QTH-020-01-F-D-DP-A-K
    SAMTEC(申泰)
    SMD,P=0.5mm
    PIN:40P 间距:0.5MM 立贴
QTH-020-01-F-D-DP-A-K 数据手册
REVISION AH QTH-XXX-XX-X-D-DP-XXX DO NOT SCALE FROM THIS PRINT C "D" REF .7875 20.003 REF 9 EQ. SPCS @ .059[1.50] =.532 13.50 (TYP) .020 0.50 REF .059 1.50 REF 01 .155 3.94 REF (SEE NOTE 13) .235 5.97 REF PLATING SPECIFICATION -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (USE T-1GXX-XX-F) (SEE NOTE 7) -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (USE T-1GXX-XX-L) -H: 30µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL (USE T-1GXX-XX-G) -C: 50µ" ELECTRO-POLISHED SELECTIVE IN CONTACT AREA, MATTE TIN ON TAIL (USE T-1GXX-XX-L) .008 0.20 REF .644 16.36 REF "A" ROW SPECIFICATION -D: DOUBLE (USE QTH-30-01-D-XX) No OF BANKS C QTH-30-XX-D-XX-A T-1SXX-XX-X (SEE TABLE 1) .155±.003 3.94±0.08 (SEE NOTE 13) "B" REF .098 2.49 REF SEE NOTE 10 "A" .038 0.95 REF DIFFERENTIAL PAIRS * = RELEASED FOR ASO ONLY (APPLICATION SPECIFIC ORDER) ** = -02 LEAD STYLE NOT RELEASED FOR PRODUCTION 02 .047 1.19 REF OPTION -A: ALIGNMENT PINS (SEE FIGS 1 & 3, SHT 2) -LC: LOCKING CLIPS (USE LC-08-TM-01, SEE FIG 2) (SEE NOTE 12) -K: POLYIMIDE FILM (USE K-DOT-.276-.375-.005) (AVAILABLE ON -01 THRU -04 & -09 AND -10 ONLY)(SEE FIG 4, SHT 2) -TR: TAPE & REEL (60 POS MAX) (40 POS MAX FOR -GP OPTION) (N/A ON -05 THRU -08) -GP: GUIDE POSTS OPTION ** (AVAILABLE ON -01 & **-02 ONLY) (USE QTH-30-XX-D-XX-GP) (SEE FIG 8, SHT 4) -RT1: RETENTION OPTION (SEE FIG 9, SHT 4) (ONLY AVAILABLE ON -01 LEAD STYLE) (MUST USE -A OPTION) (USE QTH-30-01-D-XX-A-RT1 & T-1R36-01-F) (NOT AVAILABLE WITH -LC OR -GP) (NOT AVAILABLE ON -080 & -100 POS) -L: LATCHING OPTION (SEE FIG 10, SHT 5) (ONLY AVAILABLE ON -01 LEAD STYLE) (USE QTH-30-01-D-XX-L) (NOT AVAILABLE WITH -LC, -GP, -FL, OR -RT1) (40 POS MAX) -FL: FRICTION LOCKS (SEE FIG 11, SHT 5) (NOT AVAILABLE WITH -GP) No OF POSITIONS -020, -040, -060, ***-080, ***-100 (PER ROW) ***SEE NOTE 11 LEAD STYLE -01: .1680[4.267] *-02: .2861[7.264] *-03: .4042[10.267] *-04: .6001[15.243] *-05: .7181[18.240] *-06: .8361[21.237] *-07: .9542[24.237] *-08: 1.1511[29.238] *-09: .5224[13.269] *-10: .5618[14.270] .745 18.92 REF "A" .003[.08] .002[.05] C (SEE NOTE 5 & 8) C T-1G1-XX-X SEE TABLE 2 (SEE NOTE 8) "E" REF .280 7.11 .035 0.89 REF .031 0.79 REF .015 0.38 REF .0375 0.953 REF NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 6 OZ FOR –01 & -02, 8 OZ FOR –03 THRU –09. 3. MINIMUM GROUND PLANE RETENTION: 1 LB. 4. PARTS TO BE MOLDED TO POSITION. 5. MAXIMUM VARIANCE OF .002[0.05]. APPLIES TO SIGNAL OR GROUNDS INDEPENDENT OF THE GROUND OR SIGNAL PINS RESPECTIVELY. 6. LEAD STYLES -03 THRU -08: TOP BODY (QTH) CANNOT HAVE -A OPTION. 7. -L PLATING CAN BE SUBSTITUTED FOR -F PLATING. -G PLATED GROUND PLANE CAN BE SUSTITUTED FOR –F PLATED GROUND PLANE. 8. GROUND PLANE PRESS HEIGHT MUST BE .003 [0.08] LESS THAN THE MAXIMUM HEIGHT OR .002[0.05] GREATER THAN THE MINIMUM HEIGHT OF SIGNAL PIN. 9. T-1R36 RETENTION TO BODY TO BE 1.0 LBF. 10. CUT OFF BURR NOT TO EXCEED .003[0.08] IN ANY DIRECTION, BURR PLUS TAB HEIGHT NOT TO EXCEED .006[0.15]. 11. FOR NEW APPLICATIONS REQUIRING THESE POSITIONS, PLEASE CONTACT SAMTEC INTERCONNECT PROCESSING GROUP. 12. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE -LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION. 13. PIN CAN EXTEND PAST WALL .003[0.08] MAX. SECTION "A"-"A" FIG 1 -A: ALIGNMENT PIN OPTION (QTH-060-01-X-D-A SHOWN) (FOR -01 & -02 LEAD STYLE ONLY) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] MATERIAL: ANGLES 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP UL94V-0, COLOR: BLACK TERMINAL & GROUND PLANE: PHOS BRONZE F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-DP-XXX-MKT.SLDDRW SHEET SCALE: 1.75:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DIFFERENTIAL PAIRS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-DP-XXX BY: KEVIN B 09-14-2010 SHEET 1 OF 5 REVISION AH QTH-30-XX-D-XX C .0800 2.032 .055 1.40 LC-08-TM-01 .010 0.25 REF .056 1.42 REF "E" REF (SEE TABLE 3, SHT 1) FIG 2 -LC: LOCKING CLIP OPTION (QTH-060-01-X-D-LC SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) QTH-30-02-D-XX (SEE NOTE 6) .038 0.95 REF QTHH-30-XX-D-XX-A "E" REF (SEE TABLE 3, SHT 1) .035 0.89 REF .080 2.03 REF FIG 3 -A: ALIGNMENT PIN OPTION (QTH-060-05-X-D-DP-A SHOWN) (FOR -03 THRU -08 LEAD STYLE ONLY) (SEE TABLE 4, SHT 3) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) "R" REF .020±.010 0.51±0.25 C "S"±.020[0.51] "T" * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. C FIG 4 -K: POLYIMIDE FILM PAD OPTION (USE K-.276-.375-.005) .276 7.01 DO NOT SCALE DRAWING SHEET SCALE: 1.75:1 F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-DP-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DIFFERENTIAL PAIRS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-DP-XXX BY: KEVIN B 09-14-2010 SHEET 2 OF 5 REVISION AH .006 0.15 MAX BURR + TAB HEIGHT TAB DETAIL 'E' .003 0.08 MAX TAB HEIGHT SEE NOTE 10 "B" C QTH-30-02-D-XX (SEE NOTE 6) T-1S60-XX-X C .278 7.07 REF .118 3.00 REF +.003[.08] "C" -.001[.03] (SEE NOTES 5 & 8) 'E' C "B" .155±.003 3.94±0.08 (SEE NOTE 13) SEE TABLE 2 (SEE NOTE 8) T-1G1-XX-X QTHH-30-01-D-XX .056 1.42 REF SEE NOTE 10 .281 7.14 .037 0.94 REF .265 6.73 REF SECTION "B"-"B" FIG 5 QTH-060-03-X-D-DP-LC SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) C "C" C .155±.003 3.94±0.08 (SEE NOTE 13) .155±.003 3.94±0.08 "D" T-1S61-XX-X T-1S60-XX-X C C +.003[.08] -.001[.03] +.003[.08] "C" -.001[.03] (SEE NOTES 5 & 8) "C" (SEE NOTES 5 & 8) C .432 10.97 REF "C" QTHH-30-03-D-XX FIG 6 QTH-060-05-X-D-DP SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 3) C SEE TABLE 2 (SEE NOTE 8) SEE NOTE 10 T-1G17-XX-X SECTION "C"-"C" SCALE 1.25 : 1 .600 15.24 REF QTHH-030-04-D-XX SEE TABLE 2 (SEE NOTE 8) "D" FIG 7 QTH-060-07-X-D-DP SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 3) * PROPRIETARY NOTE SHEET SCALE: 1.75:1 F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-DP-XXX-MKT.SLDDRW SECTION "D"-"D" * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SEE NOTE 10 T-1G17-XX-X 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DIFFERENTIAL PAIRS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-DP-XXX BY: KEVIN B 09-14-2010 SHEET 3 OF 5 REVISION AH C "G" REF "H" REF "F" REF CL CL SEE TABLE 5 .295 7.49 .125 3.18 REF FIG 8 -GP: GUIDE POST OPTION (QTH-060-01-X-D-DP-GP SHOWN) (FOR -01 & -02 LEAD STYLE ONLY) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (* = NOT ENGINEERING APPROVED) "J" REF CL QTH-30-01-D-XX-A-RT1 "K" .069 1.76 REF C 'G' FIG 9 C -RT1: RETENTION OPTION (QTH-060-01-X-D-DP-A-RT1 SHOWN) (FOR -01 LEAD STYLE ONLY) (NOT AVAILABLE WITH -LC OR -GP OPTIONS) (NOT AVAILABLE ON -080 & -100 POS) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) .190 4.83 (SEE NOTE 9) .100 2.54 REF .070 1.78 REF DETAIL 'G' SCALE 3 : 1 T-1R36-01-F (2 PLCS) .062 1.57 REF F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-DP-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DIFFERENTIAL PAIRS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-DP-XXX BY: KEVIN B 09-14-2010 SHEET 4 OF 5 REVISION AH "L" REF FIG 10 -L: LATCHING OPTION (QTH-040-01-X-DP-L SHOWN) (AVAILABLE ON -01 LEAD STYLE ONLY) (NOT AVAILABLE WITH -LC, -GP, -FL, OR -RT1 OPTIONS) (40 POS MAX) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) C "M" .020 0.50 REF QTH-30-01-D-XX-L WT-56-01-T .010 0.25 REF (TYP) .025 0.64 REF .053±.002 1.35±0.05 "N" C .012 0.30 REF .008 0.20 REF .070 1.78 REF (TYP) .015 0.38 REF .015 0.38 REF QTH-30-XX-D-XX-X-FL DETAIL 'J' SCALE 12 : 1 DETAIL 'H' SCALE 12 : 1 'J' 'H' * FIG 11 -FL: FRICTION LOCKS (NOT AVAILABLE WITH -GP OPTION) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 F:\DWG\MISC\MKTG\QTH-XXX-XX-X-D-DP-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .5mm DIFFERENTIAL PAIRS TERMINAL ASSEMBLY DWG. NO. QTH-XXX-XX-X-D-DP-XXX BY: KEVIN B 09-14-2010 SHEET 5 OF 5
QTH-020-01-F-D-DP-A-K 价格&库存
很抱歉,暂时无法提供与“QTH-020-01-F-D-DP-A-K”相匹配的价格&库存,您可以联系我们找货
    • 1+69.72480
    • 10+67.53240
    • 14+64.15578
    库存:10
    • 1+87.208621+11.28177
