SEAM-50-01-S-10-2-RA-K-TR 数据手册
HIGH-DENSITY
OPEN-PIN-FIELD ARRAYS
(1.27 mm) .050" PITCH
FEATURES & BENEFITS
• Maximum grounding & routing flexibility
• Up to 560 single-ended I/Os or 140 differential pairs
• Rugged Edge Rate® contacts
• Variety of designs and options: Right-Angle, Guide Posts, 85 Ω Elevated Risers,
85 Ω Tuned, Press-Fit and Press-Fit Right-Angle, Guide Post Field Termination Kits
10 YEAR MFG
WITH 30 µ" GOLD
• Compatible with UMPT/UMPS for power/signal flexibility
EXTENDED LIFE
PRODUCT
• Cable mates (SEAC Series) and Jack Screw Standoffs (JSO Series) also available
HIGH MATING
CYCLES
• Standards: VITA 47, VITA 57.1 FMC, VITA 57.4 FMC+, VITA 74 VNX, PISMO™ 2
• Supports high-speed protocols such as Ethernet, PCI Express®,
Fibre Channel & InfiniBand
(1.12 mm) .044"
Nominal Wipe
Solder Charges
MAXIMUM GROUNDING & ROUTING FLEXIBILITY
Power / Signal
Applications
Differential Pair
Single-Ended
Power
KEY SPECIFICATIONS
PITCH
STACK
HEIGHTS
1.27 mm x
1.27 mm
7 mm 18.5 mm
TOTAL
PINS
40 - 560
INSULATOR
MATERIAL
Black LCP
CONTACT
MATERIAL
PLATING
OPERATING
TEMP RANGE
Au or Sn over
-55 °C to +125 °C
Copper Alloy
50 µ" (1.27 µm) Ni
CURRENT
RATING
WORKING
VOLTAGE
LEAD-FREE
SOLDERABLE
2.7 A per pin
(10 adjacent
pins powered)
7 mm stack
height
240 VAC
Yes
Note: Some lengths, styles and options
are non-standard, non-returnable
F-221 (Rev 01JUN21)
samtec.com/SEARAY
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(1.27 mm) .050" PITCH • SEAM/SEAF SERIES
SERIES
POSITIONS PER ROW
SEAM
–10, –15, –20, –30,
–40, –50
Terminal
SEAF
SEAM & SEAF: -10 only
available in -04 Row
Socket
LEAD
STYLE
PLATING
OPTION
NO. OF
ROWS
–L
Specify
LEAD
STYLE
from
chart
–04
= 10 µ" (0.25 µm)
Gold on contact
area, Matte Tin on
solder tail
= 30 µ" (0.76 µm)
Gold on contact
area, Matte Tin on
solder tail
SEAF: -15 only available in -04
or -10 Row with -5.0 Lead Style
SEAM
–1
–A
–05
–08
= Lead-Free
Solder Charge
= Alignment Pin
–K
–2
–10
Polyimide Film Pick &
Place Pad
–TR
= Tape & Reel
SEAM: -04,
-05 & -06
(Rows not
available
with -06.5
Lead Style)
B
Board Mates:
SEAF, SEAFP
Standoffs:
JSO
- A - K - "X" R
SOLDER
TYPE
= Tin/Lead
Alloy Solder
Charge
–06
–S
SEAM: -15 only available in -04
Row with -02.0 Lead Style, and
-10 Row with any Lead Style;
No. of positions x (1.27) .050 + (4.98) .196
A
No. of positions x (1.27) .050 + (3.58) .141
–FR
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec for
quantity breaks)
LEAD
STYLE
A
–02.0
(5.61) .221
–03.0
(6.60) .260
NO. OF
ROWS
B
–04
(7.06) .278
–05, –06 (9.60) .378
–03.5
(7.11) .280
–08
(12.14) .478
–06.5
(10.16) .400
–10
(14.68) .578
–07.0
(10.59) .417
–09.0
(12.60) .496
–11.0
(14.61) .575
ALSO AVAILABLE
View complete specifications at: samtec.com?SEAM
SEAF
Board Mates:
SEAM, SEAMP,
SEAR, SEAMI
Standoffs:
JSO
See website for 14 row option.
LEAD
STYLE
B
No. of positions x
(1.27) .050 + (5.82) .229
(1.27)
.050
A
NO. OF
ROWS
B
(5.66) .223
–05.0
(5.05) .199
–04
–06.0
(6.05) .238
–05, –06
(8.20) .323
–06.5
(6.55) .258
–08
(10.74) .423
–07.5
(7.54) .297
–10
(13.28) .523
A
No. of positions x
View complete specifications at: samtec.com?SEAF
STANDARDS
MATED HEIGHTS
SEAM LEAD STYLE
SEAF LEAD STYLE
VITA 47
–05.0
–06.0
–06.5
–07.5
–02.0
7 mm
8 mm
8.5 mm
9.5 mm
–03.0
8 mm
9 mm
9.5 mm
10.5 mm
–03.5
8.5 mm
9.5 mm
10 mm
11 mm
–06.5
11.5 mm
12.5 mm
13 mm
14 mm
–07.0
12 mm
13 mm
13.5 mm
14.5 mm
–09.0
14 mm
15 mm
15.5 mm
16.5 mm
–11.0
16 mm
17 mm
17.5 mm
18.5 mm
VITA 57.1 FMC
VITA 57.4 FMC+
VITA 74 VNX
PISMOTM2
Visit www.samtec.com/standards
for more information.
Notes:
IPC-A-610F and
IPC J-STD-001F Class 3 solder joint.
samtec.com/SEARAY
F-221 (Rev 01JUN21)
SEAM-50-01-S-10-2-RA-K-TR 价格&库存
很抱歉,暂时无法提供与“SEAM-50-01-S-10-2-RA-K-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+307.54080
- 100+292.16376
- 国内价格 香港价格
- 1+751.385321+97.20316
- 10+640.4873510+82.85682
- 国内价格 香港价格
- 50+523.2766850+67.69383
