JMD CONNECTOR
0.5mm
Emboss Tape
Board-to-board connectors
(.020") pitch
Features––––––––––––––––––––––––
• Smooth connection
Thanks to the cantilever type contacts, mating is very smooth.
• Distortion preventive construction
Box-shaped plug housing has guide ribs on both ends, which
prevents distortion.
• Wide range of circuits
No.of circuits available are from 20 to 100, every 10 circuiits.
• Embossed taping for automatic mounting
This connector is supplied in embossed tape packaging, for
mounting by automatic placement machines.
Specifications –––––––––––––––––––
• Current rating: 0.5A AC,DC
• Voltage rating: 50V AC,DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/50m Ω max.
After environmental testing/100m Ω max.
• Insulation resistance:
50M Ω min.
• Withstanding voltage: 100V AC/minute
* Contact JST if Lead-Free product is required.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
0 Recognized E60389
1
Certified LR20812
375
JMD
CONNECTOR
Plug ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Top entry type
Side entry type
C
B
A
0.5
(.020)
2.3(.091)
0.2(.008)
0.2(.008)
2.3
(.091)
4.8(.189)
C
0.5
(.020)
A
B
1.15(.045)
Model No.
Circuits
Circuits
Dimensions mm(in.)
ModelTop
No.entry type
Top
entry(.177")
type
4.5mm
5.0mm (.197")
1.3(.051)
Dimensions mm(in.)
A
B
C
C
A
B
Side entry type
Side entry type
6.0mm (.236")
Q'ty /
Q´ty
reel/
reel
20P-JMDSS-G-1-TF
20PS-JMDSS-G-1-TF
4.5(.177)
9.1( .358)
5.7( .224)
1,500
30
30P5.0-JMDSS-G-1-TF
30PS-JMDSS-G-1-TF
7.0(.276)
11.6( .457)
8.2( .323)
1,500
40
40P-JMDSS-G-1-TF
40P5.0-JMDSS-G-1-TF
40PS-JMDSS-G-1-TF
9.5(.374)
14.1( .555)
10.7( .421)
1,500
50
50P-JMDSS-G-1-TF
50P6.0-JMDSS-G-1-TF
50PS-JMDSS-G-1-TF
12.0(.472)
16.6( .654)
13.2( .520)
1,500
60
60P-JMDSS-G-1-TF
60P6.0-JMDSS-G-1-TF
60PS-JMDSS-G-1-TF
14.5(.571)
19.1( .752)
15.7( .618)
1,500
70
70P-JMDSS-G-1-TF
70P6.0-JMDSS-G-1-TF
70PS-JMDSS-G-1-TF
17.0(.669)
21.6( .850)
18.2( .717)
1,500
80
80P-JMDSS-G-1-TF
80PS-JMDSS-G-1-TF
19.5(.768)
24.1( .949)
20.7( .815)
1,500
100
100P-JMDSS-G-1-TF
100PS-JMDSS-G-1-TF
24.5(.965)
29.1(1.146)
25.7(1.012)
1,500
Material and Finish
Contact: Phosphor bronze, gold-plated
Housing: Polyamide, UL94V-0
Solder tab: Brass, copper-undercoated, tin/lead-plated
Note: The products listed above are supplied on embossed-tape.
Receptacle –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Circuits
0.2(.008)
3.1
(.122)
C
2.3
(.091)
0.5
(.020)
A
B
376
1.7
(.067)
Dimensions mm(in.)
Model No.
A
B
C
Q'ty /
reel
20R-JMDSS-G-1-TF
4.5(.177)
9.1( .358)
5.7( .224)
1,500
30
30R-JMDSS-G-1-TF
7.0(.276)
11.6( .457)
8.2( .323)
1,500
40
40R-JMDSS-G-1-TF
9.5(.374)
14.1( .555)
10.7( .421)
1,500
50
50R-JMDSS-G-1-TF
12.0(.472)
16.6( .654)
13.2( .520)
1,500
60
60R-JMDSS-G-1-TF
14.5(.571)
19.1( .752)
15.7( .618)
1,500
70
70R-JMDSS-G-1-TF
17.0(.669)
21.6( .850)
18.2( .717)
1,500
80
80R-JMDSS-G-1-TF
19.5(.768)
24.1( .949)
20.7( .815)
1,500
100
100R-JMDSS-G-1-TF
24.5(.965)
29.1(1.146)
25.7(1.012)
1,500
Material and Finish
JMD
CONNECTOR
Taping specifications ––––––––––––––––––––––––––––––––––––––––––––––––––––––
380 ± 2.0(14.961 ±.079)dia.
Feeding direction
1.55±0.05
(.061±.002)dia.
20 to
50 circuits
W±0.3(.012)
12.0±0.1
(.472±.004)
S±0.1(.004)
12.0±0.1
(.472±.004)
12.0±0.1
(.472±.004)
Dimensions mm(in.)
F
S
W
W1
Q'ty /
reel
16.0( .630)
17.5( .689)
1,500
30
11.5( .453)
24.0( .945)
25.5(1.004)
1,500
40
11.5( .453)
24.0( .945)
25.5(1.004)
1,500
50
11.5( .453)
24.0( .945)
25.5(1.004)
1,500
60
14.2( .559)
28.4(1.118)
32.0(1.260)
32.0(1.260)
1,500
70
14.2( .559)
28.4(1.118)
32.0(1.260)
32.0(1.260)
1,500
80
20.2( .795)
40.4(1.591)
44.0(1.732)
44.0(1.732)
1,500
100
20.2( .795)
40.4(1.591)
44.0(1.732)
44.0(1.732)
1,500
PC board layout (viewed from component side) ––––––
0.5±0.03
(.020±.001)
0.3±0.05
(.012±.002)
Note: 1. Specifications conform to JIS C 0806. The tape width, connector
loading recess square hole dimensions, etc. are determined by the
number of circuits and external shape of the connector to be loaded.
Note: 2. Specifications are subject to change without prior notice.
Assembly layout–––––––––––––––––––––
Top entry type
1.55 0.85
(.061) (.033)
4.3(.169)
1.4(.055)
0.5(.020)
2.9(.114)
5.8(.228)[ Receptacle]
5.6(.220)
Plug: top entry type
Receptacle
0.85 1.55
(.033) (.061)
0.5±0.03
(.020±.001)
0.3±0.05
(.012±.002)
( )P-JMDSS-G-1-TF : 4.5(.177)
( )P5.0-JMDSS-G-1-TF : 5.0(.197)
( )P6.0-JMDSS-G-1-TF : 6.0(.236)
Circuits
1.55±0.05
(.061±.002)dia.
4±0.1
1.65±0.1
(.157±.004) (.065±.004)
Feeding direction
S±0.1(.004)
60 to 100
circuits
W±0.3(.012)
1.55±0.05
(.061±.002)dia.
Carrier tape
F±0.1(.004)
2.0±0.1
(.079±.004)
F±0.1(.004)
60 to 100
circuits
4±0.1
(.157±.004)
1.75±0.1
(.069±.004)
Feeding direction
Cover tape
Carrier tape
Cover tape
W±0.3(.012)
12.0±0.1
(.472±.004)
1.75±0.1
(.069±.004)
20 to
50 circuits
4±0.1
1.65±0.1
1.75±0.1
(.069±.004)
Feding direction
F±0.1(.004)
Feeding direction
Plug: side entry type
F±0.1(.004)
4±0.1
2.0±0.1
(.157±.004) (.079±.004)
1.55±0.05
(.061±.002)dia.
1.75±0.1
(.069±.004)
Receptacle
Leader part
100(3.937)min.
The end part Connector
160(6.299)min. mounting part 400(15.748)min.
2.0± 0.5
(.079± .020)
W1 +2.5
-1.0
( +.098
-.039)
Cover tape leader
W±0.3(.012)
[13(.512)dia.]
Feeding direction
Carrier tape
Side entry type
1.35
(.053)
5.6(.220)
3.05(.120)
1.35
(.053)
1.4
(.055)
2.6(.102)
4.8(.189)
Note:
1. Tolerances are non-cumulative: ±0.03mm (±.001") for all centers.
2. The dimensions above should serve as a guideline. Contact JST for details.
377
很抱歉,暂时无法提供与“50P-JMDSS-G-1-TF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+15.273431+1.97853
- 10+12.9573410+1.67851
- 25+12.1414725+1.57282
- 50+11.5608550+1.49760
- 100+11.00733100+1.42590
- 250+10.31801250+1.33661
- 500+9.82514500+1.27276
- 国内价格 香港价格
- 1500+9.092381500+1.17784
- 3000+8.658653000+1.12165
- 4500+8.414614500+1.09004
- 7500+8.117077500+1.05149
- 10500+7.9268710500+1.02686
