DF40BG-70DP-0.4V(51)
    HRS(广濑)
    CONN HDR 70POS 0.4MM SMD GOLD
DF40BG-70DP-0.4V(51) 数据手册
0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors DF40 Series Space saving Space saving -%edh#!%#)bbe^iX]!&#*bb]Z^\]i (#(-bb 9;)% &-#+bb ■Features High contact reliability - effective mating length 0.45mm 1. High density mounting H]dX`VWhdgei^dcg^Wh In addition to its space saving design, several stack heights are available and add versatility to any application. Stack heights : 1.5mm, 2.0mm, 2.5mm, 3.0mm, 3.5mm, and 4.0mm. %#)*bb 2. Multiple stack height options &#*∼)#%bb Space saving design that has a minimum connector width, yet still retains a sufficient vacuum area for easy pick-and-place mounting Minimum width : 3.38mm 3. High contact reliability 4. Excellent self-aligning range The use of guide ribs allows 0.33mm of selfalignment on this connector. 5. Reinforced structure with shock absorbing ribs Both sides of the connector have been reinforced with the addition of shock absorbing ribs. 6. Solder wicking prevention Nickel-plated barriers were added to protect the contact areas from potential solder wicking. 7. Contamination resistant design When mated, the connector’s design covers the contacts which help to keep dust and other debris away from the contacts. The SMT leads are kept very close to the connector housing which also helps to prevent shorts caused by debris on the exposed contacts. 8. RoHS compliant Environment friendly and does not use RoHS specified prohibited materials. All materials and substances used to produce these parts comply with the RoHS standards. 9. High speed signal with noise prevention AdX`hnhiZb &%edh#id*%edh# Stacking height variations Standard type Stacking height 10 12 20 24 30 34 40 44 50 60 70 80 90 100 No. of Contacts Despite its small stature and low profile, the contacts deliver strong contact forces and an effective mating length of 0.45mm on the 1.5mm stacking height. This connector utilizes a locking system that prevents accidental unmating issues and emits a clear tactile click to ensure that mating has been completed. 1.5 mm ○ ○ ○ ○ ○ ○ ○ − ○ ○ ○ ○ ○ ○ 2.0 mm − ○ ○ ○ ○ − ○ ○ ○ ○ ○ ○ − − 2.5 mm ○ − ○ − ○ − ○ − ○ ○ − − − − 3.0 mm − − − − ○ − ○ ○ ○ ○ ○ ○ ○ ○ 3.5 mm − − ○ − ○ − ○ − ○ ○ − ○ − − 4.0 mm − − − − − − − − ○ ○ − ○ ○ − Shielded type Stacking height 30 48 70 No. of Contacts Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. *#%bb :m^hi^c\ egdYjXih 1.5 mm ○ ○ − 3.0 mm − ○ ○ The shielded type can support high speed signal transmissions with noise prevention. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2022.9 1 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Product Specifications Ratings Rated Current 0.3A Rated Voltage AC, DC 30V Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Operating Temperature Range -35 to +85℃ (Note 1) Operating Humidity Range 20 to 80% Storage Temperature Range -10 to +60℃ (Note 2) Storage Humidity Range 40 to 70% (Note 2) Specifications Conditions 1. Insulation Resistance 50Mø min Measured with DC 100V 2. Withstanding Voltage No flashover or breakdown Apply AC 100V for 1 minute 3. Contact Resistance 90mø max Measured with AC 20mV, 1 kHz and 1mA 4. Vibration Resistance No electrical discontinuity of 1µs or greater Frequency 10-55 Hz, half amplitude 0.75mm, 3 directions for 2 hours 5. Humidity Resistance Contact resistance : 90mø max Insulation resistance : 25mø min Left at temperature 40 ± 2ç, humidity 90 to 95%, 96 hours 6. Temperature Cycles Contact resistance : 90mø max Insulation resistance : 50mø min (-55ç : 30 minutes → 5~35ç : 10 minutes → 85ç : 30 minutes → 5~35ç : 10 minutes) 5 cycles 7. Durability Contact resistance : 90mø max 30 mating cycles 8. Soldering Heat Resistance Should be no melting of resin parts that affects its performance Reflow : according to the Recommended Temperature Profile Hand solder : Soldering iron temperature 350ç, no more than 3 seconds. Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use. The operating temperature and humidity range covers the non-energized condition of connectors after board mounting and the temporary storage conditions during transportation, etc. ■Materials (Standard, non shielded type) / Finish Product Receptacle Header Component Insulator Contact Insulator Contact Materials LCP Phosphor bronze LCP Phosphor bronze Finish Black Gold plating Black Gold plating UL Regulation UL94V-0 --------------UL94V-0 --------------- Materials LCP Finish Black Phosphor bronze Gold plating LCP Black Phosphor bronze Gold plating UL Regulation UL94V-0 ----------------------------UL94V-0 ----------------------------- ■Materials (Shielded type) / Finish Product Receptacle Header 2 Component Insulator Contact Shield plate Insulator Contact Reinforcing metal fitting DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Product Number Structure (Standard, non-shielded type) Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacle DF40 # − (**) − * DS − 0.4 V (**) ❶ ❷ ❸ ❹ Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ Series Name: DF40 ❷ Style B : With reinforcing metal fitting HB : With reinforcing metal fitting (The H denotes a stacking height 2.5mm or above) C : Without reinforcing metal fitting HC : Without reinforcing metal fitting (The H denotes a stacking height 2.5mm or above) ❺ ❻ ❼ ❽ ❹ No. of Contacts ❸ Stacking height Display Stacking height None 1.5mm 2.0 2.0mm 2.5 2.5mm 3.0 3.0mm 3.5 3.5mm 4.0 4.0mm ❺ Connector Type DS : Double row receptacle ❻ Contact Pitch : 0.4mm ❼ Mating direction Shape V : Vertical SMT ❽ Packaging Type (51) Embossed tape packaging ●Header DF40 # − * DP − 0.4 V (**) ❶ ❷ ❸ ❹ ❶ Series Name : DF40 ❺ ❻ ❼ ❸ No. of Contacts ❺ Contact Pitch : 0.4mm ❻ Mating direction V : Vertical SMT ❷ Style ❹ Connector Type C : Without reinforcing metal fitting DP : Double row pin header ❼ Packaging Type (51) Embossed tape packaging ■Shielded type ●Receptacle DF40 GB − (**) − * DS − 0.4 V (**) ❶ ❷ ❸ ❹ ❺ ❻ ❸ Stacking height ❶ Series Name : DF40 ❷ Style GB : With shield Display 1.5 3.0 ❼ ❽ ❺ Connector Type DS : Double row receptacle Stacking height 1.5mm 3.0mm ❻ Contact Pitch : 0.4mm ❼ Mating direction V : Vertical SMT ❹ No. of Contacts ❽ Packaging Type (51) Embossed tape packaging ●Header DF40 GB − * DP − 0.4 V (**) ❶ ❷ ❶ Series Name : DF40 ❸ ❹ ❺ ❻ ❸ No. of Contacts ❷ Style ❹ Connector Type GB : With reinforcing metal fitting DP : Double row pin header (For use with shielded product ) ❼ ❺ Contact Pitch : 0.4mm ❻ Mating direction V : Vertical SMT ❼ Packaging Type (51) Embossed tape packaging 3 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Receptacle (Stacking height 1.5mm) A±0.2 B±0.08 3.38±0.2 2.88±0.2 P=0.4±0.05 0.12±0.02 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D±0.15 Vacuum pick up area : C±0.2 BRecommended PCB layout B±0.02 B±0.02 0 2.38 -0.05 1.5MAX 3.78 +0.05 0 0 2.38 -0.05 1.5MAX 3.78 +0.05 0 1.2±0.02 P=0.4±0.02 P=0.4±0.02 0.2±0.02 0.2±0.02 DF40C(Without reinforcing metal fitting) DF40B(With reinforcing metal fitting) ■Stacking height 1.5mm 【Specification No.】 (51) : Embossed package 5,000 pcs/reel Unit : mm Part No. HRS No. No. of Contacts A B DF40B-10DS-0.4V(51) 684-4038-8 51 10 4.6 1.6 DF40B-12DS-0.4V(51) DF40B-30DS-0.4V(51) DF40B-50DS-0.4V(51) DF40B-60DS-0.4V(51) DF40B-80DS-0.4V(51) DF40C-20DS-0.4V(51) DF40C-24DS-0.4V(51) DF40C-30DS-0.4V(51) DF40C-34DS-0.4V(51) DF40C-40DS-0.4V(51) DF40C-50DS-0.4V(51) DF40C-60DS-0.4V(51) DF40C-70DS-0.4V(51) DF40C-80DS-0.4V(51) DF40C-90DS-0.4V(51) DF40C-100DS-0.4V(51) 684-4152-3 51 684-4090-8 51 684-4018-0 51 684-4049-4 51 684-4052-9 51 684-4005-9 51 684-4006-1 51 684-4007-4 51 684-4023-0 51 684-4008-7 51 684-4009-0 51 684-4004-6 51 684-4016-5 51 684-4002-0 51 684-4124-8 51 684-4033-4 51 12 30 50 60 80 20 24 30 34 40 50 60 70 80 90 100 5.0 8.6 12.6 14.6 18.6 6.6 7.4 8.6 9.4 10.6 12.6 14.6 16.6 18.6 20.6 22.6 2.0 5.6 9.6 11.6 15.6 3.6 4.4 5.6 6.4 7.6 9.6 11.6 13.6 15.6 17.6 19.6 C D 1.0 1.5 3.2 1.0 1.2 1.5 2.3 1.45 3.2 Note 1 : Please place orders by full reel. Note 2 : The surface of the 60 to 100 pos. parts have a small, concave section that will not affect the vacuum pick up operation. Note 3 : Resist coating area. Note 4 : This connector is NOT polarized. 4 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Receptacle (Stacking height 2.0mm) A±0.2 B±0.08 3.38±0.2 2.94±0.2 P=0.4±0.05 0.12±0.02 BRecommended PCB layout B±0.02 B±0.02 1.2±0.02 P=0.4±0.02 0 2.38 -0.05 1.5MAX 0 2.38 -0.05 1.5MAX 3.78 +0.05 0 P=0.4±0.02 3.78 +0.05 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D±0.15 Vacuum pick up area : C±0.2 0.2±0.02 0.2±0.02 DF40C(Without reinforcing metal fitting) DF40B(With reinforcing metal fitting) ■Stacking height 2.0mm 【Specification No.】 (51) : Embossed package 4,000 pcs/reel Unit : mm Part No. HRS No. No. of Contacts A B C DF40B(2.0)-12DS-0.4V(51) 684-4150-8 51 12 5.0 2.0 1.0 DF40B(2.0)-80DS-0.4V(51) 684-4128-9 51 80 18.6 15.6 3.2 DF40C(2.0)-20DS-0.4V(51) 684-4040-0 51 20 6.6 3.6 1.0 DF40C(2.0)-24DS-0.4V(51) 684-4021-2 51 24 7.4 4.4 1.2 DF40C(2.0)-30DS-0.4V(51) 684-4058-5 51 30 8.6 5.6 1.5 DF40C(2.0)-40DS-0.4V(51) 684-4042-5 51 40 10.6 7.6 DF40C(2.0)-50DS-0.4V(51) 684-4091-0 51 50 12.6 9.6 DF40C(2.0)-60DS-0.4V(51) 684-4034-7 51 60 14.6 11.6 DF40C(2.0)-70DS-0.4V(51) 684-4147-3 51 70 16.6 13.6 DF40C(2.0)-80DS-0.4V(51) 684-4132-6 51 80 18.6 15.6 D 1.95 3.2 Note 1 : Please place orders by full reel. Note 2 : The surface of the 60 to 100 pos. parts have a small, concave section that will not affect the vacuum pick up operation. Note 3 : Resist coating area. Note 4 : This connector is NOT polarized. 5 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Receptacle (Stacking height 2.5mm to 4.0mm) A±0.2 B±0.08 3.38±0.2 2.94±0.2 P=0.4±0.05 0.12±0.02 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D±0.15 Vacuum pick up area : C±0.2 BRecommended PCB layout B±0.02 B±0.02 0 2.38 -0.05 1.5MAX 3.78 +0.05 0 0 2.38 -0.05 0.92MAX 3.78 +0.05 0 1.2±0.02 P=0.4±0.02 P=0.4±0.02 0.2±0.02 0.2±0.02 DF40HC(Without reinforcing metal fitting) DF40HB(With reinforcing metal fitting) ■Stacking height 2.5mm 【Specification No.】 (51) : Embossed package 3,000 pcs/reel Unit : mm Part No. HRS No. No. of Contacts A B DF40HB(2.5)-10DS-0.4V(51) 684-4189-3 51 10 4.6 1.6 DF40HC(2.5)-20DS-0.4V(51) 684-4126-3 51 20 6.6 3.6 DF40HC(2.5)-40DS-0.4V(51) 684-4112-9 51 40 10.6 7.6 DF40HC(2.5)-50DS-0.4V(51) 684-4101-2 51 50 12.6 9.6 DF40HC(2.5)-60DS-0.4V(51) 684-4085-8 51 60 14.6 11.6 ■Stacking height 3.0mm C D 1.0 2.4 3.2 【Specification No.】 (51) : Embossed package 3,000 pcs/reel Unit : mm Part No. HRS No. No. of Contacts A B C DF40HC(3.0)-30DS-0.4V(51) 684-4098-0 51 30 8.6 5.6 1.5 DF40HC(3.0)-40DS-0.4V(51) 684-4169-6 51 40 10.6 7.6 DF40HC(3.0)-44DS-0.4V(51) 684-4076-7 51 44 11.4 8.4 DF40HC(3.0)-50DS-0.4V(51) 684-4099-2 51 50 12.6 9.6 DF40HC(3.0)-60DS-0.4V(51) 684-4100-0 51 60 14.6 11.6 DF40HC(3.0)-70DS-0.4V(51) 684-4138-2 51 70 16.6 13.6 DF40HC(3.0)-80DS-0.4V(51) 684-4180-9 51 80 18.6 15.6 DF40HC(3.0)-90DS-0.4V(51) 684-4161-4 51 90 20.6 17.6 DF40HC(3.0)-100DS-0.4V(51) 684-4151-0 51 100 22.6 19.6 3.2 D 2.9 Note 1 : Please place orders by full reel. Note 2 : The surface of the 60 to 100 pos. parts have a small, concave section that will not affect the vacuum pick up operation. Note 3 : Resist coating area. Note 4 : This connector is NOT polarized. 6 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Stacking height 3.5mm 【Specification No.】 (51) : Embossed package 2,000 pcs/reel Unit : mm Part No. HRS No. No. of Contacts A B C DF40HC(3.5)-20DS-0.4V(51) 684-4188-0 51 20 6.6 3.6 1.0 DF40HC(3.5)-30DS-0.4V(51) 684-4136-7 51 30 8.6 5.6 1.5 DF40HC(3.5)-40DS-0.4V(51) 684-4209-9 51 40 10.6 7.6 DF40HC(3.5)-50DS-0.4V(51) 684-4109-4 51 50 12.6 9.6 DF40HC(3.5)-60DS-0.4V(51) 684-4102-5 51 60 14.6 11.6 DF40HC(3.5)-80DS-0.4V(51) 684-4162-7 51 80 18.6 15.6 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Stacking height 4.0mm D 3.4 3.2 【Specification No.】 (51) : Embossed package 2,000 pcs/reel Unit : mm Part No. HRS No. No. of Contacts A B DF40HB(4.0)-50DS-0.4V(51) 684-4104-0 51 50 12.6 DF40HC(4.0)-50DS-0.4V(51) 684-4215-1 51 50 12.6 DF40HC(4.0)-60DS-0.4V(51) 684-4133-9 51 60 14.6 11.6 DF40HC(4.0)-80DS-0.4V(51) 684-4140-4 51 80 18.6 15.6 DF40HC(4.0)-90DS-0.4V(51) 684-4165-5 51 90 20.6 17.6 C D 3.2 3.9 9.6 Note 1 : Please place orders by full reel. Note 2 : The surface of the 60 to 100 pos. parts have a small, concave section that will not affect the vacuum pick up operation. Note 3 : Resist coating area. Note 4 : This connector is NOT polarized. 7 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Receptacle (Stacking height 1.5mm, with shield) < 30 contact > 3.38±0.3 8.64±0.3 6.48±0.1 5.6±0.08 P=0.4±0.05 0.2±0.02 0.12±0.02 Vacuum pick up area: 1.5±0.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.45±0.15 3.12±0.2 < 48 contact > 3.38±0.3 P=0.4±0.05 12.24±0.3 10.08±0.1 9.2±0.08 3.2±0.08 0.2±0.02 0.12±0.02 0.12±0.02 Vacuum pick up area: 3.2±0.2 1.45±0.15 3.12±0.2 BRecommended PCB layout 0.2±0.02 0.6±0.02 0.28±0.02 2.64−00.05 2.38−00.05 1.5MAX 0 4.08 3.78+00.05 +0.05 4.08+00.05 2.64−00.05 P=0.4±0.02 10.08±0.02 9.2±0.02 3.2±0.02 0.6±0.02 0.6±0.02 0.2±0.02 ■Stacking height 1.5mm 4.08+00.05 < 48 contact > 6.48±0.02 5.6±0.02 P=0.4±0.02 1.5MAX 2.38−00.05 3.78+00.05 < 30 contact > 0.28±0.02 【Specification No.】 (51) : Embossed package 5,000 pcs/reel Unit : mm Part No. HRS No. No. of Contacts Signal contact Ground contact DF40GB(1.5)-30DS-0.4V(51) 684-4198-4 51 30 30 4 DF40GB(1.5)-48DS-0.4V(51) 684-4194-3 51 48 40 12 Note 1 : Please place orders by full reel. Note 2 : Resist coating area. Note 3 : This connector is NOT polarized. 8 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Receptacle (Stacking height 3.0mm, with shield) < 48 contact > 3.38±0.3 P=0.4±0.05 12.24±0.3 10.08±0.1 9.2±0.08 3.2±0.08 0.2±0.02 0.12±0.02 0.12±0.02 Vacuum pick up area: 3.2±0.2 2.9±0.15 < 70 contact > 16.64±0.3 13.6±0.08 9.2±0.08 3.6±0.08 3.38±0.2 3.68±0.2 3.38±0.3 P=0.4±0.05 0.2±0.02 0.12±0.02 0.12±0.05 Vacuum pick up area: 3.2±0.2 2.9±0.15 3.12±0.2 BRecommended PCB layout < 70 contact > 14.48±0.02 13.6±0.02 9.2±0.02 3.6±0.02 10.08±0.02 9.2±0.02 0.6±0.02 0.28±0.02 1.5MAX 1.5MAX 0.2±0.02 2.64−00.05 P=0.4±0.02 0.6±0.02 4.08+00.05 3.78+00.05 2.38−00.05 3.2±0.02 0.6±0.02 2.64−00.05 4.08+00.05 P=0.4±0.02 0.2±0.02 ■Stacking height 3.0mm 0.6±0.02 0.6±0.02 0.6±0.02 4.08+00.05 < 48 contact > 4.08+00.05 3.78+00.05 2.38−00.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.12±0.2 0.28±0.02 【Specification No.】 (51) : Embossed package 3,000 pcs/reel Unit : mm Part No. HRS No. No. of Contacts Signal contact Ground contact DF40GB(3.0)-48DS-0.4V(51) 684-4197-1 51 48 40 12 DF40GB(3.0)-70DS-0.4V(51) 684-4196-9 51 70 54 20 Note 1 : Please place orders by full reel. Note 2 : The surface of the 70 pos. part have a small, concave section that will not affect the vacuum pick up operation. Note 3 : Resist coating area. Note 4 : This connector is NOT polarized. 9 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Header A±0.2 B±0.08 1.85±0.2 2.97±0.2 P=0.4±0.05 1.14±0.15 0.15±0.02 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Vacuum pick up area : C±0.2 BRecommended PCB layout 7¤%#%' %#%* % (#(, %#+*¤%#%' %#(¤%#%' % '#%* "%#%* E2%#)¤%#%' %#'(¤%#%' %#(*¤%#%' Unit : mm Part No. HRS No. No. of Contacts A B DF40C-10DP-0.4V(51) 684-4035-0 51 10 3.52 1.6 C DF40C-12DP-0.4V(51) 684-4149-9 51 12 3.92 2.0 DF40C-20DP-0.4V(51) 684-4010-9 51 20 5.52 3.6 DF40C-24DP-0.4V(51) 684-4011-1 51 24 6.32 4.4 1.2 DF40C-30DP-0.4V(51) 684-4012-4 51 30 7.52 5.6 1.5 DF40C-34DP-0.4V(51) 684-4024-3 51 34 8.32 6.4 2.3 DF40C-40DP-0.4V(51) 684-4013-7 51 40 9.52 7.6 DF40C-44DP-0.4V(51) 684-4077-0 51 44 10.32 8.4 DF40C-50DP-0.4V(51) 684-4014-0 51 50 11.52 9.6 DF40C-60DP-0.4V(51) 684-4003-3 51 60 13.52 11.6 DF40C-70DP-0.4V(51) 684-4015-2 51 70 15.52 13.6 DF40C-80DP-0.4V(51) 684-4001-8 51 80 17.52 15.6 DF40C-90DP-0.4V(51) 684-4125-0 51 90 19.52 17.6 DF40C-100DP-0.4V(51) 684-4032-1 51 100 21.52 19.6 1.0 3.2 Note 1 : Please place orders by full reel. Note 2 : There are no concave parts on the header side contact part to increase the mating strength for 60 pos. or above. Note 3 : Use the contacts at the four corners as metal fittings. Do not use them as signal or power contacts. Note 4 : The surface of the 90 pos and higher parts have a small, concave section that will not affect the vacuum pick up operation. Note 5 : This connector is NOT polarized. 10 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ■Header (For use with shielded product) A±0.3 B±0.1 C±0.08 2.97±0.2 2.02±0.2 1.85±0.2 P=0.4±0.05 1.52±0.2 BRecommended PCB layout D+00.05 E−00.05 B±0.02 F−00.05 C±0.02 1.88−00.05 1.02−00.05 2.05−00.05 0.23±0.02 3.32+00.05 0.35±0.02 2.42+00.05 P=0.4±0.02 3.37+00.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.08±0.02 1.14±0.15 Vacuum pick up area: G±0.2 0.15±0.02 Unit : mm Part No. HRS No. No. of Contacts A B C DF40GB-30DP-0.4V(51) 684-4200-4 51 30 DF40GB-48DP-0.4V(51) 684-4195-6 51 48 DF40GB-70DP-0.4V(51) 684-4199-7 51 70 15.16 D E F G 7.16 6.67 5.6 10.76 10.27 9.2 8.74 7.32 6.12 1.5 12.34 10.92 9.72 3.2 14.67 13.6 16.74 15.32 14.12 3.2 Note 1 : Please place orders by full reel. Note 2 : There are no concave parts of header side contact part to increase the mating strength for 60 pos. or above. Note 3 : Resist coating area. Note 4 : This connector is NOT polarized. 11 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors BEmbossed Carrier Tape Dimensions (JIS C 0806 compliant) Ø1 3 ±0 Ø80±1 Ø380±2 A B±0.1 A±0.3 0° Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø1.5 holes for feed mechanism 12 0° .2 2±0.5 0 .8 1± F-F C±0.1 F 2±0.1 Product label Ø2 1 0. + 0 .5 4±0.1 ●Reel Condition Dimensions 12 Ø1 1.75±0.1 ●Receptacle (Stacking height 1.5mm) A G G E±0.5 D±1 0.2±0.05 .1 +00 5 0.7 H R 0.3±0.1 F G-G 1.65±0.15 H 8±0.1 Unreeling Direction .1 +0 0 .75 R0 ■Stacking height 1.5mm Part No. A Unit : mm B DF40#-10DS-0.4V(51) − DF40#-12DS-0.4V(51) − DF40#-20DS-0.4V(51) 16 − DF40#-30DS-0.4V(51) − DF40#-34DS-0.4V(51) − 24 − DF40#-50DS-0.4V(51) − DF40#-60DS-0.4V(51) − DF40#-70DS-0.4V(51) DF40#-80DS-0.4V(51) DF40#-90DS-0.4V(51) DF40#-100DS-0.4V(51) DF40GB(1.5)-30DS-0.4V(51) DF40GB(1.5)-48DS-0.4V(51) D E 7.5 21.5 17.5 11.5 29.5 25.5 − DF40#-24DS-0.4V(51) DF40#-40DS-0.4V(51) C 32 28.4 14.2 37.5 33.5 44 40.4 20.2 49.5 45.5 11.5 29.5 25.5 24 − − Note 1 : For 10 to 60 contact position parts, the carrier tape only has one row of holes. The carrier for parts with 70 contacts and above has two rows of holes. 12 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors BEmbossed Carrier Tape Dimensions (JIS C 0806 compliant) 1.75±0.1 ●Receptacle (Stacking height 2.0mm to 2.5mm) Ø2 Ø1 3 G G E±0.5 D±1 .1 +0 0 Unreeling Direction 5 0.7 J 0.3±0.1 H J F±0.15 0.2±0.05 8±0.1 R G-G .1 +00 .75 R0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.1 A±0.3 Ø80±1 0° 0° 12 12 C±0.1 0 .8 1± Ø1.5 holes for feed mechanism Ø380±2 .1 +0 0 2±0.5 .2 .5 H Product label H-H ±0 Ø1 4±0.1 2±0.1 ●Reel Dimensions ■Stacking height 2.0mm Part No. DF40#(2.0)-12DS-0.4V(51) DF40#(2.0)-20DS-0.4V(51) DF40#(2.0)-24DS-0.4V(51) DF40#(2.0)-30DS-0.4V(51) DF40#(2.0)-40DS-0.4V(51) DF40#(2.0)-50DS-0.4V(51) DF40#(2.0)-60DS-0.4V(51) DF40#(2.0)-70DS-0.4V(51) DF40#(2.0)-80DS-0.4V(51) A 16 24 32 ■Stacking height 2.5mm Part No. DF40H#(2.5)-10DS-0.4V(51) DF40H#(2.5)-20DS-0.4V(51) DF40H#(2.5)-40DS-0.4V(51) DF40H#(2.5)-50DS-0.4V(51) DF40H#(2.5)-60DS-0.4V(51) B − − − − − − − 28.4 C D E 7.5 21.5 17.5 11.5 29.5 25.5 14.2 37.5 33.5 Unit : mm F 2.2 Unit : mm A B C D E F − 16 7.5 21.5 17.5 − 2.72 − 24 11.5 29.5 25.5 − − Note 1 : For 10 to 60 contact position parts, the carrier tape only has one row of holes. The carrier for parts with 70 contacts and above has two rows of holes. 13 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors BEmbossed Carrier Tape Dimensions (JIS C 0806 compliant) 1.75±0.1 ●Receptacle (Stacking height 3.0mm to 4.0mm) Product label 2±0.5 Ø80±1 B±0.1 A±0.3 Ø380±2 0° 12 Ø1.5 holes for feed mechanism 12 0° Ø1 3 0 .8 1± C±0.1 .2 H-H Ø2 .1 +0 0 .5 H ±0 Ø1 4±0.1 2±0.1 ●Reel Condition Dimensions Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. G G E±0.5 D±1 .1 +00 J 5 0.7 R 0.4±0.1 H J F±0.15 0.2±0.05 8±0.1 G-G Unreeling Direction .1 +00 .75 R0 ■Stacking height 3.0mm Part No. DF40H#(3.0)-30DS-0.4V(51) DF40H#(3.0)-40DS-0.4V(51) DF40H#(3.0)-44DS-0.4V(51) DF40H#(3.0)-50DS-0.4V(51) DF40H#(3.0)-60DS-0.4V(51) DF40H#(3.0)-70DS-0.4V(51) DF40H#(3.0)-80DS-0.4V(51) DF40H#(3.0)-90DS-0.4V(51) DF40H#(3.0)-100DS-0.4V(51) DF40GB(3.0)-48DS-0.4V(51) DF40GB(3.0)-70DS-0.4V(51) A B C D E 24 − − − − − 11.5 29.5 25.5 32 28.4 14.2 37.5 33.5 44 40.4 20.2 49.5 45.5 24 32 − 28.4 11.5 14.2 29.5 37.5 25.5 33.5 C 7.5 D 21.5 E 17.5 11.5 29.5 25.5 C D E 11.5 29.5 25.5 14.2 20.2 37.5 49.5 33.5 45.5 ■Stacking height 3.5mm Part No. A B DF40H#(3.5)-20DS-0.4V(51) DF40H#(3.5)-30DS-0.4V(51) DF40H#(3.0)-40DS-0.4V(51) DF40H#(3.5)-50DS-0.4V(51) DF40H#(3.5)-60DS-0.4V(51) 16 − − − − − 24 ■Stacking height 4.0mm Part No. DF40H#(4.0)-50DS-0.4V(51) DF40H#(4.0)-60DS-0.4V(51) DF40H#(4.0)-80DS-0.4V(51) DF40H#(4.0)-90DS-0.4V(51) A 24 32 44 B − − 28.4 40.4 Unit : mm F 3.15 Unit : mm F 3.72 Unit : mm F 4.15 Note 1 : For 10 to 60 contact position parts, the carrier tape only has one row of holes. The carrier for parts with 70 contacts and above has two rows of holes. 14 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors ●Reel Dimensions Product label 0° A B±0.1 A±0.3 0° 12 12 C±0.1 0 .8 1± E±0.5 G D±1 H .1 +00 5 .7 Ø0 0.3±0.1 F G-G 1.34±0.15 0.2±0.05 H Unreeling Direction .1 +0 0 .75 Ø0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A G Ø1.5 holes for feed mechanism Ø80±1 Ø2 2±0.5 Ø380±2 F-F .2 .1 +0 0 F ±0 .5 4±0.1 2±0.1 Ø1 3 Ø1 1.75±0.1 ●Header Unit : mm Part No. DF40C-10DP-0.4V(51) DF40C-12DP-0.4V(51) A 12 − − 16 − DF40C-30DP-0.4V(51) − DF40C-34DP-0.4V(51) − 24 − DF40C-50DP-0.4V(51) − DF40C-60DP-0.4V(51) − DF40C-70DP-0.4V(51) DF40C-80DP-0.4V(51) DF40C-90DP-0.4V(51) DF40C-100DP-0.4V(51) DF40GB-30DP-0.4V(51) DF40GB-48DP-0.4V(51) DF40GB-70DP-0.4V(51) D E 5.5 17.5 13.5 7.5 21.5 17.5 11.5 29.5 25.5 − DF40C-40DP-0.4V(51) DF40C-44DP-0.4V(51) C − DF40C-20DP-0.4V(51) DF40C-24DP-0.4V(51) B 32 28.4 14.2 37.5 33.5 44 40.4 20.2 49.5 45.5 16 − 7.5 21.5 17.5 11.5 29.5 25.5 24 − − Note 1 : For 10 to 60 contact position parts, the carrier tape only has one row of holes. The carrier for parts with 70 contacts and above has two rows of holes. 15 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors BOperating Precautions 1. Recommended Solder Profile Temperature (ç) 250 250ç 220ç 60 seconds or below 200 180ç 150 150ç 90 to 120 seconds 100 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 50 Normal temperature 0 50 100 150 200 250 300 Heating time (sec.) 【Conditions】 1. Peak temperature 2. Heating part 3. Preheating part 4. Number of times Maximum of 250ç Minimum of 220ç within 60 seconds 150 to 180ç 90 to 120 seconds Maximum of 2 cycles Note 1 : The temperature shows PCB surface temperature near the connector lead part. 2. Recommended hand solder conditions Soldering iron temperature 340 ±10ç, solder time no more than 3 seconds 3. Recommended screen thickness: Opening ratio (pattern area ratio) Thickness : 0.12mm Opening ratio : DS side 80% DP side 80% 4. Leaning of PCB 16 Max 0.02mm at the center of connector (using both edges of connector as criteria) 5. Washing Cleaning/washing is not recommended for this connector. Cleaning agents can deteriorate the mechanical operation and the environmental resistance of this connector. 6. Precautions ■ Do not mate or unmate these connectors until they are mounted, failure to follow this precaution can lead to deformation or damage to these connectors. ■ Provide another form of support to the PCB, this connector was not designed to be the main form of support. ■ Mating and unmating with excessive force can cause damage. ■ Do not apply excessive amounts of flux as it may cause excess solder and flux wicking. ■ There may be a slight variance in the color of the molding between production lots, this variance will not affect the performance of the connector. ■ Refer to the next page for the handling precautions when mating and unmating the connectors. ■ If the connector becomes disconnected due to impact, a fall or a counterforce to the FPC, it may be necessary to hold the connector in place with an addition to the device’s case or other cushioning material to hold the connector in place. DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors BPrecautions when connector mating DF40*-*DS-0.4V Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF40*-*DS-0.4V Prior to mating, locate the guidance ribs and align the header. Do not apply excess force to the connector during mating. Doing so can lead to contact damage. Make sure that the connector is parallel to the other side, it then will drop down slightly. Continue to press it down until it is fully mated while maintaining the angle. Do not apply excessive force as it may damage the contacts. 17 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors BPrecautions when unmating a connector 9;)%"9H"%#)K Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9;)%"9E"%#)K To unmate this connector, lift evenly across the header, making sure that each side stays parallel to each other. If circumstances prevent the connectors from staying parallel to each other, then one side may be lifted as shown in the diagram. This method is only approved if the connector is mounted onto an extremely rigid circuit board. If the board were to warp during this process it may result in damage to the connector or its solder joints. Pitch direction Corner direction Do not try to disconnect these connectors by pulling on one side or a corner, or unmate it while it is securely mounted onto a rigid FPC. These actions may lead to deformities and ultimately a damaged connector. As shown in the figure to the left, do not unmate it from the width direction (front to back), it may damage contacts. Width direction 18 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors BPrecautions when unmating a connector The contact may peel away if there is not enough rigidity in FPC. Receptacle FPC When mounting the receptacle side to FPC which does not have enough rigidity, the contact may peel away soldered connection. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Header We recommended to mount the header side to the FPC. Header FPC We have conducted evaluations on the requirements needed for FPC rigidity. If you need to mount the receptacle to the FPC, contact your local Hirose Rep for this data. Receptacle Even when mounting the header side to FPC, if the rigidity of FPC is low, the connector may break as shown in the left figure. Please check the strength and durability of FPC before using. For the evaluation results of each item and FPC rigidity, please contact us. 19 DF40 Series●0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board and Board-to-FPC Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 20 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 09/2022. Contents are subject to change without notice for the purpose of improvements.
物料型号:HIROSE ELECTRIC CO., LTD. 的DF40系列,0.4mm间距,1.5至4.0mm高度,板对板和板对FPC连接器。
器件简介: - 高密度安装,节省空间设计,最小连接器宽度为3.38mm。 - 提供多种堆叠高度选项,增加应用的多样性。
引脚分配: - 提供了不同堆叠高度和引脚数量的详细配置,例如1.5mm、2.0mm、2.5mm、3.0mm、3.5mm和4.0mm堆叠高度,以及10至100不等的引脚数量。
参数特性: - 额定电流0.3A,额定电压AC/DC 30V。 - 工作温度范围-35至+85°C。 - 绝缘电阻最小50MΩ,接触电阻最大90mΩ。 - 抗振性和湿度抵抗力,以及温度循环和耐久性测试。
功能详解: - 具有自对准范围,使用导轨允许0.33mm的自对准。 - 带有防焊桥的加固结构,两侧都有防震肋。 - 防污染设计,当连接时,连接器的设计覆盖了接触点,有助于保持接触点远离灰尘和其他碎屑。
应用信息: - 适用于需要高可靠性的应用,如汽车行业。
封装信息: - 提供了详细的材料和表面处理信息,例如绝缘体材料为LCP,黑色,接触材料为磷青铜,表面镀金。
操作注意事项: - 提供了焊接和手工焊接的推荐条件,以及清洗和操作时的注意事项。
其他: - 文档最后提供了HIROSE ELECTRIC CO., LTD.的联系信息和公司地址。
DF40BG-70DP-0.4V(51) 价格&库存
很抱歉,暂时无法提供与“DF40BG-70DP-0.4V(51)”相匹配的价格&库存,您可以联系我们找货
