ASP-129646-22
ASP-129646-22
    SAMTEC(申泰)
    SMD,P=0.64mm
    板对板连接器 立贴 针脚数:52Pin 间距:0.64mm 排数:2
ASP-129646-22 数据手册
REVISION A NOTES: 1. CUSTOM BODY NOT AVAILABLE AS STANDARD. 2. REPRESENTS A CRITICAL DIMENSION. 3. MAXIMUM BURR ALLOWANCE: .0015[0.038] 4. MINIMUM PUSHOUT FORCE: SIGNAL: .5 LB, GROUND: 1 LB 5. MAX VARIANCE OF .002[0.05] 6. DIMENSION APPLIES TO CONTACTS & GROUND PLANE. 7. GROUND PLANE PRESS HEIGHT MUST BE .003[0.08] LESS THAN THE MAX HEIGHT OR .001[0.03] GREATER THAN THE MINIMUM HEIGHT OF THE CONTACT. 8. MAXIMUM CUT FLASH: .010[0.25] 9. PARTS TO BE PACKAGED IN TRAYS. DO NOT SCALE FROM THIS PRINT .946±.010 24.02±0.25 .625 15.88 (1 BANK x .8400[21.336]) - .2150[5.461] .083 2.10 REF .009 0.23 REF (TYP) 02 BY SIGNING THIS DOCUMENT YOU ARE ACCEPTING THE CONDITIONS SET WITHIN. YOUR REQUIREMENTS MUST BE LISTED WITHIN THIS DRAWING. WHERE NO DIRECTION FROM THE CUSTOMER IS IDENTIFIED SAMTEC'S PROCESS REQUIREMENTS WILL BE USED. .275 6.99 REF CL .320 8.13 REF 01 .004 0.10 .535 13.59 REF "A" 4 .134 3.40 (MEASURED CONTACT TO CONTACT) .173±.020 4.38±0.51 .431 10.95 REF 1 +.004 +0.10 .371 - .002 9.42 - 0.05 (SEE NOTES 5, 6 & 7) "A" .050 1.27 REF .004[0.10] (SEE NOTE 6) .040 1.02 REF (TYP) .686 17.42 REF EXCEPTIONS: PHONE No: PRINTED NAME: CUSTOMER SIGNATURE: COMPANY: DATE: 2 .051 1.30 REF SECTION "A"-"A" PICK & PLACE PAD NOT SHOWN FOR CLARITY .810 20.57 REF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: ITEM NO. PART NUMBER QUANTITY MATERIAL 1 ASP-144730-03-B 1.0000 VECTRA E130i, COLOR: BLACK 2 C-223-06.25-S 52.000 PHOS BRONZE 3 T-1G28-06.25-L 1.0000 PHOS BRONZE 4 PPP-51 1.0000 VECTRA E130, COLOR: BLACK 5 TY-ASP146 1.0000 BLACK HIPS 3 .320±.006 8.13±0.15 DECIMALS ANGLES .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] 2 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 DO NOT SCALE DRAWING PLATING: CONTACTS: CONTACT AREA: .000030 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL GROUND PLANE: CONTACT AREA: .000010 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL c:\enterprisevault\DWG\MISC\MKTG\ASP-129646-22-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. MODIFIED ELEVATED QFS ASP-129646-22 BY: J. BROWNING 06/26/2014 SHEET 1 OF 2 REVISION A RECOMMENDED PCB LAYOUT (ALL DIMENSIONS ARE SYMMETRIC ABOUT THE CENTERLINE) .985 25.02 .810 20.57 .710 18.03 .625 15.88 .025 0.64 (TYP) .046 1.17 NPTH (TYP 2 PLCS) 01 .590 14.99 .340 8.64 .080 2.03 CL .085 2.16 (TYP) .020 0.51 02 .016 0.41 (TYP) CL PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. MODIFIED ELEVATED QFS ASP-129646-22 BY: J. BROWNING 06/26/2014 SHEET 2 OF 2 c:\enterprisevault\DWG\MISC\MKTG\ASP-129646-22-MKT.SLDDRW
ASP-129646-22 价格&库存
很抱歉,暂时无法提供与“ASP-129646-22”相匹配的价格&库存,您可以联系我们找货
ASP-129646-22
  • 1+139.399421+18.06882
  • 10+128.9975710+16.72055
  • 25+118.6331125+15.37711
  • 50+103.1912650+13.37556
  • 100+96.75280100+12.54101
库存:219
ASP-129646-22
库存:60
ASP-129646-22
  • 60+100.73014
库存:119
ASP-129646-22
    • 1+106.36920
    • 10+103.17240
    库存:3
