ASP-137969-02
REVISION
NOTES:
1. STANDARD PART SET UP AS ASP.
2. C REPRESENTS A CRITICAL DIMENSION.
3. MAXIMUM BURR ALLOWANCE: .038 [.0015].
4. MINIMUM PUSHOUT FORCE: 2.22N [.5LB].
5. PARTS TO BE PACKAGED IN TAPE & REEL.
16.30 .642 REF
((11 POS x .800[.0315]) + 7.50 [.300])
13.12 .517 REF
6.00 .236
REF
22
"A"
02
+0.50
+.020
0.20 - 0.20 .008 - .008
3
"A"
2.10 .083
5.60 .220
REF
3.36 .132
REF
01
0.800 .0315 (TYP)
(TOL NON-ACCUM)
21
SECTION "A"-"A"
SCALE 4 : 1
C2
C1
8.00 .315
2.58±0.12 .101±.005
11.93 .470
"B"
4
1.24 .049 REF
0.50 [.200] x 45°
REF (TYP)
1
3.35 .132
REF
ACCEPTANCE OF DRAWING
ACCEPTED WITH DEVIATIONS LISTED
C7
5.30 .209 REF
5.15±0.50 .203±.020
C8
5.46 .215
C4
5.335 .2100
1.17 .046
2
C9
.10[.004]
0.25 .010
REF (TYP)
1.32 .052
REF
"B"
0.94 .037
REF
14.6 .575
11.60 .457 REF
8.000 .315
1.04 .041 REF
C5
+0.18
1.10 .043
REF
C3
+.007
5.41 - 0.13 .213 - .005
0.64 .025
REF
1.32 .052
REF
SECTION "B"-"B"
SCALE 4 : 1
DETAIL "C"
SCALE 8 : 1
"C"
FAX No:
PHONE No:
PRINTED NAME
CUSTOMER SIGNATURE
COMPANY:
DATE:
1.50 .059 REF
0.800 .0315
ITEM NO.
PART NUMBER
QUANTITY
MATERIAL
1
ERF8-011-05.0-DV-L
1.0000
VECTRA E130i, COLOR: BLACK
2
C-211-05.0-S
22.000
BeCu, 390 HT
3
WT-30-01-F
2.0000
BeCu, #25, 1/2 HT
4
K-DOT-.236-.343-005
1.0000
POLYIMIDE FILM
5
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
C6
CT-ERF8034MS
1.0000
CONDUCTIVE POLYMER
DECIMALS
.X: .3[.01]
.XX: .13[.005]
.XXX: .051[.0020]
ANGLES
2
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
B
PLATING:
CONTACT AREA: .000030 GOLD OVER .000050 NICKEL
REMAINDER: .000200 REF TIN OVER .000050 NICKEL
LATCHES: .000003 GOLD OVER .000050 NICKEL
F:\DWG\SW\ASP\137000\ASP-137969-02.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
SHEET SCALE: 1:0.333333
DESCRIPTION:
DWG. NO.
BY: TIM P.
MODIFIED ERF8 ASSEMBLY
ASP-137969-02
01/12/2011 SHEET 1 OF 3
ASP-137969-02
17.80 .701
(KEEPOUT AREA)
REVISION B
14.60 .575
0.83±0.05 .033±.00
22 PTH (2 PLCS)
( 1.58 [.062] PAD)
TO BE SOLDERED USING
PASTE-IN-HOLE TECHNOLOGY
11.60 .457
8.00 .315
1.80 .071 (TYP)
0.800 .0315 (TYP)
(TOL NON-ACCUM)
02
"F"
1.50 .059
01
1.45±0.08 .057±.003
NPTH (2 PLCS)
11.61 .457
REF
2.10 .083 REF
6.30 .248
(KEEPOUT AREA)
CL
5.60 .220
CL
21
0.500 .0197
(TYP)
1.10 .043
(TYP)
RECOMMENDED PCB LAYOUT
14.60 .575
"F"
8.00 .315
0.80 .031 (TYP)
(TOL. NON-ACCUM)
'G'
SECTION "F"-"F"
LATCH ENGAGING VIEW
02
2.24 .088
(2 PLCS)
22
5.60 .220
01
1.10 .043
(TYP)
"E"
21
0.50 .020
(TYP)
RECOMMENDED STENCIL LAYOUT
'H'
11.53 .454
REF
2.03 .080
REF
"E"
PIN ENGAGING VIEW
DETAIL 'G'
SCALE 6 : 1
SECTION "E"-"E"
DETAIL 'H'
SCALE 6 : 1
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY:
TIM P.
ASP-137969-02
01/12/2011
SHEET 2 OF 3
ASP-137969-02
REVISION B
32.00 1.260
REF
16.00 .630
REF (TYP)
5
USER DIRECTION OF UNREELING
POCKET NOT DETAILED
PACKAGING VIEW
PROPRIETARY NOTE
SHEET SCALE: 1:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY:
TIM P.
ASP-137969-02
01/12/2011
SHEET 3 OF 3
很抱歉,暂时无法提供与“ASP-137969-02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+63.34200
- 10+61.88400
- 30+60.91200
