ASP-103612-05
ASP-103612-05
    SAMTEC(申泰)
    SMD,P=1.27mm
    板对板连接器 立贴 针脚数:114Pin 间距:1.27mm 排数:6
ASP-103612-05 数据手册
NOTES: 1. ASP-103597-01-B BODY FOR NON-STANDARD 19 POSITION. 2. C REPRESENTS A CRITICAL DIMENSION. 3. MAXIMUM BURR ALLOWANCE: .0005[0.013] C 4. MINIMUM PUSHOUT FORCE: .5 LB 5. CONTACT TO BE FLUSH TO ±.002[0.05] RECESSED. 6. ONE REEL MINIMUM PLATING REQUIREMENT (85,000 CONTACTS PER REEL). 7. ALL DIMS TO BE SYMMETRICAL ABOUT THE CENTERLINE WITHIN ±.001[0.03]. 8. MAXIMUM VARIATION BETWEEN SOLDERBALLS: .0025[0.064] 9. REFER TO VISUAL INSPECTION BOARD FOR SOLDERBALL APPEARANCE CHECKS. 10. THE DISTANCE FROM THE CENTER OF ANY SOLDERBALL TO THE CENTER OF ANY ADJACENT INNER PEG SHALL BE .025±.005[0.64±0.13]. 11. SOLDER JOINTS TO BE INSPECTED PER IPC SPECIFICATION 12.2.12 (IPC-A-610C). 12. PARTS TO BE PACKAGED IN TAPE & REEL. FOR QTY'S LESS THAN 125 PCS, NO TRAILER OR LEADER WILL BE SUPPLIED. 13. NOTE DELETED. REVISION C2-B-MV H ANY REV MADE TO THIS PRINT MUST HAVE AN UPDATED MKT PRINT 1.732 44.00 REF 1.0700 27.178 REF .9700 24.638 REF .630 16.00 REF C1-A-MV C .9000±.0020 22.860±0.051 (19 POS - 1) X .0500[1.270] .017±.010 0.43±0.25 19 USER DIRECTION OF UN-REELING POCKET NOT DETAILED .320 8.13 REF 01 5 BY SIGNING THIS DOCUMENT YOU ARE ACCEPTING THE CONDITIONS SET WITHIN. YOUR REQUIREMENTS MUST BE LISTED WITHIN THIS DRAWING. WHERE NO DIRECTION FROM THE CUSTOMER IS IDENTIFIED SAMTEC'S PROCESS REQUIREMENTS WILL BE USED. A B C .145 3.68 REF D E .095 2.41 REF .250 6.35 PACKAGING VIEW F .035 0.89 REF 4 .354 8.99 .308±.020 7.82±0.51 .309 7.85 .139 3.54 SEE NOTE 5 2 .104 2.64 REF .134±.003 3.41±0.08 EXCEPTIONS: 1 PHONE No: PRINTED NAME: CUSTOMER SIGNATURE: COMPANY: DATE: "A" .012 0.31 (SEE NOTE 8) "A" SECTION "A"-"A" UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: ITEM NO. PART NUMBER QUANTITY MATERIAL 1 ASP-103597-01-B 1.0000 UL 94 V0, COLOR: BLACK 2 C-226-03-H 114.00 PHOS BRONZE, 521 HARD TEMPER 3 SDB-030-6337 114.00 63% TIN /37% LEAD 4 K-DOT-.354-.469-.005 1.0000 POLYIMIDE FILM 5 CT-ASP1132MS .00148 CONDUCTIVE POLYMER DECIMALS .XX: .01 .XXX: .005 .XXXX: .0020 ANGLES 2 3 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: VITA 42 (LEADED) SOCKET ASSEMBLY PLATING: CONTACT AREA: .000030 GOLD OVER .000050 NICKEL REMAINDER: .000003 FLASH GOLD OVER .000050 NICKEL DWG. NO. F:\DWG\MISC\MKTG\ASP-103612-05-MKT.SLDDRW BY: B. COOPER ASP-103612-05 12/08/06 SHEET 1 OF 2 REVISION H RECOMMENDED BOARD LAYOUT 01 .9000 22.860 19 A B C .2500 6.350 RECOMMENDED STENCIL LAYOUT STENCIL TO BE .0060[0.152] THICK D E F .900 22.86 .050 1.27 (TYP) 'A' 19 01 NOTE: OUTER ROWS MAY NOT NEED VIAS - THIS IS LEFT TO THE DISCRETION OF THE BOARD DESIGNER. A B C D E .250 6.35 F .050 1.27 (TYP) .0250 0.635 (TYP) .0250 0.635 .0100 0.254 TRACE .0310 0.787 FREE OF SOLDER MASK .0250 0.635 PAD .0100 0.254 VIA (PLATED) 45° PROPRIETARY NOTE DETAIL 'A' SCALE 12 : 1 .0200 0.508 PAD THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: VITA 42 (LEADED) SOCKET ASSEMBLY DWG. NO. F:\DWG\MISC\MKTG\ASP-103612-05-MKT.SLDDRW ASP-103612-05 BY: B. COOPER 12/08/06 SHEET 2 OF 2
ASP-103612-05 价格&库存
很抱歉,暂时无法提供与“ASP-103612-05”相匹配的价格&库存,您可以联系我们找货
ASP-103612-05
  • 1+210.55248
  • 10+188.15328
  • 30+165.75408
库存:3
ASP-103612-05
  • 1+306.278791+39.69957
  • 10+260.3241810+33.74297
  • 25+244.0244925+31.63022
  • 50+240.0678350+31.11736
库存:52
ASP-103612-05
  • 675+198.59183675+25.74129
库存:52
