FX8C-60/60P11-SV2J(71)
    HRS(广濑)
    CONN HDR 120POS .6MM (2PCS)
FX8C-60/60P11-SV2J(71) 数据手册
0.6mm Pitch Stacking Height 3mm to 16mm Connectors FX8/FX8C Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX8 Series FX8C Series Note: that FX8 series and FX8C series are not mated with each other. Features 1. Stacking Height: 3mm to 16mm ●Stacking Height 3,4mm-FX8 Series Stacking height of mated connectors ranges from 3mm to 16mm. (Fig.1.2) 2. SMT Coplanarity The coplanar tolerance at the solder area is less than 0.1mm. 3,4mm 3. Mating Guide Built-in guide ribs and a chamfer allow for ±0.6 mm of mis-alignmet and ensures easy mating. Fig.1 4. Mis-insertion Prevention Bosses located on the bottom side of the connector differ in position and diameter to prevent mis-orientating the parts on the board. ●Stacking Height 5 to 16mm-FX8C Series 5. Dual Connected Products In order to enhance mounting reliability and a c c u ra c y w h e n m o u n t i n g t wo o f t h e s a m e connectors at the same time, Hirose offers the option of having two connectors attached to one another by means of a spacer. Pitch between the two connectors is 11mm. 5 to 16mm Fig.2 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.6④ 1 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors FX8 Series Product Specifications Rating Operating Temperature Range -55ç to +85ç (Note 1) Storage Temperature Range -10ç to +60ç(Note 2) Current rating 0.4A Storage Humidity Range 40% to 70%(Note 2) Voltage rating 100V AC Operating Humidity Range -40% to 80% Items 1. Insulation Resistance 2. Withstanding voltage 3. Contact Resistance Specifications 1000Mø min No flashover or insulation breakdown. 45mø max. Conditions 250V DC 300V AC/1 min 100mA Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 axis directions. 4. Vibration No electrical discontinuity of 1µs or more 5. Humidity (Steady state) Contact resistance : 55mø max. : Insulation resistance : 100Mø min. Contact resistance : 55mø max. : Insulation resistance : 100Mø min. 7. Mating Cycles Contact resistance : 55mø max. 8. Resistance to Soldering No deformation of components affecting heat performance. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6. Temperature Cycle 96 hours at 40ç and humidity of 90% to 95% (-55ç : 30 minutes, 15 to 35ç : 2 to 3 minutes 85ç : 30 minutes, 15 to 35ç : 2 to 3 minutes) 5 cycles 50 cycles Reflow : At the recommended temperature profile Manual soldering : 360ç for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range includes the non conducting condition in storage, shipment or during transportation. Material / Finish Part Insulator Material PPS Finish Remarks Light brown UL94V-0 Contact area Gold plated Header Contact ––––––– Lead area Tin (Note 2) Phosphor bronze Contact area Receptacle Contact Gold plated ––––––– Lead area Note 1 : Slight color difference to the resin may occur. This will not affect fit, form or function of the connector. Note 2 : FX8-*P-SV is gold plated. ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Single Product Mating Sectional View FX8 - 120 P - SV 1 (92) 1 2 3 4 5 6 q Series Name : FX8 w No. of contacts : 60, 80, 90, 120, 140 e Connector type r Contact type P : Header S : Receptacle SV : Board vertical type t Product height variation : none= standard (minimum low profile) 1 : +1mm y Package Form None, (71) : Tray package product (21), (91) : Tube packaging product (22), (92) : Emboss tape package product (The above illustration represents the stacking height 3mm type.) ●Single Product FX8-**S-SV 2 FX8-**P-SV 3mm FX8-**P-SV1 4mm 3 to 4 BStacking Height Variation FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors A±0.3 Header B +0.05 _0.2 C +0.05 _0.2 [FX8-**P-SV] D±0.2 (C1) Polarization mark (Ø0.9) t0.2±0.03∞w0.25±0.03 E±0.1 (2.4) (Ø0.6) 2-(C0.2) (1.5) (2.4) Unit : mm ** Part No. HRS No. No. of contacts A B C D E FX8-60P-SV(**) 578-0001-6 ** 60 24.60 23.00 20.70 17.40 22.20 FX8-80P-SV(**) 578-0003-1 ** 80 30.60 29.00 26.70 23.40 28.20 FX8-90P-SV(**) 578-0004-4 ** 90 33.60 32.00 29.70 26.40 31.20 FX8-100P-SV(**) 578-0005-7 ** 100 36.60 35.00 32.70 29.40 34.20 FX8-120P-SV(**) 578-0006-0 ** 120 42.60 41.00 38.70 35.40 40.20 FX8-140P-SV(**) 578-0007-2 ** 140 48.60 47.00 44.70 41.40 46.20 RoHS Yes ** 71 : Tray packaging, 91 : Tube packaging, 92 : Embossed tape packaging Note 1 : Please place orders in full magazine/tube quantities. Note 2 : Reels are sold containing 1,000 pcs/reel. Please refer to the delivery form on page 6 for details. Note 3 : Please note that tray packaged parts are not suitable for use with automatic mounting processes. A±0.3 B +0.05 _0.2 [FX8-***P-SV1] C +0.05 _0.2 D±0.2 0.6±0.1 (0.75) 0 6.5 _0.3 3.45±0.25 (0.4) 5.1±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.75) 0 2.45±0.25 6.5 _0.3 5.1±0.3 (0.4) 0.6±0.1 (1) Polarization mark (Ø0.9) (Ø0.6) t0.2±0.03∞w0.25±0.03 E±0.1 (2.4) 2-(C0.2) (1.5) (2.4) Unit : mm ** Part No. HRS No. No. of contacts A B C D E FX8-60P-SV1(**) 578-0041-0 ** 60 24.60 23.00 20.70 17.40 22.20 FX8-80P-SV1(**) 578-0043-6 ** 80 30.60 29.00 26.70 23.40 28.20 FX8-90P-SV1(**) 578-0044-9 ** 90 33.60 32.00 29.70 26.40 31.20 FX8-100P-SV1(**) 578-0045-1 ** 100 36.60 35.00 32.70 29.40 34.20 FX8-120P-SV1(**) 578-0046-4 ** 120 42.60 41.00 38.70 35.40 40.20 FX8-140P-SV1(**) 578-0047-7 ** 140 48.60 47.00 44.70 41.40 46.20 RoHS Yes ** 71 : Tray packaging, 91 : Tube packaging, 92 : Embossed tape packaging Note 1 : Please place orders in full magazine/tube quantities. Note 2 : The embossed tape packaged parts are available for all pin counts, except the 140 pin count. Reels are sold containing 1,000 pcs/reel. Please refer to the delivery form on page 15 for details. Note 3 : Please note that tray packaged parts are not suitable for use with automatic mounting processes. 3 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors Receptacle A±0.3 B +0.2 0 C +0.2 0 [FX8-**S-SV] (1) D±0.2 2.25±0.25 (0.75) 0 7_0.3 5.6±0.3 0.6±0.1 Polarization mark (Back side) t0.2±0.03∞w0.25±0.03 (Ø0.6) (Ø0.9) E±0.1 (2.4) 2-(C0.2) (1.8) (2.4) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Part No. ** HRS No. No. of contacts A B C D E FX8-60S-SV(**) 578-0201-5 ** 60 24.60 23.05 20.80 17.40 22.20 FX8-80S-SV(**) 578-0203-0 ** 80 30.60 29.05 26.80 23.40 28.20 FX8-90S-SV(**) 578-0204-3 ** 90 33.60 32.05 29.80 26.40 31.20 FX8-100S-SV(**) 578-0205-6 ** 100 36.60 35.05 32.80 29.40 34.20 FX8-120S-SV(**) 578-0206-9 ** 120 42.60 41.05 38.80 35.40 40.20 FX8-140S-SV(**) 578-0207-1 ** 140 48.60 47.05 44.80 41.40 46.20 RoHS Yes ** None : Tray packaging, 21 : Tube packaging, 22 : Embossed tape packaging Note 1 : Please place orders in full magazine/tube quantities. Note 2 : Reels are sold containing 1,000 pcs/reel. Please refer to the delivery form on page 6 for details. Note 3 : Please note that tray packaged parts are not suitable for use with automatic mounting processes. PCB Mounting Pattern 4 Header Receptacle ・Recommended metal mask thickness : t = 0.15mm ・Recommended metal mask thickness : t = 0.15mm ・If the inside (the connector mounting lower side) of the SMT portion is not treated with the insulation tape and so on, the area is specified as a pattern prohibited area. FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors Connector Precautions for use 1. Tolerance Clearance on the Mating Side The effective contact length of the product is set to 0.7mm. Please make sure there is less than 0.2mm clearance between the header and receptacle during mating. 2. Support between the PCBs Please be sure to fix the boards to each other with screws or other means of support. Do not use only the mated connector to support the boards. Stack 3mm 3 +0.3 _0.2 mm Stack 4mm 4 +0.3 _0.2 mm Note : Please Note that the above stacking tolerance doesn't include the solder paste thickness. 4. Multiple mounting on same PCB is not recommended in principle 5. Mounting Temperature Profile (Reference) 260 (MAX 250ç) 240 220ç 220 200ç 200 Temperature Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. Stacking Height Tolerance for Mating 180 160 140 150ç (ç) 0 90 to 120s Pre-heating time (150 to 200ç) MAX 60s Soldering Time (220ç min.) Time (Second) HRS test conditions Test boardGlass epoxy 161mm∞100mm∞1.6mm thick Solder method : Reflow Solder composition : Paste, 96.5%Sn/3%Ag/0.5%Cu Metal mask : 0.15mm thick Reflow cycles : 2 cycles The temperature profile is based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/ thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. 5 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors Packaging Type Packaging Type Tube packaging No. of contacts 60 contacts 80 contacts 90 contacts 100 contacts 120 contacts 140 contacts Pieces per tube 21 pcs 17 pcs 15 pcs 14 pcs 12 pcs 10 pcs Sales unit Per tube. Please place orders in full magazine/tube quantities. Tube Total Length 550mm±2mm Tape Width Embossed Tape Packaging 44mm 44mm 44mm 56mm 56mm Product Pitch 12mm Embossed Reel diameter Refer to the table on catalog page 6. Pieces per reel 1000 pcs/reel Sales unit Per reel 72mm * The chart above applies only to individual connectors. Dual connected products are packaged and shipped in trays only. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. * Packaging Specification [Tube packaging] Receptacle [FX8-**S-SV (21)] Header [FX8-**P-SV (91)] [FX8-**P-SV1 (91)] (7.2) (5.2) 550±2 (9.8) (9.7) 550±2 Polarity mark Marking Polarity mark Marking [Embossed Tape Package] Embossed Carrier Tape Dimensions Unreeling direction Ø1 E Ø80 .5 Ø1 (1.7) Termination Installation area: Leader area (400mm min.) section End Contact area (The product includes 1000 pieces.) Space (More than 10 pockets) A B 1.5 44.4[56.4][72.4] 3 2 20.2 [26.2][34.2] 4 1.75 12 2 C 0.4 40.4 [52.4][68.4] 44 [56][72] D Reel Dimensions (FREE) Emboss tape Space Cover tape (10 pockets min.) *The figure above shows the receptacle in its pocket. Unit : mm P/S Header Receptacle Part No. FX8-**P-SV (92) FX8-**P-SV1 (92) FX8-**S-SV (22) ** : No. of contacts Note 1 : Ø 330 are for 60, 80 and 90 contacts. Ø 360 are for 100, 120 and 140 contacts. 6 A B 5.5 7.9 6.0 8.4 C D 3.2 4.2 2.6 E Ø 330 12 (Note 1) Ø 330 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors FX8C Series Product Specifications Ratings Rated current : 0.4A Operation temperature range : -55 to +85°C (Note 1) Storage temperature range : -10 to +60°C (Note 2) Rated voltage : AC 100V Operation humidity range : 40 to 80% Storage humidity range : 40 to 70% (Note 2) Items 1. Insulation resistance 2. Withstand voltage 3. Contact resistance 4. Vibration proof 5. Moisture resistance Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6. Temperature cycle 7. Mating cycles 8. Soldering heat resistance Specifications Min of 100Mø No flashover or dielectric breakdown. Max of 80Mø No electrical discontinuity lasting for a min of 1μs. Conditions Measured at 250 V DC 300V AC for 1 minute Measured at 100 mA 10 to 55Hz, half amplitude : 0.75mm, 3 axis directions, 10 cycles each. Contact resistance : a max of 100mø ; Insulation resistance : a min of 100Mø Left for 96 hours at the temperature of 40 ±2°C and the humidity of 90 to 95% Contact resistance : a max of 100mø ; Insulation resistance : a min of 100ø Contact resistance : a max of 100mø No dissolution of the resin affecting performance. (-55°C for 30 minutes → 15 to 35°C for 2 to 3 minutes → 85°C for 30 minutes → 15 to 35°C for 2 to 3 minutes) in 5 cycles 50 times Reflow : With recommended temperature profile, at the soldering iron temperature of 350°C for 5 seconds Note 1 : Includes the temperature rise caused by current flow. Note 2 : Storage as described here represents the long-term-storage status of unused items before they are mounted on PCB. Operation humidity range applies to the unpowered status after the items are mounted on PCB. Note 3 : The contact resistance noted above is measured using a connector combination with a 16mm stack height. Material / Finish Part name Insulator Material PPS resin Treatment Light brown Remarks UL94V-0 Contact area Gold plating ––––––– Lead area Pure tin plating (Note 2) Phosphor bronze Contact area Gold plating Receptacle contact ––––––– Lead area Pure tin plating (Note 2) Note 1 : Black dots or other color irregularities may occur in the insulator resin. In addition, the color may change if exposed to sunlight or florescent light. But this does not affect the quality or performance. Note 2 : FX8C-*P-SV (*) and FX8C-*S-SV are gold plated. Header contact ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Single Product FX8C - 120 P - SV 1 (91) 1 2 3 4 5 6 t Variable product height : None : Standard (Minimum height product) 1 : +1mm 6 : +6mm y Packaged state (71) : Tray packaging (68), (91) : Magazine/tube packaging (92) : Embosses tape packaging (93) : Vacuum tape, embosses tape packaging q Series name : FX8C w No. of contacts : 60, 80, 100, 120, 140 e Connector type : P : Header S : Receptacle r Contact form : SV : Vertical PCB type ●Two-connected products FX8C - 120/120 P 11 - SV 1 J 1 2 q Series name : FX8C 3 4 5 6 7 r Pitch between dual connected products t Contact form : SV : Vertical PCB type w No. of contacts : 60∞2, 80∞2, 100∞2, 120∞2, 140∞2 Example : 120/120=240 contacts y Variable product height : None : Standard (Minimum height product) 1 : +1mm 6 : +6mm u J : Dual connected product e Connector type : P : Header S : Receptacle *Dual connected products are packed in trays as the standard delivery method. 7 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors Stacking Height Variations Receptacle FX8C-**P-SV FX8C-**/**P11-SVJ FX8C-**P-SV1 FX8C-**/**P11-SV1J FX8C-**P-SV2 FX8C-**/**P11-SV2J FX8C-**P-SV4 FX8C-**/**P11-SV4J FX8C-**P-SV6 FX8C-**/**P11-SV6J FX8C-**S-SV FX8C-**/**S11-SVJ FX8C-**S-SV5 FX8C-**/**S11-SV5J 5mm 10mm 6mm 11mm 7mm 12mm 9mm 14mm 11mm 16mm 5 to 16 Header Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ** ** ** (2)Effective mating length (Stacking height) (2)Effective mating length ** ** ** ** ** ** ** ** ** 8 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors A±0.25 B +0.05 – 0.2 C +0.05 – 0.2 Header (Single Product) D±0.2 0 6.5 _0.3 5.1±0.3 P±0.6±0.1 (C1) 4.45±0.25 (0.4) [FX8C-**P-SV] Polarity mark t0.2±0.03∞w0.25±0.03 (Ø0.6) E±0.1 (0.75) (Ø0.9) 2-(C0.2) (2.4) (1.5) (2.4) HRS No. 578-0501-9 ** 578-0503-4 ** 578-0505-0 ** 578-0506-2 ** 578-0507-5 ** No. of contacts 60 80 100 120 140 A 24.60 30.60 36.60 42.60 48.60 B 23.00 29.00 35.00 41.00 47.00 C 20.70 26.70 32.70 38.70 44.70 D 17.40 23.40 29.40 35.40 41.40 E 22.20 28.20 34.20 40.20 46.20 RoHS Yes Note 1 : Embossed tape packaging product are sold in full reel quantities. For details, see the item showing delivery forms in Page 16. Note 2 : Please place orders in full magazine/tube quantities. Note 3 : Please note that tray packaged parts are not suitable for use with automatic mounting processes. A±0.3 B +0.05 – 0.2 C +0.05 – 0.2 D±0.2 (0.4) 5.1±0.3 0 6.5 _0.3 P=0.6±0.1 (C1) Polarity mark F±0.25 [FX8C-**P-SV1] [FX8C-**P-SV2] [FX8C-**P-SV4] [FX8C-**P-SV6] (0.75) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Part No. FX8C-60P-SV(**) FX8C-80P-SV(**) FX8C-100P-SV(**) FX8C-120P-SV(**) FX8C-140P-SV(**) (Ø0.9) t0.2±0.03∞w0.25±0.03 E±0.1 (1.5) (Ø0.6) (2.4) (2.4) 2-(C0.2) Unit : mm Part No. FX8C-60P-SV1(**) FX8C-60P-SV2(**) FX8C-60P-SV4(**) FX8C-60P-SV6(**) FX8C-80P-SV1(**) FX8C-80P-SV2(**) FX8C-80P-SV4(**) FX8C-80P-SV6(**) FX8C-100P-SV1(**) FX8C-100P-SV2(**) FX8C-100P-SV4(**) FX8C-100P-SV6(**) FX8C-120P-SV1(**) FX8C-120P-SV2(**) FX8C-120P-SV4(**) FX8C-120P-SV6(**) FX8C-140P-SV1(**) FX8C-140P-SV2(**) FX8C-140P-SV4(**) FX8C-140P-SV6(**) HRS No. 578-0521-6 ** 578-0541-3 ** 578-0581-8 ** 578-0601-3 ** 578-0523-1 ** 578-0543-9 ** 578-0583-3 ** 578-0603-9 ** 578-0525-7 ** 578-0545-4 ** 578-0585-9 ** 578-0605-4 ** 578-0526-0 ** 578-0546-7 ** 578-0586-1 ** 578-0606-7 ** 578-0527-2 ** 578-0547-0 ** 578-0587-4 ** 578-0607-0 ** No. of contacts A B C D E 60 24.60 23.00 20.70 17.40 22.20 80 30.60 29.00 26.70 23.40 28.20 100 36.60 35.00 32.70 29.40 34.20 120 42.60 41.00 38.70 35.40 40.20 140 48.60 47.00 44.70 41.40 46.20 F 5.45 6.45 8.45 10.45 5.45 6.45 8.45 10.45 5.45 6.45 8.45 10.45 5.45 6.45 8.45 10.45 5.45 6.45 8.45 10.45 RoHS Yes Note 1 : Embossed tape packaging product are sold in full reel quantities. For details, see the item showing delivery forms in Page 16. Note 2 : Please place orders in full magazine/tube quantities. Note 3 : For FX8C-**P-SV6 connectors, there is a spacer attached between the leads. Please request the specific drawing for clarification. Note 4 : Please note that tray packaged parts are not suitable for use with automatic mounting processes. 9 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors Receptacle (Single Product) (C1) 0 7_0.3 5.6±0.3 P=0.6±0.1 A±0.3 B +0.2 0 C +0.2 0 D±0.2 Polarity mark (back) 3.95±0.25 [FX8C-**S-SV] (0.75) (Ø0.9) t0.2±0.03∞w0.25±0.03 E±0.1 (Ø0.6) (2.4) 2-(C0.2) (1.8) (2.4) Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. FX8C-60S-SV(**) FX8C-80S-SV(**) FX8C-100S-SV(**) FX8C-120S-SV(**) FX8C-140S-SV(**) HRS No. 578-0801-2 ** 578-0803-8 ** 578-0805-3 ** 578-0806-6 ** 578-0807-9 ** No. of contacts 60 80 100 120 140 A 24.60 30.60 36.60 42.60 48.60 B 23.05 29.05 35.05 41.05 47.05 C 20.80 26.80 32.80 38.80 44.80 D 17.40 23.40 29.40 35.40 41.40 E 22.20 28.20 34.20 40.20 46.20 RoHS Yes Note 1 : Embossed tape packaging product are sold in full reel quantities. For details, see the item showing delivery forms in Page 16. Note 2 : Please place orders in full magazine/tube quantities. Note 3 : Please note that tray packaged parts are not suitable for use with automatic mounting processes. A±0.3 B +0.2 0 C +0.2 0 D±0.2 P=0.6±0.1 0 7_0.3 5.6±0.3 (C1) [FX8C-**S-SV5] (0.75) 8.95±0.25 Polarity mark (back) (Ø0.9) t0.2±0.03∞w0.25±0.03 (Ø0.6) E±0.1 (2.4) Part No. FX8C-60S-SV5(**) FX8C-80S-SV5(**) FX8C-100S-SV5(**) FX8C-120S-SV5(**) FX8C-140S-SV5(**) HRS No. 578-0821-0 ** 578-0823-5 ** 578-0825-0 ** 578-0826-3 ** 578-0827-6 ** No. of contacts 60 80 100 120 140 2-(C0.2) (1.8) (2.4) A 24.6 30.6 36.6 42.6 48.6 B 23.05 29.05 35.05 41.05 47.05 C 20.8 26.8 32.8 38.8 44.8 Unit : mm D 17.4 23.4 29.4 35.4 41.4 E 22.2 28.2 34.2 40.2 46.2 RoHS Yes Note 1 : Embossed tape packaging product are sold in full reel quantities. For details, see the item showing delivery forms in Page 16. Note 2 : Please place orders in full magazine/tube quantities. Note 3 : Please note that tray packaged parts are not suitable for use with automatic mounting processes. BRecommended PCB layout and metal mask dimensions for single connector (mounting side) Header Receptacle [FX8C-**P-SV*] [FX8C-**S-SV, SV5*] Polarity mark position Polarity mark position *Recommended metal mask thickness : t = 0.15mm 10 *Recommended metal mask thickness : t = 0.15mm *The inside of SMT land (bottom of the connector being mounted) will be a patterning restricted area if no treatment such as insulation tape is applied. (FX8C-**S-SV, SV5 are not applicable.) FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors A±0.3 B±0.3 C +0.05 – 0.2 D +0.05 – 0.2 Header (Dual Connected Product) (3.35) (16.1) (11) [FX8C-**/**P11-SVJ] E±0.2 Polarity mark (4.5) F±0.1 HRS No. 578-0651-1 71 578-0653-7 71 578-0655-2 71 578-0656-5 71 578-0657-8 71 No. of contacts 60×2 80×2 100×2 120×2 140×2 A 31.70 37.70 43.70 49.70 55.70 B 24.70 30.70 36.70 42.70 48.70 C 23.00 29.00 35.00 41.00 47.00 D 20.70 26.70 32.70 38.70 44.70 E 17.40 23.40 29.40 35.40 41.40 F 22.20 28.20 34.20 40.20 46.20 RoHS Yes Note : Dual connected products are packaged and shipped in trays. And as such, are not suitable for use with automatic mounting processes. A±0.3 B±0.3 C+0.05 – 0.2 +0.05 D – 0.2 E±0.2 (16.1) (11) [FX8C-**/**P11-SV1J] [FX8C-**/**P11-SV2J] [FX8C-**/**P11-SV4J] [FX8C-**/**P11-SV6J] Polarity mark (G) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Part No. FX8C-60/60P11-SVJ(71) FX8C-80/80P11-SVJ(71) FX8C-100/100P11-SVJ(71) FX8C-120/120P11-SVJ(71) FX8C-140/140P11-SVJ(71) F±0.1 (4.5) Unit : mm Part No. HRS No. FX8C-60/60P11-SV1J(71) FX8C-60/60P11-SV2J(71) FX8C-60/60P11-SV4J(71) 578-0671-9 71 578-0691-6 71 578-0731-9 71 FX8C-60/60P11-SV6J(71) FX8C-80/80P11-SV1J(71) FX8C-80/80P11-SV2J(71) FX8C-80/80P11-SV4J(71) FX8C-80/80P11-SV6J(71) FX8C-100/100P11-SV1J(71) FX8C-100/100P11-SV2J(71) FX8C-100/100P11-SV4J(71) FX8C-100/100P11-SV6J(71) FX8C-120/120P11-SV1J(71) FX8C-120/120P11-SV2J(71) FX8C-120/120P11-SV4J(71) FX8C-120/120P11-SV6J(71) FX8C-140/140P11-SV1J(71) FX8C-140/140P11-SV2J(71) FX8C-140/140P11-SV4J(71) FX8C-140/140P11-SV6J(71) 578-0751-6 71 578-0673-4 71 578-0693-1 71 578-0733-4 71 578-0753-1 71 578-0675-0 71 578-0695-7 71 578-0735-0 71 578-0755-7 71 578-0676-2 71 578-0696-0 71 578-0736-2 71 578-0756-0 71 578-0677-5 71 578-0697-2 71 578-0737-5 71 578-0757-2 71 No. of contacts 60×2 A B C D E F 31.70 24.70 23.00 20.70 17.40 22.20 80×2 37.70 30.70 29.00 26.70 23.40 28.20 100×2 43.70 36.70 35.00 32.70 29.40 34.20 120×2 49.70 42.70 41.00 38.70 35.40 40.20 140×2 55.70 48.70 47.00 44.70 41.40 46.20 G H 4.35 5.35 7.35 5.45 6.45 8.45 9.35 4.35 5.35 7.35 9.35 4.35 5.35 7.35 9.35 4.35 5.35 7.35 9.35 4.35 5.35 7.35 9.35 10.45 5.45 6.45 8.45 10.45 5.45 6.45 8.45 10.45 5.45 6.45 8.45 10.45 5.45 6.45 8.45 10.45 RoHS Yes Note 1 : Dual connected products are packaged and shipped in trays. And as such, are not suitable for use with automatic mounting processes. ** ** Note 2 : For FX8C- / P11-SV6J connectors, there is a spacer attached between the leads. Please request the specific drawing for clarification. 11 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors A±0.3 B±0.3 ■Receptacle (Dual Connected Product) E±0.2 (3.4) (16.6) (11) [FX8C-**/**S11-SVJ] C +0.2 0 D +0.2 0 Polarity mark (back) F±0.1 (4) Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. FX8C-60/60S11-SVJ(71) FX8C-80/80S11-SVJ(71) FX8C-100/100S11-SVJ(71) FX8C-120/120S11-SVJ(71) FX8C-140/140S11-SVJ(71) HRS No. 578-0901-7 71 578-0903-2 71 578-0905-8 71 578-0906-0 71 578-0907-3 71 No. of contacts 60×2 80×2 100×2 120×2 140×2 A 31.70 37.70 43.70 49.70 55.70 B 24.60 30.60 36.60 42.60 48.60 C 23.05 29.05 35.05 41.05 47.05 D 20.80 26.80 32.80 38.80 44.80 E 17.40 23.40 29.40 35.40 41.40 F 22.20 28.20 34.20 40.20 46.20 RoHS Yes Note : Dual connected products are packaged and shipped in trays. And as such, are not suitable for use with automatic mounting processes. [FX8C-**/**S11-SV5J] A±0.3 B±0.3 C +0.2 0 D +0.2 0 (16.6) (11) E±0.2 (8.4) Polarity mark (back) F±0.1 (4) Unit : mm Part No. FX8C-60/60S11-SV5J(71) FX8C-80/80S11-SV5J(71) FX8C-100/100S11-SV5J(71) FX8C-120/120S11-SV5J(71) FX8C-140/140S11-SV5J(71) HRS No. 578-0921-4 71 578-0923-0 71 578-0925-5 71 578-0926-8 71 578-0927-0 71 No. of contacts 60×2 80×2 100×2 120×2 140×2 A 31.70 37.70 43.70 49.70 55.70 B 24.60 30.60 36.60 42.60 48.60 C 23.05 29.05 35.05 41.05 47.05 D 20.80 26.80 32.80 38.80 44.80 E 17.40 23.40 29.40 35.40 41.40 F 22.20 28.20 34.20 40.20 46.20 RoHS Yes Note : Dual connected products are packaged and shipped in trays. And as such, are not suitable for use with automatic mounting processes. BRecommended PCB layout and metal mask dimensions for dual connected products (mounting side) Header Receptacle [FX8C-**/**P 11-SVJ, SV1J] [FX8C-**/**S 11-SVJ, SV5J] Polarity mark position Polarity mark position *Recommended metal mask thickness : 0.15mm 12 *Recommended metal mask thickness: t = 0.15mm *The inside of SMT land (bottom of the connector being mounted) will be a patterning restricted area if no treatment such as insulation tape is applied. (FX8C-**/**S11-SV5J is not applicable.) FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors BDetailed drawing on dual connected products after the spacers are removed (individual connector from dual connected product) Header Polarity mark Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Polarity mark Receptacle Polarity mark (back) Polarity mark (back) 13 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors BHow to Use the Connector 1. Permissible gap between mating surfaces The effective mating length of this product is 2.0mm. Please make sure that the gap between the header and receptacle when mated will be 1.2mm or less. 2. Fixation between mounted PCBs If the connector is secured to the board with only other connectors, please make sure that no vibrations or impact will occur. 3. Tolerances in stacking height when mated Stack Amm A +0.3 −0.2 mm Note: Please note that the thickness of solder cream is not taken into account for the above tolerances in stacking height. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. Using dual connected products Dual connected products are fixed with spacers on both longitudinal sides. However, the products cannot be mated in that state. Please make sure to remove the spacers before mating. (Please do not remove the spacers before mounting on PCB.) spacers Coupler (joint) Before removing the joint bar After removing the joint bar Note : Please use dual-connected products for multiple mounting. However, multiple mounting of dual-connected products are not recommended. 5. Temperature profile for mounting (reference) (Peak temperature : Max 250ç) 260 240 220ç 220 200ç Temperature (ç) 200 Reflow method Reflow with infrared light and heat (SENSBEY NR-II) Environment in the reflow furnace Ambient air 180 160 140 Solder 150ç PCB 0 (90 to 120 seconds) Preheating period (150 to 200ç) Within 60 seconds Soldering period (a minimum of 220ç) 6. Usage Recommendations Metal mask thickness Cream type (Sn-3Ag-0.5Cu) (Flux contained amount : 11 Wt%) (M705-221CM5-42-10.5 manufactured by Senju Metal Industry Co., Ltd.) Size 161 ∞ 100 ∞ 1.6mm Material : Glass epoxy Thickness : 0.15mm Note 1 : This temperature profile shows recommended values. Temperature should be measured on the top of the connector. Note 2 : The reflow process should be limited to two times. Note 3 : Results may differ depending on the type and manufacturer of solder cream, PCB size, mounting materials and other conditions. Please be sure to confirm the mounting conditions before use. This product has been thin-formed for minimization. Care should be taken that excessive prying mating/unmating could cause damage and contact failure. 14 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors BForm of Delivery Packaging style No. of contacts Product quantity Magazine packaging Sales unit Overall magazine length Tape width (JIS) Product pitch Embossed tape packaging Embossed reel diameter Product quantity Sales unit 60 contacts 80 contacts 100 contacts 120 contacts 140 contacts 21 pieces 17 pieces 14 pieces 12 pieces 10 pieces Please place orders in full magazine/tube quantities. 550mm ± 2mm 44 56 72 (12mm) Please see the table shown in Page 16 of this catalog. Please see the table shown in Page 16 of this catalog. Full reels. Please see the table shown in page 16 of this catalog. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. **The chart above applies only to individual connectors. Dual connected products will be packaged and delivered in trays. BPackaging Specification [Magazine Packaging] ●Header [FX8C-**P-SV(91)] [FX8C-**P-SV1(91)] [FX8C-**P-SV2(91)] [FX8C-**P-SV4(91)] [FX8C-**P-SV6(91)] Polarity mark Marking ●Receptacle [FX8C-**S-SV(68)] [FX8C-**S-SV5(91)] Polarity mark Marking P/S Header Receptacle Part No. FX8C-**P-SV(91) FX8C-**P-SV1(91) FX8C-**P-SV2(91) FX8C-**P-SV4(91) FX8C-**P-SV6(91) FX8C-**S-SV(68) FX8C-**S-SV5(91) Polarity mark (back) A 9 10 11 13 15 7.4 12.4 15 FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors [Embossed Tape Packaging] ●Carrier Dimensions ●Reel Dimensions Unreeling direction 0.4 or 0.5 4 .5 Ø1 Reel dimensions 2 Ø13 2 1.75 C 44.4[56.4][72.4] 40.4 [52.4] [68.4] 44 [56] [72] E Ø80*1 20.2 [26.2][34.2] D Ø2 1 12 Leader (400 mm or longer) Attachment Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.7 +0.15 0 Termination 1.5 A B Cavity (10 pockets or more) * The figure above shows FX8 receptacles packaged on a embossed tape. Dimensions shown in brackets [ ] are those for tape widths of 56mm or 72mm. Embossed tape Cavity Cover tape (10 pockets or more) *1 For FX8C-140S-SV(92), E dimension is 370 in diameter and core dimension is 100 in diameter. *2 For FX8C-120P-SV2(92), FX8C-120S-SV5(92), and FX8C-140S-SV5(92), E dimension is 380 in diameter. Note : Some products are not available packaged on an embossed tape. Please be sure to clarify the packaging type before you order. Unit : mm P/S Part No. FX8C-**P-SV(92) FX8C-**P-SV1(92) FX8C-**P-SV2(92) FX8C-**P-SV4(92) FX8C-**P-SV6(92) FX8C-**S-SV(92) FX8C-**S-SV5(92) Header Receptacle A B C D E 5.5 5.5 5.5 5.5 5.5 6.0 6.0 7.9 7.9 7.9 7.9 7.9 8.4 8.4 5.2 6.2 7.2 9.2 11.2 4.3 9.3 1.2 1.2 1.2 1.2 1.2 1.2 1.2 Ø370 Ø370 Ø330 Ø370 Ø370 Ø330 Ø370 Product quantity 1000 pcs/reel 1000 pcs/reel 500 pcs/reel *2 500 pcs/reel 500 pcs/reel 1000 pcs/reel *1 500 pcs/reel *2 ** : No. of contacts ® 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 06/2018. Contents are subject to change without notice for the purpose of improvements.
FX8C-60/60P11-SV2J(71) 价格&库存
很抱歉,暂时无法提供与“FX8C-60/60P11-SV2J(71)”相匹配的价格&库存,您可以联系我们找货
