1mm Pitch Connectors for Vertical Connection
FX5 Series
Connecting Height: Low profile
FX5_*P_SH
PCB
Fig.1
■Features
1. Header Side : 2 Types Available
Connecting Height: High profile
Two header types are available, low and high profiles.
Combined with various contact positions, the FX5 is
versatile to work in many application. (See Fig.1 and 2)
FX5_*S2A_DSA
FX5_*P_SH3
2. Two-step, Sequential Mating
The mating sequence features a 2-step, "first mate-last
break" condition that helps to protect the circuit.
3. Mating Guide
A guide rib is provided along with a self-alignment
range of ± 1mm to allow for easy mating operations.
( 6.6 )
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
( 3.6 )
FX5_*S2A_DSA
4. SMT Coplanarity
The coplanarity of SMT soldered area has a high accuracy
of 0.1mm.
PCB
5. Miniaturization
Fig.2
The FX5 uses about 30% less mounting area on the
board compared with a 1.27mm pitch connector.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2015.4w
1
FX5 Series●1mm Pitch Connectors for Vertical Connection
■Product Specifications
Current rating 0.5A
Operating Temperature Range -55ç to +85ç (Note 1)
Storage Temperature Range -10ç to +60ç (Note 2)
Voltage rating 100V AC
Operating Humidity Range 40% to 80%
Storage Humidity Range
Ratings
Items
Specifications
100M ohms min.
250V DC
2. Withstanding voltage
No flashover or insulation breakdown.
300V AC/1 minute
3. Contact Resistance
50m ohms max.
5. Moisture Resistance
6. Temperature Cycle
Conditions
1. Insulation Resistance
4. Vibration Resistance
7. Mating Cycles
8. Resistance to Soldering
heat
40% to 70%
100mA
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm,
No electrical discontinuity of 1μs or more
Contact resistance: 60m ohms max.
2 hours in each of the 3 directions.
96 hours at temperature of 40ç and humidity of
Insulation resistance: 100M ohms min.
90% to 95%
(-55ç: 30 minutes, 15 to 35ç: 2 to 3 minutes
(-85ç: 30 minutes, 15 to 35ç: 2 to 3minutes) 5 cycles
500 cycles
SMT
No deformation of components affecting
performance.
DIP
Reflow: At the recommended temperature profile
Manual soldering: 360°C for 5 seconds
Solder Bath: 260ç for 10 seconds
Manual soldering: 360ç for 5 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for a long time prior to use. Operating temperature and humidity range includes a
non-conducting state of installed connectors in storage, shipment, or during transportation.
■Material
Part
Material
Finish
Remarks
Insulator
Polyamide
Beige
UL94V-0
Header Contact
Brass
Contact area : Gold plated
Receptacle Contact
Phosphor bronze
Lead area : Tin plated
Note : The black dots on the insulater will not affect performance
■Product Number Structure
●Header
FX5 – * P – SH 3
q
q Series Name
w
e
r
t
t Connector Height
: FX5
w Number of Contacts : 20, 40, 52, 56, 68, 80
Blank
: 6.5mm
e Connector Type
3
: 9.5mm
P: Header
r Contact type
SH
: Right angle SMT type
Note: The 56 contact header is for SH 3 type only.
●Receptacle
FX5 – * S 2 A – DSA L
q
q Series Name
w
: FX5
e Connector Type
S: Receptacle
r Contact Sequence
2
t Serial No. : A
2
: 2 Stages Sequence
e
r
t
y
u
y Contact type
DSA
: Straight through hole type
u Board prefixed pin
Blank
: Without board prefixed pin
L
: With board Prefixed pin
■Header
●High profile
V'
W&
V&
V&
W&
W
V
6
7¤%#(
8¤%#*
9¤%#(
EdaVg^inBVg`
V&
V'
* == (number of contacts)/2
V
6
7¤%#(
8¤%#*
9¤%#(
EdaVg^inBVg`
%î
&T%#'
%î
&T%#'
W
W'
W'
W&
V&
V&
W&
V'
W
V
i%#'¤%#%*£l%#'¤%#%*
'T¢'#(¤%#&*
很抱歉,暂时无法提供与“FX5-56P-SV”相匹配的价格&库存,您可以联系我们找货
