EX60B-29P-FL
EX60B-29P-FL
    HRS(广濑)
    CONN RECEPT 29POS 0.6MM R/A SMD
EX60B-29P-FL 数据手册
Low-Angle Mating / Unmating Interface Connectors EX60B Series Rotating mating/unmating guide Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Plug (Cradle mount) ■Features 1. Angle Mating / Unmating The cradle mount plug incorporates a unique rotating mating/unmating guide allowing the portable device to be placed or removed at an angle, up to 20° max. In addition, the angle mating force is approximately 3N(29 pos.), with extremely low unmating forces. Receptacle (Portable device mount) Angle mating/unmating Lift (rotate) Mating at 20° angle 20° 2. High durability Bellow configuration of the contacts guarantees 10,000 angle mating/unmating cycles, without any degradation of electrical and mechanical performance. 3. High-Speed Data Transfer A full eye pattern is maintained at a speed of 2.5 G bps, making it applicable for high-speed differential signals of the USB 2.0 and PCIEXPRESS. High speed data transfer 2.5 Gbps Eye Pattern Output Waveform 4. Secure attachment Standard or extended flange versions of the receptacle can be mounted directly to the portable device’s case. The cradle mount plug is attached using screws. 5. Low profile - Space-Saving Small size (4 mm high ∞ 6.8 mm deep) of the Receptacle allows efficient use of space in a portable device. Extended flange mounting ■Applications PDA and POS terminals, electronic books, tablet PCs, mobile TVs, media players, digital cameras and other devices requiring high durability angle mating/unmating connectors. Device case Extended flanges In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2014.3e 1 EX60B Series●Low-Angle Mating / Unmating Interface Connectors ■Specifications Current raring 0.5A Rating Operating temperature range Voltage rating 125V AC Characteristic Specification Conditions 1.Insulation resistance 1000Mø min. 250V DC 2.Dielectric withstanding voltage No flashover or insulation breakdown. 250V AC/ one minute 3.Contact resistance 60mø max. 100mA DC 4.Vibration No electrical discontinuity of 1μ sec. max. Frequency: 10 to 55 Hz, single amplitude of 0.75mm, Contact resistance: 100mø max. 5.Shock for 2 hours in 6 axis. No electrical discontinuity of 1μ sec. max. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 6. Mating/un-mating Contact resistance: 100mø max. 3 cycles in each of the 6 axis. Mating: With corresponding connector. 10N max. (Horizontal), forces Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. _55ç to +85ç 5N max. (At 20° angle) Un-mating: 10N max. (Horizontal), 2N max. (At 20° angle) 7.Durability 5000 cycles (Straight mating) Contact resistance: 100mø max. 10000 cycles (At 20° angle) (mating/un-mating) 8.Temperature cycle 9.Humidity Contact resistance: 100mø max. : -55ç ➝ +15ç to +35ç ➝ +85ç ➝ + 15ç to +35ç Temperature ➝ +2 to 3 ➝ 30 ➝ +2 to 3 Insulation resistance: 1000M ø min. Time (Minutes) : -30 Contact resistance: 100mø max. 96 hours at temperature of 60ç and humidity of 90% to 95%. 5 cycles Insulation resistance: 5Mø min.(Dry state) 10.Salt spray 5% salt water solution for 48 hours No corrosions Note: Includes temperature rise caused by the current flow. ■Materials/ Finish ●Receptacles (Portable device mount) Component Material Finish Remarks Insulator LCP Color: Black UL94V-0 Contacts Copper alloy Contact area: Gold plated ------- Stainless steel Tin plated ------- Metal shield ●Plugs (Cradle mount) Component Insulator Contacts Material Finish Remarks Polyamide Color: Black UL94V-0 Copper alloy Contact area: Gold plated ------- Metal shield Stainless steel Tin-plated ------- Guide Stainless steel ------- ------- Spring Stainless steel ------- ------- ■Ordering information ●Receptacles (Portable device mount) EX 60 B - 29 P - FL 1 2 1 3 4 5 1 Series name : EXB 2 Termination type : 60 : Right angle SMT 3 Number of contacts : 15, 29 ●Plugs (Cradle mount) 4 Contact type EX 60 B - 29 S 1 2 2 1 3 4 P : Male contact (Receptacle = device mount) S : Female contact (Plug = cradle mount) 5 Option FL : Extended flanges EX60B Series●Low-Angle Mating / Unmating Interface Connectors ■Receptacles A ●15 pos., 29 pos. (Standard) 0.2(Contact width) 6.8 P=0.6 B C D E 4 Part number CL No. HRS No. A EX60B-29P 29 CL232-0611-5 16.8 EX60B-15P 15 CL232-0621-9 8.4 0.9 0.3 F 1 4.1 0.8 EX60B G B C D E 13.65 12.35 14.25 12.95 9.45 8.15 10.05 F G 13.5 12.2 9.3 8.0 8.75 RoHS YES 16.8 ●29 pos. (Extended flanges) P=0.6 0.2(Contact width) 1.6 6.8 Extended flanges 13.65 12.35 14.25 14.65 12.95 13.35 CL No. RoHS 232-0612-8 YES 4 0.3 13.5 1 4.1 0.9 Part number 0.8 EX60B EX60B-29P-FL 4.05 Contact No. 29 Contact No. 1 12.2 BRecommended PCB mounting pattern ●EX60B-15P 16.8 4 PCB edge Ø1.6 11.4 12.2 13.4 14.6 10.9 4.7 2.1 Through hole PCB edge Pad 0.4 2 4.7 Pad Through hole Pad 2 2 Pad 8.4 P=0.6 0.4 0.4 2.1 P=0.6 2.4 Ø1.6 3.7 9.2 2 ●EX60B-29P and EX60B-29P-FL 0.4 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.05 Contact No. ** Contact No. 1 7.9 12.1 13.3 3 EX60B Series●Low-Angle Mating / Unmating Interface Connectors ■Portable device case cutout A B Part number (1) 4.25 EX60B-29P EX60B-29P-FL EX60B EX60B-15P A B 14.5 13.2 10.3 9 Board mounting surface 12 Unreeling direction 4 Ø1 .5 2 1.75 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Packaging specifications D (2) (Ø380) C B A Unreeling direction (Ø 13 ) Part number EX60B-29P EX60B-29P-FL EX60B-15P Note: 1,200 pieces per reel. 4 A B C D 20.2 40.4 44.0 44.4 14.2 28.4 32.0 32.4 EX60B Series●Low-Angle Mating / Unmating Interface Connectors ■Plug (Cradle mount) ●15 pos., 29 pos. A B D C 1.3 (3.1) 8.5 Ø2 .4 0.2(Contact width) H Rotating mating unmating guide I Contact No.** K L Part number Number of contacts HRS No. A B C EX60B-29S 29 CL232-0613-0 (16.0) (15.6) 13.6 EX60B-15S 15 CL232-0622-1 (11.8) (11.4) 9.4 3.85 J 4.35 0.8 0.9 1.7 Contact No.1 0.3 0.8 2.2 M D E F G 13.2 11.15 10.75 16.8 9.0 6.95 6.55 8.4 4.1 H 13.3 I J K L M 12.0 11.85 11.45 15.85 15.45 9.1 7.8 7.65 7.25 11.65 11.25 2.35 RoHS YES ■Recommended PCB mounting pattern A B C D E F 3.9 0.8(Through hole) 2 0.4 2.2 2.95 P=0.6 1.8 G 2.2(Land) 1.4(Through hole) R0 .4 R0 .8 1.6(Land) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. G P=0.6 2.2 F E PCB edge Part number A B C D E F G EX60B-29S 15.85 15.45 13.6 13.2 11.85 11.45 16.8 EX60B-15S 11.65 11.25 9.4 9.0 7.65 7.25 8.4 Ø2.6(Hole) 5 EX60B Series●Low-Angle Mating / Unmating Interface Connectors ■Cradle case mounting recommendations - Plug 2MIN A 1 B (1) (4.1) AX °M 25 5.5MIN 2 2 Board mounting surface Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Screw attachment Notes 1 Notes 2 Notes 3 Part number A B EX60B-29S 13.65 12.35 EX60B-15S 9.45 8.15 The maximum opening angle of the rotating mating/unmating guide is 25°. Do not exceed this angle. Device’s case must have the recommended cutout dimensions. Assure that there is no interference with the free movement and operation of the mating/unmating guide. Use screw (not supplied) to attach the receptacle to the case. ■Packaging Specifications (Plug, EX60B-29S) Ø1 .5 Unreeling direction 16 4 2 1.75 2.4 D (2) Center of vacuum pick-up area (Ø380) B C 14.4 A Unreeling direction ) 13 (Ø Note: 800 pieces per reel. 6 Part number A B C D EX60B-29S 26.2 52.4 56.0 56.4 EX60B-15S 20.2 40.4 44.0 44.4 EX60B Series●Low-Angle Mating / Unmating Interface Connectors ■Mating cross-section (14) Flange Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (4.75) EX60B-**P Receptacle (Portable device mount) EX60B-**S Plug (cradle mount) Flange ■Recommended Temperature Profile (Tamperature) (ç) 250ç 230ç min 250 200 150 180ç 150ç 100 90 sec. 30 sec. 50 Preheating Soldering (Time) Note 1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 7 EX60B Series●Low-Angle Mating / Unmating Interface Connectors ■Portable device case and cradle design requirements 1. Mating/unmating angles (see illustrations below) (1) Angle on the Z-axis is 20° max. (2) Angle on the X-axis is 3° max. Mating/ unmating angle 3° (X-axis) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Mating/unmating angle 20° (Z-axis) Cradle 2.Dimensional requirements (1) Distance between the flanges of the receptacle and plug: 0 to 0.7 mm. (2) Distance between the PCB mounting surface of the plug (cradle) and the PCB surface of the receptacle (portable device): 4.8±0.1 mm. (1) 0 to 0.7mm (2) 4.8±0.1mm Receptacle front flange surface Cradle Cradle connector flange surface 3.Portable device removal The point of the rotation of the portable device during it’s removal from the cradle should be at the distance of 6.5 mm min. as illustrated below. Lift and remove Point of rotation Portable device 6.5 min Cradle ® 8 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 3/2014. Contents are subject to change without notice for the purpose of improvements.
EX60B-29P-FL 价格&库存
很抱歉,暂时无法提供与“EX60B-29P-FL”相匹配的价格&库存,您可以联系我们找货
