FX11B-60P/6-SV(91)
FX11B-60P/6-SV(91)
    HRS(广濑)
    CONN HDR 60POS 2.5MM
FX11B-60P/6-SV(91) 数据手册
0.5mm Pitch Connectors with Ground Plate for 2mm to 3mm High-Speed Board-to-Board Connections FX11 Series Stacking height : 2.5mm, 3mm ■Features 10 Signal : 1 Ground Arrangement 1. Low Profile Design The board-to-board mating height of 2mm, 2.5mm and 3mm suits smaller, thinner case designs. (Fig.2) 2. Improved Transmission Efficiency Between Boards Transmission characteristics have been improved through a design that fixes ground plates to both sides of the header and receptacle. Ground Plate Signal contact m 5m 0.7 Housing 3. 10 Signal:1 Ground Arrangement mm 0.5 Metal fitting Signal and ground are arranged in a ratio of 10 : 1 with the ground plate connected to the board Via SMT. The ground stability achieved serves to reduce noise. (Fig.1) m 5m 0.7 Fig.1 Ground plate and metal fitting make contact 4. Metal Fittings for Added Strength Stacking Height Variation Metal fittings provide for greater adhesion to the board, which protects the connector against sheaning forces. The unique connector design provides a connection between the fitting and the ground plate for a stronger ground. '#* !( bb 'bb 5. Suited to High-Density Applications The signal contact pitch of 0.5mm affords a compact connector, and reduces mounting space on the board. Note: 2.0mm type product cannot be used or interchanged with the 2.5mm or 3.0mm type product. Fig.2 6. Structure Prevents Solder Wicking Structure Prevent Solder Wicking A solder gap has been designed into the contact SMT portion to prevent solder wicking. (Fig.3) 7. High Contact Reliability HdaYZg\Veedgi^dc Effective wipe length is 0.55mm (2mm height) and 1mm(2.5mm, 3mm height) for signal contacts. 7dVgYbdjci^c\edgi^dc AVcY 8dciVXi hjg[VXZ 8. Optional Ground Plate Fig.3 An alternate style is also available without the ground plate. The space provided by the absence of the ground plate is filled with additional signal contacts. ■Signal Integrity Features 120 ICR 3mm(Without GND) 60 115 50 110 30 ●Differential Impedance The differential impedance is 100 + /- 10ø for FX11 at 50 ps rise time(20% to 80%). Impedance 3mm(Without GND) 105 40 Z(ø) ●Insertion-Loss-to-Crosstalk Ratio (ICR) The insertion-loss-to-crosstalk ratio (ICR) with five differential FEXT aggressors meets the extrapolated IEEE802.3ap specification to 10+ Gbps. ICR(dB) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Stacking height : 2mm 100 95 20 90 10 0 85 ICR IEEEspec 0 1 2 3 4 5 6 7 8 9 10 80 0.8 Frequency(GHz) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. FX11- 3mm DifferentialTDR 0.9 1 1.1 1.2 Time(ns) 2017.11e 1.3 1.4 1.5 1 FX11 Series●0.5mm Pitch Connectors with Ground Plate for 2mm to 3mm High-Speed Board-to-Board Connections BStacking height variation ● With ground plate Header Receptacle FX11L#-*P / *-SV FX11L#-*S / *-SV 2mm Header Receptacle FX11#-*P / *-SV FX11#-*P / *-SV0.5 2.5mm 3mm FX11#-*S / *-SV ● Without ground plate Header Receptacle FX11L#-*P-SV FX11L#-*S-SV 2mm Header Receptacle FX11#-*P-SV FX11#-*P-SV0.5 2.5mm 3mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX11#-*S-SV Note 1: The thickness of the solder paste is not included in the stacking height. Note 2: 2mm type and 2.5mm, 3mm type, with ground plate type and without ground type are not mated with each other. BCross section of mating H^\cVaedgi^dc %#** :[[ZXi^kZbVi^c\aZc\i] %#** :[[ZXi^kZl^eZaZc\i] ● Stacking height : 2mm
FX11B-60P/6-SV(91)
物料型号:HIROSE ELECTRIC CO., LTD.生产的FX11系列,0.5mm间距的带接地板的2mm至3mm堆叠高度的高速板对板连接器。
器件简介: - 提供了低剖面设计,适合更小、更薄的机箱设计。 - 通过在插座和连接器的两侧固定接地板来提高板之间的传输效率。 - 信号和地的排列比例为10:1,接地板通过SMT连接到板上,提高了接地稳定性,有助于降低噪声。
引脚分配: - 信号接触点间距为0.5mm,提供紧凑的连接器,减少了板上的安装空间。 - 有带接地板和不带接地板的型号,信号/地分别为60/6、80/8、100/10、120/12。
参数特性: - 额定电流:0.3A - 工作温度范围:-55至+85°C - 存储温度范围:-10至+60°C - 绝缘电阻:100MΩ或更高 - 耐电压:150V AC下1分钟无闪络或击穿
功能详解: - 信号完整性特性包括插入损耗与串扰比(ICR),满足IEEE802.3ap规范至10+ Gbps。 - 差分阻抗为100±10Ω,在FX11的50ps上升时间内(20%至80%)。
应用信息: - 适用于高密度应用,如汽车领域等需要高可靠性的应用。
封装信息: - 提供了详细的安装尺寸和推荐的土地模式尺寸(金属掩膜尺寸)。 - 推荐金属掩膜厚度:0.15mm。
FX11B-60P/6-SV(91) 价格&库存
很抱歉,暂时无法提供与“FX11B-60P/6-SV(91)”相匹配的价格&库存,您可以联系我们找货
