ERM8-050-01-L-D-RA-L-TR
    SAMTEC(申泰)
    .8MMEDGERATETERMINALASSEMBLY
ERM8-050-01-L-D-RA-L-TR 数据手册
RUGGED HIGH-SPEED STRIPS FEATURES & BENEFITS Edge Rate® rugged high-speed connector strips are designed for high speed, high cycle applications, and enabled by Samtec's signal integrity-optimized Edge Rate® contact system. • Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch • 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch • 0.635 mm pitch system with extremely slim 2.5 mm body width • Rugged latching, locking and 360º shielding • Up to 1.5 mm contact wipe; robust when "zippered" during unmating Signal integrity-optimized Edge Rate® contact system reduces broadside coupling • Compatible with UMPT/UMPS for power/signal flexibility EDGE RATE® STACK HEIGHT FLEXIBILITY (actual size in mm) 5 ERX6 7 11 10 9 12 13 16 15 14 17 18 Sockets shown actual size with 40 total positions ERX5 ERX6 ERM5/ERF5 ERX8 ERM8/ERF8 KEY SPECIFICATIONS SERIES PITCH STACK HEIGHTS TOTAL PINS / PAIRS ERM5 / ERF5 0.50 mm 7-12 mm 20-150 ERM6 / ERF6 0.635 mm 5 mm 20-120 ERM8 / ERF8 0.80 mm 7-18 mm 10-200 F-221 INSULATOR MATERIAL TERMINAL MATERIAL Phosphor Bronze or BeCu (ERM5), BeCu (ERF5) Black LCP Copper Alloy Phosphor Bronze or BeCu (ERM8), BeCu (ERF8) PLATING OPERATING TEMP RANGE Au or Sn over 50 µ" -55 °C to +125 °C (1.27 µm) Ni LEAD-FREE SOLDERABLE Yes samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.80 mm) .0315" PITCH • RIGHT-ANGLE & EDGE MOUNT HIGH-SPEED HEADERS - ERM8 Right-Angle Terminal POSITIONS PER ROW - 01 –010, –013, –020, –025, –030, –040, –049, –050, –060, –070, –075 - - PLATING OPTION D RA - –L - OPTIONS "X"R –K = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on tail –TR = (6.00 mm) .236" DIA Polyimide Film Pick & Place Pad = Tape & Reel –FR –L = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) = Latching –DS ERM8-RA Board Mates: ERF8 Cable Mates: ERCD (5.75) .226 No. of Positions x (0.80) .0315 + (13.00) .512 = Differential Pair (–013, –025 Position only) (Hot Swap) (11.00) .433 (6.25) .246 (7.52) .296 –L View complete specifications at: samtec.com?ERM8-RA ERM8 - Edge Mount Terminal POSITIONS PER ROW –010, –013, –020, –025, –030, –040, –049, –050, –060, –070, –075 - 01 PLATING OPTION - D –L = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on tail - EM2 = (1.60 mm) .062" Thick PCB - OPTIONS –L = Latching (Mates to ERF8 Lead Style –05.0 or –RA Only) –DS = Differential Pair (–013 & –025 Position only) (Hot Swap) –EGPS = Extended Guide Post Shield (–010, –020, –025, –030 Position Only) –DSS = Differential Pair + Extended Guide Post Shield (–025 Position Only) (Hot Swap) "X"R –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) No. of positions x (0.80) .0315 + (9.00) .354 ERM8-EM Board Mates: ERF8 Cable Mates: ERCD EGPS = No. of positions x (0.80) .0315 + (10.00) .394 (3.82) .150 (3.20) .126 (5.60) .220 (5.70) .224 (6.80) .268 (12.95) 0.51 –L View complete specifications at: samtec.com?ERM8-EM –L (14.79) .582 –EGPS Note: Some lengths, styles and options are non-standard, non-returnable. F-221 samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
ERM8-050-01-L-D-RA-L-TR 价格&库存
很抱歉,暂时无法提供与“ERM8-050-01-L-D-RA-L-TR”相匹配的价格&库存,您可以联系我们找货
  • 1+102.371231+12.83755
  • 10+92.4797910+11.59715
  • 25+87.4214825+10.96283
  • 50+84.7095550+10.62274
  • 100+74.81303100+9.38170
库存:117
  • 100+81.31959100+10.19764
库存:117
  • 200+74.81351200+9.38176
  • 600+65.70864600+8.23999
  • 1000+63.738091000+7.99288
库存:117
