REVISION J
J
REVISION
REF: SEAF-40-06.5-S-10-1-A-K-TR-VITA57
NOTES:
1. FILL ROWS 3, 4, 7, 8 ONLY, VITA 57 CONNECTOR.
2. NOTE DELETED.
3. C REPRESENTS A CRITICAL DIMENSION.
4. MINIMUM PUSHOUT FORCE: 0.50 LBS.
5. DIMENSION C8 MUST BE MEASURED IN THE FOUR OUTSIDE CORNERS USING
INSPECTION FIXTURE AT-1817-836-2, USE CO-AU-WI-2003-M FOR PROCESS.
6. MAXIMUM ROW TO ROW VARIATION .003[0.08],
MEASURED FIRST & LAST POSITIONS ONLY, ALL ROWS. C
7. ATTACH LABEL "SEAX-0001" TO EACH TAPE & REEL PACKAGE.
8. PARTS TO BE PACKAGED IN TAPE & REEL.
C
.009[.23]
C
.011 0.28
REF
.002±.003 0.05±0.08
(SEE NOTE 5 & 6)
2.229 56.62 REF
1.9500 49.530
.156 3.96 REF
.033 0.84 REF
3
.0500 1.270 (TYP)
.404 10.25
K
J
H
G
F
E
D
C
B
A
C
ACCEPTANCE OF DRAWING
ACCEPTED WITH DEVIATIONS LISTED
.461 11.71
REF
.039±.020 0.98±0.51
.930±.020 23.62±0.51
C
2
.035 0.90
REF
C
"B"
.0175±.0030 0.445±0.08
C
.0645 1.638
(TYP)
.0530 1.346
.040 1.02
REF
.258 6.55 REF
(INCLUDES K-DOT)
1.9500 49.530
C
C
SECTION "B"-"B"
SCALE 2.5 : 1
"B"
'C'
2.1410 54.381
.034 0.86 REF
'A'
FAX No:
.044 1.12 REF
PHONE No:
PRINTED NAME
CUSTOMER SIGNATURE
1
.300 7.62
REF
C
.050 1.27 REF
.044 1.12 REF
COMPANY:
C
.035±.005 0.89±0.13
(TYP)
.017 0.42
C
L
REF
.050 1.27 REF
2.170 55.12 REF
.050 1.27 (TYP)
DATE:
.100 2.54
REF (TYP)
01
40
.521 13.23
REF
DETAIL 'C'
SCALE 6 : 1
.033 0.84
REF
C
CL
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ITEM NO.
PART NUMBER
QUANTITY
MATERIAL
1
SEAF-40-06.5-10-A
1.0000
LCP UL 94 V0, COLOR: BLACK
2
NEW-SUB-C-209-06.5-S-1
160.00
COPPER ALLOY / LEADED SOLDER
3
CT-SEAF028MS
1.0000
CONDUCTIVE POLYMER
4
K-DOT-.404-.500-.005
1.0000
POLYIMIDE FILM
ANGLES
.XX: .01[.3]
.XXX: .005[.13]
.XXXX: .0020[.051]
2
.120 3.05
REF
DETAIL 'A'
SCALE 3.5 : 1
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 1.75:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.050 PITCH SOCKET ARRAY ASSEMBLY
PLATING:
CONTACT AREA: .000030 GOLD OVER .000050 NICKEL
REMAINDER: .000200 REF TIN OVER .000050 NICKEL
DWG. NO.
F:\DWG\MISC\MKTG\ASP-127796-01-MKT.SLDDRW
BY: B. PERRY
ASP-127796-01
08/25/2006
SHEET 1 OF 4
RECOMMENDED PCB LAYOUT FOR ASP-127796-01
ASP-127796-01
REVISION J
2.141 54.38
1.950 49.53
.16 4.0 REF
.12 3.1 REF
CONNECTOR ASSEMBLY OUTLINE
.0500 1.270 (TYP)
CL
.22 5.6 REF
01
40
.1500 3.810
H
.52 13.2
REF
G
CL
.250 6.35
D
C
.120 3.05
.050 1.27
NPTH (2 PLCS)
.0955 2.426
.030 0.76 REF
.025 0.64 (TYP)
(SURFACE MOUNT PAD)
ALL DIMENSIONS SYMMETRIC ABOUT THE CENTERLINE
PROPRIETARY NOTE
SHEET SCALE: 1:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
ASP-127796-01
BY: B. PERRY
08/25/2006
SHEET 2 OF 4
RECOMMENDED STENCIL LAYOUT FOR ASP-127796-01
ASP-127796-01
REVISION J
NOTE:
STENCIL TO BE .0060[.152] THICK.
1.950 49.53
.0500 1.270
01
40
H
G
CL
.1500 3.810
D
C
.2500 6.35
CL
.035 0.89 (TYP)
PROPRIETARY NOTE
SHEET SCALE: 1:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
ASP-127796-01
BY: B. PERRY
08/25/2006
SHEET 3 OF 4
ASP-127796-01
REVISION J
A
.945 24.00 REF
(TYP)
01
4
2.835 72.00
REF
40
"D"
"D"
USER DIRECTION OF UN-REELING
POCKET NOT DETAILED
PROPRIETARY NOTE
SECTION "D"-"D"
PACKAGING VIEW
SHEET SCALE: 1.5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
ASP-127796-01
BY: B. PERRY
08/25/2006
SHEET 4 OF 4
很抱歉,暂时无法提供与“ASP-127796-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+130.35376200+16.89633
- 国内价格
- 1+203.66640
- 30+194.28120
- 国内价格
- 1+110.44000
- 2+104.94000
- 4+102.19000
- 8+100.81500
