FX8C-120/120S11-SV5J(95) 数据手册
0.6mm Pitch Stacking Height 3mm to 16mm Connectors
FX8/FX8C Series
Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
FX8 Series
FX8C Series
Note: that FX8 series and FX8C series are not mated with each other.
Features
1. Stacking Height: 3mm to 16mm
●Stacking Height 3,4mm-FX8 Series
Stacking height of mated connectors ranges from
3mm to 16mm. (Fig.1.2)
2. SMT Coplanarity
The coplanar tolerance at the solder area is less
than 0.1mm.
3,4mm
3. Mating Guide
Built-in guide ribs and a chamfer allow for ±0.6
mm of mis-alignmet and ensures easy mating.
Fig.1
4. Mis-insertion Prevention
Bosses located on the bottom side of the connector
differ in position and diameter to prevent mis-orientating
the parts on the board.
●Stacking Height 5 to 16mm-FX8C Series
5. Dual Connected Products
In order to enhance mounting reliability and
a c c u ra c y w h e n m o u n t i n g t wo o f t h e s a m e
connectors at the same time, Hirose offers the
option of having two connectors attached to one
another by means of a spacer. Pitch between the
two connectors is 11mm.
5 to 16mm
Fig.2
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2018.6④
1
FX8/FX8C Series●0.6mm Pitch Stacking Height 3mm to 16mm Connectors
FX8 Series
Product Specifications
Rating
Operating Temperature Range -55ç to +85ç (Note 1) Storage Temperature Range -10ç to +60ç(Note 2)
Current rating 0.4A
Storage Humidity Range 40% to 70%(Note 2)
Voltage rating 100V AC Operating Humidity Range -40% to 80%
Items
1. Insulation Resistance
2. Withstanding voltage
3. Contact Resistance
Specifications
1000Mø min
No flashover or insulation breakdown.
45mø max.
Conditions
250V DC
300V AC/1 min
100mA
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
2 hours in each of the 3 axis directions.
4. Vibration
No electrical discontinuity of 1µs or more
5. Humidity (Steady state)
Contact resistance : 55mø max. : Insulation
resistance : 100Mø min.
7. Mating Cycles
8. Resistance to Soldering No deformation of components affecting
heat
performance.
6. Temperature Cycle
96 hours at 40ç and humidity of 90% to 95%
(-55ç : 30 minutes, 15 to 35ç : 2 to 3 minutes
85ç : 30 minutes, 15 to 35ç : 2 to 3 minutes) 5 cycles
50 cycles
Reflow : At the recommended temperature profile
Manual soldering : 360ç for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity range includes the non conducting condition in storage, shipment or during transportation.
Material / Finish
Part
Insulator
Material
PPS
Finish
Remarks
Light brown
UL94V-0
Contact area
Gold plated
Header Contact
Lead area
Tin (Note 2)
Phosphor bronze
Contact area
Receptacle Contact
Gold plated
Lead area
Note 1 : Slight color difference to the resin may occur. This will not affect fit, form or function of the connector.
Note 2 : FX8-*P-SV is gold plated.
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Single Product
Mating Sectional View
FX8 - 120 P - SV 1 (92)
1
2
3
4
5
6
q Series Name : FX8
w No. of contacts : 60, 80, 90, 120, 140
e Connector type
r Contact type
P : Header
S : Receptacle
SV : Board vertical type
t Product height variation : none= standard (minimum low profile)
1 : +1mm
y Package Form
None, (71) : Tray package product
(21), (91) : Tube packaging product
(22), (92) : Emboss tape package product
(The above illustration represents the stacking height 3mm type.)
●Single Product
FX8-**S-SV
2
FX8-**P-SV
3mm
FX8-**P-SV1
4mm
3 to 4
BStacking Height Variation
A±0.3
Header
B +0.05
_0.2
C +0.05
_0.2
[FX8-**P-SV]
D±0.2
(C1)
Polarization mark
(Ø0.9)
t0.2±0.03∞w0.25±0.03
E±0.1
(2.4)
(Ø0.6)
2-(C0.2)
(1.5)
(2.4)
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
E
FX8-60P-SV(**)
578-0001-6 **
60
24.60
23.00
20.70
17.40
22.20
FX8-80P-SV(**)
578-0003-1 **
80
30.60
29.00
26.70
23.40
28.20
FX8-90P-SV(**)
578-0004-4 **
90
33.60
32.00
29.70
26.40
31.20
FX8-100P-SV(**)
578-0005-7 **
100
36.60
35.00
32.70
29.40
34.20
FX8-120P-SV(**)
578-0006-0 **
120
42.60
41.00
38.70
35.40
40.20
FX8-140P-SV(**)
578-0007-2 **
140
48.60
47.00
44.70
41.40
46.20
RoHS
Yes
** 71 : Tray packaging, 91 : Tube packaging, 92 : Embossed tape packaging
Note 1 : Please place orders in full magazine/tube quantities.
Note 2 : Reels are sold containing 1,000 pcs/reel. Please refer to the delivery form on page 6 for details.
Note 3 : Please note that tray packaged parts are not suitable for use with automatic mounting processes.
A±0.3
B +0.05
_0.2
[FX8-***P-SV1]
C +0.05
_0.2
D±0.2
0.6±0.1
(0.75)
6.5 _0.3
3.45±0.25
(0.4) 5.1±0.3
(0.75)
2.45±0.25 6.5 _0.3
5.1±0.3
(0.4)
0.6±0.1
(1)
Polarization mark
(Ø0.9)
(Ø0.6)
E±0.1
(2.4)
2-(C0.2)
(1.5)
(2.4)
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
E
FX8-60P-SV1(**)
578-0041-0 **
60
24.60
23.00
20.70
17.40
22.20
FX8-80P-SV1(**)
578-0043-6 **
80
30.60
29.00
26.70
23.40
28.20
FX8-90P-SV1(**)
578-0044-9 **
90
33.60
32.00
29.70
26.40
31.20
FX8-100P-SV1(**)
578-0045-1 **
100
36.60
35.00
32.70
29.40
34.20
FX8-120P-SV1(**)
578-0046-4 **
120
42.60
41.00
38.70
35.40
40.20
FX8-140P-SV1(**)
578-0047-7 **
140
48.60
47.00
44.70
41.40
46.20
RoHS
Yes
Note 2 : The embossed tape packaged parts are available for all pin counts, except the 140 pin count. Reels are sold containing
1,000 pcs/reel. Please refer to the delivery form on page 15 for details.
3
Receptacle
A±0.3
B +0.2
C +0.2
[FX8-**S-SV]
(1)
D±0.2
2.25±0.25
(0.75)
7_0.3
5.6±0.3
0.6±0.1
Polarization mark (Back side)
t0.2±0.03∞w0.25±0.03 (Ø0.6)
(Ø0.9)
E±0.1
(2.4)
2-(C0.2)
(1.8)
(2.4)
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
E
FX8-60S-SV(**)
578-0201-5 **
60
24.60
23.05
20.80
17.40
22.20
FX8-80S-SV(**)
578-0203-0 **
80
30.60
29.05
26.80
23.40
28.20
FX8-90S-SV(**)
578-0204-3 **
90
33.60
32.05
29.80
26.40
31.20
FX8-100S-SV(**)
578-0205-6 **
100
36.60
35.05
32.80
29.40
34.20
FX8-120S-SV(**)
578-0206-9 **
120
42.60
41.05
38.80
35.40
40.20
FX8-140S-SV(**)
578-0207-1 **
140
48.60
47.05
44.80
41.40
46.20
RoHS
Yes
** None : Tray packaging, 21 : Tube packaging, 22 : Embossed tape packaging
PCB Mounting Pattern
4
Header
Receptacle
・Recommended metal mask thickness : t = 0.15mm
・If the inside (the connector mounting lower side) of the SMT portion is not
treated with the insulation tape and so on, the area is specified as a pattern prohibited area.
Connector Precautions for use
1. Tolerance Clearance on the Mating Side
The effective contact length of the product is set to 0.7mm. Please make sure there is less than 0.2mm
clearance between the header and receptacle during mating.
2. Support between the PCBs
Please be sure to fix the boards to each other with screws or other means of support. Do not use only the
mated connector to support the boards.
Stack 3mm
3 +0.3
_0.2 mm
Stack 4mm
4 +0.3
_0.2 mm
Note : Please Note that the above stacking tolerance doesn't include the solder paste thickness.
4. Multiple mounting on same PCB is not recommended in principle
5. Mounting Temperature Profile (Reference)
260
(MAX 250ç)
240
220ç
220
200ç
200
Temperature
3. Stacking Height Tolerance for Mating
180
160
140
150ç
(ç)
90 to 120s
Pre-heating time
(150 to 200ç)
MAX 60s
Soldering Time
(220ç min.)
Time (Second)
HRS test conditions
Test boardGlass epoxy 161mm∞100mm∞1.6mm thick
Solder method
: Reflow
Solder composition : Paste, 96.5%Sn/3%Ag/0.5%Cu
Metal mask
: 0.15mm thick
Reflow cycles
: 2 cycles
The temperature profile is based on the above
conditions.
In individual applications the actual temperature
may vary, depending on solder paste type, volume/
thickness and board size/thickness. Consult your
solder paste and equipment manufacturer for
specific recommendations.
5
Packaging Type
Packaging Type
Tube packaging
No. of contacts
60
contacts
80
contacts
90
contacts
100
contacts
120
contacts
140
contacts
Pieces per tube
21 pcs
17 pcs
15 pcs
14 pcs
12 pcs
10 pcs
Sales unit
Per tube. Please place orders in full magazine/tube quantities.
Tube Total Length
550mm±2mm
Tape Width
Embossed Tape
Packaging
44mm
44mm
44mm
56mm
56mm
Product Pitch
12mm
Embossed Reel diameter
Refer to the table on catalog page 6.
Pieces per reel
1000 pcs/reel
Sales unit
Per reel
72mm
* The chart above applies only to individual connectors.
Dual connected products are packaged and shipped in trays only.
Packaging Specification
[Tube packaging]
Receptacle
[FX8-**S-SV (21)]
Header
[FX8-**P-SV (91)]
[FX8-**P-SV1 (91)]
(7.2)
(5.2)
550±2
(9.8)
(9.7)
550±2
Polarity mark
Marking
Polarity mark
Marking
[Embossed Tape Package]
Embossed Carrier Tape Dimensions
Unreeling direction
Ø1
E
Ø80
.5
Ø1
(1.7)
Termination
Installation area: Leader area
(400mm min.)
section
End Contact area
(The product includes 1000 pieces.)
Space
(More than 10 pockets)
A
B
1.5
44.4[56.4][72.4]
3
2
20.2 [26.2][34.2]
4
1.75
12
2
C
0.4
40.4 [52.4][68.4]
44 [56][72]
D
Reel Dimensions (FREE)
Emboss tape
Space
Cover tape
(10 pockets min.)
*The figure above shows the receptacle in its pocket.
Unit : mm
P/S
Header
Receptacle
Part No.
FX8-**P-SV (92)
FX8-**P-SV1 (92)
FX8-**S-SV (22)
** : No. of contacts
Note 1 : Ø 330 are for 60, 80 and 90 contacts.
Ø 360 are for 100, 120 and 140 contacts.
6
A
B
5.5
7.9
6.0
8.4
C
D
3.2
4.2
2.6
E
Ø 330
12
(Note 1)
Ø 330
FX8C Series
Ratings
Rated current : 0.4A
Operation temperature range : -55 to +85°C (Note 1) Storage temperature range : -10 to +60°C (Note 2)
Rated voltage : AC 100V Operation humidity range : 40 to 80%
Storage humidity range : 40 to 70% (Note 2)
Items
1. Insulation resistance
2. Withstand voltage
3. Contact resistance
4. Vibration proof
5. Moisture resistance
6. Temperature cycle
7. Mating cycles
8. Soldering heat
resistance
Specifications
Min of 100Mø
No flashover or dielectric breakdown.
Max of 80Mø
No electrical discontinuity lasting for a min
of 1μs.
Conditions
Measured at 250 V DC
300V AC for 1 minute
Measured at 100 mA
10 to 55Hz, half amplitude : 0.75mm,
3 axis directions, 10 cycles each.
Contact resistance : a max of 100mø ;
Insulation resistance : a min of 100Mø
Left for 96 hours at the temperature of 40 ±2°C
and the humidity of 90 to 95%
Insulation resistance : a min of 100ø
No dissolution of the resin affecting
performance.
(-55°C for 30 minutes → 15 to 35°C for 2 to 3 minutes → 85°C
for 30 minutes → 15 to 35°C for 2 to 3 minutes) in 5 cycles
50 times
Reflow : With recommended temperature profile, at
the soldering iron temperature of 350°C for 5 seconds
Note 1 : Includes the temperature rise caused by current flow.
Note 2 : Storage as described here represents the long-term-storage status of unused items before they are mounted on PCB.
Operation humidity range applies to the unpowered status after the items are mounted on PCB.
Note 3 : The contact resistance noted above is measured using a connector combination with a 16mm stack height.
Material / Finish
Part name
Insulator
Material
PPS resin
Treatment
Light brown
Remarks
UL94V-0
Contact area
Gold plating
Lead area
Pure tin plating (Note 2)
Phosphor bronze
Contact area
Gold plating
Receptacle contact
Lead area
Note 1 : Black dots or other color irregularities may occur in the insulator resin. In addition, the color may change if exposed to
sunlight or florescent light. But this does not affect the quality or performance.
Note 2 : FX8C-*P-SV (*) and FX8C-*S-SV are gold plated.
Header contact
●Single Product
FX8C - 120 P - SV 1 (91)
1
2
3
4
5
6
t Variable product height : None : Standard (Minimum height product)
1 : +1mm 6 : +6mm
y Packaged state
(71) : Tray packaging
(68), (91) : Magazine/tube packaging
(92) : Embosses tape packaging
(93) : Vacuum tape, embosses tape packaging
q Series name : FX8C
w No. of contacts : 60, 80, 100, 120, 140
e Connector type : P : Header
S : Receptacle
r Contact form : SV : Vertical PCB type
●Two-connected products
FX8C - 120/120 P 11 - SV 1 J
1
2
3
4
5
6
7
r Pitch between dual connected products
t Contact form : SV : Vertical PCB type
w No. of contacts : 60∞2, 80∞2, 100∞2, 120∞2, 140∞2
Example
: 120/120=240 contacts
y Variable product height : None : Standard (Minimum height product)
1 : +1mm 6 : +6mm
u J : Dual connected product
S : Receptacle
*Dual connected products are packed in trays as the standard delivery method.
7
Stacking Height Variations
Receptacle
FX8C-**P-SV
FX8C-**/**P11-SVJ
FX8C-**P-SV1
FX8C-**/**P11-SV1J
FX8C-**P-SV2
FX8C-**/**P11-SV2J
FX8C-**P-SV4
FX8C-**/**P11-SV4J
FX8C-**P-SV6
FX8C-**/**P11-SV6J
FX8C-**S-SV
FX8C-**/**S11-SVJ
FX8C-**S-SV5
FX8C-**/**S11-SV5J
5mm
10mm
6mm
11mm
7mm
12mm
9mm
14mm
11mm
16mm
5 to 16
Header
(2)Effective
mating length
(Stacking height)
(2)Effective
mating length
8
A±0.25
B +0.05
– 0.2
C +0.05
– 0.2
Header (Single Product)
D±0.2
6.5 _0.3
5.1±0.3
P±0.6±0.1
(C1)
4.45±0.25 (0.4)
[FX8C-**P-SV]
Polarity mark
E±0.1
(0.75)
(Ø0.9)
2-(C0.2)
(2.4)
(1.5)
(2.4)
HRS No.
578-0501-9 **
578-0503-4 **
578-0505-0 **
578-0506-2 **
578-0507-5 **
No. of contacts
60
80
100
120
140
A
24.60
30.60
36.60
42.60
48.60
B
23.00
29.00
35.00
41.00
47.00
C
20.70
26.70
32.70
38.70
44.70
D
17.40
23.40
29.40
35.40
41.40
E
22.20
28.20
34.20
40.20
46.20
RoHS
Yes
Note 1 : Embossed tape packaging product are sold in full reel quantities. For details, see the item showing delivery forms in Page 16.
Note 2 : Please place orders in full magazine/tube quantities.
A±0.3
B +0.05
– 0.2
C +0.05
– 0.2
D±0.2
(0.4)
5.1±0.3
6.5 _0.3
P=0.6±0.1
(C1)
Polarity mark
F±0.25
[FX8C-**P-SV1]
[FX8C-**P-SV2]
[FX8C-**P-SV4]
[FX8C-**P-SV6]
(0.75)
Unit : mm
Part No.
FX8C-60P-SV(**)
FX8C-80P-SV(**)
FX8C-100P-SV(**)
FX8C-120P-SV(**)
FX8C-140P-SV(**)
(Ø0.9)
E±0.1
(1.5)
(Ø0.6)
(2.4)
(2.4)
2-(C0.2)
Unit : mm
Part No.
FX8C-60P-SV1(**)
FX8C-60P-SV2(**)
FX8C-60P-SV4(**)
FX8C-60P-SV6(**)
FX8C-80P-SV1(**)
FX8C-80P-SV2(**)
FX8C-80P-SV4(**)
FX8C-80P-SV6(**)
FX8C-100P-SV1(**)
FX8C-100P-SV2(**)
FX8C-100P-SV4(**)
FX8C-100P-SV6(**)
FX8C-120P-SV1(**)
FX8C-120P-SV2(**)
FX8C-120P-SV4(**)
FX8C-120P-SV6(**)
FX8C-140P-SV1(**)
FX8C-140P-SV2(**)
FX8C-140P-SV4(**)
FX8C-140P-SV6(**)
HRS No.
578-0521-6 **
578-0541-3 **
578-0581-8 **
578-0601-3 **
578-0523-1 **
578-0543-9 **
578-0583-3 **
578-0603-9 **
578-0525-7 **
578-0545-4 **
578-0585-9 **
578-0605-4 **
578-0526-0 **
578-0546-7 **
578-0586-1 **
578-0606-7 **
578-0527-2 **
578-0547-0 **
578-0587-4 **
578-0607-0 **
No. of contacts
A
B
C
D
E
60
24.60
23.00
20.70
17.40
22.20
80
30.60
29.00
26.70
23.40
28.20
100
36.60
35.00
32.70
29.40
34.20
120
42.60
41.00
38.70
35.40
40.20
140
48.60
47.00
44.70
41.40
46.20
F
5.45
6.45
8.45
10.45
5.45
6.45
8.45
10.45
5.45
6.45
8.45
10.45
5.45
6.45
8.45
10.45
5.45
6.45
8.45
10.45
RoHS
Yes
Note 3 : For FX8C-**P-SV6 connectors, there is a spacer attached between the leads. Please request the specific drawing for clarification.
Note 4 : Please note that tray packaged parts are not suitable for use with automatic mounting processes.
9
Receptacle (Single Product)
(C1)
7_0.3
5.6±0.3
P=0.6±0.1
A±0.3
B +0.2
C +0.2
D±0.2
Polarity mark (back)
3.95±0.25
[FX8C-**S-SV]
(0.75)
(Ø0.9)
E±0.1
(Ø0.6)
(2.4)
2-(C0.2)
(1.8)
(2.4)
Unit : mm
Part No.
FX8C-60S-SV(**)
FX8C-80S-SV(**)
FX8C-100S-SV(**)
FX8C-120S-SV(**)
FX8C-140S-SV(**)
HRS No.
578-0801-2 **
578-0803-8 **
578-0805-3 **
578-0806-6 **
578-0807-9 **
No. of contacts
60
80
100
120
140
A
24.60
30.60
36.60
42.60
48.60
B
23.05
29.05
35.05
41.05
47.05
C
20.80
26.80
32.80
38.80
44.80
D
17.40
23.40
29.40
35.40
41.40
E
22.20
28.20
34.20
40.20
46.20
RoHS
Yes
A±0.3
B +0.2
C +0.2
D±0.2
P=0.6±0.1
7_0.3
5.6±0.3
(C1)
[FX8C-**S-SV5]
(0.75)
8.95±0.25
(Ø0.9)
E±0.1
(2.4)
Part No.
FX8C-60S-SV5(**)
FX8C-80S-SV5(**)
FX8C-100S-SV5(**)
FX8C-120S-SV5(**)
FX8C-140S-SV5(**)
HRS No.
578-0821-0 **
578-0823-5 **
578-0825-0 **
578-0826-3 **
578-0827-6 **
No. of contacts
60
80
100
120
140
2-(C0.2)
(1.8)
(2.4)
A
24.6
30.6
36.6
42.6
48.6
B
23.05
29.05
35.05
41.05
47.05
C
20.8
26.8
32.8
38.8
44.8
Unit : mm
D
17.4
23.4
29.4
35.4
41.4
E
22.2
28.2
34.2
40.2
46.2
RoHS
Yes
BRecommended PCB layout and metal mask dimensions for single connector (mounting side)
Header
Receptacle
[FX8C-**P-SV*]
[FX8C-**S-SV, SV5*]
Polarity mark
position
Polarity mark position
*Recommended metal mask thickness : t = 0.15mm
10
*The inside of SMT land (bottom of the connector being mounted)
will be a patterning restricted area if no treatment such as
insulation tape is applied.
(FX8C-**S-SV, SV5 are not applicable.)
A±0.3
B±0.3
C +0.05
– 0.2
D +0.05
– 0.2
Header (Dual Connected Product)
(3.35)
(16.1)
(11)
[FX8C-**/**P11-SVJ]
E±0.2
Polarity mark
(4.5)
F±0.1
HRS No.
578-0651-1 71
578-0653-7 71
578-0655-2 71
578-0656-5 71
578-0657-8 71
No. of contacts
60×2
80×2
100×2
120×2
140×2
A
31.70
37.70
43.70
49.70
55.70
B
24.70
30.70
36.70
42.70
48.70
C
23.00
29.00
35.00
41.00
47.00
D
20.70
26.70
32.70
38.70
44.70
E
17.40
23.40
29.40
35.40
41.40
F
22.20
28.20
34.20
40.20
46.20
RoHS
Yes
Note : Dual connected products are packaged and shipped in trays. And as such, are not suitable for use with automatic mounting processes.
A±0.3
B±0.3
C+0.05
– 0.2
+0.05
D – 0.2
E±0.2
(16.1)
(11)
[FX8C-**/**P11-SV1J]
[FX8C-**/**P11-SV2J]
[FX8C-**/**P11-SV4J]
[FX8C-**/**P11-SV6J]
Polarity mark
(G)
Unit : mm
Part No.
FX8C-60/60P11-SVJ(71)
FX8C-80/80P11-SVJ(71)
FX8C-100/100P11-SVJ(71)
FX8C-120/120P11-SVJ(71)
FX8C-140/140P11-SVJ(71)
F±0.1
(4.5)
Unit : mm
Part No.
HRS No.
FX8C-60/60P11-SV1J(71)
FX8C-60/60P11-SV2J(71)
FX8C-60/60P11-SV4J(71)
578-0671-9 71
578-0691-6 71
578-0731-9 71
FX8C-60/60P11-SV6J(71)
FX8C-80/80P11-SV1J(71)
FX8C-80/80P11-SV2J(71)
FX8C-80/80P11-SV4J(71)
FX8C-80/80P11-SV6J(71)
FX8C-100/100P11-SV1J(71)
FX8C-100/100P11-SV2J(71)
FX8C-100/100P11-SV4J(71)
FX8C-100/100P11-SV6J(71)
FX8C-120/120P11-SV1J(71)
FX8C-120/120P11-SV2J(71)
FX8C-120/120P11-SV4J(71)
FX8C-120/120P11-SV6J(71)
FX8C-140/140P11-SV1J(71)
FX8C-140/140P11-SV2J(71)
FX8C-140/140P11-SV4J(71)
FX8C-140/140P11-SV6J(71)
578-0751-6 71
578-0673-4 71
578-0693-1 71
578-0733-4 71
578-0753-1 71
578-0675-0 71
578-0695-7 71
578-0735-0 71
578-0755-7 71
578-0676-2 71
578-0696-0 71
578-0736-2 71
578-0756-0 71
578-0677-5 71
578-0697-2 71
578-0737-5 71
578-0757-2 71
No. of
contacts
60×2
A
B
C
D
E
F
31.70 24.70 23.00 20.70 17.40 22.20
80×2
37.70 30.70 29.00 26.70 23.40 28.20
100×2
43.70 36.70 35.00 32.70 29.40 34.20
120×2
49.70 42.70 41.00 38.70 35.40 40.20
140×2
55.70 48.70 47.00 44.70 41.40 46.20
G
H
4.35
5.35
7.35
5.45
6.45
8.45
9.35
4.35
5.35
7.35
9.35
4.35
5.35
7.35
9.35
4.35
5.35
7.35
9.35
4.35
5.35
7.35
9.35
10.45
5.45
6.45
8.45
10.45
5.45
6.45
8.45
10.45
5.45
6.45
8.45
10.45
5.45
6.45
8.45
10.45
RoHS
Yes
Note 1 : Dual connected products are packaged and shipped in trays. And as such, are not suitable for use with automatic mounting processes.
Note 2 : For FX8C- / P11-SV6J connectors, there is a spacer attached between the leads. Please request the specific drawing for clarification.
11
A±0.3
B±0.3
■Receptacle (Dual Connected Product)
E±0.2
(3.4)
(16.6)
(11)
[FX8C-**/**S11-SVJ]
C +0.2
D +0.2
F±0.1
(4)
Unit : mm
Part No.
FX8C-60/60S11-SVJ(71)
FX8C-80/80S11-SVJ(71)
FX8C-100/100S11-SVJ(71)
FX8C-120/120S11-SVJ(71)
FX8C-140/140S11-SVJ(71)
HRS No.
578-0901-7 71
578-0903-2 71
578-0905-8 71
578-0906-0 71
578-0907-3 71
No. of contacts
60×2
80×2
100×2
120×2
140×2
A
31.70
37.70
43.70
49.70
55.70
B
24.60
30.60
36.60
42.60
48.60
C
23.05
29.05
35.05
41.05
47.05
D
20.80
26.80
32.80
38.80
44.80
E
17.40
23.40
29.40
35.40
41.40
F
22.20
28.20
34.20
40.20
46.20
RoHS
Yes
[FX8C-**/**S11-SV5J]
A±0.3
B±0.3
C +0.2
D +0.2
(11)
E±0.2
(8.4)
F±0.1
(4)
Unit : mm
Part No.
FX8C-60/60S11-SV5J(71)
FX8C-80/80S11-SV5J(71)
FX8C-100/100S11-SV5J(71)
FX8C-120/120S11-SV5J(71)
FX8C-140/140S11-SV5J(71)
HRS No.
578-0921-4 71
578-0923-0 71
578-0925-5 71
578-0926-8 71
578-0927-0 71
No. of contacts
60×2
80×2
100×2
120×2
140×2
A
31.70
37.70
43.70
49.70
55.70
B
24.60
30.60
36.60
42.60
48.60
C
23.05
29.05
35.05
41.05
47.05
D
20.80
26.80
32.80
38.80
44.80
E
17.40
23.40
29.40
35.40
41.40
F
22.20
28.20
34.20
40.20
46.20
RoHS
Yes
BRecommended PCB layout and metal mask dimensions for dual connected products (mounting side)
Header
Receptacle
[FX8C-**/**P 11-SVJ, SV1J]
[FX8C-**/**S 11-SVJ, SV5J]
*Recommended metal mask thickness : 0.15mm
12
*Recommended metal mask thickness: t = 0.15mm
(FX8C-**/**S11-SV5J is not applicable.)
BDetailed drawing on dual connected products after the spacers are removed
(individual connector from dual connected product)
Header
Polarity mark
Polarity mark
Receptacle
13
BHow to Use the Connector
1. Permissible gap between mating surfaces
The effective mating length of this product is 2.0mm. Please make sure that the gap between the header
and receptacle when mated will be 1.2mm or less.
2. Fixation between mounted PCBs
If the connector is secured to the board with only other connectors, please make sure that no vibrations or
impact will occur.
3. Tolerances in stacking height when mated
Stack
Amm
A
+0.3
−0.2
mm
Note: Please note that the thickness of solder cream is not taken into account for the above tolerances in
stacking height.
4. Using dual connected products
Dual connected products are fixed with spacers on both longitudinal sides. However, the products cannot
be mated in that state. Please make sure to remove the spacers before mating. (Please do not remove the
spacers before mounting on PCB.)
spacers
Coupler
(joint)
Before removing the joint bar
After removing the joint bar
Note : Please use dual-connected products for multiple mounting.
However, multiple mounting of dual-connected products are not recommended.
5. Temperature profile for mounting (reference)
(Peak temperature : Max 250ç)
260
240
220ç
220
200ç
Temperature (ç)
200
Reflow method
Reflow with infrared light and heat
(SENSBEY NR-II)
Environment in the
reflow furnace
Ambient air
180
160
140
Solder
150ç
PCB
(90 to 120 seconds)
Preheating period
(150 to 200ç)
Within 60 seconds
Soldering period
(a minimum of 220ç)
6. Usage Recommendations
Metal mask thickness
Cream type (Sn-3Ag-0.5Cu)
(Flux contained amount : 11 Wt%)
(M705-221CM5-42-10.5
manufactured by Senju Metal
Industry Co., Ltd.)
Size 161 ∞ 100 ∞ 1.6mm
Material : Glass epoxy
Thickness : 0.15mm
Note 1 : This temperature profile shows recommended values.
Temperature should be measured on the top of the
connector.
Note 2 : The reflow process should be limited to two times.
Note 3 : Results may differ depending on the type and
manufacturer of solder cream, PCB size, mounting
materials and other conditions. Please be sure to
confirm the mounting conditions before use.
This product has been thin-formed for minimization.
Care should be taken that excessive prying mating/unmating could cause damage and contact failure.
14
BForm of Delivery
Packaging style
No. of contacts
Product quantity
Magazine packaging
Sales unit
Overall magazine length
Tape width (JIS)
Product pitch
Embossed tape packaging Embossed reel diameter
Product quantity
Sales unit
60 contacts
80 contacts 100 contacts 120 contacts 140 contacts
21 pieces
17 pieces
14 pieces
12 pieces
10 pieces
550mm ± 2mm
44
56
72
(12mm)
Please see the table shown in Page 16 of this catalog.
Full reels. Please see the table shown in page 16 of this catalog.
**The chart above applies only to individual connectors.
Dual connected products will be packaged and delivered in trays.
BPackaging Specification
[Magazine Packaging]
●Header
[FX8C-**P-SV(91)]
[FX8C-**P-SV1(91)]
[FX8C-**P-SV2(91)]
[FX8C-**P-SV4(91)]
[FX8C-**P-SV6(91)]
Polarity mark
Marking
●Receptacle
[FX8C-**S-SV(68)]
[FX8C-**S-SV5(91)]
Polarity mark
Marking
P/S
Header
Receptacle
Part No.
FX8C-**P-SV(91)
FX8C-**P-SV1(91)
FX8C-**P-SV2(91)
FX8C-**P-SV4(91)
FX8C-**P-SV6(91)
FX8C-**S-SV(68)
FX8C-**S-SV5(91)
A
9
10
11
13
15
7.4
12.4
15
[Embossed Tape Packaging]
●Carrier Dimensions
●Reel Dimensions
Unreeling direction
0.4 or 0.5
4
.5
Ø1
Reel dimensions
44.4[56.4][72.4]
E
Ø80*1
40.4 [52.4] [68.4]
44 [56] [72]
Termination
Leader (400 mm or longer)
1.7 +0.15
Powered by TCPDF (www.tcpdf.org)
2
Ø13
2
1.75
C
20.2 [26.2][34.2]
D
Ø2
1
12
1.5
A
B
Cavity
(10 pockets or more)
The figure above shows FX8 receptacles packaged on a
embossed tape. Dimensions shown in brackets [ ] are those
for tape widths of 56mm or 72mm.
Embossed tape
Cavity
Cover tape
*1 For FX8C-140S-SV(92), E dimension is 370 in diameter
and core dimension is 100 in diameter.
*2 For FX8C-120P-SV2(92), FX8C-120S-SV5(92), and
FX8C-140S-SV5(92), E dimension is 380 in diameter.
Note : Some products are not available packaged on an embossed tape.
Please be sure to clarify the packaging type before you order.
Unit : mm
P/S
Part No.
FX8C-**P-SV(92)
FX8C-**P-SV1(92)
FX8C-**P-SV2(92)
FX8C-**P-SV4(92)
FX8C-**P-SV6(92)
FX8C-**S-SV(92)
FX8C-**S-SV5(92)
Header
Receptacle
A
B
C
D
E
5.5
5.5
5.5
5.5
5.5
6.0
6.0
7.9
7.9
7.9
7.9
7.9
8.4
8.4
5.2
6.2
7.2
9.2
11.2
4.3
9.3
1.2
1.2
1.2
1.2
1.2
1.2
1.2
Ø370
Ø370
Ø330
Ø370
Ø370
Ø330
Ø370
Product
quantity
1000 pcs/reel
1000 pcs/reel
500 pcs/reel *2
500 pcs/reel
500 pcs/reel
1000 pcs/reel *1
500 pcs/reel *2
16
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 06/2018. Contents are subject to change without notice for the purpose of improvements.
