insertions and extractions. ENVIRONMENTAL CHARACTERISTICS 40±2 C, 90 ~ 95 %, Damp Heat (Steady state) Exposed at Rapid Change of Temperature Temperature -55 → +85 C Time 30 → 30 min. under 5 cycles. (Relocation time to chamber : within 2~3 MIN) Cold Exposed at -55℃, 96 h Exposed at 105℃, 96 h Dry Heat 2 96 h. Sulfur Dioxide Exposed at 25±2℃, 75±5%RH, 25 PPM for 96 h. (Test standard: IEC 68) Resistance to Soldering Heat 1)Reflow soldering : Peak TMP : 260℃MAX Reflow TMP: 220℃MIN for 60sec 2) Soldering irons : 360℃ MAX. for 5 sec. Soldered at solder temperature 240±3℃ for immersion duration, 3 sec. Solderability 2 △ COUNT DESCRIPTION OF REVISIONS DESIGNED 2 DIS-F-00002057 TS.OONO REMARKS (1) Include temperature rise caused by current-carrying. (2) “STORAGE” means a long-term storage state for the unused product before assembly to PCB. Unless otherwise specified, refer to IEC 60512. Note QT:Qualification Test FORM HD0011-2-1 AT:Assurance Test X:Applicable Test PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. DATE HT.YAMAGUCHI 17.02.01 APPROVED HS.OKAWA 14.07.22 CHECKED KN.SHIBUYA 14.07.22 DESIGNED TS.OONO 14.07.22 DRAWN TS.OONO 14.07.22 DRAWING NO. SPECIFICATION SHEET CHECKED ELC-353542-00-00 FX23-120P-0.5SV15 CL573-3006-4-00 2 △ 1/1
FX23-120P-0.5SV15 价格&库存
很抱歉,暂时无法提供与“FX23-120P-0.5SV15”相匹配的价格&库存,您可以联系我们找货
FX23-120P-0.5SV15
    FX23-120P-0.5SV15
      库存:480
      FX23-120P-0.5SV15
        • 1+63.710251+8.24663
        • 5+54.554285+7.06149
        • 10+46.7999110+6.05776
        • 30+41.6413930+5.39005
        • 50+40.6047150+5.25586
        • 60+40.3476160+5.22258
        • 100+39.82513100+5.15495
        库存:153
