ASP-130367-01
ASP-130367-01
    SAMTEC(申泰)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:40Pin 间距:0.8mm 排数:2
ASP-130367-01 数据手册
ASP-130367-01 E REVISION NOTES: 1. STANDARD PART SET UP AS ASP. 2. CX-X-XX REPRESENTS A CRITICAL DIMENSION. 3. MAXIMUM BURR ALLOWANCE: .038 [.0015]. 4. MINIMUM PUSHOUT FORCE: 2.22N [.5LB]. 5. PARTS TO BE PACKAGED IN TRAYS. 23.50 .925 REF ((20 POS x .800 [.0315]) + 7.50 [.300]) 20.32 .800 REF "A" 6.00 .236 REF 02 3 0.20 .008 40 2.22 .087 REF "A" 5.60 .220 REF 3.36 .132 REF 01 39 ACCEPTANCE OF DRAWING ACCEPTED WITH DEVIATIONS LISTED 0.800 .0315 (TYP) (TOL NON-ACCUM) C2-A-MV SECTION "A"-"A" SCALE 4 : 1 15.20 .598 C1-A-MV 19.13 .753 C7-B,I-MV 2.58±0.12 .101±.00 5.30 .209 REF 8.75±0.50 .344±.020 "B" 5 0.50 [.200] x 45° REF (TYP) 1 3.35 .132 REF 2 1.17 .046 5.46 .215 C4-B-DC 5.335 .2100 C8-F-OG .10[.004] "B" 21.80 .858 0.94 .037 REF 1.10 .043 REF C3-A-MV E C5-A-MV SECTION "B"-"B" SCALE 4 : 1 1.32 .052 REF FAX No: PHONE No: 3 MAX SWAY (TYP) 5.41±0.25 .213±.010 0.64 .025 REF 18.80 .740 REF 15.20 .598 PRINTED NAME CUSTOMER SIGNATURE COMPANY: DATE: 0.25 .010 REF (TYP) 1.04 .041 REF 1.32 .052 REF (TYP) 1.50 .059 REF DETAIL "C" SCALE 8 : 1 "C" 0.800 .0315 ITEM NO. PART NUMBER QUANTITY MATERIAL 1 ERF8-20-05.0-DV-SL 1.0000 VECTRA E130i, COLOR: BLACK 2 C-211-05.0-S 40.000 BeCu, 390 HT 3 WT-30-01-F 2.0000 BeCu, #25, 1/2 HT 4 TY-ERF8034-20-5-L 1.0000 BLACK HIPS 5 K-850-650 1.0000 POLYIMIDE FILM C6-A-MV UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS .X: .3[.01] .XX: .13[.005] .XXX: .051[.0020] ANGLES 2 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING PLATING: CONTACT AREA: .000030 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL LATCHES: .000003 GOLD OVER .000050 NICKEL F:\dwg\sw\asp\130000\ASP-130367-01.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 SHEET SCALE: 1:0.333333 DESCRIPTION: DWG. NO. ERF8 ASSEMBLY ASP-130367-01 BY: D FRALEY 03/22/2007 SHEET 1 OF 2 25.00 .984 (KEEPOUT AREA) ASP-130367-01 REVISION E 21.79 .858 18.80 .740 4.90 .193 (TYP) 40 0.83±0.02 .033±.00 PTH (2 PLCS) ( 1.58 [.062] PAD) CL 6.30 .248 (KEEPOUT AREA) 15.20 .598 0.800 .0315 (TYP) (TOL NON-ACCUM) 02 5.61 .221 "F" 1.50 .059 CL 01 1.45±0.08 .057±.00 NPTH (2 PLCS) 21.79 .858 'G' 0.80 .031 (TYP) (TOL. NON-ACCUM) 1.58 .062 (2 PLCS) "F" LATCH ENGAGING VIEW 1.10 .043 (TYP) 0.500 .0197 (TYP) RECOMMENDED PCB LAYOUT 11.87 .467 REF 2.36 .093 REF 39 15.20 .598 02 40 SECTION "F"-"F" 5.60 .220 1.10 .043 (TYP) "E" 01 39 0.50 .020 (TYP) RECOMMENDED STENCIL LAYOUT 'H' 11.53 .454 REF 2.03 .080 REF DETAIL 'G' SCALE 6 : 1 "E" PIN ENGAGING VIEW DETAIL 'H' SCALE 6 : 1 SECTION "E"-"E" PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 code: 55322 DESCRIPTION: DWG. NO. F:\dwg\sw\asp\130000\ASP-130367-01.SLDDRW FAX: 812-948-5047 e-Mail: info@SAMTEC.com ERF8 ASSEMBLY ASP-130367-01 BY: D FRALEY 03/22/2007 SHEET 2 OF 2
ASP-130367-01 价格&库存
很抱歉,暂时无法提供与“ASP-130367-01”相匹配的价格&库存,您可以联系我们找货
ASP-130367-01
    • 1+72.75960
    • 10+70.61040
    库存:3
