IT2-380S-BGA
IT2-380S-BGA
    HRS(广濑)
    CONN RECEPT 380POS
IT2-380S-BGA 数据手册
High Speed, Parallel Board-to-Board Connector 380 contacts, Ball-Grid array termination IT2 Series The IT2 series - TDR TTD11 IT2 connector d e u Magnitude(dB) The IT2 series - Insertion Loss SDD12 ■Features Differential impedance: 100ø +/- 10% (Tr. 70 ps) 2. Contact reliability d e Hirose’s unique double contact point on each of the contacts assures highly reliable electrical and mechanical performance. b o t d 3. Self-alignment d e h c S Frequency(Hz) Dual contact points Our unique 3-piece modular design together with large tolerances in the X and Y axis allows mating of several connectors mounted on the same PCB. e l u n i t n o c is 1. High-speed transmission Floating Floating 4. Low insertion / withdrawal forces The unique contact configuration assures insertion force of 75 N max. 5. Customized Board-to-Board distance IT2 series-380 pos. Transmission module can be designed to accommodate distance of 15 to 50 mm between parallel boards. ■Applications Routers, servers, base stations, communication equipment and other applications requiring high density and high speed connections between parallel boards. Force(N) Nov.1.2022 Oct.1.2021 Copyright Copyright 2021 2022 HIROSE HIROSE ELECTRIC ELECTRIC CO., CO., LTD. LTD. All All Rights Rights Reserved. Reserved. SMA connentor Insertion depth(mm) 15mm~50mm A311 IT2 Series●High Speed, Parallel Board-to-Board (Stacking) Connector 380 contacts, Ball-Grid array termination ■Production Specifications Ratings Current rating 0.5A Current voltage 50V AC Nov.1.2022 Oct.1.2021 Copyright Copyright 2021 2022 HIROSE HIROSE ELECTRIC ELECTRIC CO., CO., LTD. LTD. All All Rights Rights Reserved. Reserved. Item Operating temperature range -55ç to +85ç (Note 1) Storage temperature range -10ç to +60ç (Note 2) Operating humidity Relative humidity 95% Storage humidity range range (No condensation) Specification Conditions 1. Insulation resistance 100 Mø min. 2. Withstanding voltage No flashover or insulation breakdown. 3. Contact resistance 50 mø max. (* Including conductor resistance.) No electrical discontinuity of 1 μs or more. 4. Vibration No damage, cracks, or parts dislocation. No electrical discontinuity of 1 μs. min. 5. Shock No damage, cracks, or parts dislocation. 6. Humidity Contact resistance: 20 mø max. 7. Temperature cycle Insulation resistance: 100 Mø min. No damage, cracks, or parts dislocation. Contact resistance: 20 mø max. 8. Durability (insertion/ withdrawal) Insulation resistance: 100 Mø min. No damage, cracks, or parts dislocation. 9. Resistance to soldering heat 40% to 70% (Note 2) 100V DC 150V AC / one minute 100 mA (Corresponding connector: IT2-380P-15H) Frequency: 10 to 55 Hz, single amplitude of 0.75mm, 10 cycle in each of the 3 directions. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 96 hours at 40ç±2ç and humidity of 90% to 95% Temperature: –55ç / +15ç to +35ç / +85ç / +15ç to +35ç Duration: 30 / 5 max. / 30 / 5 max. (Minutes) 5 cycles 20 cycles No deformation of components affecting performance. d e u Reflow: At the recommended temperature profile (Peak temperature: 250ç max.) Detailed solder profile can be requested. n i t n Note1: Includes temperature rise caused by current flow. Note2: The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation. Note3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials/Finish Receptacle Part Insulator Contacts Metal fitting Material LCP Phosphor bronze Phosphor bronze h c S Part Insulator Board Note: Lead free products t d d e Finish Color: Black Contact area: Gold plated Tin plated Remarks Material Finish Remarks PBT FR-4 Color: Black/gray Contact area: Gold plated UL94V-0 ---------- ed Transmission module b o o c is e l u UL94V-0 ------------------- ■Ordering information Receptacles 1 Series name 2 Number of contacts : 380 IT2 - 380 S - BGA 1 2 3 : IT2 3 Connector 4 S : Receptacle P : Transmission module 4 BGA Transmission module Ball grid allay (Lead free) IT2 - 380 P * - 15H 1 2 3 5 6 5 Transmission S : Standard M : Customized 6 Board to board distance 15H : 15mm 26H : 26mm 17H : 17mm 30H : 30mm 20H : 20mm 35H : 35mm 25H : 25mm A312 IT2 Series●High Speed, Parallel Board-to-Board (Stacking) Connector 380 contacts, Ball-Grid array termination ■Receptacle (2 required) 48.2±0.5 Contact No. 1 C 20 19 22.6±0.5 38 C Part Number IT2-380S-BGA CL No. 641-2001-9 RoHS YES 1 0.16 F G 1 No.1 Drilled hole H Row D Row F Row H Row M Row P G 1.5±0.05 Drilled hole F t d ed e l u 43.7 Row A Row C Row E Row G Row J b o Row K 1 19 (=1∞19) Row B E o c is Ø1.3±0.05 18 (=1∞18) 4 Row T Row L Row N Row R Row U Row V Row W Row Y d e 21.4 18 (=1∞18) n i t n BDetail “H” D 1.5±0.1 No.37 No.38 C Position No.1 indicator BRecommend PCB mounting pattern 1.2±0.1 d e u Row A No.37 Row A No.38 Row B No.37 (Contact pad) 380-Ø0.635±0.03 0.1 D E (Solder resist) 380-Ø0.7±0.03 0.1 D E Ø1.3±0.05 0.16 F G Drilled hole ■Transmission module (1 required) 24.8±0.5 h c S 54.8±0.5 ±0.5 Nov.1.2022 Oct.1.2021 Copyright Copyright 2021 2022 HIROSE HIROSE ELECTRIC ELECTRIC CO., CO., LTD. LTD. All All Rights Rights Reserved. Reserved. Lot No. Lot No. Part Number IT2-380PS-15H IT2-380PS-17H IT2-380PS-20H IT2-380PS-25H IT2-380PS-26H IT2-380PS-30H IT2-380PS-35H Position No.1 indicator CL No. 641-2151-1 641-2155-2 641-2256-0 641-2251-6 641-2255-7 641-2301-2 641-2300-0 Board-to-board Distance 15mm 17mm 20mm 25mm 26mm 30mm 35mm RoHS YES A313 IT2 Series●High Speed, Parallel Board-to-Board (Stacking) Connector 380 contacts, Ball-Grid array termination BRecommend Temperature Profile ●Using Lead-free Solder Paste Temp. (ç) 300ç 5 sec. max. 260 ç 250ç 200ç 225 ç Solder composition: Paste, 96.5% Sn/3.0% Ag/0.5% Cu 180 ç 150ç Nov.1.2022 Oct.1.2021 Copyright Copyright 2021 2022 HIROSE HIROSE ELECTRIC ELECTRIC CO., CO., LTD. LTD. All All Rights Rights Reserved. Reserved. 100ç A314 60s - 160s 40s - 120s Preheating soldering Time (s) ■Recomonded spacer Hight d e u The two parallel boards connected by the IT2 connectors should be fastened to additioal spacers between them. Board-to-board Distance Part Number CL No. 15mm IT2-380PS-15H 641-2151-1 17mm IT2-380PS-17H 641-2155-2 20mm IT2-380PS-20H 641-2256-0 25mm IT2-380PS-25H 641-2251-6 26mm IT2-380PS-26H 30mm IT2-380PS-30H 35mm IT2-380PS-35H d e h c S e l u o t d be o c s n i t n di Recomonded spacer Hight 15.35±0.05 mm 17.35±0.05 mm 20.35±0.05 mm 25.35±0.05 mm 641-2255-7 26.35±0.05 mm 641-2301-2 30.35±0.05 mm 641-2300-0 35.35±0.05 mm
IT2-380S-BGA 价格&库存
很抱歉,暂时无法提供与“IT2-380S-BGA”相匹配的价格&库存,您可以联系我们找货
