REVISION AM
QSH-XXX-XX-X-D-DP-XXX
No OF POSITIONS
C
DO NOT
SCALE FROM
THIS PRINT
OPTION
-A: ALIGNMENT PINS
(USE QSH-30-01-D-XX-A,
SEE FIG 2)
-GP: GUIDE POSTS
(USE QSH-30-01-D-XX-GP,
SEE FIG 4)
-LC: LOCKING CLIPS(SEE NOTE 12)
(USE LC-08-TM-01, SEE FIG 1)
-K: POLYIMIDE FILM PAD
(USE K-DOT-.325-.450-.005, SEE FIG. 3)
-TR: TAPE & REEL (60 POS MAX)
-TY: TRAY PACKAGING
(NOT AVAILABLE WITH -TR)
-FL: FRICTION LOCKS
(SEE FIG 5, SHEET 3)
(NOT AVAILABLE WITH -GP)
-RT1: RETENTION (MUST USE -A OPTION)
(USE QSH-30-01-D-XX-A-RT1
& SUB-SC-05-01-FF) (SEE FIG 6, SHEET 3)
(NOT AVAILABLE WITH -LC, -GP, OR -FL)
(NOT AVAILABLE WITH -080 & -100 POS)
-L: LATCHING
(SEE FIG 7, SHEET 4)
(USE QSH-30-01-D-XX-A-L)
(NOT AVAILABLE WITH -LC, -GP, -FL, OR -RT1)
-020, -040, -060,
**-080, **-100
(PER ROW)
{(No OF POS / 20) x .7875[20.003]} + .050[1.27] REF 61.28
LEAD STYLE
-01: .1280 [3.251]
PLATING SPECIFICATION
(SEE NOTE 11)
-F: 3µ" FLASH SELECTIVE IN CONTACT AREA,
MATTE TIN ON TAIL
(USE T-1G2-01-F) (SEE NOTE 9)
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT
AREA, MATTE TIN ON TAIL
(USE T-1G2-01-L) (SEE NOTE 9)
-H: 30µ" HEAVY GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
(USE T-1G2-01-G)
-C: 50µ" ELECTRO-POLISHED SELECTIVE GOLD
IN CONTACT AREA, MATTE TIN ON TAIL
9 EQ SPACES @ .059 [1.50] REF
.7875 20.00
(TYP)
02
.245 6.22
REF
01
'A'
.659 16.73 REF
.037 0.93 REF
DIFFERENTIAL PAIRS
.006 0.15 REF
.059 1.50 REF
.285 7.24
REF
.0197 0.500 REF
C-126-01-X CAN BE SUBBED
FOR C-126-21-X
ROW SPECIFICATION
-D: DOUBLE (USE QSH-30-01-D-XX)
** = SEE NOTE 10
.150 3.81 REF
No OF BANKS
.0030 0.08 REF
C
.055 1.40
.165+-.005
.001
QSH-30-01-D-XX
"A"
+.0030
"A"
.725 18.42 REF
C
SEE TABLE 1
C-126-21-X
* SEE NOTE 11
.064 1.62 REF
LC-08-TM-01
T-1G2-01-X
+0.076
.1280 - .0010 3.251 - 0.025
(SEE NOTE 2 & 5)
C
.120 3.05 REF
.010 0.25
REF
4.19+-0.13
0.03
.038 0.95 REF
.056 1.42 REF
.2950 7.493 REF
({(No OF POS / 20) x .7875[20.003]} + .005[.13]) .005[.13]
SECTION "A"-"A"
FIG 1
-LC: LOCKING CLIP OPTION SHOWN
NOTES:
1. C
REPRESENTS A CRITICAL DIMENSION.
2. MAXIMUM VARIANCE: .002 [0.05]
3. MAXIMUM BURR ALLOWANCE: .0015 [0.038]
4. MINIMUM PUSHOUT FORCE: 4 OZ
5. DIMENSION APPLIES TO GROUND PLANE AND CONTACT.
6. MINIMUM GROUND PLANE RETENTION: 8 OZ
7. -L PLATING CAN BE SUBSTITUTED FOR -F PLATING.
8. SUB-SC-05-01-XX RETENTION TO BE 1.0 LBF IN BODY.
9. MAY SUB C-126-01-X for C-126-21-X.
10. FOR NEW APPLICATIONS REQUIRING THESE POSITIONS PLEASE
CONTACT SAMTEC INTERCONNECT PROCESSING GROUP.
11. FOR -80, -100 POSITIONS USE C-269-11-X. DO NOT SUB C-126.
12. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION
IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS
MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE –LC OPTION."
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: BLACK, LCP
FLAMMABILITY RATING: UL94VO
TERMINAL: PHOS BRONZE
GROUND PLANE: PHOS BRONZE
F:\DWG\MISC\MKTG\QSH-XXX-XX-X-D-DP-XXX-MKT.SLDDRW
SHEET SCALE: 3:2
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.5mm DIFFERENTIAL PAIRS HS SOCKET ASSEMBLY
DWG. NO.
BY: KEVIN B
06/13/00
SHEET 1 OF 4
REVISION AM
02
QSH-30-01-D-XX-A
.038 0.95 REF
.035 0.89 REF
01
((No OF POS / 20) x .7875[20.003]) + .005[0.13] REF
DETAIL 'A'
SCALE 3 : 1
FIG 2
-A: ALIGNMENT PIN OPTION SHOWN
"R" REF
.133 3.38
C
"S" .020[.51]
C
.020±.020 0.51±0.51
.325 8.26
FIG 3
NOTE: "R" = ((No OF POSITIONS / 20) x .7875[20.003]) + .050[1.27]
"S" = (("R" - .325[8.26]) /2) .020[.51]
PROPRIETARY NOTE
SHEET SCALE: 1.5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KEVIN B
06/13/00
SHEET 2 OF 4
REVISION AM
.005 0.13
REF
C
((No OF POS / 20) X .7875[20.003]) + .4285[10.884] REF
.102 2.58 REF
"B"
"B"
((No OF POS / 20) X .7875[20.003]) + .225[5.72] REF
.080 2.03
REF (TYP)
.005 0.13
REF
QSH-30-01-D-XX-FL
.220 5.58 REF
.140 3.56 THRU REF
.026 0.66
REF (TYP)
'A'
QSH-30-01-D-XX-GP
DETAIL 'A'
SCALE 8 : 1
.124 3.15 REF
SECTION "B"-"B"
FIG 4
FIG 5
-FL: FRICTION LOCKS
(NOT AVAILABLE WITH -GP OPTION)
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
-GP: GUIDE POST OPTION SHOWN
FIG 6
((No OF BANKS) x .7875[20.003]) + .650[16.51] REF
C4
-RT1: RETENTION OPTION
(NOT AVAILABLE WITH -LC, -GP, OR -FL OPTIONS)
C
.003[0.08]
.004[0.10]
((No OF BANKS) x .7875[20.003]) + .341[8.66]
"D"
.045 1.14 REF
"D"
C
.150 3.81
'E'
DETAIL 'E'
SCALE 3 : 1
SUB-SC-05-01-FF (2 PLCS)
.148 3.76 REF
C
PROPRIETARY NOTE
.003[0.08]
.004[0.10]
SECTION "D"-"D"
SCALE 1.5 : 1
SHEET SCALE: 1.25:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KEVIN B
06/13/00
SHEET 3 OF 4
REVISION AM
((No. OF POSITIONS /20) x .7875[20.003]) + .2600[6.604] REF
((No. OF POSITIONS / 20) x .7875[20.003]) + .1093[2.776]
.0300 0.762 REF
C
QSH-30-01-D-XX-A-L
.160 4.06
REF
.053±.002 1.35±0.05
C
.025 0.64 REF
WT-56-01-T
((No. OF POSITIONS /20) x .7875[20.003]) + .1715[4.356]
C
.010 0.25
REF (TYP)
FIG 7
-L: RETENTION OPTION
(NOT AVAILABLE WITH -LC, -GP, -FL, OR -RT1 OPTIONS)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KEVIN B
06/13/00
SHEET 4 OF 4
