BASIC BLADE & BEAM
HEADER & SOCKET
(0.80 mm) .0315" PITCH • BTE/BSE SERIES
BTE
BTE
Mates:
BSE
BSE
NO. OF POSITIONS
PER ROW
–020, –040,–060,
–080, –100, –120
Mates:
BTE
SPECIFICATIONS
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over 50 µ" (1.27 µm) Ni
Current Rating:
2 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
225 VAC with 5 mm Stack Height
Max Cycles:
100
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
-D-A-
–F
(5.97)
.235
A
BSE
NO. OF POSITIONS
PER ROW
- 01 -
–020, –040, –060,
–080, –100, –120
MOQ Required
30 µ" (0.76 µm) Gold
Edge Mount Capability
Friction Lock option
11 mm, 14 mm, 16.10 mm,
19.10 mm, 22 mm, 25 mm
and 30 mm Stack
Height (Caution: Some
automatic placement/
inspection machines may
have component height
restrictions. Please consult
machinery specifications.)
= (7.00 mm)
.275" DIA
Polyimide Film
Pick & Place Pad
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–TR
= Tape & Reel
(80 positions
maximum)
A
MATED HEIGHT
–01
(4.27) .168
LEAD STYLE MATED HEIGHT*
–02
(7.21) .284
PLATING OPTION
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–C*
EXTENDED LIFE
PRODUCT
–01
(5.00 mm) .1971"
–02
(8.00 mm) .315"
*Processing conditions
will affect mated height.
–F
= Electro-Polished Selective
50 µ" (1.27 µm) min
Au over 150 µ" (3.81 µm)
Ni on Signal Pins in contact
area, Matte Tin over
50 µ" (1.27 µm) min
Ni on all solder tails
(*–C Plating passes
10 year MFG testing)
(7.24)
.285
–FR
= Full Reel
Tape & Reel
(must order
maximum
quantity per
reel; contact
Samtec for
quantity breaks)
(80 positions
maximum)
LEAD
STYLE
= Gold Flash on contact,
Matte Tin on tail
No. of positions x (0.80) .0315
+ (5.27) .2075
OTHER
OPTION
–K
Matte Tin on tail
50 µ" (1.27 µm) min
50 µ" (1.27 µm) min
(*–C Plating passes
+ (4.00) .1575
ALSO AVAILABLE
10 YEAR MFG
WITH 50 µ" GOLD
PLATING OPTION
–C*
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (020-080)
(0.15 mm) .006" max (100-120)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
Board Stacking:
For applications requiring more
than two connectors per board
or 80 positions or higher,
contact ipg@samtec.com
-D-A-
OTHER
OPTION
–TR
= Tape & Reel
(80 positions
maximum)
–FR
= Full Reel
Tape & Reel
(must order
maximum
quantity per
reel; contact
Samtec for
quantity breaks)
(80 positions
maximum)
(3.25)
.128
HIGH MATING
CYCLES
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(3.05)
.120
samtec.com?BTE or samtec.com?BSE
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-221
很抱歉,暂时无法提供与“BTE-100-01-F-D-K”相匹配的价格&库存,您可以联系我们找货
