DF17A(3.0)-30DS-0.5V(57)
    HRS(广濑)
    CONN RECEPT 30POS .5MM SMD GOLD
DF17A(3.0)-30DS-0.5V(57) 数据手册
0.5mm Pitch Board to Board Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF17 Series Solution of Connector Damage Caused when Mobile Phone is Dropped ■Features 1. Withstands Drop Impact or Shock ・All 4 sides covered by box design ・Bellows contacts strong against vibration ・Convex on receptacle increases strength enhance shock-proof, pinch-proof and scoop-proof performance. (Fig.1)(Fig.2) 2. With Metal Fitting available In order to grade up the strength against the mechanical stress, the metal fitting specification is also available. 3. Wide Variety of No. of Positions Fig.1 The connectors are lined up per 10 contacts from 20 to 80 pos. to take countermeasures for multi-signalization. 4. Stacking Height 4 to 8mm The stacking height can be selected (per milimeter) between 4mm and 8mm in combination of the receptacle with the header. Fig.2 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.12 1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF17 Series●0.5mm Pitch Board to Board Connector DF17#(□)-*DS-0.5V Receptacle 3.0 4.0 Receptacle DF17(3.0H)-*DS-0.5V Header Header DF17(1.0H)-*DP-0.5V 4mm 2.0 5mm 6mm 5.5mm 6.5mm 7mm 8mm 2.5 DF17#(□)-*DP-0.5V 4.0 ■Applications Mobile phones, LCD, miniature equipment and so on 2 Note : The stacking height doesn't include the solder paste thickness. DF17 Series●0.5mm Pitch Board to Board Connector ■Product Specifications Rating Current rating Voltage rating 0.3A 50V AC Items Operating Temperature Range -35 to 85ç (Note 1) Storage Temperature Range -10 to 60ç (Note 2) 40 to 80% 40 to 70% Operating Humidity Range Storage Humidity Range Specifications Conditions 1. Insulation Resistance 500MΩ min. 2. Withstanding voltage No flashover or insulation breakdown. 3. Contact Resistance 60mΩ max. 100V DC 150V AC/1 minute 100mA Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. 4. Vibration No electrical discontinuity of 1μs or more 5. Humidity (Steady state) Contact resistance : 60mΩ max. Insulation resistance : 250MΩ min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6. Temperature Cycle Contact resistance : 60mΩ max. Insulation resistance : 500MΩ min. (-55ç : 30 minutes 5 to 35ç : 10 minutes 85ç : 30 minutes 5 to 35ç : 10 minutes) 5 cycles Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7. Durability (Mating/un-mating) Contact resistance : 60mΩ 8. Resistance to Soldering heat 50 cycles Reflow : At the recommended temperature profile Manual soldering : 350ç for 3 seconds No deformation of components affecting performance. Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials / Finish Product Receptacle Header Part Material Finish Remarks Insulator Polyamide White UL94V-0 Contact Phosphor copper Gold plated (Note 1) --------------- Solder tab Phosphor copper Tin-lead plated --------------- Insulator Polyamide White UL94V-0 Contact Phosphor copper Gold plated (Note 2) --------------- Solder tab Phosphor copper Tin-lead plated --------------- Note1 : DF17(0.3)-*DS-0.5V : Contact area : gold plating/lead area : flash gold plated DF17(4.0)-*DS-0.5V : Contact area : gold plating/lead area : tin plated DF17(4.0)-*DP-0.5V : Contact area : gold plating/lead area : tin plated Note2 : The header gold plated product : Contact area : gold plating/lead area : tin plated DF17(1.0H)-*DS-0.5V only : Contact area : gold plating/lead area : flash gold plated ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacle/Header DF17 # 1 (**) 2 - * DS - 0.5 V (**) 4 3 1 Series Name : DF17 6 7 8 4 Number of Pos. 2 Type DF17 DF17B 5 20, 26, 30, 40, 50, 60, 70, 80 contacts Solder tab K K Boss K ∞ 5 Connector Type DS : Receptacle DP : Header 6 Contact Pitch : 0.5mm 7 Contact Style V : Straight SMT 3 Product height The stacking height can be determined by adding the figures in parentheses to receptacle and header. 8 Packaging Type (57) : Gold plated,embossed tape packaging 3 DF17 Series●0.5mm Pitch Board to Board Connector ■Receptacle A B With Solder Tab C D 3.9 1.8 5.7 A 4.7 P=0.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.2 H 0.7 G 0.2 Ø0.5 1.5 1.9 E F ● Stacking Height : 4mm Part No. HRS No. Number of Pos. A B C D E F DF17(3.0H)-26DS-0.5V(57) 683-0253-2 57 26 11.5 08.3 07.0 06.0 08.5 11.3 DF17(3.0H)-30DS-0.5V(57) 683-0268-0 57 30 12.5 09.3 08.0 07.0 09.5 12.3 DF17(3.0H)-60DS-0.5V(57) 683-0361-5 57 60 20.0 16.8 15.5 14.5 17.0 19.8 DF17(3.0H)-70DS-0.5V(57) 683-0393-1 57 70 22.5 19.3 18.0 17.0 19.5 22.3 DF17(3.0H)-80DS-0.5V(57) 683-0369-7 57 80 25.0 21.8 20.5 19.5 22.0 24.8 G H RoHS 3.0 3.0 YES G H RoHS 3.5 3.0 YES G H RoHS 4.5 4.0 YES ● Stacking Height : 5mm, 7mm Part No. HRS No. Number of Pos. A B C D E F DF17(3.0)-20DS-0.5V(57) 683-0002-2 57 020 10.0 06.8 05.5 04.5 07.0 09.8 DF17(3.0)-26DS-0.5V(57) 683-0241-3 57 026 11.5 08.3 07.0 06.0 08.5 11.3 DF17(3.0)-30DS-0.5V(57) 683-0003-5 57 030 12.5 09.3 08.0 07.0 09.5 12.3 DF17(3.0)-40DS-0.5V(57) 683-0004-8 57 040 15.0 11.8 10.5 09.5 12.0 14.8 DF17(3.0)-50DS-0.5V(57) 683-0005-0 57 050 17.5 14.3 13.0 12.0 14.5 17.3 DF17(3.0)-60DS-0.5V(57) 683-0006-3 57 060 20.0 16.8 15.5 14.5 17.0 19.8 DF17(3.0)-70DS-0.5V(57) 683-0007-6 57 070 22.5 19.3 18.0 17.0 19.5 22.3 DF17(3.0)-80DS-0.5V(57) 683-0008-9 57 080 25.0 21.8 20.5 19.5 22.0 24.8 ● Stacking Height : 6mm, 8mm Part No. HRS No. Number of Pos. A B C D E F DF17(4.0)-20DS-0.5V(57) 683-0042-7 57 20 10.0 06.8 05.5 04.5 07.0 09.8 DF17(4.0)-30DS-0.5V(57) 683-0043-0 57 30 12.5 09.3 08.0 07.0 09.5 12.3 DF17(4.0)-40DS-0.5V(57) 683-0044-2 57 40 15.0 11.8 10.5 09.5 12.0 14.8 DF17(4.0)-50DS-0.5V(57) 683-0045-5 57 50 17.5 14.3 13.0 12.0 14.5 17.3 DF17(4.0)-60DS-0.5V(57) 683-0046-8 57 60 20.0 16.8 15.5 14.5 17.0 19.8 DF17(4.0)-70DS-0.5V(57) 683-0047-0 57 70 22.5 19.3 18.0 17.0 19.5 22.3 DF17(4.0)-80DS-0.5V(57) 683-0048-3 57 80 25.0 21.8 20.5 19.5 22.0 24.8 Note 1 : In regard to this product, the embossed tape packaging is the standard packaging. (1000 pcs./ reel.) Note 2 : If the without boss specification is required, please contact HRS sales department. 4 DF17 Series●0.5mm Pitch Board to Board Connector ■ Header With Solder Tab A B C D A 5.7 4.7 3.8 1.8 P=0.5 H G 0.25 0.2 1.9 E 1.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.7 Ø0.5 F ● Stacking Height : 4mm Part No. HRS No. Number of Pos. A B C D E F DF17(1.0H)-26DP-0.5V(57) 683-0257-3 57 26 11.5 08.2 07.1 06.0 08.5 11.3 DF17(1.0H)-30DP-0.5V(57) 683-0272-7 57 30 12.5 09.2 08.1 07.0 09.5 12.3 DF17(1.0H)-60DP-0.5V(57) 683-0365-6 57 60 20.0 16.7 15.6 14.5 17.0 19.8 DF17(1.0H)-70DP-0.5V(57) 683-0397-2 57 70 22.5 19.2 18.1 17.0 19.5 22.3 DF17(1.0H)-80DP-0.5V(57) 683-0373-4 57 80 25.0 21.7 20.6 19.5 22.0 24.8 G H RoHS 3.3 1.0 YES G H RoHS 4.3 2.0 YES G H RoHS 6.3 4.0 YES G H RoHS 4.8 2.5 YES ● Stacking Height : 5mm, 6mm Part No. HRS No. Number of Pos. A B C D E F DF17(2.0)-20DP-0.5V(57) 683-0082-1 57 020 10.0 06.7 05.6 04.5 07.0 09.8 DF17(2.0)-30DP-0.5V(57) 683-0083-4 57 030 12.5 09.2 08.1 07.0 09.5 12.3 DF17(2.0)-40DP-0.5V(57) 683-0084-7 57 040 15.0 11.7 10.6 09.5 12.0 14.8 DF17(2.0)-50DP-0.5V(57) 683-0085-0 57 050 17.5 14.2 13.1 12.0 14.5 17.3 DF17(2.0)-60DP-0.5V(57) 683-0086-2 57 060 20.0 16.7 15.6 14.5 17.0 19.8 DF17(2.0)-70DP-0.5V(57) 683-0087-5 57 070 22.5 19.2 18.1 17.0 19.5 22.3 DF17(2.0)-80DP-0.5V(57) 683-0088-8 57 080 25.0 21.7 20.6 19.5 22.0 24.8 ● Stacking Height : 7mm, 8mm Part No. HRS No. Number of Pos. A B C D E F DF17(4.0)-20DP-0.5V(57) 683-0122-4 57 20 10.0 06.7 05.6 04.5 07.0 09.8 DF17(4.0)-30DP-0.5V(57) 683-0123-7 57 30 12.5 09.2 08.1 07.0 09.5 12.3 DF17(4.0)-40DP-0.5V(57) 683-0124-0 57 40 15.0 11.7 10.6 09.5 12.0 14.8 DF17(4.0)-50DP-0.5V(57) 683-0125-2 57 50 17.5 14.2 13.1 12.0 14.5 17.3 DF17(4.0)-60DP-0.5V(57) 683-0126-5 57 60 20.0 16.7 15.6 14.5 17.0 19.8 DF17(4.0)-70DP-0.5V(57) 683-0127-8 57 70 22.5 19.2 18.1 17.0 19.5 22.3 DF17(4.0)-80DP-0.5V(57) 683-0128-0 57 80 25.0 21.7 20.6 19.5 22.0 24.8 ● Stacking Height : 5.5mm,6.5mm Part No. HRS No. Number of Pos. A B C D E F DF17(2.5)-26DP-0.5V(57) 683-0245-4 57 26 11.5 08.2 07.1 06.0 08.5 11.3 DF17(2.5)-80DP-0.5V(57) 683-0168-5 57 80 25.0 21.7 20.6 19.5 22.0 24.8 Note 1 : In regard to this product, the embossed tape packaging is the standard packaging. (1000 pcs./reel.) Note 2 : If the without boss specification is required, please contact HRS sales department. 5 DF17 Series●0.5mm Pitch Board to Board Connector ■PCB Mounting Pattern ●Receptacle ●Header J+0.1 0 0 K -0.1 D±0.03 1.9±0.02 0 S -0.05 6.3 +0.1 0 2.1+0.1 0 P= 0.5±0.02 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. .05 +00 .6 Ø0 0.25±0.02 E±0.03 Number of Pos. 020 D 04.5 E 07.0 J 10.4 K 07.6 S Receptacle 4.3 026 06.0 08.5 11.9 9.1 Header 4.0 030 07.0 09.5 12.9 10.1 040 09.5 12.0 15.4 12.6 050 12.0 14.5 17.9 15.1 060 14.5 17.0 20.4 17.6 070 17.0 19.5 22.9 20.1 080 19.5 22.0 25.4 22.6 Note 1 : * The recommended solder paste thickness is 150µm. If the pattern is included in the shaded area, and not treated with resist, it could touch the connector contact. Note 2 : If the boss isn't included, the boss hole shown in the above figure isn't required. 6 DF17 Series●0.5mm Pitch Board to Board Connector ■Packaging Specification 2±0.1 .1 +00 .5 Ø1 12±0.1 4±0.1 Y−Y N±0.3 M±0.1 L±0.1 Y 1.75±0.1 ●Embossed Carrier Tape Dimensions ■Receptacle R0 5 .7 0.2±0.05 R0 .75 +0 0 .1 5 15 0. + 0 Y Unreeling direction 0.3±0.1 X−X Connector L P±0.15 M P Q R Connector L M N P Q R DF17#(3.0)-20DS-0.5V 11.5 24 3.8 25.5 330 DF17#(3.0)-50DS-0.5V 14.2 28.4 32 3.8 33.5 330 DF17#(3.0)-30DS-0.5V 11.5 24 3.8 25.5 330 DF17#(3.0)-60DS-0.5V 14.2 28.4 32 3.8 33.5 330 DF17#(3.0)-40DS-0.5V 11.5 24 3.8 25.5 330 DF17#(3.0)-70DS-0.5V 20.2 40.4 44 3.8 45.5 330 DF17#(3.0)-26DS-0.5V 11.5 24 3.8 25.5 330 DF17#(3.0)-80DS-0.5V 20.2 40.4 44 3.8 45.5 330 N P Q R M N P Q R DF17#(4.0)-20DS-0.5V 11.5 Connector L 24 4.8 25.5 330 DF17#(4.0)-50DS-0.5V 14.2 Connector L 28.4 32 4.8 33.5 330 DF17#(4.0)-30DS-0.5V 11.5 24 4.8 25.5 330 DF17#(4.0)-60DS-0.5V 14.2 28.4 32 4.8 33.5 330 DF17#(4.0)-40DS-0.5V 11.5 24 4.8 25.5 330 DF17#(4.0)-70DS-0.5V 20.2 40.4 44 4.8 45.5 330 DF17#(4.0)-80DS-0.5V 20.2 40.4 44 4.8 45.5 330 Connector L M N P Q R - 24 3.3 25.5 330 DF17#(3.0)-30DS-0.5V 11.5 - 24 3.3 25.5 330 DF17#(3.0)-60DS-0.5V 14.2 28.4 32 3.3 33.5 330 DF17#(3.0)-70DS-0.5V 20.2 40.4 44 3.3 45.5 330 DF17#(3.0)-80DS-0.5V 20.2 40.4 44 3.3 45.5 330 DF17#(3.0)-26DS-0.5V 11.5 .2 ●Reel Dimensions Ø1 3± 0 Ø1.5 Lead hole depth ØR±2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. X X Q±0.5 (Q+4)±1 7 DF17 Series●0.5mm Pitch Board to Board Connector 2±0.1 4±0.1 .1 +00 .5 Ø1 12±0.1 1.75±0.1 ■Header Y−Y N±0.3 M±0.1 L±0.1 Y R0 5 .7 +0 0 .15 .75 R0 0.2±0.05 15 0. + 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. X X Unreeling direction Connector Y 0.3±0.1 P±0.15 X−X N P Q R DF17#(2.0)-20DP-0.5V 11.5 24 4.6 25.5 330 DF17#(2.0)-30DP-0.5V 11.5 24 4.6 25.5 330 DF17#(2.0)-40DP-0.5V 11.5 24 4.6 25.5 DF17#(2.5)-26DP-0.5V 11.5 24 5.1 25.5 DF17#(2.5)-80DP-0.5V 20.2 44 5.1 45.5 330 N P Q R DF17#(4.0)-20DP-0.5V 11.5 24 6.6 25.5 380 DF17#(4.0)-30DP-0.5V 11.5 24 6.6 25.5 380 DF17#(4.0)-40DP-0.5V 11.5 24 6.6 25.5 380 Connector L L Connector L M N P Q R DF17#(2.0)-50DP-0.5V 14.2 28.4 32 4.6 33.5 330 DF17#(2.0)-60DP-0.5V 14.2 28.4 32 4.6 33.5 330 330 DF17#(2.0)-70DP-0.5V 20.2 40.4 44 4.6 45.5 330 330 DF17#(2.0)-80DP-0.5V 20.2 40.4 44 4.6 45.5 330 M N P Q R DF17#(4.0)-50DP-0.5V 14.2 28.4 32 6.6 33.5 380 DF17#(4.0)-60DP-0.5V 14.2 28.4 32 6.6 33.5 380 DF17#(4.0)-70DP-0.5V 20.2 40.4 44 6.6 45.5 380 DF17#(4.0)-80DP-0.5V 20.2 40.4 44 6.6 45.5 380 M N P Q R DF17(1.0H)-26DP-0.5V 11.5 - 24 3.6 25.5 330 DF17(1.0H)-30DP-0.5V 11.5 - 24 3.6 25.5 330 DF17(1.0H)-60DP-0.5V 14.2 28.4 32 3.6 33.5 330 DF17(1.0H)-70DP-0.5V 20.2 40.4 44 3.6 45.5 330 DF17(1.0H)-80DP-0.5V 20.2 40.4 44 3.6 45.5 330 Connector L Connector L Ø1 3± 0.2 ●Reel Dimensions ØR±2 Ø1.5 Lead hole depth Q±0.5 8 (Q+4)±1 DF17 Series●0.5mm Pitch Board to Board Connector ■Precautions Temperature (ç) 250ç 250 220ç 200 180ç 150 1. Recommended 150ç 90~120sec Preheating 100 Temperature Profile Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (SMT) 60sec max Soldering 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Note1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note2 : The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2. Recommended Manual Soldering Condition Soldering iron temperature: 350±3çoldering time: Within 2 seconds (SMT) 3. Recommended Screen Thickness 0.15mm (SMT) 4. Board Warp(SMT) Max 0.02mm in the connector center area, based on the both connector edges 5. Cleaning Condition Refer to the "Nylon Connector Use Hand book". ■ The header is designed in a structure where contacts are exposed. Touching it with bare hands would cause contact failure or electrostatic element damage. ■ Where no board is mounted, the insertion or extraction will cause damage or contact deformation. 6. Cautions ■ Avoid retaining the board with the connector only, and fix the board by any other means than the connector. ■ Excessive scoop insertion or extraction may result in damage. ■ In the manual soldering process, don't carry out the flux coating which will cause a flux blister on the connector. ■ The color phase of this product may be slightly different from that of the formed product according to the manufacturing lot. However, the difference doesn't affect the performance. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 12/2021. Contents are subject to change without notice for the purpose of improvements. 9
物料型号:HIROSE ELECTRIC CO., LTD. 制造的DF17系列,0.5mm间距的板对板连接器。
器件简介: - 该连接器设计用于承受跌落冲击或震动,具有以下特点: - 四周覆盖的盒式设计 - 波纹管接触件,抗振动能力强 - 插座上的凸出部分增强了防震、防卡和防舀性能
引脚分配: - 连接器根据10个接触点的增量排列,从20到80个位置,以应对多信号化的需求。
参数特性: - 工作温度范围:-35°C至85°C - 存储温度范围:-10°C至60°C - 绝缘电阻:最小500MΩ - 耐电压:150V AC,1分钟无闪络或绝缘击穿 - 接触电阻:最大60mΩ - 振动测试:在10至55 Hz的频率下,单振幅0.75mm,每个方向2小时,无电气中断 - 湿热测试:在40°C和90%至95%湿度下,96小时,接触电阻最大60mΩ,绝缘电阻最小250MΩ - 温度循环测试:(-55°C:30分钟 5至35°C:10分钟 85°C:30分钟5至35°C:10分钟)5个周期 - 耐久性:插拔50次,接触电阻最大60mΩ - 耐焊接热:回流焊接时无影响性能的组件变形
功能详解: - 提供金属配件规格以增强机械应力下的强度。 - 可选择的堆叠高度从4mm到8mm。
应用信息: - 适用于移动电话、液晶显示器、微型设备等。
封装信息: - 绝缘体材料:聚酰胺,白色,UL94V-0等级。 - 接触材料:磷青铜,金镀层。 - 焊盘材料:磷青铜,锡铅镀层。
DF17A(3.0)-30DS-0.5V(57) 价格&库存
很抱歉,暂时无法提供与“DF17A(3.0)-30DS-0.5V(57)”相匹配的价格&库存,您可以联系我们找货
