FX4C1-80P-1.27DSA
FX4C1-80P-1.27DSA
    HRS(广濑)
    CONN HEADER 80POS 1.27MM GOLD
FX4C1-80P-1.27DSA 数据手册
Stacking Height 5 to 11mm Half Pitch Connector FX4 Series Stacking Height Flexible 5 to 11mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DIP type The mounting area 70% reduced, compared with conventional product (FX2 series) FX2 series FX4 series (Compared with 60 contacts) ■Features The FX4 series is a miniature board to board connectors, where the stacking height can be set at the 1mm interval. ●Through hole Type 1. Small and Light The mounting space and weight is reduced about 30%, compared to the conventional product (HRS FX2 series), respectively, and the mounting area about 70% reduced, compared to the conventional one. 2. Stacking Height 5 to 11mm The board to board stacking height can be set per 1mm from 5mm up to 11mm. 3. Flux Swell Prevention When solder is dipped, the flux swell from the board rear side is completely prevented. 4. Mis-insertion Prevention and Low Insertion/Extraction Force Mechanism The connection area is designed to completely prevent the mis-insertion. Moreover, the low insertion/extraction mechanism is adopted. ■Applications Computers, peripheral equipments, business equipments, etc. A119 FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector ■Product Specifications Rating Current rating 0.5A Operating Temperature Range -55ç to +85ç (Note 1) Storage Temperature Range -10ç to +60ç (Note 2) Voltage rating 125V AC Operating Humidity Range 40% to 80% Storage Humidity Range 40% to 70% Item Specification Condition 1. Insulation Resistance 100M ohms min. Measured at 250V PC 2. Withstanding Voltage No flashover or insulation breakdown. 300V AC for 1 minute 3. Resistance 45m ohms max. 100mA 4. Vibration No electrical discontinuity of 1μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Contact resistance: 55m ohms max. Insulation resistance: 100M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6. Temperature Cycle Contact resistance : 55m ohms max. (-55ç: 30 minutes 15 to 35ç: 2 to 3 minutes Insulation resistance : 100M ohms min. (-85ç: 30 minutes 15 to 35ç: 2 to 3minutes) 5 cycles 7. Durability (Mating/un-mating) Contact resistance : 55m ohms max. 300 cycles 8. Resistance to Soldering heat No deformation of components affecting performance. Solder bath: 260ç for 10 seconds Manual soldering: 360ç for 5 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Part Material Finish Remarks Insulator Polyamide Beige Selective gold plated UL94V-0 ________ Selective gold plated ________ Receptacle Contact Phosphor bronze Header Contact Note : The black dots on the insulater will not affect performance. ■Ordering Information ●Dip Type FX4C 1 - 80 P - 1.27 DSA L q w e q Series Name : FX4C r t y r Connector Type w Product Height Variable:None: Standard 1: +1mm 2: +2mm 3: +3mm e Number of Contacts: 20, 32, 40, 52, 60, 68, 80 u P : Header S : Receptacle t Contact Pitch : 1.27mm y Contact type DSA : Straight u L: Board prefixed pin BApplication Pattern and Stacking Height Combination ●Through hole Type Unit: mm Receptacle Header A120 FX4C -*S FX4C2-*S FX4C3-*S (Catalog page A124) (Catalog page A125) (Catalog page A126) FX4C -*P (Catalog page A121) 5 7 8 FX4C1-*P (Catalog page A122) 6 8 9 FX4C3-*P (Catalog page A123) 8 10 11 FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Header (Through hole Type)-Stacking Height: Standard type BPCB mounting pattern Unit: mm Part Number CL No. FX4C-20P-1.27DSA(71) 574-0001-0-71 FX4C-20P-1.27DSAL(71) 574-0051-9-71 FX4C-32P-1.27DSA(71) 574-0002-3-71 FX4C-32P-1.27DSAL(71) 574-0052-1-71 FX4C-40P-1.27DSA(71) 574-0003-6-71 FX4C-40P-1.27DSAL(71) 574-0053-4-71 FX4C-52P-1.27DSA(71) 574-0004-9-71 FX4C-52P-1.27DSAL(71) 574-0054-7-71 FX4C-60P-1.27DSA(71) 574-0005-1-71 FX4C-60P-1.27DSAL(71) 574-0055-0-71 FX4C-68P-1.27DSA(71) 574-0006-4-71 FX4C-68P-1.27DSAL(71) 574-0056-2-71 FX4C-80P-1.27DSA(71) 574-0007-7-71 FX4C-80P-1.27DSAL(71) 574-0057-5-71 Number of Contacts A B C 20 21.87 14.58 11.43 32 29.49 22.2 19.05 40 34.57 27.28 24.13 52 42.19 34.9 31.75 60 47.27 39.98 36.83 68 52.35 45.06 41.91 80 59.97 52.68 49.53 D ________ RoHS 20.32 ________ 27.94 ________ 33.02 ________ 40.64 ________ YES 45.72 ________ 50.8 ________ 58.42 A121 FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Header (Through hole Type)-Stacking Height: Standard+1mm type A122 BPCB mounting pattern Unit: mm Part Number CL No. FX4C1-20P-1.27DSA(71) 574-0011-4-71 FX4C1-20P-1.27DSAL(71) 574-0061-2-71 FX4C1-32P-1.27DSA(71) 574-0012-7-71 FX4C1-32P-1.27DSAL(71) 574-0062-5-71 FX4C1-40P-1.27DSA(71) 574-0013-0-71 FX4C1-40P-1.27DSAL(71) 574-0063-8-71 FX4C1-52P-1.27DSA(71) 574-0014-2-71 FX4C1-52P-1.27DSAL(71) 574-0064-0-71 FX4C1-60P-1.27DSA(71) 574-0015-5-71 FX4C1-60P-1.27DSAL(71) 574-0065-3-71 FX4C1-68P-1.27DSA(71) 574-0016-8-71 FX4C1-68P-1.27DSAL(71) 574-0066-6-71 FX4C1-80P-1.27DSA(71) 574-0017-0-71 FX4C1-80P-1.27DSAL(71) 574-0067-9-71 Number of Contacts A B C 20 21.87 14.58 11.43 32 29.49 22.2 19.05 40 34.57 27.28 24.13 52 42.19 34.9 31.75 60 47.27 39.98 36.83 68 52.35 45.06 41.91 80 59.97 52.68 49.53 D ________ RoHS 20.32 ________ 27.94 ________ 33.02 ________ 40.64 ________ 45.72 ________ 50.8 ________ 58.42 YES FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Header (Through hole Type)-Stacking Height: Standard+3mm type BPCB mounting pattern Unit: mm Part Number CL No. FX4C3-20P-1.27DSA(71) 574-0031-1-71 FX4C3-20P-1.27DSAL(71) 574-0081-0-71 FX4C3-32P-1.27DSA(71) 574-0032-4-71 FX4C3-32P-1.27DSAL(71) 574-0082-2-71 FX4C3-40P-1.27DSA(71) 574-0033-7-71 FX4C3-40P-1.27DSAL(71) 574-0083-5-71 FX4C3-52P-1.27DSA(71) 574-0034-0-71 FX4C3-52P-1.27DSAL(71) 574-0084-8-71 FX4C3-60P-1.27DSA(71) 574-0035-2-71 FX4C3-60P-1.27DSAL(71) 574-0085-0-71 FX4C3-68P-1.27DSA(71) 574-0036-5-71 FX4C3-68P-1.27DSAL(71) 574-0086-3-71 FX4C3-80P-1.27DSA(71) 574-0037-8-71 FX4C3-80P-1.27DSAL(71) 574-0087-6-71 Number of Contacts A B C 20 21.87 14.58 11.43 32 29.49 22.2 19.05 40 34.57 27.28 24.13 52 42.19 34.9 31.75 60 47.27 39.98 36.83 68 52.35 45.06 41.91 80 59.97 52.68 49.53 D ________ RoHS 20.32 ________ 27.94 ________ 33.02 ________ 40.64 ________ YES 45.72 ________ 50.8 ________ 58.42 A123 FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle (Through hole Type)-Stacking Height: Standard type A124 BPCB mounting pattern Unit: mm Part Number CL No. FX4C-20S-1.27DSA(71) 574-0101-5-71 FX4C-20S-1.27DSAL(71) 574-0151-3-71 FX4C-32S-1.27DSA(71) 574-0102-8-71 FX4C-32S-1.27DSAL(71) 574-0152-6-71 FX4C-40S-1.27DSA(71) 574-0103-0-71 FX4C-40S-1.27DSAL(71) 574-0153-9-71 FX4C-52S-1.27DSA(71) 574-0104-3-71 FX4C-52S-1.27DSAL(71) 574-0154-1-71 FX4C-60S-1.27DSA(71) 574-0105-6-71 FX4C-60S-1.27DSAL(71) 574-0155-4-71 FX4C-68S-1.27DSA(71) 574-0106-9-71 FX4C-68S-1.27DSAL(71) 574-0156-7-71 FX4C-80S-1.27DSA(71) 574-0107-1-71 FX4C-80S-1.27DSAL(71) 574-0157-0-71 Number of Contacts A B C 20 21.87 11.43 18.48 32 29.49 19.05 26.1 40 34.57 24.13 31.18 52 42.19 31.75 38.8 60 47.27 36.83 43.88 68 52.35 41.91 48.96 80 59.97 49.53 56.58 D ________ RoHS 20.32 ________ 27.94 ________ 33.02 ________ 40.64 ________ 45.72 ________ 50.8 ________ 58.42 YES FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle (Through hole Type)-Stacking Height: Standard+2mm type BPCB mounting pattern Unit: mm Part Number CL No. FX4C2-20S-1.27DSA(71) 574-0121-2-71 FX4C2-20S-1.27DSAL(71) 574-0171-0-71 FX4C2-32S-1.27DSA(71) 574-0122-5-71 FX4C2-32S-1.27DSAL(71) 574-0172-3-71 FX4C2-40S-1.27DSA(71) 574-0123-8-71 FX4C2-40S-1.27DSAL(71) 574-0173-6-71 FX4C2-52S-1.27DSA(71) 574-0124-0-71 FX4C2-52S-1.27DSAL(71) 574-0174-9-71 FX4C2-60S-1.27DSA(71) 574-0125-3-71 FX4C2-60S-1.27DSAL(71) 574-0175-1-71 FX4C2-68S-1.27DSA(71) 574-0126-6-71 FX4C2-68S-1.27DSAL(71) 574-0176-4-71 FX4C2-80S-1.27DSA(71) 574-0127-9-71 FX4C2-80S-1.27DSAL(71) 574-0177-7-71 Number of Contacts A B C 20 21.87 11.43 18.48 32 29.49 19.05 26.1 40 34.57 24.13 31.18 52 42.19 31.75 38.8 60 47.27 36.83 43.88 68 52.35 41.91 48.96 80 59.97 49.53 56.58 D ________ RoHS 20.32 ________ 27.94 ________ 33.02 ________ 40.64 ________ YES 45.72 ________ 50.8 ________ 58.42 A125 FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle (Through hole Type)-Stacking Height: Standard+3mm type A126 BPCB mounting pattern Unit: mm Part Number CL No. FX4C3-20S-1.27DSA(71) 574-0131-6-71 FX4C3-20S-1.27DSAL(71) 574-0181-4-71 FX4C3-32S-1.27DSA(71) 574-0132-9-71 FX4C3-32S-1.27DSAL(71) 574-0182-7-71 FX4C3-40S-1.27DSA(71) 574-0133-1-71 FX4C3-40S-1.27DSAL(71) 574-0183-0-71 FX4C3-52S-1.27DSA(71) 574-0134-4-71 FX4C3-52S-1.27DSAL(71) 574-0184-2-71 FX4C3-60S-1.27DSA(71) 574-0135-7-71 FX4C3-60S-1.27DSAL(71) 574-0185-5-71 FX4C3-68S-1.27DSA(71) 574-0136-0-71 FX4C3-68S-1.27DSAL(71) 574-0186-8-71 FX4C3-80S-1.27DSA(71) 574-0137-2-71 FX4C3-80S-1.27DSAL(71) 574-0187-0-71 Number of Contacts A B C 20 21.87 11.43 18.48 32 29.49 19.05 26.1 40 34.57 24.13 31.18 52 42.19 31.75 38.8 60 47.27 36.83 43.88 68 52.35 41.91 48.96 80 59.97 49.53 56.58 D ________ RoHS 20.32 ________ 27.94 ________ 33.02 ________ 40.64 ________ 45.72 ________ 50.8 ________ 58.42 YES FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector BConnector Precautions 1. Tolerance Clearance on Mating Side Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The effective connecting length of the product is set to 1.5mm. Please use the product to specify the clearance between the header and the receptacle in the connection process within 1mm. 2. Prefixed Process to Board (Through hole Type) If the prefixed work is required for mounting on the board, please use the prefixed pin type. (Applicable board thickness t = 1.6±0.1) Cautions:When the connector is installed in the board, the dip post is guided into the board through-hole in order to prevent the dip post breakage, and then insert the board in parallel to the connector so as to push in the prefixed pin. A127
FX4C1-80P-1.27DSA AI解析
物料型号:HIROSE ELECTRIC CO., LTD. 的 FX4 系列,包括不同堆叠高度(5至11mm)和引脚数量(20至80)的板对板连接器。
器件简介: - FX4系列是微型板对板连接器,具有1mm间隔的可调节堆叠高度。 - 与传统产品(FX2系列)相比,安装空间和重量分别减少了约30%,安装面积减少了约70%。
引脚分配:引脚间距为1.27mm,有直引脚(DSA)和板前引脚(L)类型。
参数特性: - 电流额定值:0.5A - 工作温度范围:-55℃至+85℃ - 存储温度范围:-10℃至+60℃ - 电压额定值:125V AC - 工作湿度范围:40%至80% - 存储湿度范围:40%至70%
功能详解: - 防止焊料膨胀:浸焊时,可完全防止从板后侧的助焊剂膨胀。 - 防止误插和低插入/拔出力机制:连接区域设计可完全防止误插,采用低插入/拔出力机制。
应用信息:适用于计算机、外围设备、商用设备等。
封装信息: - 绝缘体材料:聚酰胺,米色,UL94V-0等级。 - 插座接触件:选择性金镀。 - 公头接触件:铟青铜,选择性金镀。
订购信息:提供了不同类型(插座和公头)、不同堆叠高度和引脚数量的型号示例。
*介绍内容由AI识别生成
FX4C1-80P-1.27DSA 价格&库存
很抱歉,暂时无法提供与“FX4C1-80P-1.27DSA”相匹配的价格&库存,您可以联系我们找货
