ERF8-030-07.0-L-DV-EGPS-K-TR
    SAMTEC(申泰)
    .8MMEDGERATESOCKETASSEMBLY
ERF8-030-07.0-L-DV-EGPS-K-TR 数据手册
RUGGED HIGH-SPEED STRIPS FEATURES & BENEFITS Edge Rate® rugged high-speed connector strips are designed for high speed, high cycle applications, and enabled by Samtec's signal integrity-optimized Edge Rate® contact system. • Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch • 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch • 0.635 mm pitch system with extremely slim 2.5 mm body width • Rugged latching, locking and 360º shielding • Up to 1.5 mm contact wipe; robust when "zippered" during unmating Signal integrity-optimized Edge Rate® contact system reduces broadside coupling • Compatible with UMPT/UMPS for power/signal flexibility EDGE RATE® STACK HEIGHT FLEXIBILITY (actual size in mm) 5 ERX6 7 11 10 9 12 13 16 15 14 17 18 Sockets shown actual size with 40 total positions ERX5 ERX6 ERM5/ERF5 ERX8 ERM8/ERF8 KEY SPECIFICATIONS SERIES PITCH STACK HEIGHTS TOTAL PINS / PAIRS ERM5 / ERF5 0.50 mm 7-12 mm 20-150 ERM6 / ERF6 0.635 mm 5 mm 20-120 ERM8 / ERF8 0.80 mm 7-18 mm 10-200 F-221 INSULATOR MATERIAL TERMINAL MATERIAL Phosphor Bronze or BeCu (ERM5), BeCu (ERF5) Black LCP Copper Alloy Phosphor Bronze or BeCu (ERM8), BeCu (ERF8) PLATING OPERATING TEMP RANGE Au or Sn over 50 µ" -55 °C to +125 °C (1.27 µm) Ni LEAD-FREE SOLDERABLE Yes samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.80 mm) .0315" PITCH • SHIELDED HIGH-SPEED HEADERS & SOCKETS TYPE ERM8 = Shielded Terminal ERF8 = Shielded Socket - POSITIONS PER ROW –010, –020, –025, –030 - - LEAD STYLE –02.0 = 2 mm (ERM8 with –S only) –05.0 = 5 mm (ERF8 with –S & ERM8 with – EGPS & –DSS only) –07.0 = 7 mm (ERF8 with –EGPS only) –09.0 - - PLATING OPTION DV –L - OPTIONS –S = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –TR = Shield (Lead Styles: ERM8 –02.0 only; ERF8 –05.0 only) = Tape & Reel –EGPS –FR = Extended Guide Post Shield (Lead Styles: ERM8 –05.0 & -09.0 only; ERF8 –07.0 only) –S = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) –DSS = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail = Differential Pair with Extended Guide Post Shield (ERM8 only, with –05.0 & -09.0 Lead Styles, –10 & –025 Pos. only) –K = Polyimide Film Pick & Place Pad (–02.0 Lead Style N/A) = 9 mm (ERM8 with –EGPS & –DSS only) "X"R –P = Pick & Place Pad (ERM8 –02.0 & -05.0 Lead Styles only) ERM8-S Board Mates: See "Mated Height" Chart 01 No. of Positions x (0.80) .0315 + (6.00) .236 LEAD STYLE (7.20) .283 (Note: ERF8-S does not mate with ERM8-EGPS) A B –05.0 (9.87) .389 (10.81) .425 -09.0 (13.87) .546 (14.81) .583 02 (7.18) .283 A B (5.97) .235 –S OPTION –EGPS OR –DSS OPTION View complete specifications at: samtec.com?ERM8 MATED HEIGHTS 7 MM ERF8-S ERM8-02.0-S to ERF8-05.0-S Board Mates: See "Mated Height" Chart (Note: ERM8-EGPS does not mate with ERF8-S) 9 MM 12 MM 16 MM ERM8-05.0-EGPS ERM8-09.0-EGPS ERM8-02.0-S to to to ERF8-07.0-EGPS ERF8-07.0-EGPS ERF8-07.0-EGPS A 01 (6.80) .268 02 LEAD STYLE –05.0 –07.0 B (7.20) .283 B (-S) (-EGPS) (5.90) .232 N/A N/A (7.42) .292 B –S POSITIONS PER ROW A –010 (18.00) .71 –020 (26.00) 1.02 –025 (30.00) 1.18 –030 (34.00) 1.34 View complete specifications at: samtec.com?ERF8 Note: Some lengths, styles and options are non-standard, non-returnable. samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
ERF8-030-07.0-L-DV-EGPS-K-TR 价格&库存
很抱歉,暂时无法提供与“ERF8-030-07.0-L-DV-EGPS-K-TR”相匹配的价格&库存,您可以联系我们找货
