ERM5-050-05.0-S-DV-K-TR
    SAMTEC(申泰)
    .5MMEDGERATETERMINALASSEMBLY
ERM5-050-05.0-S-DV-K-TR 数据手册
RUGGED HIGH-SPEED STRIPS FEATURES & BENEFITS Edge Rate® rugged high-speed connector strips are designed for high speed, high cycle applications, and enabled by Samtec's signal integrity-optimized Edge Rate® contact system. • Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch • 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch • 0.635 mm pitch system with extremely slim 2.5 mm body width • Rugged latching, locking and 360º shielding • Up to 1.5 mm contact wipe; robust when "zippered" during unmating Signal integrity-optimized Edge Rate® contact system reduces broadside coupling • Compatible with UMPT/UMPS for power/signal flexibility EDGE RATE® STACK HEIGHT FLEXIBILITY (actual size in mm) 5 ERX6 7 11 10 9 12 13 16 15 14 17 18 Sockets shown actual size with 40 total positions ERX5 ERX6 ERM5/ERF5 ERX8 ERM8/ERF8 KEY SPECIFICATIONS SERIES PITCH STACK HEIGHTS TOTAL PINS / PAIRS ERM5 / ERF5 0.50 mm 7-12 mm 20-150 ERM6 / ERF6 0.635 mm 5 mm 20-120 ERM8 / ERF8 0.80 mm 7-18 mm 10-200 F-221 INSULATOR MATERIAL TERMINAL MATERIAL Phosphor Bronze or BeCu (ERM5), BeCu (ERF5) Black LCP Copper Alloy Phosphor Bronze or BeCu (ERM8), BeCu (ERF8) PLATING OPERATING TEMP RANGE Au or Sn over 50 µ" -55 °C to +125 °C (1.27 µm) Ni LEAD-FREE SOLDERABLE Yes samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.50 mm) .0197" PITCH • RUGGED HIGH-SPEED STRIPS SERIES - ERM5 Header ERF5 Socket POSITIONS PER ROW –010, –020, –030, –040, –050, –060, –070, –075 - - LEAD STYLE –02.0 PLATING OPTION - DV - –L = 2 mm Body Height (ERM5 only) = 4 mm Body Height (ERM5 only) –05.0 –TR = Tape & Reel –K –FR = (3.50 mm) .138" DIA Polyimide Film Pick & Place Pad (ERM5 –04.0 –05.0 and Lead Style only) = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) = (6.00 mm) .236" DIA Polyimide Film Pick & Place Pad (ERF5 only) = 5 mm Body Height –07.0 –P = 7 mm Body Height (ERF5 only & Available up to 50 Pos. only) = Plastic Pick & Place Pad (ERM5 –02.0 Lead Style only; ERM5 –010 Postions and ERF5 Not Available) ERM5 "X"R (required in callout) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on Tail –04.0 - PICK & PLACE PAD No. of Positions x (0.50) .0197 + (6.80) .268 Board Mates: ERF5 (4.95) .195 (2.50) .098 A LEAD STYLE (ERM5) A (ERF5) B –02.0 (4.84) .191 N/A –04.0 (6.84) .269 N/A –05.0 (7.84) .309 (4.91) .193 -07.0 N/A (6.91) .272 MATED HEIGHT* No. of Positions x (0.50) .0197 + (6.80) .268 ERF5 (4.95) .195 Board Mates: ERM5 ERM5 LEAD STYLE (4.73) .186 No. of Positions x (0.50) .0197 + (6.80) .268 01 (4.73) .186 (4.95) .195 B 02 View complete specifications at: samtec.com?ERM5 or samtec.com?ERF5 ERF5 - Right-Angle Socket POSITIONS PER ROW –010, –020, –030, –040, –050 ERF5-RA Board Mates: ERM5 - 01 - PLATING OPTION - D - RA - –L ERF5 LEAD STYLE -05.0 B -07.0 -02.0 (7.00) .276 (9.00) .354 -04.0 (9.00) .354 (11.00) .433 -05.0 (10.00) .394 (12.00) .472 *Processing conditions will affect mated height. "X"R –TR = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Tape & Reel –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) No. of Positions x (0.50) .0197 + (10.30) .406 (6.83) .269 (4.75) .187 Note: Some lengths, styles and options are non-standard, non-returnable. View complete specifications at: samtec.com?ERF5-RA samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
ERM5-050-05.0-S-DV-K-TR 价格&库存
很抱歉,暂时无法提供与“ERM5-050-05.0-S-DV-K-TR”相匹配的价格&库存,您可以联系我们找货
