BTH-120-01-L-D-A-K
BTH-120-01-L-D-A-K
    SAMTEC(申泰)
    SMD,P=0.5mm
    PIN:240P 间距:0.5MM 立贴
BTH-120-01-L-D-A-K 数据手册
BASIC BLADE & BEAM HEADER (0.50 mm) .0197" PITCH • BTH SERIES BTH BTH Mates: BSH - SPECIFICATIONS Lead-Free Solderable: Yes SMT Lead Coplanarity: Vertical= (0.10 mm) .004" max (030-090), (0.15 mm) .006" max (120-150)* Right-angle= (0.15 mm) .006" max (030-090)* *(.004” stencil solution may be available; contact IPG@samtec.com) Board Stacking: For applications requiring more than two connectors per board or 90 positions or higher, contact ipg@samtec.com -D-A- PLATING OPTION –F OTHER OPTION –K = Gold Flash on contact, Matte Tin on tail = (7.00 mm) .276” DIA Polyimide Film Pick & Place Pad –L –TR = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Tape & Reel (120 positions maximum) –C* (5.97) .235 (4.06) .160 –FR = Electro-Polished Selective 50 µ" (1.27 µm) min Au over 150 µ" (3.81 µm) Ni on Signal Pins in contact area, Matte Tin over 50 µ" (1.27 µm) min Ni on all solder tails (*–C Plating passes 10 year MFG testing) No. of Positions x (0.50) .01969 + (5.00) .197 = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) (120 positions maximum) MATED HEIGHT (4.27) .168 LEAD STYLE MATED HEIGHT* –01 BTH - ALSO AVAILABLE NO. OF POSITIONS PER ROW –030, –060,–090 MOQ Required 30 µ" (0.76 µm) Gold Edge Mount Capability 8 mm, 11 mm, 16 mm, 19 mm and 22 mm Stack Height (Caution: Some automatic placement/ inspection machines may have component height restrictions. Please consult machinery specifications.) (11 mm, 16 mm, 19 mm and 22 mm not available with 50 positions) - 01 - –030, –050, –060, –090, –120, –150 Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.0 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 175 VAC Max Cycles: 100 PROCESSING NO. OF POSITIONS PER ROW (5.00 mm) .1971" *Processing conditions will affect mated height. - 01 - PLATING OPTION - D - RA - WT - –F OTHER OPTION –K = Gold Flash on contact, Matte Tin on tail = (7.00 mm) .276” DIA Polyimide Film Pick & Place Pad –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail No. of Positions x (0.50) .01969 + (10.88) .428 (9.78) .385 (3.05) .120 10 YEAR MFG WITH 50 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES (8.85) .348 Note: Some lengths, styles and options are non-standard, non-returnable. samtec.com?BTH Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
BTH-120-01-L-D-A-K
- 物料型号:BTH系列,有多种选项,如-030, -050, -060, -090, -120, -150,以及不同的表面处理,如Gold Flash和Matte Tin。 - 器件简介:BTH系列是一种具有0.50mm间距的刀片和梁式连接器。 - 引脚分配:引脚数量根据型号不同而变化,引脚间距为0.50mm。 - 参数特性: - 电流额定值:每针2.0A(2针供电) - 工作温度范围:-55°C至+125°C - 电压额定值:175VAC - 最大周期数:100次 - 接触材料:磷青铜,镀金或锡 - 功能详解:文档提到了电抛光选择性镀金和锡,以及信号引脚的特定镀层要求。 - 应用信息:适用于需要高连接周期和长寿命产品的应用。 - 封装信息:提供了不同堆叠高度的边缘安装能力,以及不同数量的引脚位置。
BTH-120-01-L-D-A-K 价格&库存
很抱歉,暂时无法提供与“BTH-120-01-L-D-A-K”相匹配的价格&库存,您可以联系我们找货
BTH-120-01-L-D-A-K
    • 1+66.38760
    • 10+64.92960
    • 30+63.95760
    库存:5
