BM10NB(0.8)-24DS-0.4V(75) 数据手册
0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors
BM10 Series
Decrease in the board-occupied area
BM10
4.56mm
BM10 Series:P=0.4mm, H=0.8mm 40pos.
2.98mm
Other HRS connector
P=0.4mm, H=0.9mm
10.22mm
10.4mm
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Conventional connector
4.56×10.22
= 46.60mm2
33.5%
saving of space
BM10
2.98×10.4
= 30.99mm2
figure.1
High contact reliability
■Features
1.Higher density of the board-mounted
components
Extremely small board mounting pattern and low above theboard profile makes the connectors ideally suited for small
device applications.
Globally unrivalled compact depth : when mated 2.98mm
Header 2.46mm
Length - world’s smallest class : 10.4mm
Main contact
point
Header contact
Auxiliary lock
point
Receptacle contact
figure.2
2.Reliable electrical and mechanical connection
Despite its small mated height, unique contact configuration,
with a 2-point contacts and effective mating length of
0.2mm(height 0.8mm), assures highly reliable connection while
confirming a complete mating with a definite tactile feel.
Splatter protection
8dciVXiVgZVh
3.Large self-alignment distance
The connectors will self-align within 0.3 mm.
4.Built-in shock absorbing feature
The protrusions and indents in the insulator bodies protect the
connectors from failures when exposed to sudden impact.
8dciVXiVgZVh
5.Solder wicking prevention
Nickel barriers prevent un-intentional solder wicking.
6.Contamination protection
Insulator walls protect the contact areas against flux splatter or
other physical particles contamination.
7.Conducive traces on the PCB can run under
the connector
No exposed contacts on the bottom of the connector.
8dciVXiVgZVhVgZcdiZmedhZYidi]Zdjih^YZ
eZcZigVi^dcd[i]Z[ajmdgdi]Zge]nh^XVaeVgi^XaZh#
figure.3
2022.2
1
BM10 Series●0.4mm Contact Pitch,Stacking Height 0.8mm Board-to-Board /Board-to-FPC Connectors
■Specifications
Current rating
0.3A
Operating
-35°C to +85°C (Note 1)
temperature range
Storage
-10°C to +60°C (Note 2)
temperature range
Voltage rating
30V AC, DC
Operating
humidity range
Storage
humidity range
Ratings
Item
RH 20% to 80%
Specification
RH 40% to 70% (Note 2)
Conditions
1.Insulation resistance
50Mø min
100V DC
2.Withstanding voltage
No flashover or insulation breakdown
100V AC / 1minute
3.Contact resistance
100mø max.
20mV AC, 1kHz, 1mA
4.Vibration
No electrical discontinuity of 1µs or longer
No damage or parts dislocation
Frequency : 10 to 55 Hz, 5min, single amplitude of 0.75
mm, 10cycles, for each directions.
5.Humidity
Contact resistance : 100mø max.,
Insulation resistance : 25Mø min.
96hours at 40 ±2°C and humidity of 90 to 95%
Insulation resistance : 50Mø min.
-55°C ➝ 5 to 35°C ➝ 85°C ➝ 5 to 35°C
Time : 30min. ➝ 10min. ➝ 30min. ➝ 10min.
5cycles
10cycles
No deformation of components affecting performance
Reflow : At the recommended temperature profile
Manual soldering : 350°C for 3 seconds
6.Temperature cycle
7.Durability
8.Resistance to
soldering heat
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use.
The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting and the
temporary storage conditions of transportation, etc.
Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications
for a specific part number shown.
■Material
Product
Part
Material
Finish
Remarks
Receptacle
Insulator
LCP
Color:Black
UL94V-0
Header
Contacts
Phosphor bronze
Gold plated
■Ordering information
●Receptacles / Headers
BM 10 # (0.8) − * DS − 0.4 V (**)
❶
❷
❸
❹
❶ Series name : BM
❷ Series No. : 10
❸ Configuration
B : With mettal fittings
NB : With mettal fittings
❹ Stacking Height : 0.8mm
❺ Number of contacts.10 to 60
2
❺
❻
❼
❽
❾
❻ Connector style
DS : Double-row receptacle
DP : Double-row header
❼ Contact pitch : 0.4mm
❽ Termination type V…SMT vertical mount
❾ Packaging
(51) : Embossed tape packaging (8,000 pieces per reel)
(53) : Embossed tape packaging (1,000 pieces per reel)
■H=0.8mm Receptacles (With metal fittings)
A
B
2.9
2.98
P=0.4
2.64
D
0.08
■Recommended PCB mounting pattern
F +0.05
E -0.05
B±0.02
3.28 +0.05
P=0.4±0.02
3.44 +0.05
0.8
Pick and place area : C
0.23±0.02
All dimensions : mm
Part Number
BM10NB(0.8)-10DS-0.4V(51)
BM10NB(0.8)-16DS-0.4V(51)
BM10NB(0.8)-20DS-0.4V(51)
BM10NB(0.8)-24DS-0.4V(51)
BM10NB(0.8)-30DS-0.4V(51)
BM10NB(0.8)-34DS-0.4V(51)
BM10NB(0.8)-40DS-0.4V(51)
BM10NB(0.8)-44DS-0.4V(51)
BM10NB(0.8)-50DS-0.4V(51)
BM10NB(0.8)-60DS-0.4V(51)
HRS No.
684-6100-0 51
684-6110-4 51
684-6105-4 51
684-6101-3 51
684-6106-7 51
684-6108-2 51
684-6107-0 51
684-6109-5 51
684-6102-6 51
684-6103-9 51
Number of Contacts
10
16
30
34
40
44
50
60
A
4.4
5.6
6.4
7.2
8.4
9.2
10.4
11.2
12.4
14.4
B
1.6
2.8
3.6
4.4
5.6
6.4
7.6
8.4
9.6
11.6
C
0.8
1.6
1.6
2
2
2.4
2.4
2.8
2.8
3.2
D
3.1
4.3
5.1
5.9
7.1
7.9
9.1
9.9
11.1
13.1
E
2.18
3.38
4.18
4.98
6.18
6.98
8.18
8.98
10.18
12.18
F
4.02
5.22
6.02
6.82
8.02
8.82
10.02
10.82
12.02
14.02
Note 1 : Order by number of reels.
Note 2 : This connector is NOT polarized.
3
■Headers (With metal fittings)
A
B
1.8
1.62
2.46
P=0.4
0.08
0.08
0.63
0.15
D
■Recommended metal mask dimensions
F
+0.05
E -0.05
B±0.02
2.76 +0.05
1.98 +0.05
P=0.4±0.02
0.23±0.02
All dimensions : mm
Part Number
BM10B(0.8)-10DP-0.4V(51)
BM10B(0.8)-16DP-0.4V(51)
BM10B(0.8)-20DP-0.4V(51)
BM10B(0.8)-24DP-0.4V(51)
BM10B(0.8)-30DP-0.4V(51)
BM10B(0.8)-34DP-0.4V(51)
BM10B(0.8)-40DP-0.4V(51)
BM10B(0.8)-44DP-0.4V(51)
BM10B(0.8)-50DP-0.4V(51)
BM10B(0.8)-60DP-0.4V(51)
HRS No.
684-6007-5 51
684-6047-0 51
684-6009-0 51
684-6011-2 51
684-6013-8 51
684-6015-3 51
684-6003-4 51
684-6039-1 51
684-6017-9 51
684-6001-9 51
4
Number of Contacts
10
16
30
34
40
44
50
60
A
3.32
4.52
5.32
6.12
7.32
8.12
9.32
10.12
11.32
13.32
B
1.6
2.8
3.6
4.4
5.6
6.4
7.6
8.4
9.6
11.6
C
0.8
1.6
1.6
2
2
2.4
2.4
2.8
2.8
3.2
D
2.74
3.94
4.74
5.54
6.74
7.54
8.74
9.54
10.74
12.74
E
2.3
3.5
4.3
5.1
6.3
7.1
8.3
9.1
10.3
12.3
F
3.18
4.38
5.18
5.98
7.18
7.98
9.18
9.98
11.18
13.18
■Embossed Carrier Tape Dimensions
6¤%#(
JcgZZa^c\Y^gZXi^dc
6¤%#(
7¤%#&
●Receptacle (less than 24 positions)
7¤%#&
●Receptacle (24 and above positions)
JcgZZa^c\Y^gZXi^dc
5
8¤%#*
9¤&
Unit : mm
6
Part Number
A
B
C
D
BM10#(0.8)-10DS-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-16DS-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-20DS-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-24DS-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-30DS-0.4V(51)
24
11.5
25.5
29.5
BM10#(0.8)-34DS-0.4V(51)
24
11.5
25.5
29.5
BM10#(0.8)-40DS-0.4V(51)
24
11.5
25.5
29.5
BM10#(0.8)-44DS-0.4V(51)
24
11.5
25.5
29.5
BM10#(0.8)-50DS-0.4V(51)
24
11.5
25.5
29.5
BM10#(0.8)-60DS-0.4V(51)
24
11.5
25.5
29.5
EVgicjbWZgaVWZa
■Reel dimensions (Receptacles)
●Header
JcgZZa^c\Y^gZXi^dc
7
8¤%#*
9¤&
Unit : mm
8
Part Number
A
B
C
D
BM10#(0.8)-10DP-0.4V(51)
12
5.5
13.5
17.5
BM10#(0.8)-16DP-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-20DP-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-24DP-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-30DP-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-34DP-0.4V(51)
16
7.5
17.5
21.5
BM10#(0.8)-40DP-0.4V(51)
24
11.5
25.5
29.5
BM10#(0.8)-44DP-0.4V(51)
24
11.5
25.5
29.5
BM10#(0.8)-50DP-0.4V(51)
24
11.5
25.5
29.5
BM10#(0.8)-60DP-0.4V(51)
24
11.5
25.5
29.5
EVgicjbWZgaVWZa
■Reel dimensions (Header)
■Usage Recommendations
1.Recommended temperature profile
IZbeZgVijgZ
+%hZXbVm
.%s&'%hZX
GddbiZbeZgVijgZ
I^bZhZX#
Note 1 : Up to 2 cycles of Reflow soldering are possible under the
same conditions, provided that there is a return to normal
temperature between the first and second cycle.
Note 2 : The temperature profile indicates the board surface
temperature at the point of contacts with the connector
terminals.
2.Recommended manual soldering
3.Recommended screen thickness and open
area ratio (Pattern area ratio)
Manual soldering : 340±10ç for 3 seconds
Header, Receptacle : Thickness 0.12mm
: Open area ratio 100%
* When using nitrogen-reflow, 75% only at the header side.
4.Board warpage
Maximum of 0.02mm at the connector center, with both ends of the
connector as reference points.
5.Cleaning conditions
Cleaning is not recommended.
If you clean this product, please evaluate its performance before using it.
(Cleaning may impair the mating/unmating properties and lower
resistance to environmental factors.)
6.Precautions
■ Be careful when mating/unmating the connector when it is not mounted
on the PCB as it may cause damage/deformation to contacts.
■ Avoid supporting the PCB only with the connectors.
Support it by other means such as bolts, screws, posts, etc.
■ Excessive prying during unmating/mating may result in damage.
■ In the case of hand soldering, please do not apply any flux which
could cause flux wicking.
■ This product may have slight color differences due to production
lot variability, but this does not affect the performance.
■ Please refer to the following page for handling precautions when
inserting and removing.
■ Because the product can disengage if dropped (or other impact),
or by FPC routing, it is advised to secure the mated connectors
to the board with housings and cushioning materials
9
■Handling Precautions when Mating Connectors
BM10*(0.8)-*DP-0.4V
BM10*(0.8)-*DS-0.4V
Keep the connectors parallel to each other
when positioning. The connectors will selfalign in horizontal directions.
Do not attempt to mate the connectors starting
at one end or side.
Press-down even until fully mated.
10
■CHandling Precautions When Un-mating Connectors
BM10*(0.8)-*DP-0.4V
Fully mated
BM10*(0.8)-*DS-0.4V
Lift even, keeping both connectors parallel to
each other
E^iX]dg^ZciVi^dc
8dgcZgdg^ZciVi^dc
L^Yi]dg^ZciVi^dc
When handling, circumstances may prevent
the connectors from being kept parallel when
un-mating. One end may be lifted as shown.
However, to use this procedure the connector
must be mounted on sufficiently rigid circuit
board.
Any deflection of the board during this
operation may result in damage to the
connector or solder joints.
Do not attempt to start the un-mating of the
connectors from one side or corner.
Failure to exercise caution when un-mating
the connectors mounted on the non-rigid FPC
may also result in connector breakage.
It is the responsibility of the user to perform
verification of the repeated mating / un-mating
cycles with the connectors mounted on the
applicable FPC.
When the rigidity of the FPC is low, there is a
risk that the connector could break as
illustrated in the diagram at left.
Please use the connectors after performing a
check of repeated operation with the FPC that
the customer will be using.
Evaluative results of FPC rigidity and various
items are available. Please inquire.
11
MEMO:
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
12
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 02/2022. Contents are subject to change without notice for the purpose of improvements.
