DF12(3.0)-50DS-0.5V(80) 数据手册
0.5mm Pitch SMT Board-to-Board Connector
DF12 Series
Correspond to automatic mounting
The vacuum pick-up area secures the automatic mounting
Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
machine for pick and place.
Fig.1
■Features
1. Broad Variations of Stacking Height
In addition to 0.5mm pitch ultra-miniature size connector, the stacking height of 3mm, 3.5mm, 4mm, and 5mm are provided.
Header/Receptacle
DF12#(3.0)-*DS-0.5V
DF12#-*DS-0.5V
Combination stacking height Combination stacking height
DF12#(3.0)-*DP-0.5V
3.0
DF12#(3.5)-*DP-0.5V
3.5
DF12#(4.0)-*DP-0.5V
4.0
DF12#(5.0)-*DP-0.5V
5.0
Note 1 : (**) of the product name DF12# (**) indicates the stacking height.
Note 2 : The stacking height doesn't include the soldering paste thickness.
[Stacking Height Variation]
Stacking Height
Number of Contacts
3.0mm
3.5mm
4.0mm
5.0mm
10 contacts
K
14 contacts
K
20 contacts
K
K
K
K
30 contacts
K
K
K
K
32 contacts
K
K
36 contacts
K
K
K
K
40 contacts
K
K
K
K
50 contacts
K
K
K
K
60 contacts
K
K
K
K
K
80 contacts
2. Corresponding to Automatic Mounting
The connector has the vacuum pick-up area to enable automatic mounting with the embossed tape packaging.(Fig.1)
3. Metal Fitting Available
The product including the metal fitting to prevent solder peeling is provided, considering the mounting on FPC.
A193
DF12 Series●0.5mm Pitch SMT Board-to-Board Connector
■Product Specifications
Voltage rating 50V AC Operating Humidity Range
Item
Operating Temperature Range -45 to +125ç (Note 1) Storage Temperature Range
Current rating 0.3A
Rating
-40 to 80%
Storage Humidity Range
Specification
-10 to +60ç (Note 2)
-40 to 70% (Note 2)
Condition
1. Insulation Resistance
500MΩ min.
100V DC
2. Withstanding voltage
No flashover or insulation breakdown.
150V AC/1 minute
3. Contact Resistance
50mΩ max.
100mA
4. Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Contact resistance : 50mΩ max. Insulation resistance:500MΩ min 96 hours at temperature of 40±2ç and humidity of 90% to 95%
6. Temperature Cycle
Contact resistance : 50mΩ max. Insulation resistance:500MΩ min (-65ç : 30 minutes 5 to 35ç : 10 minutes 125ç : 30 minutes 5 to 35ç : 10 minutes) 5 cycles
7. Durability (Mating/un-mating) Contact resistance : 50mΩ max.
8. Resistance to Soldering heat
50 cycles
No deformation of components affecting performance.
Reflow : At the recommended temperature profile
Manual soldering : 350ç for 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
■Material / Finish
Product
Part
Receptacle/Header
Material
Finish
Remarks
Insulator
Polyamide
Beige
UL94-V0
Contact
Phosphor copper
Gold plated
Fitting
Brass
Tin plated
■Product Number Structure
●Receptacle
DF12
q
q Series Name
# (**) - * DS - 0.5 V (**)
w
e
t
y
e Stacking height
: DF12
w Type
3.0
Fitting
Boss
K
K
A
K
B
K
C
Blank
r
Blank
u
y Contact Pitch : 0.5mm
u Contact Style
: 3.0mm
: 3.5 to 5.0mm
V : Straight SMT
r Number of Contacts : 10, 14, 20, 30, 32,
i Packaging Type
36, 40, 50, 60, 80
(81) : Embossed tape packaging
(1,000pcs/reel) (A, C type)
t Connector Type
(86) : Embossed tape packaging
DS : Double-row receptacle
●Header
DF12
q
q Series Name
(1,000pcs/reel) (Blank, B type)
# (**) - * DP - 0.5 V (**)
w
e
r
t
y
e Stacking height
: DF12
w Type
i
u
i
t Connector Type
Indication Stacking Height
DP : Double-row pin header
Fitting
Boss
3.0
3.0mm
Blank
K
K
3.5
3.5mm
u Contact Style
4.0
4.0mm
V : Straight SMT
5.0mm
i Packaging Type
B
K
D
K
E
5.0
(1,000pcs/reel) (D, E type)
36, 40, 50, 60, 80
A194
■Receptacle
Without metal fitting
●Stacking Height: 3mm Product
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
DF12A (3.0)-10DS-0.5V (81)
DF12A (3.0)-14DS-0.5V (81)
DF12A (3.0)-20DS-0.5V (81)
DF12A (3.0)-30DS-0.5V (81)
DF12A (3.0)-32DS-0.5V (81)
DF12A (3.0)-36DS-0.5V (81)
DF12A (3.0)-40DS-0.5V (81)
DF12A (3.0)-50DS-0.5V (81)
DF12A (3.0)-60DS-0.5V (81)
DF12A (3.0)-80DS-0.5V (81)
DF12C (3.0)-10DS-0.5V (81)
DF12C (3.0)-14DS-0.5V (81)
DF12C (3.0)-20DS-0.5V (81)
DF12C (3.0)-30DS-0.5V (81)
DF12C (3.0)-32DS-0.5V (81)
DF12C (3.0)-36DS-0.5V (81)
DF12C (3.0)-40DS-0.5V (81)
DF12C (3.0)-50DS-0.5V (81)
DF12C (3.0)-60DS-0.5V (81)
DF12C (3.0)-80DS-0.5V (81)
537-0626-9 81
537-0915-6 81
537-0628-4 81
537-0630-6 81
537-0637-5 81
537-0631-9 81
537-0632-1 81
537-0634-7 81
537-0636-2 81
537-0638-8 81
537-0686-0 81
537-0917-1 81
537-0688-6 81
537-0690-8 81
537-0697-7 81
537-0691-0 81
537-0692-3 81
537-0694-9 81
537-0696-4 81
537-0212-6 81
10
14
32
36
40
50
60
80
10
14
32
36
40
50
60
80
04.6
05.6
07.1
09.6
10.1
11.1
12.1
14.6
17.1
22.1
04.6
05.6
07.1
09.6
10.1
11.1
12.1
14.6
17.1
22.1
02.0
03.0
04.5
07.0
07.5
08.5
09.5
12.0
14.5
19.5
02.0
03.0
04.5
07.0
07.5
08.5
09.5
12.0
14.5
19.5
03.1
04.1
05.6
08.1
08.6
09.6
10.6
13.1
15.6
20.6
03.1
04.1
05.6
08.1
08.6
09.6
10.6
13.1
15.6
20.6
04.1
05.1
06.6
09.1
09.6
10.6
11.6
14.1
16.6
21.6
2.2
2.2
Remarks
With boss
YES
Without boss
●Stacking Height: 3.5 to 5mm Product
Part No.
HRS No.
RoHS
Unit : mm
No. of Contacts
A
B
C
D
DF12A-20DS-0.5V (81)
537-0078-5 81
04.5
05.6
06.6
DF12A-30DS-0.5V (81)
537-0080-7 81
30
09.6
07.0
08.1
09.1
DF12A-32DS-0.5V (81)
537-0087-6 81
32
10.1
07.5
08.6
09.6
DF12A-36DS-0.5V (81)
537-0081-0 81
36
11.1
08.5
09.6
10.6
DF12A-40DS-0.5V (81)
537-0082-2 81
40
12.1
09.5
10.6
11.6
DF12A-50DS-0.5V (81)
537-0084-8 81
50
14.6
12.0
13.1
14.1
16.6
DF12A-60DS-0.5V (81)
537-0086-3 81
60
17.1
14.5
15.6
DF12C-20DS-0.5V (81)
537-0203-5 81
04.5
05.6
DF12C-30DS-0.5V (81)
537-0205-0 81
30
09.6
07.0
08.1
DF12C-32DS-0.5V (81)
537-0212-6 81
32
10.1
07.5
08.6
DF12C-36DS-0.5V (81)
537-0206-3 81
36
11.1
08.5
09.6
DF12C-40DS-0.5V (81)
537-0207-6 81
40
12.1
09.5
10.6
DF12C-50DS-0.5V (81)
537-0209-1 81
50
14.6
12.0
13.1
DF12C-60DS-0.5V (81)
537-0211-3 81
60
17.1
14.5
15.6
E
2.7
Remarks
RoHS
With boss
YES
2.7
Without boss
Note 1: Please order the embossed tape packaging product per reel. (1000 pcs./reel)
A195
■Receptacle With metal fitting
F
A
B
1.5
4.6
2.4
1.5
3.6
0.5
P=0.5
0.2
Ø0.5
D
1.5
●Stacking Height : 3mm Product
Part No.
DF12 (3.0)-10DS-0.5V (86)
DF12 (3.0)-14DS-0.5V (86)
DF12 (3.0)-20DS-0.5V (86)
DF12 (3.0)-30DS-0.5V (86)
DF12 (3.0)-32DS-0.5V (86)
DF12 (3.0)-36DS-0.5V (86)
DF12 (3.0)-40DS-0.5V (86)
DF12 (3.0)-50DS-0.5V (86)
DF12 (3.0)-60DS-0.5V (86)
DF12 (3.0)-80DS-0.5V (86)
DF12B (3.0)-10DS-0.5V (86)
DF12B (3.0)-14DS-0.5V (86)
DF12B (3.0)-20DS-0.5V (86)
DF12B (3.0)-30DS-0.5V (86)
DF12B (3.0)-32DS-0.5V (86)
DF12B (3.0)-36DS-0.5V (86)
DF12B (3.0)-40DS-0.5V (86)
DF12B (3.0)-50DS-0.5V (86)
DF12B (3.0)-60DS-0.5V (86)
DF12B (3.0)-80DS-0.5V (86)
HRS No.
537-0601-8 86
537-0914-3 86
537-0603-3 86
537-0605-9 86
537-0612-4 86
537-0606-1 86
537-0607-4 86
537-0609-0 86
537-0611-1 86
537-0613-7 86
537-0651-6 86
537-0916-9 86
537-0653-1 86
537-0655-7 86
537-0662-2 86
537-0656-0 86
537-0657-2 86
537-0659-8 86
537-0661-0 86
537-0663-5 86
Unit : mm
No. of Contacts
10
14
32
36
40
50
60
80
10
14
32
36
40
50
60
80
A
4.6
5.6
7.1
9.6
10.1
11.1
12.1
14.6
17.1
22.1
4.6
5.6
7.1
9.6
10.1
11.1
12.1
14.6
17.1
22.1
B
2.0
3.0
4.5
7.0
7.5
8.5
9.5
12.0
14.5
19.5
2.0
3.0
4.5
7.0
7.5
8.5
9.5
12.0
14.5
19.5
C
3.1
4.1
5.6
8.1
8.6
9.6
10.6
13.1
15.6
20.6
3.1
4.1
5.6
8.1
8.6
9.6
10.6
13.1
15.6
20.6
D
4.1
5.1
6.6
9.1
9.6
10.6
11.6
14.1
16.6
21.6
E
2.2
2.2
F
5.6
6.6
8.1
10.6
11.1
12.1
13.1
15.6
18.1
23.1
5.6
6.6
8.1
10.6
11.1
12.1
13.1
15.6
18.1
23.1
Remarks
Part No.
RoHS
With metal fitting
With boss
YES
With metal fitting
Without boss
●Stacking Height : 3.5 to 5mm Product
Unit : mm
HRS No.
No. of Contacts
A
B
C
D
DF12-20DS-0.5V (86)
537-0003-6 86
04.5
05.6
06.6
08.1
DF12-30DS-0.5V (86)
537-0005-1 86
30
09.6
07.0
08.1
09.1
10.6
DF12-32DS-0.5V (86)
537-0012-7 86
32
10.1
07.5
08.6
09.6
DF12-36DS-0.5V (86)
537-0006-4 86
36
11.1
08.5
09.6
10.6
DF12-40DS-0.5V (86)
537-0007-7 86
40
12.1
09.5
10.6
DF12-50DS-0.5V (86)
537-0009-2 86
50
14.6
12.0
13.1
DF12-60DS-0.5V (86)
537-0011-4 86
60
17.1
14.5
15.6
16.6
DF12B-20DS-0.5V (86)
537-0303-0 86
04.5
05.6
DF12B-30DS-0.5V (86)
537-0305-5 86
30
09.6
07.0
08.1
10.6
DF12B-32DS-0.5V (86)
537-0312-0 86
32
10.1
7.5
8.6
11.1
E
F
Remarks
12.1
With metal fitting
11.6
13.1
With boss
14.1
15.6
18.1
YES
08.1
RoHS
11.1
2.7
DF12B-36DS-0.5V (86)
537-0306-8 86
36
11.1
08.5
09.6
12.1
With metal fitting
DF12B-40DS-0.5V (86)
537-0307-0 86
40
12.1
09.5
10.6
13.1
Without boss
DF12B-50DS-0.5V (86)
537-0309-6 86
50
14.6
12.0
13.1
15.6
DF12B-60DS-0.5V (86)
537-0311-8 86
60
17.1
14.5
15.6
18.1
Note : Please order the embossed tape packaging product per reel. (1000 pcs./reel)
A196
0.25
E
0.6
C
2.7
■Header Without metal fitting
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
DF12D (3.0)-10DP-0.5V (81)
537-0791-5 81
10
04.7
2.0
03.2
04.1
DF12D (3.0)-14DP-0.5V (81)
537-0920-6 81
14
05.7
3.0
04.2
05.1
DF12D (3.0)-20DP-0.5V (81)
537-0793-0 81
04.5
05.7
06.6
DF12D (3.0)-30DP-0.5V (81)
537-0795-6 81
30
09.7
07.0
08.2
09.1
DF12D (3.0)-32DP-0.5V (81)
537-0802-0 81
32
10.2
07.5
08.7
09.6
DF12D (3.0)-36DP-0.5V (81)
537-0796-9 81
36
11.2
08.5
09.7
10.6
DF12D (3.0)-40DP-0.5V (81)
537-0797-1 81
40
12.2
09.5
10.7
11.6
DF12D (3.0)-50DP-0.5V (81)
537-0799-7 81
50
14.7
12.0
13.2
14.1
DF12D (3.0)-60DP-0.5V (81)
537-0801-7 81
60
17.2
14.5
15.7
16.6
DF12D (3.0)-80DP-0.5V (81)
537-0803-2 81
80
22.2
19.5
20.7
21.6
DF12E (3.0)-10DP-0.5V (81)
537-0826-8 81
10
04.7
02.0
03.2
DF12E (3.0)-14DP-0.5V (81)
537-0921-9 81
14
05.7
03.0
04.2
DF12E (3.0)-20DP-0.5V (81)
537-0828-3 81
04.5
05.7
DF12E (3.0)-30DP-0.5V (81)
537-0830-5 81
30
09.7
07.0
08.2
DF12E (3.0)-32DP-0.5V (81)
537-0837-4 81
32
10.2
07.5
08.7
DF12E (3.0)-36DP-0.5V (81)
537-0831-8 81
36
11.2
08.5
09.7
DF12E (3.0)-40DP-0.5V (81)
537-0832-0 81
40
12.2
09.5
10.7
DF12E (3.0)-50DP-0.5V (81)
537-0834-6 81
50
14.7
12.0
13.2
DF12E (3.0)-60DP-0.5V (81)
537-0836-1 81
60
17.2
14.5
15.7
DF12E (3.0)-80DP-0.5V (81)
537-0838-7 81
80
22.2
19.5
20.7
E
Remarks
2.3
RoHS
With boss
YES
2.3
Without boss
Note : Order the emboss package product per reel. (1000 pcs./reel)
A197
Part No.
DF12D (3.5)-20DP-0.5V (81)
DF12D (3.5)-30DP-0.5V (81)
DF12D (3.5)-36DP-0.5V (81)
DF12D (3.5)-40DP-0.5V (81)
DF12D (3.5)-50DP-0.5V (81)
DF12D (3.5)-60DP-0.5V (81)
DF12D (4.0)-20DP-0.5V (81)
DF12D (4.0)-30DP-0.5V (81)
DF12D (4.0)-32DP-0.5V (81)
DF12D (4.0)-36DP-0.5V (81)
DF12D (4.0)-40DP-0.5V (81)
DF12D (4.0)-50DP-0.5V (81)
DF12D (4.0)-60DP-0.5V (81)
DF12D (5.0)-20DP-0.5V (81)
DF12D (5.0)-30DP-0.5V (81)
DF12D (5.0)-36DP-0.5V (81)
DF12D (5.0)-40DP-0.5V (81)
DF12D (5.0)-50DP-0.5V (81)
DF12D (5.0)-60DP-0.5V (81)
DF12E (3.5)-20DP-0.5V (81)
DF12E (3.5)-30DP-0.5V (81)
DF12E (3.5)-36DP-0.5V (81)
DF12E (3.5)-40DP-0.5V (81)
DF12E (3.5)-50DP-0.5V (81)
DF12E (3.5)-60DP-0.5V (81)
DF12E (4.0)-20DP-0.5V (81)
DF12E (4.0)-30DP-0.5V (81)
DF12E (4.0)-32DP-0.5V (81)
DF12E (4.0)-36DP-0.5V (81)
DF12E (4.0)-40DP-0.5V (81)
DF12E (4.0)-50DP-0.5V (81)
DF12E (4.0)-60DP-0.5V (81)
DF12E (5.0)-20DP-0.5V (81)
DF12E (5.0)-30DP-0.5V (81)
DF12E (5.0)-36DP-0.5V (81)
DF12E (5.0)-40DP-0.5V (81)
DF12E (5.0)-50DP-0.5V (81)
DF12E (5.0)-60DP-0.5V (81)
HRS No.
537-0428-5 81
537-0430-7 81
537-0431-0 81
537-0432-2 81
537-0434-8 81
537-0436-3 81
537-0453-2 81
537-0455-8 81
537-0802-0 81
537-0456-0 81
537-0457-3 81
537-0459-9 81
537-0461-0 81
537-0478-3 81
537-0480-5 81
537-0481-8 81
537-0482-0 81
537-0484-6 81
537-0486-1 81
537-0528-0 81
537-0530-1 81
537-0531-4 81
537-0532-7 81
537-0534-2 81
537-0536-8 81
537-0553-7 81
537-0555-2 81
537-0929-0 81
537-0556-5 81
537-0557-8 81
537-0559-3 81
537-0561-5 81
537-0578-8 81
537-0580-0 81
537-0581-2 81
537-0582-5 81
537-0584-0 81
537-0586-6 81
Unit : mm
No. of Contacts
36
40
50
60
32
36
40
50
60
36
40
50
60
36
40
50
60
32
36
40
50
60
36
40
50
60
A
7.2
9.7
11.2
12.2
14.7
17.2
7.2
9.7
10.2
11.2
12.2
14.7
17.2
7.2
9.7
11.2
12.2
14.7
17.2
7.2
9.7
11.2
12.2
14.7
17.2
7.2
9.7
10.2
11.2
12.2
14.7
17.2
7.2
9.7
11.2
12.2
14.7
17.2
Note : Plaese order the embossed tape packaging product per reel. (1000 pcs./reel)
A198
B
4.5
7.0
8.5
9.5
12.0
14.5
4.5
7.0
7.5
8.5
9.5
12.0
14.5
4.5
7.0
8.5
9.5
12.0
14.5
4.5
7.0
8.5
9.5
12.0
14.5
4.5
7.0
7.5
8.5
9.5
12.0
14.5
4.5
7.0
8.5
9.5
12.0
14.5
C
5.7
8.2
9.7
10.7
13.2
15.7
5.7
8.2
8.7
9.7
10.7
13.2
15.7
5.7
8.2
9.7
10.7
13.2
15.7
5.7
8.2
9.7
10.7
13.2
15.7
5.7
8.2
8.7
9.7
10.7
13.2
15.7
5.7
8.2
9.7
10.7
13.2
15.7
D
06.6
09.1
10.6
11.6
14.1
16.6
06.6
09.1
09.6
10.6
11.6
14.1
16.6
06.6
09.1
10.6
11.6
14.1
16.6
E
Remarks
RoHS
2.8
3.3
With boss
4.3
YES
2.8
3.3
4.3
Without boss
■Header With metal fitting
F
A
B
4.6
1.5
2.45
3.8
0.4
P=0.5
0.25
E
0.6
0.25
C
Ø0.5
D
1.5
Unit : mm
Part No.
NRS No.
No. of Contacts
A
B
C
D
DF12 (3.0)-10DP-0.5V (86)
537-0721-0 86
10
04.7
02.0
03.2
04.1
E
05.6
F
DF12 (3.0)-14DP-0.5V (86)
537-0918-4 86
14
05.7
03.0
04.2
05.1
06.6
DF12 (3.0)-20DP-0.5V (86)
537-0723-5 86
04.5
05.7
06.6
08.1
DF12 (3.0)-30DP-0.5V (86)
537-0725-0 86
30
09.7
07.0
08.2
09.1
10.6
DF12 (3.0)-32DP-0.5V (86)
537-0732-6 86
32
10.2
07.5
08.7
09.6
DF12 (3.0)-36DP-0.5V (86)
537-0726-3 86
36
11.2
08.5
09.7
10.6
DF12 (3.0)-40DP-0.5V (86)
537-0727-6 86
40
12.2
09.5
10.7
11.6
13.1
DF12 (3.0)-50DP-0.5V (86)
537-0729-1 86
50
14.7
12.0
13.2
14.1
15.6
DF12 (3.0)-60DP-0.5V (86)
537-0731-3 86
60
17.2
14.5
15.7
16.6
18.1
DF12 (3.0)-80DP-0.5V (86)
537-0733-9 86
80
22.2
19.5
20.7
21.6
23.1
DF12B (3.0)-10DP-0.5V (86)
537-0756-4 86
10
04.7
02.0
03.2
05.6
DF12B (3.0)-14DP-0.5V (86)
537-0919-7 86
14
05.7
03.0
04.2
06.6
DF12B (3.0)-20DP-0.5V (86)
537-0758-0 86
04.5
05.7
08.1
DF12B (3.0)-30DP-0.5V (86)
537-0760-1 86
30
09.7
07.0
08.2
10.6
DF12B (3.0)-32DP-0.5V (86)
537-0767-0 86
32
10.2
07.5
08.7
DF12B (3.0)-36DP-0.5V (86)
537-0761-4 86
36
11.2
08.5
09.7
DF12B (3.0)-40DP-0.5V (86)
537-0762-7 86
40
12.2
09.5
10.7
13.1
DF12B (3.0)-50DP-0.5V (86)
537-0764-2 86
50
14.7
12.0
13.2
15.6
DF12B (3.0)-60DP-0.5V (86)
537-0766-8 86
60
17.2
14.5
15.7
18.1
DF12B (3.0)-80DP-0.5V (86)
537-0768-3 86
80
22.2
19.5
20.7
23.1
2.3
2.3
11.1
12.1
11.1
12.1
Remarks
RoHS
With metal fitting
With boss
YES
With metal fitting
Without boss
A199
F
A
B
4.6
1.5
2.45
3.8
0.4
P=0.5
D
1.5
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
DF12 (3.5)-20DP-0.5V (86)
DF12 (3.5)-30DP-0.5V (86)
DF12 (3.5)-36DP-0.5V (86)
DF12 (3.5)-40DP-0.5V (86)
DF12 (3.5)-50DP-0.5V (86)
DF12 (3.5)-60DP-0.5V (86)
DF12 (4.0)-20DP-0.5V (86)
DF12 (4.0)-30DP-0.5V (86)
DF12 (4.0)-32DP-0.5V (86)
DF12 (4.0)-36DP-0.5V (86)
DF12 (4.0)-40DP-0.5V (86)
DF12 (4.0)-50DP-0.5V (86)
DF12 (4.0)-60DP-0.5V (86)
DF12 (5.0)-20DP-0.5V (86)
DF12 (5.0)-30DP-0.5V (86)
DF12 (5.0)-36DP-0.5V (86)
DF12 (5.0)-40DP-0.5V (86)
DF12 (5.0)-50DP-0.5V (86)
DF12 (5.0)-60DP-0.5V (86)
DF12B (3.5)-20DP-0.5V (86)
DF12B (3.5)-30DP-0.5V (86)
DF12B (3.5)-36DP-0.5V (86)
DF12B (3.5)-40DP-0.5V (86)
DF12B (3.5)-50DP-0.5V (86)
DF12B (3.5)-60DP-0.5V (86)
DF12B (4.0)-20DP-0.5V (86)
DF12B (4.0)-30DP-0.5V (86)
DF12B (4.0)-32DP-0.5V (86)
DF12B (4.0)-36DP-0.5V (86)
DF12B (4.0)-40DP-0.5V (86)
DF12B (4.0)-50DP-0.5V (86)
DF12B (4.0)-60DP-0.5V (86)
DF12B (5.0)-20DP-0.5V (86)
DF12B (5.0)-30DP-0.5V (86)
DF12B (5.0)-36DP-0.5V (86)
DF12B (5.0)-40DP-0.5V (86)
DF12B (5.0)-50DP-0.5V (86)
DF12B (5.0)-60DP-0.5V (86)
537-0028-7 86
537-0030-9 86
537-0031-1 86
537-0032-4 86
537-0034-0 86
537-0036-5 86
537-0053-4 86
537-0055-0 86
537-0926-2 86
537-0056-2 86
537-0057-5 86
537-0059-0 86
537-0061-2 86
537-0153-9 86
537-0155-4 86
537-0156-7 86
537-0157-0 86
537-0159-5 86
537-0161-7 86
537-0328-0 86
537-0330-2 86
537-0331-5 86
537-0332-8 86
537-0334-3 86
537-0336-9 86
537-0353-8 86
537-0355-3 86
537-0927-5 86
537-0356-6 86
537-0357-9 86
537-0359-4 86
537-0361-6 86
537-0378-9 86
537-0380-0 86
537-0381-3 86
537-0382-6 86
537-0384-1 86
537-0386-7 86
36
40
50
60
32
36
40
50
60
36
40
50
60
36
40
50
60
32
36
40
50
60
36
40
50
60
7.2
9.7
11.2
12.2
14.7
17.2
7.2
9.7
10.2
11.2
12.2
14.7
17.2
7.2
9.7
11.2
12.2
14.7
17.2
7.2
9.7
11.2
12.2
14.7
17.2
7.2
9.7
10.2
11.2
12.2
14.7
17.2
7.2
9.7
11.2
12.2
14.7
17.2
4.5
7.0
8.5
9.5
12.0
14.5
4.5
7.0
7.5
8.5
9.5
12.0
14.5
4.5
7.0
8.5
9.5
12.0
14.5
4.5
7.0
8.5
9.5
12.0
14.5
4.5
7.0
7.5
8.5
9.5
12.0
14.5
4.5
7.0
8.5
9.5
12.0
14.5
5.7
8.2
9.7
10.7
13.2
15.7
5.7
8.2
8.7
9.7
10.7
13.2
15.7
5.7
8.2
9.7
10.7
13.2
15.7
5.7
8.2
9.7
10.7
13.2
15.7
5.7
8.2
8.7
9.7
10.7
13.2
15.7
5.7
8.2
9.7
10.7
13.2
15.7
06.6
09.1
10.6
11.6
14.1
16.6
06.6
09.1
09.6
10.6
11.6
14.1
16.6
06.6
09.1
10.6
11.6
14.1
16.6
A200
0.25
E
Ø0.5
0.6
0.25
C
E
2.8
3.3
4.3
2.8
3.3
4.3
F
8.1
10.6
12.1
13.1
15.6
18.1
8.1
10.6
11.1
12.1
13.1
15.6
18.1
8.1
10.6
12.1
13.1
15.6
18.1
8.1
10.6
12.1
13.1
15.6
18.1
8.1
10.6
11.1
12.1
13.1
15.6
18.1
8.1
10.6
12.1
13.1
15.6
18.1
Remarks
RoHS
With metal fitting
With boss
YES
With metal fitting
Without boss
BEmbossed Carrier tape Dimensions
●Receptacle
●Header
Connector
DF12#(3.0)-10DS-0.5V
DF12#(3.0)-14DS-0.5V
DF12#(3.0)-20DS-0.5V
DF12#(3.0)-30DS-0.5V
DF12#(3.0)-32DS-0.5V
DF12#(3.0)-36DS-0.5V
DF12#(3.0)-40DS-0.5V
DF12#(3.0)-50DS-0.5V
DF12#(3.0)-60DS-0.5V
DF12#(3.0)-80DS-0.5V
DF12#(3.0)-10DP-0.5V
DF12#(3.0)-14DP-0.5V
DF12#(3.0)-20DP-0.5V
DF12#(3.0)-30DP-0.5V
DF12#(3.0)-32DP-0.5V
DF12#(3.0)-36DP-0.5V
DF12#(3.0)-40DP-0.5V
DF12#(3.0)-50DP-0.5V
DF12#(3.0)-60DP-0.5V
DF12#(3.0)-80DP-0.5V
DF12#-20DS-0.5V
DF12#-30DS-0.5V
DF12#-32DS-0.5V
DF12#-36DS-0.5V
DF12#-40DS-0.5V
DF12#-50DS-0.5V
DF12#-60DS-0.5V
A
B
16
7.5
24
32
44
16
24
C
D
F
G
17.5 21.5
11.5
0.38 25.5 29.5
14.2
20.2
7.5
E
0.30
2.6
33.5 37.5
45.5 49.5
0.30
12
17.5 21.5
11.5
25.5 29.5
0.38
32
44
16
14.2
20.2
7.5
24
11.5
32
8
12
8
14.2 12
33.5 37.5
45.5 49.5
17.5 21.5
3.1
Connector
DF12#(3.5)-20DP-0.5V
DF12#(3.5)-30DP-0.5V
DF12#(3.5)-36DP-0.5V
DF12#(3.5)-40DP-0.5V
DF12#(3.5)-50DP-0.5V
DF12#(3.5)-60DP-0.5V
DF12#(4.0)-30DP-0.5V
DF12#(4.0)-32DP-0.5V
DF12#(4.0)-36DP-0.5V
DF12#(4.0)-40DP-0.5V
DF12#(4.0)-50DP-0.5V
DF12#(4.0)-60DP-0.5V
DF12#(5.0)-20DP-0.5V
DF12#(5.0)-30DP-0.5V
DF12#(5.0)-36DP-0.5V
DF12#(5.0)-40DP-0.5V
DF12#(5.0)-50DP-0.5V
DF12#(5.0)-60DP-0.5V
A
16
B
7.5
24
11.5
32
16
14.2
7.5
24
11.5
32
16
C
D
12
8
12
8
0.38
3.1
12
8
12
8
E
3.6
0.30
25.5 29.5
0.38
0.30
33.5 37.5
0.38 17.5 21.5
0.30
33.5 37.5
17.5 21.5
12
11.5
32
14.2
25.5 29.5
0.38
0.30
14.2
7.5
24
F
G
17.5 21.5
0.38
4.6
8
12
25.5 29.5
0.30
0.38 33.5 37.5
0.30
25.5 29.5
0.38
0.30
0.38 33.5 37.5
A201
Ø1
3±
Product name label
0.2
●Reel Dimensions
A202
Ø330±2
Ø80±1
PS
Lead hole depth
F±0.5
G±1
Refer to former page for F, G dimensions.
BRecommended PCB mounting pattern
■DF12 with metal fitting
■DF12 without metal fitting
Note 1 : Refer to A195 to A200 for sides A, B, and D.
Note 2 : If the boss isn't included, the boss shown in the above figure isn't required.
Note 3 :
If the pattern is included in the shaded area, and not treated with resist, it could touch the connector contact .
BPrecautions for Use
1.Recommended Temperature Profile (SMT)
Temperature (ç)
250
250ç
220ç
200
60sec max
Soldering
180ç
150
Powered by TCPDF (www.tcpdf.org)
150ç
90 to 120sec
Preheating
100
50
Room
temperature
100
150
200
250
300
Time (sec)
Note1 : UP to 2 cycles of Reflow soldering are possible under the
same conditions, provided that there is a return to normal
temperature between the first and second cycle.
Note2 : The temperature profile indicates the board surface
temperature at the point of contacts with the connector
terminals.
2.Recommended Manual Soldering Condition (SMT) Soldering iron temperature : 350ç, Soldering time : Within 3 seconds
3.Recommended Screen Thickness and 0.12mm
open area ratio(Pattern area ratio)
Open area ratio : 70%
4.Board Warp(SMT)
Maxmum 0.02mm in the connector center area, based on both connector edges
5.Cleaning Condition
Refer to "Nylon Connector Use Hand book".
6.Cautions
■ The receptacle is designed in a structure where contacts are exposed. Touching it with
bare hands would cause contact failure or electrostatic element damage.
■ Where no board is mounted, the insertion or extraction will cause damage or
contact deformation.
■ Avoid retaining the board with the connector only, and fix the board by any other means
than the connector.
■ Excessive scoop insertion or extraction may result in damage.
■ In the manual soldering process, don't carry out the flux coating which will cause a flux
blister on the connector.
■ The color phase of this product may be slightly different from that of the formed product
according to the manufacturing lot. However, the difference doesn't affect the performance.
A203
