LSHM-140-02.5-L-DV-A-S-TR 数据手册
FINE PITCH
SELF MATING CONNECTORS
(0.50 mm) .0197" PITCH
FEATURES & BENEFITS
• Ten stack height options from 5.00 mm to 12.00 mm
• 0.50 mm, 0.635 mm or 0.80 mm pitches
• Audible click when mated
• Mating and unmating forces approximately
4-6x greater than typical micro pitch connectors
• Self-mating system reduces inventory cost
• Parallel, perpendicular and coplanar systems
• Shield option
• Lubricated option
ACTUAL SIZE SHOWN
SLIM BODY DESIGNS
(40 total positions each)
5.00
4.60
14.70
17.45
20.40
5.00
LSHM
LSS
LSEM
LSHM
8 mm STACK HEIGHT
LSHM
12 mm STACK HEIGHT
LSHM
5 mm STACK HEIGHT
KEY SPECIFICATIONS
INSULATOR
MATERIAL
CONTACT
MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT
RATING
SMT
COPLANARITY
LEAD-FREE
SOLDERABLE
Black LCP
Phosophor
Bronze
Au or Sn over 50 µ"
(1.27 µm) Ni
-55 °C to +125 °C
LSHM: 2.0 A per pin
LSS: 1.7 A per pin
LSEM: 1.8 A per pin
(0.10 mm) .004" max
Yes
F-221
samtec.com/RazorBeam
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
14
G b p s
(0.50 mm) .0197" PITCH • RUGGED HERMAPHRODITIC CONNECTORS
LSHM
-1
NO. PINS
PER ROW
05, 10, 20,
30, 40, 50
LEAD
STYLE
(Vertical)
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
–F
–01
= Standard
-A-
–DV
= Gold flash
on contact,
Matte Tin on tail
= With
Shield
–DH
–N
= Right-angle
(Lead style –01
& –L1 only)
=10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
SHIELD
OPTION
–S
= Vertical
–L
(Right-angle)
TAIL
OPTION
= Without
Shield
K
–K
= (3.50 mm)
.138" DIA
Polyimide
film Pick &
Place Pad
–RH
= Reverse
Right-angle
(Lead style –01
& –L1 only
(Right-angle)
–L1
= Lubricated
"X"R
–TR
= Tape &
Reel
–FR
= Full Reel
Tape & Reel
(must order
maximum
quantity
per reel;
contact
Samtec for
quantity
breaks)
LSHM
Board Mates:
LSHM
Cable Mates:
HLCD
LEAD STYLE
No. of positions x
(0.50) .0197
+ (4.70) .185
–02.5 & –02.5
–02.5 & –03.0
–03.0 & –03.0
–02.5 & –04.0
B
LEAD STYLE
LEAD STYLE
(LUBRICATED)
A
B
–02.5
–L2.5
(3.95) .156
(1.00) .039
–03.0
–L3.0
(4.45) .175
(1.50) .059
–04.0
–L4.0
(5.45) .215
(2.50) .098
–06.0
–L6.0
(7.45) .293
(4.50) .177
(STANDARD)
–03.0 & –04.0
(4.98)
.196
–04.0 & –04.0
A
No. of positions
x (0.50) .0197
+ (4.95) .195
No. of positions
x (0.50) .0197
+ (2.00) .078
—DV—S
—DV—N
MATED
HEIGHT *
(5.00) .196
(5.50) .217
(6.00) .236
(6.50) .256
(7.00) .276
(8.00) .315
–02.5 & –06.0
(8.50) .335
–04.0 & –06.0
(10.00) .394
–03.0 & –06.0
–06.0 & –06.0
(9.00) .354
(12.00) .472
*Processing conditions will affect
mated height.
(2.75)
.108
(8.25)
.325
(5.13)
.202
No. of positions
x (0.50) .0197
+ (4.95) .195
(5.13)
.202
No. of positions
x (0.50) .0197
+ (2.65) .104
—DH—S
—RH—S
No. of positions
x (0.50) .0197
+ (7.70) .303
No. of positions
x (0.50) .0197
+ (4.70) .185
(7.80)
.307
(5.13)
.202
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
No. of positions
x (0.50) .0197
+ (1.90) .074
(4.88)
.192
No. of positions
x (0.50) .0197
+ (6.60) .259
—DH—N
(8.85)
.348
—RH—N
View complete specifications at: samtec.com?LSHM
F-221
LSHM-140-02.5-L-DV-A-S-TR 价格&库存
很抱歉,暂时无法提供与“LSHM-140-02.5-L-DV-A-S-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 575+43.30601575+5.43066
- 1150+38.796461150+4.86515
- 国内价格 香港价格
- 1+64.794911+8.12541
- 10+62.0512910+7.78135
- 25+60.0090725+7.52526
- 50+55.2424050+6.92751
- 100+49.29428100+6.18160
