BM10NB(0.6)-24DS-0.4V(51)
    HRS(广濑)
    CONN RCPT 24POS 0.4MM SMD GOLD
BM10NB(0.6)-24DS-0.4V(51) 数据手册
0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors BM10 Series Decrease in the board-occupied area BM10 4.56mm BM10 Series:P=0.4mm, H=0.8mm 40pos. 2.98mm Other HRS connector P=0.4mm, H=0.9mm 10.22mm 10.4mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Conventional connector 4.56×10.22 = 46.60mm2 33.5% saving of space BM10 2.98×10.4 = 30.99mm2 figure.1 High contact reliability ■Features 1.Higher density of the board-mounted components Extremely small board mounting pattern and low above theboard profile makes the connectors ideally suited for small device applications. Globally unrivalled compact depth : when mated 2.98mm Header 2.46mm Length - world’s smallest class : 10.4mm Main contact point Header contact Auxiliary lock point Receptacle contact figure.2 2.Reliable electrical and mechanical connection Despite its small mated height, unique contact configuration, with a 2-point contacts and effective mating length of 0.2mm(height 0.8mm), assures highly reliable connection while confirming a complete mating with a definite tactile feel. Splatter protection 8dciVXiVgZVh 3.Large self-alignment distance The connectors will self-align within 0.3 mm. 4.Built-in shock absorbing feature The protrusions and indents in the insulator bodies protect the connectors from failures when exposed to sudden impact. 8dciVXiVgZVh 5.Solder wicking prevention Nickel barriers prevent un-intentional solder wicking. 6.Contamination protection Insulator walls protect the contact areas against flux splatter or other physical particles contamination. 7.Conducive traces on the PCB can run under the connector No exposed contacts on the bottom of the connector. 8dciVXiVgZVhVgZcdiZmedhZYidi]Zdjih^YZ eZcZigVi^dcd[i]Z[ajmdgdi]Zge]nh^XVaeVgi^XaZh# figure.3 2022.2 1 BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ■Specifications Current rating 0.3A Operating -35°C to +85°C (Note 1) temperature range Storage -10°C to +60°C (Note 2) temperature range Voltage rating 30V AC, DC Operating humidity range Storage humidity range Ratings Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item RH 20% to 80% Specification RH 40% to 70% (Note 2) Conditions 1.Insulation resistance 50Mø min 100V DC 2.Withstanding voltage No flashover or insulation breakdown 100V AC / 1minute 3.Contact resistance 100mø max. 20mV AC, 1kHz, 1mA 4.Vibration No electrical discontinuity of 1µs or longer No damage or parts dislocation Frequency : 10 to 55 Hz, 5min, single amplitude of 0.75 mm, 10cycles, for each directions. 5.Humidity Contact resistance : 100mø max., Insulation resistance : 25Mø min. 96hours at 40 ±2°C and humidity of 90 to 95% No damage or parts dislocation Contact resistance : 100mø max., Insulation resistance : 50Mø min. No damage or parts dislocation Contact resistance : 100mø max. -55°C ➝ 5 to 35°C ➝ 85°C ➝ 5 to 35°C Time : 30min. ➝ 10min. ➝ 30min. ➝ 10min. 5cycles 10cycles No deformation of components affecting performance Reflow : At the recommended temperature profile Manual soldering : 350°C for 3 seconds 6.Temperature cycle 7.Durability 8.Resistance to soldering heat Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use. The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting and the temporary storage conditions of transportation, etc. Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Product Part Material Finish Remarks Receptacle Insulator LCP Color:Black UL94V-0 Header Contacts Phosphor bronze Gold plated --------- ■Ordering information ●Receptacles / Headers BM 10 # (0.8) − * DS − 0.4 V (**) ❶ ❷ ❸ ❹ ❶ Series name : BM ❷ Series No. : 10 ❸ Configuration B : With mettal fittings NB : With mettal fittings ❹ Stacking Height : 0.8mm ❺ Number of contacts.10 to 60 2 ❺ ❻ ❼ ❽ ❾ ❻ Connector style DS : Double-row receptacle DP : Double-row header ❼ Contact pitch : 0.4mm ❽ Termination type V…SMT vertical mount ❾ Packaging (51) : Embossed tape packaging (8,000 pieces per reel) (53) : Embossed tape packaging (1,000 pieces per reel) BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ■H=0.8mm Receptacles (With metal fittings) A B 2.9 2.98 P=0.4 2.64 D 0.08 ■Recommended PCB mounting pattern F +0.05 0 0 E -0.05 B±0.02 3.28 +0.05 0 0 2.34 -0.05 0 2.34 -0.05 P=0.4±0.02 3.44 +0.05 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.8 Pick and place area : C 0.23±0.02 All dimensions : mm Part Number BM10NB(0.8)-10DS-0.4V(51) BM10NB(0.8)-16DS-0.4V(51) BM10NB(0.8)-20DS-0.4V(51) BM10NB(0.8)-24DS-0.4V(51) BM10NB(0.8)-30DS-0.4V(51) BM10NB(0.8)-34DS-0.4V(51) BM10NB(0.8)-40DS-0.4V(51) BM10NB(0.8)-44DS-0.4V(51) BM10NB(0.8)-50DS-0.4V(51) BM10NB(0.8)-60DS-0.4V(51) HRS No. 684-6100-0 51 684-6110-4 51 684-6105-4 51 684-6101-3 51 684-6106-7 51 684-6108-2 51 684-6107-0 51 684-6109-5 51 684-6102-6 51 684-6103-9 51 Number of Contacts 10 16 20 24 30 34 40 44 50 60 A 4.4 5.6 6.4 7.2 8.4 9.2 10.4 11.2 12.4 14.4 B 1.6 2.8 3.6 4.4 5.6 6.4 7.6 8.4 9.6 11.6 C 0.8 1.6 1.6 2 2 2.4 2.4 2.8 2.8 3.2 D 3.1 4.3 5.1 5.9 7.1 7.9 9.1 9.9 11.1 13.1 E 2.18 3.38 4.18 4.98 6.18 6.98 8.18 8.98 10.18 12.18 F 4.02 5.22 6.02 6.82 8.02 8.82 10.02 10.82 12.02 14.02 Note 1 : Order by number of reels. Note 2 : This connector is NOT polarized. 3 BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ■Headers (With metal fittings) A B 1.8 1.62 2.46 P=0.4 0.08 Pick and place area : C Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.08 0.63 0.15 D ■Recommended metal mask dimensions F +0.05 0 0 E -0.05 B±0.02 2.76 +0.05 0 0 1.28 -0.05 0 0.8 -0.05 1.98 +0.05 0 P=0.4±0.02 0.23±0.02 All dimensions : mm Part Number BM10B(0.8)-10DP-0.4V(51) BM10B(0.8)-16DP-0.4V(51) BM10B(0.8)-20DP-0.4V(51) BM10B(0.8)-24DP-0.4V(51) BM10B(0.8)-30DP-0.4V(51) BM10B(0.8)-34DP-0.4V(51) BM10B(0.8)-40DP-0.4V(51) BM10B(0.8)-44DP-0.4V(51) BM10B(0.8)-50DP-0.4V(51) BM10B(0.8)-60DP-0.4V(51) HRS No. 684-6007-5 51 684-6047-0 51 684-6009-0 51 684-6011-2 51 684-6013-8 51 684-6015-3 51 684-6003-4 51 684-6039-1 51 684-6017-9 51 684-6001-9 51 Note 1 : Order by number of reels. Note 2 : This connector is NOT polarized. 4 Number of Contacts 10 16 20 24 30 34 40 44 50 60 A 3.32 4.52 5.32 6.12 7.32 8.12 9.32 10.12 11.32 13.32 B 1.6 2.8 3.6 4.4 5.6 6.4 7.6 8.4 9.6 11.6 C 0.8 1.6 1.6 2 2 2.4 2.4 2.8 2.8 3.2 D 2.74 3.94 4.74 5.54 6.74 7.54 8.74 9.54 10.74 12.74 E 2.3 3.5 4.3 5.1 6.3 7.1 8.3 9.1 10.3 12.3 F 3.18 4.38 5.18 5.98 7.18 7.98 9.18 9.98 11.18 13.18 BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ■Embossed Carrier Tape Dimensions ¢&#* -¤%#& '¤%#& )¤%#& : :": &#%*¤%#&* %#(¤%#& 6¤%#( ; ; : ;"; JcgZZa^c\Y^gZXi^dc -¤%#& '¤%#& )¤%#& : :": &#%*¤%#&* (¤%#& 6¤%#( 7¤%#& %#& % &#,*¤%#& ●Receptacle (less than 24 positions) ¢&#* Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7¤%#& %#& % &#,*¤%#& ●Receptacle (24 and above positions) ; ; : ;"; JcgZZa^c\Y^gZXi^dc 5 BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ¤% Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8¤%#* 9¤& Unit : mm 6 Part Number A B C D BM10#(0.8)-10DS-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-16DS-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-20DS-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-24DS-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-30DS-0.4V(51) 24 11.5 25.5 29.5 BM10#(0.8)-34DS-0.4V(51) 24 11.5 25.5 29.5 BM10#(0.8)-40DS-0.4V(51) 24 11.5 25.5 29.5 BM10#(0.8)-44DS-0.4V(51) 24 11.5 25.5 29.5 BM10#(0.8)-50DS-0.4V(51) 24 11.5 25.5 29.5 BM10#(0.8)-60DS-0.4V(51) 24 11.5 25.5 29.5 ¢(-%¤' ¢-%¤& ¢& ( EVgicjbWZgaVWZa #' ■Reel dimensions (Receptacles) BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ●Header )¤%#& & %# % : ) :": &#,*¤%#& '¤%#& #* ¢& -¤%#& %#-¤%#&* %#(¤%#& ')¤%#( Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. &&#*¤%#& * : JcgZZa^c\Y^gZXi^dc ; ; ;"; 7 BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ¤% Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8¤%#* 9¤& Unit : mm 8 Part Number A B C D BM10#(0.8)-10DP-0.4V(51) 12 5.5 13.5 17.5 BM10#(0.8)-16DP-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-20DP-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-24DP-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-30DP-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-34DP-0.4V(51) 16 7.5 17.5 21.5 BM10#(0.8)-40DP-0.4V(51) 24 11.5 25.5 29.5 BM10#(0.8)-44DP-0.4V(51) 24 11.5 25.5 29.5 BM10#(0.8)-50DP-0.4V(51) 24 11.5 25.5 29.5 BM10#(0.8)-60DP-0.4V(51) 24 11.5 25.5 29.5 ¢(-%¤' ¢-%¤& ¢& ( EVgicjbWZgaVWZa #' ■Reel dimensions (Header) BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ■Usage Recommendations 1.Recommended temperature profile IZbeZgVijgZ '*% '*% ''% '%% +%hZXbVm &-% &*% &*% .%s&'%hZX Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. &%% *% GddbiZbeZgVijgZ % *% &%% &*% '%% '*% (%% I^bZhZX# Note 1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.Recommended manual soldering 3.Recommended screen thickness and open area ratio (Pattern area ratio) Manual soldering : 340±10ç for 3 seconds Header, Receptacle : Thickness 0.12mm : Open area ratio 100% * When using nitrogen-reflow, 75% only at the header side. 4.Board warpage Maximum of 0.02mm at the connector center, with both ends of the connector as reference points. 5.Cleaning conditions Cleaning is not recommended. If you clean this product, please evaluate its performance before using it. (Cleaning may impair the mating/unmating properties and lower resistance to environmental factors.) 6.Precautions ■ Be careful when mating/unmating the connector when it is not mounted on the PCB as it may cause damage/deformation to contacts. ■ Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc. ■ Excessive prying during unmating/mating may result in damage. ■ In the case of hand soldering, please do not apply any flux which could cause flux wicking. ■ This product may have slight color differences due to production lot variability, but this does not affect the performance. ■ Please refer to the following page for handling precautions when inserting and removing. ■ Because the product can disengage if dropped (or other impact), or by FPC routing, it is advised to secure the mated connectors to the board with housings and cushioning materials 9 BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ■Handling Precautions when Mating Connectors BM10*(0.8)-*DP-0.4V Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BM10*(0.8)-*DS-0.4V Keep the connectors parallel to each other when positioning. The connectors will selfalign in horizontal directions. Do not attempt to mate the connectors starting at one end or side. Press-down even until fully mated. 10 BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors ■CHandling Precautions When Un-mating Connectors BM10*(0.8)-*DP-0.4V Fully mated Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BM10*(0.8)-*DS-0.4V Lift even, keeping both connectors parallel to each other E^iX]dg^ZciVi^dc 8dgcZgdg^ZciVi^dc L^Yi]dg^ZciVi^dc When handling, circumstances may prevent the connectors from being kept parallel when un-mating. One end may be lifted as shown. However, to use this procedure the connector must be mounted on sufficiently rigid circuit board. Any deflection of the board during this operation may result in damage to the connector or solder joints. Do not attempt to start the un-mating of the connectors from one side or corner. Failure to exercise caution when un-mating the connectors mounted on the non-rigid FPC may also result in connector breakage. It is the responsibility of the user to perform verification of the repeated mating / un-mating cycles with the connectors mounted on the applicable FPC. When the rigidity of the FPC is low, there is a risk that the connector could break as illustrated in the diagram at left. Please use the connectors after performing a check of repeated operation with the FPC that the customer will be using. Evaluative results of FPC rigidity and various items are available. Please inquire. 11 BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 12 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 02/2022. Contents are subject to change without notice for the purpose of improvements.
物料型号:HIROSE ELECTRIC CO., LTD.生产的BM10系列,0.4mm接触间距,0.8mm堆叠高度的板对板/板对FPC连接器。
器件简介:BM10系列连接器具有极高的密度,非常适合小型化应用。它们拥有全球最小的堆叠高度2.98mm(公头)和2.46mm(长度),以及10.4mm的总长度。
引脚分配:文档中提供了详细的引脚分配和推荐PCB布局图案,包括公头和母头的尺寸。
参数特性:包括电流额定值0.3A、电压额定值30V AC/DC、工作温度范围-35°C至+85°C等。
功能详解:连接器具有高接触可靠性、自对准能力、内置减震特性、防止焊锡桥接、防污染保护、以及PCB走线可以在连接器下方等特点。
应用信息:适用于需要高可靠性的应用,如汽车领域。在这些情况下,建议联系公司代表以获取更多信息。
封装信息:包括绝缘体材料LCP、颜色黑色、UL94V-0;接触材料为磷青铜,表面镀金。
订购信息:提供了详细的订购代码格式,以及不同接触点数的型号和对应的尺寸参数。
BM10NB(0.6)-24DS-0.4V(51) 价格&库存
很抱歉,暂时无法提供与“BM10NB(0.6)-24DS-0.4V(51)”相匹配的价格&库存,您可以联系我们找货
