DF9-31P-1V(20)
DF9-31P-1V(20)
    HRS(广濑)
    CONN HEADER 31POS 1MM SMD TIN
DF9-31P-1V(20) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. 1mm Pitch SMT Board to Board Connector(Standard Interface Connector Compliant with VESA FPDI-1) DF9 Series ■Features 1. Compliant with the VESA FPDI-1 Standard Interface Connector The 31 and 41 contact connectors comply with the standard connector specification for the flat panel display interface, which U.S VESA. has selected as FPDI-1. VESA: Video Electronics Standards Association FPDI-1: Flat Panel Display Interface 2. Perfect Mis-insertion Prevention The mating area is designed in a trapezoidal structure, and perfectly prevents the mis-insertion despite the miniature size. 3. Equipped with Easy Lock Mechanism The easy lock mechanism assures the firm insertion and extraction properties as well as the insertion/extraction feeling touch. 4. Smooth Insertion and Extraction Feeling The contact is constructed without the material fragible surface in the contact portion, and provides a smooth insertion and use feeling. 5. Setting Two Type Platings as Standard Two type platings, tin plated and gold plated, are prepared, and either appropriate plating can be selected under cost and use conditions. Structure to Prevent Mis-insertion Lock Mechanism ■Applications LCD (Liquid Crystal Display), Mobile phone, Note PC A135 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will Board be discontinued soon. Please check the products statusInterface on the HiroseConnector website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF9 Series●1mm Pitch SMT to Board Connector(Standard Compliant with VESA FPDI-1) ■Product Specifications Rating Current rating 0.5A Operating Temperature Range -45 to +125ç (Note 1) Storage Temperature Range -10 to +60ç (Note 2) Voltage rating150V AC Operating Humidity Range 40 to 80% Item Storage Humidity Range 40 to 70% specification Condition 1. Insulation Resistance 500M ohms min. 100V DC 2. Withstanding voltage No flashover or insulation breakdown. 250V AC/1 minute 3. Contact Resistance 50m ohms max. 100mA 4. Vibration No electrical discontinuity of 1µs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Contact resistance: 50m ohms max. Insulation resistance: 500M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6. Temperature Cycle Contact resistance: 50m ohms max. Insulation resistance: 500M ohms min. (-55ç: 30 minutes 5 to 35ç: 10 minutes 85ç: 30 minutes 5 to 35ç: 10 minutes) 5 cycles 7. Durability (Mating/un-mating) Contact resistance: 50m ohms max: Tin plating: 30 cycles 8. Resistance to Soldering heat No deformation of components affecting performance. Gold plating: 100 cycles Reflow: At the recommended temperature profile Manual soldering: 300ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. ■Material Product Part Material Finish Remarks Insulator Polyamide Beige UL94V-0 Contact Phosphor copper Tin plated or gold plated ––––––– Metal fitting Brass Tin plating ––––––– Receptacle/Header Note:The gold plated product contact area is plated with gold, and lead plated with tin. ■ Ordering Information Please determine the specific product. If needed, please select and order products from the product No. as listed on catalog page A280~A284. ●Receptacle/Header DF9 q q Series Name # - * S - 1 V (**) w e t w Type u S: Receptacle Fitting Boss Blank K K A ∞ K B K ∞ C ∞ ∞ e Number of Contacts P: Header t Contact Pitch : 1mm y Contact Type V: Straight SMT u Contact Surface Finish/Packaging Type (22)(32): Tin plated, embossed tape packaging (69): Gold plated, embossed tape packaging *Refer to page A141 for the bottom entry type (DF9L). A136 y r Connector Type : DF9 9 to 25,31,41,51 r The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your salesFPDI-1) representative. DF9 Series●1mm Pitch SMT Board to Board Connector(Standard Interface Connector Compliant withHirose VESA ■Receptacle With metal fitting With boss [Specific No.] _ **, (**) (32) : Tin plated, embossed tape packaging (69) : Gold plated, embossed tape packaging Unit: mm Part Number CL No. Number of Contacts A B C 9 8.3 3 4 DF9- 9S-1V (**) 540-0054-0-** 11 9.3 4 5 DF9-11S-1V (**) 540-0055-2-** 13 10.3 5 6 DF9-13S-1V (**) 540-0056-5-** 15 11.3 6 7 DF9-15S-1V (**) 540-0057-8-** 17 12.3 7 8 DF9-17S-1V (**) 540-0058-0-** 19 13.3 8 9 DF9-19S-1V (**) 540-0059-3-** 21 14.3 9 10 DF9-21S-1V (**) 540-0060-2-** 23 15.3 10 11 DF9-23S-1V (**) 540-0061-5-** 25 16.3 11 12 DF9-25S-1V (**) 540-0062-8-** 31 19.3 14 15 DF9-31S-1V (**) 540-0063-0-** 41 24.3 19 20 DF9-41S-1V (**) 540-0213-1-** 51 29.3 24 25 DF9-51S-1V (**) 540-0064-3-** Note 1 : Please order the embossed tape packaging product per reel. (1000 pcs. per reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. ■Receptacle Without metal fitting D E 7.1 8.1 9.1 10.1 11.1 12.1 13.1 14.1 15.1 18.1 23.1 28.1 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 21.1 26.1 31.1 Spec. Spec. (32) (69) K K K K K K K K K K K _ K K K K K K K K K K K K Remarks With metal fitting With boss RoHS YES With pick and place tape With boss [Specific No.] _ **, (**) (22): Tin plated, tube packaging (69): Gold plated, embossed tape packaging Unit: mm Part Number CL No. Number of Contacts A B 9 8.3 3 DF9A-09S-1V (**) 540-0004-1-** 11 9.3 4 DF9A-11S-1V (**) 540-0005-4-** 13 10.3 5 DF9A-13S-1V (**) 540-0006-7-** 15 11.3 6 DF9A-15S-1V (**) 540-0007-0-** 17 12.3 7 DF9A-17S-1V (**) 540-0008-2-** 19 13.3 8 DF9A-19S-1V (**) 540-0009-5-** 21 14.3 9 DF9A-21S-1V (**) 540-0010-4-** 23 15.3 10 DF9A-23S-1V (**) 540-0011-7-** 25 16.3 11 DF9A-25S-1V (**) 540-0012-0-** 31 19.3 14 DF9A-31S-1V (**) 540-0013-2-** 41 24.3 19 DF9A-41S-1V (**) 540-0222-2-** 51 29.3 24 DF9A-51S-1V (**) 540-0014-5-** Note 1 : Please order the emboss packaging product per reel. (1000 pcs. per reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. C D E 4 5 6 7 8 9 10 11 12 15 20 25 7.1 8.1 9.1 10.1 11.1 12.1 13.1 14.1 15.1 18.1 23.1 28.1 _ _ _ _ _ _ _ _ _ _ _ _ Spec. Spec. (22) (69) K K K K K K K K K K K _ _ _ K K _ _ K _ K K K K Remarks Without metal fitting With boss RoHS YES With pick and place tape A137 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will Board be discontinued soon. Please check the products statusInterface on the HiroseConnector website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF9 Series●1mm Pitch SMT to Board Connector(Standard Compliant with VESA FPDI-1) ■Receptacle With metal fitting Without boss [Specific No.] _ **, (**) (32): Tin plated, tube packaging (69): Gold plated, embossed tape packaging Unit: mm Part Number Number of Contacts C D E 09 08.3 03 04 DF9B-09S-1V (**) 540-0125-6-** 11 09.3 04 05 DF9B-11S-1V (**) 540-0126-9-** 13 10.3 05 06 DF9B-13S-1V (**) 540-0127-1-** 15 11.3 06 07 DF9B-15S-1V (**) 540-0128-4-** 17 12.3 07 08 DF9B-17S-1V (**) 540-0129-7-** 19 13.3 08 09 DF9B-19S-1V (**) 540-0247-3-** 21 14.3 09 10 DF9B-21S-1V (**) 540-0131-9-** 23 15.3 10 11 DF9B-23S-1V (**) 540-0132-1-** 25 16.3 11 12 DF9B-25S-1V (**) 540-0133-4-** 31 19.3 14 15 DF9B-31S-1V (**) 540-0143-8-** 41 24.3 19 20 DF9B-41S-1V (**) 540-0216-0-** 51 29.3 24 25 DF9B-51S-1V (**) 540-0145-3-** Note 1 : Please order the embossed tape packaging product per reel. (1000 pcs. per reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. _ _ _ _ _ _ _ _ _ _ _ _ 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 21.1 26.1 31.1 ■Header CL No. With metal fitting A B Spec. Spec. (32) (69) K K K K _ _ K K K K K _ K _ K K K K K _ _ K K K Remarks With metal fitting Without boss RoHS YES With pick and place tape With boss [Specific No.] _ **, (**) (32): Tin plated, tube packaging (69): Gold plated, embossed tape packaging Unit: mm Part Number CL No. Number of Contacts A B 09 08.3 03 DF9-09P-1V (**) 540-0066-9-** 11 09.3 04 DF9-11P-1V (**) 540-0067-1-** 13 10.3 05 DF9-13P-1V (**) 540-0068-4-** 15 11.3 06 DF9-15P-1V (**) 540-0069-7-** 17 12.3 07 DF9-17P-1V (**) 540-0070-6-** 19 13.3 08 DF9-19P-1V (**) 540-0071-9-** 21 14.3 09 DF9-21P-1V (**) 540-0072-1-** 23 15.3 10 DF9-23P-1V (**) 540-0073-4-** 25 16.3 11 DF9-25P-1V (**) 540-0074-7-** 31 19.3 14 DF9-31P-1V (**) 540-0075-0-** 41 24.3 19 DF9-41P-1V (**) 540-0214-4-** 51 29.3 24 DF9-51P-1V (**) 540-0088-1-** Note 1 : Please order the emboss packaging product per reel. (1000 pcs. per reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. A138 C D E 04 05 06 07 08 09 10 11 12 15 20 25 07.1 08.1 09.1 10.1 11.1 12.1 13.1 14.1 15.1 18.1 23.1 28.1 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 21.1 26.1 31.1 Spec. Spec. (32) (69) K K K K K K K K K K K _ K K K K K K K K K K K K Remarks With metal fitting With boss With pick and place tape RoHS YES The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your salesFPDI-1) representative. DF9 Series●1mm Pitch SMT Board to Board Connector(Standard Interface Connector Compliant withHirose VESA ■Header Without metal fitting With boss [Specific No.] _ **, (**) (22) : Tin plated, embossed tape packaging (69) : Gold plated, embossed tape packaging Unit: mm Part Number CL No. Number of Contacts A B 09 08.3 03 DF9A-09P-1V (**) 540-0016-0-** 11 09.3 04 DF9A-11P-1V (**) 540-0017-3-** 13 10.3 05 DF9A-13P-1V (**) 540-0018-6-** 15 11.3 06 DF9A-15P-1V (**) 540-0019-9-** 17 12.3 07 DF9A-17P-1V (**) 540-0020-8-** 19 13.3 08 DF9A-19P-1V (**) 540-0021-0-** 21 14.3 09 DF9A-21P-1V (**) 540-0022-3-** 23 15.3 10 DF9A-23P-1V (**) 540-0023-6-** 25 16.3 11 DF9A-25P-1V (**) 540-0024-9-** 31 19.3 14 DF9A-31P-1V (**) 540-0025-1-** 41 24.3 19 DF9A-41P-1V (**) 540-0223-5-** 51 29.3 24 DF9A-51P-1V (**) 540-0026-4-** Note 1 : Please order the emboss packaging product per reel. (1000 pcs. per reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. ■Header With metal fitting C D E 04 05 06 07 08 09 10 11 12 15 20 25 07.1 08.1 09.1 10.1 11.1 12.1 13.1 14.1 15.1 18.1 23.1 28.1 _ _ _ _ _ _ _ _ _ _ _ _ Spec. Spec. (22) (69) K K K K K K K _ K K K _ _ _ K K K _ K _ K K _ K Remarks Without metal fitting With boss RoHS YES With pick and place tape Without boss [Specific No.] _ **, (**) (32) : Tin plated, embossed tape packaging (69) : Gold plated, embossed tape packaging Unit: mm Part Number CL No. Number of Contacts A B 09 08.3 03 DF9B-09P-1V (**) 540-0134-7-** 11 09.3 04 DF9B-11P-1V (**) 540-0135-0-** 13 10.3 05 DF9B-13P-1V (**) 540-0136-2-** 15 11.3 06 DF9B-15P-1V (**) 540-0137-5-** 17 12.3 07 DF9B-17P-1V (**) 540-0138-8-** 19 13.3 08 DF9B-19P-1V (**) 540-0248-6-** 21 14.3 09 DF9B-21P-1V (**) 540-0140-0-** 23 15.3 10 DF9B-23P-1V (**) 540-0141-2-** 25 16.3 11 DF9B-25P-1V (**) 540-0142-5-** 31 19.3 14 DF9B-31P-1V (**) 540-0144-0-** 41 24.3 19 DF9B-41P-1V (**) 540-0221-0-** 51 29.3 24 DF9B-51P-1V (**) 540-0146-6-** Note 1 : Please order the emboss packaging product per reel. (1000 pcs./reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. C D E 04 05 06 07 08 09 10 11 12 15 20 25 _ _ _ _ _ _ _ _ _ _ _ _ 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 21.1 26.1 31.1 Spec. Spec. (32) (69) K K K K K K K K K K K _ K K _ K K K K _ _ K K K Remarks With metal fitting Without boss RoHS YES With pick and place tape A139 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will Board be discontinued soon. Please check the products statusInterface on the HiroseConnector website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF9 Series●1mm Pitch SMT to Board Connector(Standard Compliant with VESA FPDI-1) BRecommended PCB mounting pattern ●With metal fitting, with boss Note 1 : ●Without metal fitting, with boss ●Metal fitting, without boss If the pattern is included in the shaded area and not treated with resist, it could touch the connector contact . Note 2 : Please refer to each product size pattern for the universal size on the above patterns (A, B, C, D...). BApplication Pattern Board Board Note 1 : The board to board size 4.3mm in the pattern does not include the soldering paste thickness. Ø80±1 Ø330±1 Ø1 3± 0.2 BEmbossed Carrier Tape Dimensions D±0.5 Unreeling direction (D+4)±1 Unit:mm Product Type DF9-*S/P-1V DF9A-*S/P-1V DF9B-*S/P-1V A140 Size Number of Contacts 9 to 25 31 41, 51 9 to 13 15 to 25 31 41, 51 9 to 25 31 41, 51 A 24 32 44 16 24 32 44 24 32 44 B ––––––– 28.4 40.4 ––––––– ––––––– 28.4 40.4 ––––––– 28.4 40.4 C 11.5 14.2 20.2 07.5 11.5 14.2 20.2 11.5 14.2 20.2 D 25.5 33.5 45.5 17.5 22.5 33.5 45.5 25.5 33.5 45.5 E 12 12 12 08 12 12 12 12 12 12 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your salesFPDI-1) representative. DF9 Series●1mm Pitch SMT Board to Board Connector(Standard Interface Connector Compliant withHirose VESA ■Bottom Entry Header [Specific No.] _ **, (**) (31): Gold plated embossed tape packaging Part Number CL No. Number of Contacts A B C D DF9L-31P-1V (**) 540-0215-7-** 31 21.64 14 15 19.4 Spec. Remarks RoHS With metal fitting YES (31) K Note 1 : Please order the embossed tape packaging product per reel. (1000 pcs. per reel) Note 2 : The vacuum area on the embossed tape product utilizes the connector case surface. However, it is necessary to check the previous vacuum, because the surface isn't always plain. BRecommended PCB mounting pattern BApplication Pattern Board Board Board punching area Note : The 2.9mm board to board size does not include the soldering paste thickness. Note : The shaded area indicates the through-hole area. Ø330±1 Ø80±1 Ø1 3 ±0 .2 BEmbossed Carrier Tape Dimensions D±0.5 (D+4)±1 Unit: mm Product Type DF9L-31P-1V Size Number of Contacts A B C D 31 32 28.4 14.2 33.5 A141 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will Board be discontinued soon. Please check the products statusInterface on the HiroseConnector website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF9 Series●1mm Pitch SMT to Board Connector(Standard Compliant with VESA FPDI-1) BPrecautions for Use 1. Recommended Temperature Profile (SMT) Temperature (ç) 250ç 250 220ç 200 60sec max Soldering 180ç 150 150ç 90~120sec Preheating 100 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Note1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2. Recommended Manual Soldering Condition (SMT) Soldering iron temperature: 370±10ç, Soldering time: Within 3 seconds 3. Recommended Screen Thickness (SMT) 0.15mm 4. Board Warp(SMT) Maximum 0.03mm in the connector center area, based on both connector edges. 5. Cleaning Condition Refer to the "Nylon Connector Use Hand book". 6. Cautions ■ Avoid retaining the board with the connector only, and fix the board by any other means than the connector. ■ Where the board is not mounted, the insertion or extraction will cause damage or deformation in contacts. ■ Excessive scoop insertion or extraction may result in damage. ■ In the manual soldering process, don't carry out flux coating which will cause a flux blister on the connector. ■ The color phase of this product may be slightly different from that of the forming product according to the manufacturing lot. However, the difference doesn't affect the performance. A142 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: DF9A-25P-1V(52) DF9-31P-1V(31) DF9C-11S-1V(69) DF9B-9P-1V(61) DF9BA-31P-1V(69) DF9BA-21P-1V(32) DF9BA-25P-1V(32) DF9B-41S-1V(68) DF9B-41P-1V(68) DF9A-41P-1V(64)
DF9-31P-1V(20) 价格&库存
很抱歉,暂时无法提供与“DF9-31P-1V(20)”相匹配的价格&库存,您可以联系我们找货
