BM14C(0.8)-38DP-0.4V(51)
    HRS(广濑)
    CONNHDR38POS0.4MMSMD
BM14C(0.8)-38DP-0.4V(51) 数据手册
0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors BM14 Series Mating Cross-Section Diagram (H = 0.8mm type) Features Molded structure 1. Stacking height : 0.8mm Stacking height is 0.8mm. The molded structure provides security and insulation between the terminals and the board 2. Ultra space-saving design With its drastically reduced depth of 1.98mm, this series can fit in the tightest designs. Fig.1 Solid mating feedback 3. Two point contact system Dimple on contact The two point contact structure encloses the plug contacts and assures a completely secure connection. (Fig.1) Point A 4. Superior tactile feedback A clear tactile click is delivered upon the successful completion of the mating process. (Fig. 2) 5. Drop and shock resistant structure Dimples were designed into the plug contacts ; they increase retention force and absorb shock when dropped. Insertion force 70 6. User friendly operations The low-profile connectors with stacking height of 0.8mm maintain the mating self-alignment range of 0.3mm, securing easy mating operations. 7. No pattern prohibited area No restrictions on PCB layout patter n are imposed, as thin molding technology maintains the effective mating length of 0.2mm while achieving complete insulation between the bottom side of the receptacle and the board. 60 50 Insertion force (N) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Molded structure Two-point contact system 40 Clear tactile feeling 30 20 10 0 -10 Time Distance (mm) Fig.2 Image : 0.8mm stacking height In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.12r 1 BM14 Series●0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors Product Specifications Ratings Current capacity 0.3A Operating temperature range Operating humidity range -35°C to +85°C (Note 1) 20% to 80% RH Rated voltage 30V AC, DC Storage temperature range Storage humidity range -10°C to +60°C (Note 2) 40% to 70% RH (Note 2) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Conditions 1.Insulation resistance Minimum of 500Mø 100V DC 2.Withstanding voltage No flashover or insulation breakdown 100V AC / 1minute 3.Contact resistance Maximum of 100mø 20mV AC, 1kHz, 1mA 4.Vibration No electrical discontinuity of 1µs or longer Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions 5.Humidity Contact resistance : Maximum of 100mø Insulation resistance : Minimum of 25Mø 96 hours at 40 ±2ç and humidity of 90 to 95% 6.Temperature cycle Contact resistance : Maximum of 100mø Insulation resistance : Minimum of 50Mø Temperature : -55ç ➝ 5 to 35ç ➝ 85°C ➝ 5 to 35ç Time : 30 ➝ 10 ➝ 30 ➝ 10 (minutes) 5 cycles 7.Durability (mating/unmating) Contact resistance : Maximum of 100mø 10 mating cycles 8.Resistance to soldering heat No deformation of components affecting performance Reflow : At the recommended temperature profile Manual soldering: 350ç for 3 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use. The operating temperature and humidity range covers the non-energized condition of connectors after board mounting and the temporary storage conditions during transportation, etc. Materials / Finish Product Component Material Color/Finish Remarks Receptacle Insulator LCP Color: Black UL94V-0 Header Contacts Phosphor bronze Gold plated −−−− Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacles / Headers BM 14 # (**) − * DS − 0.4 V (**) ❶ ❷ ❸ ❹ ❶ Series name : BM ❺ ❻ ❼ ❽ ❾ ❻ Connector style ❷ Series No. : 14 DS : Double-row receptacle ❸ Configuration DP : Double-row plug B : With metal fittings ❼ Contact pitch : 0.4mm C : Without metal fittings ❽ Termination type ❹Stacking heights : 0.8mm ❺Number of contacts : V : SMT vertical mount ❾ Packaging (51) : Embossed tape packaging (8,000 pcs/reel) 2 BM14 Series●0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors H = 0.8mm Receptacle A B 1.98 P=0.4 0.67 Recommended PCB layout (H = 0.8mm) With metal fittings Without metal fittings B±0.02 C±0.02 0.3±0.02 P=0.4±0.02 0 1.48 -0.05 0 1.48 -0.05 2.28 +0.05 0 0.4±0.02 2.28+0.05 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.8 0.1 0.2±0.02 0.41±0.02 0.2±0.02 With metal fittings Part No. BM14B(0.8)-10DS-0.4V(51) BM14B(0.8)-12DS-0.4V(51) BM14B(0.8)-20DS-0.4V(51) BM14B(0.8)-24DS-0.4V(51) BM14B(0.8)-30DS-0.4V(51) BM14B(0.8)-34DS-0.4V(51) BM14B(0.8)-40DS-0.4V(51) BM14B(0.8)-50DS-0.4V(51) BM14B(0.8)-60DS-0.4V(51) Unit : mm HRS No. 684-8003-5 51 684-8041-4 51 684-8004-8 51 684-8005-0 51 684-8006-0 51 684-8007-6 51 684-8008-9 51 684-8009-1 51 684-8001-0 51 No. of Contacts 10 12 20 24 30 34 40 50 60 A 4.48 4.88 6.48 7.28 8.48 9.28 10.48 12.48 14.48 HRS No. 684-8017-0 51 684-8039-2 51 684-8018-2 51 684-8020-4 51 684-8022-0 51 684-8023-2 51 684-8024-5 51 No. of Contacts 14 16 24 34 44 54 64 A 4.48 4.88 6.48 8.48 10.48 12.48 14.48 Without metal fittings Part No. BM14C(0.8)-14DS-0.4V(51) BM14C(0.8)-16DS-0.4V(51) BM14C(0.8)-24DS-0.4V(51) BM14C(0.8)-34DS-0.4V(51) BM14C(0.8)-44DS-0.4V(51) BM14C(0.8)-54DS-0.4V(51) BM14C(0.8)-64DS-0.4V(51) B 2.4 2.8 4.4 5.2 6.4 7.2 8.4 10.4 12.4 C 1.6 2.0 3.6 4.4 5.6 6.4 7.6 9.6 11.6 Unit : mm B 2.4 2.8 4.4 6.4 8.4 10.4 12.4 Note 1 : Please place orders in full reel quantities. Note 2 : The only difference between "with metal fittings" and "without metal fittings" is that the contacts at the four corners will be used as reinforcing metal fittings or signal contacts. There is no difference in the performance or dimensions of the connector. Note 3 : This connector is NOT polarized. 3 BM14 Series●0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors Header A B 1 1.58 P=0.4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.61 0.15 Recommended PCB layout With metal fittings Without metal fittings C±0.02 0.285±0.02 B±0.02 0.4±0.02 0 0.54 -0.05 0.54 0 -0.05 1.88 +0.05 0 1.88 +0.05 0 P=0.4±0.02 0.23±0.02 0.33±0.02 0.23±0.02 With metal fittings Part No. BM14B(0.8)-10DP-0.4V(51) BM14B(0.8)-12DP-0.4V(51) BM14B(0.8)-20DP-0.4V(51) BM14B(0.8)-24DP-0.4V(51) BM14B(0.8)-30DP-0.4V(51) BM14B(0.8)-34DP-0.4V(51) BM14B(0.8)-40DP-0.4V(51) BM14B(0.8)-50DP-0.4V(51) BM14B(0.8)-60DP-0.4V(51) Unit : mm HRS No. 684-8010-0 51 684-8042-7 51 684-8011-3 51 684-8012-6 51 684-8013-9 51 684-8014-1 51 684-8015-4 51 684-8016-7 51 684-8002-2 51 No. of Contacts 10 12 20 24 30 34 40 50 60 A 3.66 4.06 5.66 6.46 7.66 8.46 9.66 11.66 13.66 HRS No. 684-8025-8 51 684-8040-1 51 684-8026-0 51 684-8028-6 51 684-8030-8 51 684-8031-0 51 684-8032-3 51 No. of Contacts 14 16 24 34 44 54 64 A 3.66 4.06 5.66 7.66 9.66 11.66 13.66 Without metal fittings Part No. BM14C(0.8)-14DP-0.4V(51) BM14C(0.8)-16DP-0.4V(51) BM14C(0.8)-24DP-0.4V(51) BM14C(0.8)-34DP-0.4V(51) BM14C(0.8)-44DP-0.4V(51) BM14C(0.8)-54DP-0.4V(51) BM14C(0.8)-64DP-0.4V(51) B 2.4 2.8 4.4 5.2 6.4 7.2 8.4 10.4 12.4 C 1.6 2.0 3.6 4.4 5.6 6.4 7.6 9.6 11.6 Unit : mm B 2.4 2.8 4.4 6.4 8.4 10.4 12.4 Note 1 : Please place orders in full reel quantities. Note 2 : The only difference between "with metal fittings" and "without metal fittings" is that the contacts at the four corners will be used as reinforcing metal fittings or signal contacts. There is no difference in the performance or dimensions of the connector. Note 3 : This connector is NOT polarized. 4 BM14 Series●0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors Embossed Carrier Tape Dimensions : H = 0.8mm (JIS C 0806 Compliant) K-K (D) 2±0.3 (6) J J K Unreeling direction J-J (2.2) 0.3±0.1 1.1±0.15 Without pick-and-place tape Part No. A B D 2.58 4.7 2.98 5.1 4.58 6.7 BM14B(0.8)-24DS-0.4V(51) 5.38 7.5 BM14B(0.8)-30DS-0.4V(51) 6.58 8.7 BM14B(0.8)-34DS-0.4V(51) 7.38 9.5 BM14B(0.8)-12DS-0.4V(51) BM14B(0.8)-20DS-0.4V(51) Reel Dimensions Product label Ø1.5 mm holes for feed mechanism on back edge of carrier tape 16 24 7.5 11.5 8.58 E F 17.5 21.5 10.7 25.5 29.5 BM14B(0.8)-50DS-0.4V(51) 10.58 12.7 BM14B(0.8)-60DS-0.4V(51) 12.58 14.7 Unit : mm Ø80±1 ° 0 12 Part No. Ø380±2 3± 0.2 BM14B(0.8)-40DS-0.4V(51) Ø1 0.8 1± 12 0° 2±0.5 Unit : mm C BM14B(0.8)-10DS-0.4V(51) Ø2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A±0.3 T±0.3 (C) .1 +00 K B±0.1 2±0.1 4±0.1 .5 Ø1 8±0.1 1.75±0.1 Receptacle F±1 B 16 7.5 BM14C(0.8)-14DS-0.4V(51) BM14C(0.8)-16DS-0.4V(51) C D 2.58 4.7 2.98 5.1 BM14C(0.8)-24DS-0.4V(51) 4.58 6.7 BM14C(0.8)-34DS-0.4V(51) 6.58 8.7 8.58 10.7 BM14C(0.8)-44DS-0.4V(51) E±0.5 A BM14C(0.8)-54DS-0.4V(51) BM14C(0.8)-64DS-0.4V(51) 24 11.5 10.58 12.7 E F 17.5 21.5 25.5 29.5 12.58 14.7 5 BM14 Series●0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors Ø1 8±0.1 2±0.1 4±0.1 .5 K-K (D) A±0.3 T±0.3 (C) B±0.1 .1 +00 K 1.75±0.1 Header Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.5±0.3 (6) J J J-J K Unreeling direction 0.3±0.15 0.86±0.15 (1.8) Without pick-and-place tape Part No. BM14B(**)-10DP-0.4V(51) Reel Dimensions BM14B(**)-12DP-0.4V(51) BM14B(**)-20DP-0.4V(51) 0.2 3± Ø1 5.5 16 7.5 D 3.68 – 4.28 5.88 6.68 BM14B(**)-30DP-0.4V(51) 4.77 7.88 BM14B(**)-34DP-0.4V(51) 5.57 8.68 6.77 9.88 24 11.5 BM14B(**)-50DP-0.4V(51) 8.77 11.88 BM14B(**)-60DP-0.4V(51) 10.77 13.88 E F 13.5 17.5 17.5 21.5 25.5 29.5 Unit : mm Part No. BM14C(**)-14DP-0.4V(51) BM14C(**)-16DP-0.4V(51) BM14C(**)-24DP-0.4V(51) E±0.5 BM14C(**)-34DP-0.4V(51) F±1 BM14C(**)-44DP-0.4V(51) BM14C(**)-54DP-0.4V(51) BM14C(**)-64DP-0.4V(51) 6 12 Unit : mm C – 2.77 BM14B(**)-40DP-0.4V(51) Ø80±1 Ø380±2 0° 12 Ø1.5 mm holes for feed mechanism on back edge of carrier tape 12 0° 0.8 1± Ø2 2±0.5 B 3.57 BM14B(**)-24DP-0.4V(51) Product label A A B 12 5.5 16 7.5 24 11.5 C – 3.68 D – 4.28 E F 13.5 17.5 2.77 5.88 17.5 21.5 4.77 7.88 6.77 9.88 8.77 11.88 10.77 13.88 25.5 29.5 BM14 Series●0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors Usage Recommendations 1. Recommended solder profile Temperature(ç) 250 250ç 220ç Maximum of 60 seconds 200 180ç 150 150ç 90 to 120 sec Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 50 Room temperature 0 50 100 150 200 250 300 Heating time (sec) 【Conditions】 1. Peak temperature : 250°C 2. Heating part : 220°C or more, 60 seconds or less 3. Preheating part : 150 to 180°C, 90 to 120 seconds 4. Cycle : Maximum of 2 cycles Note 1 : The temperatures indicated are the surface temperatures of a printed circuit board at the points of contact with the terminals. 2. Recommended manual soldering Manual soldering : 340 ±10°C for 3 seconds 3. Recommended screen thickness and open area ratio (Pattern area ratio) H = 0.8mm for DP and DS Thickness : 0.1mm Open area ratio : DP 0.1mm 95%, DS 0.1mm 95% H = 1.3mm for DP and DS Thickness : 0.1mm Open area ratio : DP 0.1mm 95%, DS 0.1mm 95% 4. Board warpage Maximum of 0.02mm at the connector center, with both ends of the connector as reference points 5. Cleaning conditions Cleaning is not recommended for this connector. Cleaning agents can deteriorate the mechanical operation and the environmental resistance of this connector. 6. Precautions ■Do not mate or unmate these connectors until they are mounted, failure to follow this precaution can lead to deformation or damage to these connectors. ■Provide another form of support to the PCB, this connector was not designed to be the main form of support. ■When mating/un-mating, do not twist or lift by the corners. It may cause damage or deformation. ■Do not apply excessive amounts of flux as it may cause excess solder and flux wicking. ■There may be a slight variance in the color of the molding between production lots, this variance will not affect the performance of the connector. ■Refer to the next page for the handling precautions when mating and unmating the connectors. ■If the connector becomes disconnected due to impact, a fall or a counterforce to the FPC, it may be necessary to hold the connector in place with an addition to the device’s case or other cushioning material to hold the connector in place. 7 BM14 Series●0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors Handling precautions when mating BM14#(※※)-**DP-0.4V Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BM14#(※※)-**DS-0.4V Prior to mating, locate the guide ribs and align the header. Do not apply excessive force during the mating process as it may damage the contacts. Once aligned, the position of the connector will drop down slightly. Make sure that the connector is square to the other side, then press it down until it is fully mated. 8 BM14 Series●0.4mm Pitch, 0.8mm Height, FPC-to-Board Connectors Handling precautions for unmating BM14#(※※)-**DP-0.4V Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BM14#(※※)-**DS-0.4V To unmate this connector, lift evenly across the header. Make sure that each side of the connector stays parallel to the other. If circumstances prevent the connectors from staying parallel to each other, then one side may be lifted as shown in the diagram. This method is only approved if the connector is mounted onto an extremely rigid circuit board. If the board were to warp during this process it may result in damage to the connector or its solder joints. Do not try to disconnect these connectors by pulling on one side or a single corner, or to unmate it when it is hasn’t been securely mounted onto a rigid FPC. These actions may lead to deformities and ultimately a damaged connector. Prior to the mounting of these connectors we recommend that you check the rigidity of your FPC to ensure that it meets the standards needed to support these connectors. If the FPC is not strong enough, there is a risk that the connector could break as illustrated in the diagram to the left. Proper testing and checks must be made with the customers FPC to determine if the FPC stiffener has sufficient rigidity. Evaluative reports of FPC rigidity and other items are available. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 12/2021. Contents are subject to change without notice for the purpose of improvements. 9
BM14C(0.8)-38DP-0.4V(51) 价格&库存
很抱歉,暂时无法提供与“BM14C(0.8)-38DP-0.4V(51)”相匹配的价格&库存,您可以联系我们找货
