ASP-129637-13
ASP-129637-13
    SAMTEC(申泰)
    VITA42SOCKETASSEMBLY
ASP-129637-13 数据手册
REVISION C DO NOT SCALE FROM THIS PRINT NOTES: 1. ITEMS 1, 2, 3, & 4 NOT AVAILABLE AS STANDARD. 2. REPRESENTS A CRITICAL DIMENSION. 3. MAXIMUM BURR ALLOWANCE: .0015[0.038] 4. MINIMUM PUSHOUT FORCE: SIGNAL: .5 LB, GROUND: 1 LB 5. MAXIMUM VARIANCE OF .002[0.05] 6. DIMENSION APPLIES TO CONTACTS & GROUND PLANES. 7. GROUND PLANE PRESS HEIGHT MUST BE .003[0.08] LESS THAN THE MAX HEIGHT OR .001[0.03] GREATER THAN THE MINIMUM HEIGHT OF THE TERMINAL. 8. MAXIMUM CUT FLASH: .010[0.25] 9. PARTS TO BE PACKAGED IN TRAYS. .625 15.88 26 POS - 1 @ .0250[.635] .1075 2.731 .090 2.29 REF 01 CL .286 7.26 REF 02 .009 0.23 REF (TYP) .010 0.25 REF .934 23.72 REF +.0040 "A" .408±.020 10.37±0.51 5 1 .212 5.38 REF .327 8.31 REF .735 18.67 REF +.0040 .040 1.02 REF (TYP) (SEE NOTES 5, 6, & 7) 2 3 .004[0.10] (SEE NOTE 6) +0.102 .3420 -.0020 8.688 -0.051 .347±.004 8.81±0.10 .105 2.67 REF "A" +0.102 .1150 - .0010 2.921 - 0.025 (MEASURED TERMINAL TO TERMINAL) .216 5.49 4 .290±.006 7.37±0.15 .022 0.56 REF .934 23.72 REF SECTION "A"-"A" ITEM NO. PART NUMBER QUANTITY MATERIAL 1 ASP-173281-01-B 1.0000 VECTRA E130i, COLOR: BLACK 2 ASP-129634-07-B 1.0000 VECTRA E130i, COLOR: BLACK 3 ASP-129635-02-P-S 52.000 PHOS BRONZE, 521 EXTRA SPRING TEMPER 4 ASP-129636-02-P-L 1.0000 PHOS BRONZE, 510 FULL HARD TEMPER 5 K-500-300 1.0000 POLYIMIDE FILM 6 TY-ASP145 1.0000 ANTI-STATIC BLACK HIPS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 PLATING: DO NOT SCALE DRAWING CONTACTS: CONTACT AREA: .000030 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL GROUND PLANE: CONTACT AREA: .000010 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL F:\DWG\MISC\MKTG\ASP-129637-13-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. MODIFIED ELEVATED QMS ASM ASP-129637-13 BY: J. BROWNING 06/26/2014 SHEET 1 OF 2 REVISION C RECOMMENDED PCB LAYOUT (ALL DIMENSIONS ARE SYMMETRIC ABOUT THE CENTERLINE) .735 18.67 .680 17.27 .625 15.88 02 .025 0.64 (TYP) .046 1.17 NPTH (TYP 2 PLCS) .320 8.13 .075 1.91 CL .020 0.51 .055 1.40 (TYP) 01 .016 0.41 (TYP) CL * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. F:\DWG\MISC\MKTG\ASP-129637-13-MKT.SLDDRW MODIFIED ELEVATED QMS ASM ASP-129637-13 BY: J. BROWNING 06/26/2014 SHEET 2 OF 2
ASP-129637-13 价格&库存
很抱歉,暂时无法提供与“ASP-129637-13”相匹配的价格&库存,您可以联系我们找货
ASP-129637-13
    • 65+98.23940
    • 130+83.50047
    • 260+78.70034
    • 520+68.84617
    • 1040+58.89528
    库存:10
    ASP-129637-13
    • 1+135.916641+17.66873
