ERF8-040-05.0-L-DV-L-K-TR 数据手册
REVISION AT
C
"B" REF
(SEE SHT 2, TABLE 4)
59
POSITION #1
INDICATOR
01
0.800 .0315 (TYP) C
(TOL. NON-ACCUM)
"C" (SEE SHT 2, TABLE 4)
C
3.35 .132
REF
ERF8-XXX-XX.X-DV-01
(SEE SHT 2, TABLE 3)
OPTION
-L: LATCHES (-05.0, *-07.0 & *-0.90 LEAD STYLE
ONLY, SEE NOTE 5, SEE FIG 5 & 11)
* -S: SHIELD
(-05.0 LEAD STYLE ONLY, SEE FIG 9)
-EGP: EXTENDED GUIDE POST
(SEE NOTE 6, SEE FIG 3)
-EGPS: EXTENDED GUIDE POST SHIELD
(ONLY AVAILABLE IN -07.0
LEAD STYLE AND ONLY -010, -020,
-025 & -030 POSITIONS (SEE NOTE 6, 10
& FIG 6)
-K: POLYIMIDE FILM PAD (SEE FIG 2)
LEAD STYLE
-05.0 = 5mm
5.60 .220
-07.0 = 7mm
*-09.0 = 9 mm
REF
**-10.0 = 10mm
PLATING SPECIFICATION
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
02
MATTE TIN ON TAIL
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
3.36 .132
REF
60
PACKAGING
-TR: TAPE & REEL (SEE NOTE 4 & 7)
-LEAVE BLANK FOR TRAY: (SEE NOTE 7)
No OF POSITIONS
(PER ROW)
-005, -010, -011, -013, -020, -023, -025,
-030, -035, -040, -049, -050, -060,
-070, -075, ***-100
(***-100 POSITION NOT AVAILABLE
WITH OPTIONS -L, -EGP & -EGPS OR
LEAD STYLES -07.0,-09.0 & -10.0)
"A" REF
DO NOT
SCALE FROM
THIS PRINT
ERF8-XXX-XX.X-X-DV-XXXX-XX
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
** = NOT TOOLED
*= NOT RELEASED
ROW SPECIFICATION
-DV: DOUBLE VERTICAL
"A"
2.58±0.12 .101±.005
"E" REF
C
5.40 .213 REF
1.10 .043
REF
DETAIL 'D'
SCALE 4 : 1
1.32 .052 REF
1.32 .052 REF
"A"
0.50 [.020] x 45 REF
C
"C"
1.32 .052
REF
"N"
(REF)
3 MAX SWAY
(TYP)
0.23 .009
CL
REF
'D'
C
C-211-XX.X-X
(SEE SHT 2,
TABLE 3)
"F" (TYP)
(SEE SHT 2, TABLE 5)
1.04 .041 REF
(2 PLCS)
SEE TABLE 1
CL
CL
0.90 .036 REF
5.41±0.25 .213±.010
1.50 .059
REF
0.800 .0315 (TYP)
C
(TOL NON-ACCUM)
C
C
SECTION "A"-"A"
SCALE 5 : 1
"D" REF (SEE SHT 2, TABLE 4)
FIG 1
(ERF8-030-05.0-X-DV-XX SHOWN)
(CENTER FEATURES REMOVED FOR CLARITY)
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. BURR ALLOWANCE: 0.038[.0015] MAX.
3. MINIMUM PUSHOUT FORCE: 2.22 N [.5 LB.]
4. FOR QUANTITIES UP TO 49 PIECES, NO LEADER, TRAILER, OR EIA-481-D
REEL WILL BE SUPPLIED. FOR QUANTITIES OF 50-124 PIECES, NO LEADER,
TRAILOR WILL BE SUPPLIED.
5. NOT AVAILABLE WITH -EGP OR -EGPS OPTIONS.
6. OPTION ONLY AVAILABLE ON -07.0 LEAD STYLE; NOT AVAILABLE WITH -L OPTION.
7. TRAY PACKAGING AVAILABLE ON ***100 POSITION ONLY. ***100 POSITION NOT AVAILABLE IN -TR.
8. NOTE DELETED.
9. NOT AVAILABLE WITH -EGP OR -EGPS OPTIONS.
10. FOR EGPS-K-TR COMBINATIONS LEAVE THE ZERO OFF THE FRONT OF THE LEADSTYLE CALLOUT.
F:\DWG\MISC\MKTG\ERF8-XXX-XX.X-X-DV-XXXX-XX-MKT.SLDDRW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN
MILLIMETERS [INCHES].
TOLERANCES ARE:
DECIMALS
ANGLES
X.X: 0.3 [.01]
2
X.XX: 0.13 [.005]
X.XXX: 0.050 [.0020]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, COLOR: BLACK
CONTACT & LATCHES: BeCu
SHIELD: PHOS BRONZE
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
0.8MM EDGE RATE SOCKET ASSEMBLY
DWG. NO.
BY: KNOWLDEN
9/26/2005 SHEET 1 OF 7
REVISION AT
+0.5
C
"V" REF
(SEE TABLE 5)
"F"
(SEE SHT 2
TABLE 5)
0.11±0.076 .004±.003
C
"H"
0.50[.020]
CL
3 MAX SWAY C
(TYP)
CL
"G"
6.00 .236 REF
FIG 2
-K OPTION
(USE K-DOT-.236-.343-.005)
(ERF8-030-XX.X-X-DV-K SHOWN)
IN-PROCESS
"C"
C-211-XX.X-X IN-PROCESS VIEW
"C"
"J" REF
(SEE SHT 3, TABLE 6)
1.90 .075
REF
SEE TABLE 3
1.03 .040
REF
7.00 .276
REF
WT-30-XX-T
(SEE TABLE 3)
+.020
0.20 - 0.2 .008 - .008 (TYP)
5.10 .201
REF
C
"L" 0.18[.007]
SECTION "C"-"C"
SCALE 2.5 : 1
7.25 .285
REF
C
C
"U"
2 MAX SWAY (TYP)
FIG 3
-EGP OPTION
(ERF8-030-07.0-X-DV-EGP SHOWN)
(SAME AS FIG 1, EXCEPT AS SHOWN)
(AVAILABLE ON -07.0 LEAD STYLE ONLY)
PROPRIETARY NOTE
SHEET SCALE: 2:1
(** = NOT TOOLED) (* = NOT RELEASED)
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KNOWLDEN
9/26/2005
SHEET 2 OF 7
REVISION AT
0.80 .031
CL
"E"
"B"
"B"
DETAIL "E"
SCALE 6 : 1
CL
C
"K" 0.25
C
1.71 .067 REF
"J" REF
DETAIL 'G'
SCALE 6 : 1
CL
'G'
2.50 .098
CL
CL
"U" (SEE SHT 2,
TABLE 3)
WT-30-XX-T
6.00 .236 REF
C
2 MAX SWAY (TYP)
C
"L"
0.21±0.51 .008±.020
CL
C
0.25 .010 REF
"M"
0.50[.020]
C
FIG 5
(ERF8-025-05.0-X-DV-L-K SHOWN)
(SAME AS FIG 1 & 2, EXCEPT AS SHOWN)
(AVAILABLE ON -05.0 & -07.0 LEAD STYLE ONLY)
0.64 .025
REF
RIGHT SIDE VIEW
SECTION "B"-"B"
SCALE 3 : 1
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KNOWLDEN
9/26/2005
SHEET 3 OF 7
CL
REVISION AT
"F"
"F"
C
6.200 .2441
6.80 .268
7.20 .283 REF
CL
C
"P"
CL
7.00 .276
REF
6.25 .246
"U" REF
0.64 .025
REF
CL
0.64 .025
REF (TYP)
SH29-XX-XX-X
"S" REF
"R" REF
CL
ERF8-XXX-07.0-DV-EGPS
FIG 6
(ERF8-030-07.0-X-EGPS SHOWN)
(SAME AS FIG 3, EXCEPT AS SHOWN)
"L"
C
CL
C
CL
0.25 .010
REF
5.95 .234
REF
2° MAX SWAY
(TYP)
"Q"
SECTION "F"-"F"
SCALE 2.5 : 1
"L"
4.27 .168
5.10 .201
REF
ERF8-XXX-05.0-DV-S
SH29-XX-XX-X
FIG 9
SECTION "L"-"L"
SCALE 2.5 : 1
(ERF8-030-05.0-X-DV-S SHOWN)
(SAME AS FIG 6, EXCEPT AS SHOWN)
(AVAILABLE ON -05.0 LEAD STYLE ONLY)
(NOT RELEASED)
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KNOWLDEN
9/26/2005 SHEET 4 OF 7
REVISION AT
C
2.58±0.12 .101±.005
"J" REF
"J"
5.40 .213 REF
"H"
1.24 .049 REF
ERF8-XXX-05.0-DV-S1
WT-67-02-X
(2 PLCS)
C-314-01.0-X
"E"
"F"
ERF8H-XXX-05.0-DV
C
SEE SHT 1, TABLE 1
"H"
"D" REF
+0.18
1.04 .041
REF
+.007
5.41 - 0.13 .213 - 0.004
C
"J"
SECTION "J"-"J"
SCALE 3 : 1
SECTION "H"-"H"
SCALE 3 : 1
FIG 7
(ERF8-030-10.0-X-DV SHOWN)
(NOT TOOLED)
"J" REF
"N"
"M"
ERF8-XXX-05.0-DV-S1
WT-30-08-T
C-211-09.0-X
"E"
(SEE SHT2, TABLE 5) "F"
(SEE SHT2, TABLE 5)
"U"
ERF8H-XXX-04.0-DV
"N"
"M"
SECTION "N"-"N"
SCALE 3 : 1
"D" REF
"L" REF
C
0.64 .025 REF
SECTION "M"-"M"
SCALE 3 : 1
FIG 10
(ERF8-030-09.0-X-DV SHOWN)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 7)
(NOT RELEASED)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY:KNOWLDEN
9/26/2005
SHEET 5 OF 7
REVISION AT
C
"K"±0.25
"P"
"P"
0.80 .031 REF
WT-30-10-T
1.71 .067 REF
SECTION "P"-"P"
SCALE 3 : 1
FIG 11
(ERF8-030-09.0-X-DV-L SHOWN)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 10)
(NOT RELEASED)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KNOWLDEN
9/26/2005 SHEET 6 OF 7
REVISION AT
-05.0 SHOWN
-07.0 WITH EGPS SHOWN
*-05.0 WITH -S SHOWN
*-07.0 WITH -L SHOWN
-07.0 SHOWN
-07.0 WITH -EGP SHOWN
*-09.0 OPTION
(*=NOT RELEASED)
(**=NOT TOOLED)
*-09.0 WITH -L SHOWN
PROPRIETARY NOTE
SHEET SCALE: 2:1
**-10.0 SHOWN
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KNOWLDEN
9/26/2005 SHEET 7 OF 7
