EX80-54P(01)
EX80-54P(01)
    HRS(广濑)
    CONN PLUG 54POS
EX80-54P(01) 数据手册
0.6 mm Pitch, Docking Station Connectors EX80 Series Features Input 1. Secure electrical and mechanical connection The signal contacts wipe of 1.5 mm and built-in selfalignment assures reliable connection between plug and receptacle. 2. Sequential mating Plug design assures correct contact engagement sequence: ground-signal-power. 3. Reliable ground connection Guide tabs on the metal shell assure correct grounding sequence and high ground connection reliability with the board. Sig Rate: 2.5Gbps Sig Level: 0.5Vp-p X=100ps/div Y=100mV/div Output 4. High-speed data transfer Signals of 2.5 G bps can be transferred (PCI express). 5. Prevention of flux wicking Terminations of the contacts are designed to prevent a possibility of flux wicking into the contact areas. 6. Self alignment The connectors will self-align in X/Y axis within 1.2mm (0.7mm for receptacles with self-opening shutters) 7. Dedicated power supply contacts High electrical conductivity dedicated power contacts are rated 3 A. 8. High durability Bellows contact configuration assures reliable electrical and mechanical connection for 5,000 cycles (mating/un-mating). Applications Docking stations for notebook computers and other applications requiring high reliability, high data transfer sequential mating connections. 2014.10e 1 EX80 Series●0.6 mm Pitch, Docking Station Connectors Product specifications Ratings Storage temperature range -55ç to +85ç Voltage rating 125V AC Current rating Characteristic Signal contact 0.5A Power contact 3A Specification Conditions Signal contact: 70 mø max. Power contact: 40 mø max. 100m A 2. Insulation resistance 300 Mø min. 250 V DC 3. Withstanding voltage No flashover or insulation breakdown. 350 V AC/one minute 1. Contact resistance Materials Receptacles Component Contacts Material Finish Copper alloy Selective gold plated Insulator Shell LCP ----------------- Stainless steel Nickel / tinned copper plated Plugs Component Contacts Material Finish Copper alloy Selective gold plated Insulator Shell LCP ----------------- Stainless steel Nickel / tinned copper plated Ordering information Receptacles EX 80 − 54(50) S − SH (05) q w e r t Plugs EX 80 − 54(50) P (01) q w e r y y q Series number w Model serial indicator 80 e Number of contacts r Connector types t Receptacle, with shutter y Separate specifications : EX : Vertical SMT type : 54, 100 : 54(50)... 50 contacts mounted in a 54-contact size S: Receptacle connectors (Shell ground tab length 0.9 mm) P: Plug connectors (Shell ground tab length 0.9 mm) P1: Plug connectors (Shell ground tab length 2.2 mm) SH: Built-in shutters : See the Specifications Sheet of each products. Note: All connectors in this series are designed to be placed on the PCB 1mm min. thick. 2 EX80 Series●0.6 mm Pitch, Docking Station Connectors Plugs 100 pos. 45.3 33 30 28.2 NO.2 Power contact 16.6 0.6 (7) 10.9 NO.50 NO.1 Power contact NO.51 Power contact (25) NO.100 Recommended PCB mounting pattern (PCB thickness : 1 mm min.) 15.1 4.5 14.9 6.8 9.6 10.7 39 41.1 9.6 11.7 7.8 le) 17.5 Shell ground tab (4) 2.2 (Ho 1.2 2.8(Through hole) 14.9 2- 36.4 39 41.1 .1 +0 0 .5 Ø1 46 No conductive traces ) ole (H Part No. 41.1 0.9(Through hole) +0.1 0 17.5 2-Ø1.3 +0.10 (Through hole) Removable vacuum pick-up tape 0.9 (Through hole) 6.8±0.05 Ø1.7 33 (32.4) (31.5) 30 28.2 16.6±0.05 0.6±0.05 0.4±0.05 NO.52 Power contact HRS No. Contact plating (contact area/termination) Shell plating (Body / termination) EX80-100P1(50) 232-0598-9 50 Gold / Tinned copper Packaging Nickel / Tinned copper RoHS 1 pcs/tray 54 pos. 31.5 19.2 16.2 14.4 9.7 0.6 10.9 Signal contact No.27 Signal contact No.3 Power contact No.2 Power contact No.1 0.4 1.2 (H R0 ole 2.8(Through hole) ) ho le (Th rou gh 2-Ø 1.3 Part No. 15.1 4.5 0.2 10.6 Shell ground tab (4) 10.6 8 22.6 25.2 27.3 30.2 32.2 HRS No. EX80-54P (01) 232-0610-2 01 8 25.2 27.3 30.2 3.9 9.6 11.7 7.8 ) 1.5 3.9 6.8 9.6 10.7 0.9(Through hole) .7 .45 Ø1 0.9(Through hole) 6.8 2.8(Through hole) 19.2 16.2 14.4 9.7 0.6 27.3 0.9 Recommended PCB mounting pattern (PCB thickness : 1 mm min.) Power contact No.28 Power contact No.29 Signal contact No.30 Signal contact No.54 Removable vacuum pick-up tape No conductive traces 2-Ø1.5(hole) Contact plating (contact area/termination) Shell plating (Body / termination) Gold / Tinned copper Nickel / Tinned copper Packaging RoHS 1 pcs/tray Note: The design of the EX80-54P(01) does not have a detection signal contact. 3 EX80 Series●0.6 mm Pitch, Docking Station Connectors Receptacles (Without shutter) 100 pos. 43.4 33 30 28.2 16.6 0.6 NO.52 Power contact NO.51 Power contact 8.8 (7.9) (6) NO.100 (25) NO.50 Removable vacuum pick-up tape NO.1 Power contact NO.2 Power contact 45 33 (31.5) 30 28.2 16.6±0.05 0.4±0.05 0.6±0.05 +0 0 .1 (T hr 8-Ø1 .85 ou g (Lan h h d) ole 14.9 Shell ground tab (4) 40.15 40.9 43 1.2 0.6 0.8 3.2 7.7 8.6 5.6 9.6 7.7 3.2 ) 0.9 8Ø1 . 3.6 Recommended PCB mounting pattern (PCB thickness : 1 mm min.) R le) Ho n.( Part No. mi 34 34.9 40.15 40.9 43 No conductive traces R 0.9 1. 75 .6 Ø1 14.9 HRS No. EX80-100S(50) 232-0592-2 50 EX80-100S(51) 232-0592-2 51 Contact plating (contact area/termination) Shell plating (Body / termination) Gold / Tinned copper Nickel / Tinned copper Packaging RoHS 1 pcs/tray 1,000 pcs/reel 54 pos. 29.6 25 19.2 16.2 NO.30 Signal contact NO.29 Power contact 0.6 NO.28 Power contact 6 8.8 NO.54 Signal contact 14.4 9.7 Recommended PCB mounting pattern (PCB thickness : 1 mm min.) .4 hr 16.2 ou gh 8-Ø1 14.4 ho le (Lan d) 1.2 9.7 ) 0.4 0.6 5.6 7.7 .85 NO.3 Signal contact Removable vacuum pick-up tape (17.7) (T 3.6 5 Shell ground tab (4) 0.8 0.6 8 0.9 Ø1 NO.1 Power contact NO.2 Power contact NO.27 Signal contact 19.2 9.6 8- 27.35 7.7 8.6 R0 20.2 5 le) Ho 27.1 .7 ( n. 21.1 .9 R1 mi No conductive traces .6 Ø1 8 27.35 Part No. HRS No. Contact plating (contact area/termination) Shell plating (Body / termination) Packaging EX80-54S 232-0609-3 Gold / Tinned copper Nickel / Tinned copper 1,000 pcs/reel RoHS 4 EX80 Series●0.6 mm Pitch, Docking Station Connectors Plug (For the Receptacle with shutter) 54 pos. 31.5 19.2 16.2 14.4 9.7 0.6 10.9 Signal contact No.27 Signal contact No.3 Power contact No.2 Power contact No.1 Power contact No.28 Power contact No.29 Signal contact No.30 Signal contact No.54 27.3 ole 0.2 10.6 2.8(Through hole) 2Ø1 .5 (H ol e) 8 22.6 25.2 27.3 30.2 32.2 1.5 3.9 6.8 9.6 10.7 0.9 (Through hole) gh h ole) rou (Th 1.3 2-Ø 10.6 8 25.2 27.3 30.2 3.9 9.6 11.7 7.8 ) Shell ground tab (4) 0.9 0.4 1.2 (H R0 .7 .45 Ø1 0.9(Through hole) 6.8 2.8 (Through hole) 19.2 16.2 14.4 9.7 0.6 15.6 4.5 Recommended PCB mounting pattern (PCB thickness : 1 mm min.) No conductive traces Part No. HRS No. Contact plating (contact area/termination) Shell plating (Body / termination) Packaging EX80-54(50)P 232-0607-8 Gold / Tinned copper Nickel / Tinned copper 1 pcs/tray RoHS Note: The design of the EX80-54(50)P does not have a detection signal contact. Receptacle (With shutter) 54 pos. Shown without shutter 31.4 19.2 16.2 14.4 9.7 0.6 Signal contact No.30 Power contact No.29 Power contact No.28 8.8 Signal contact No.54 Signal contact No.27 Power contact No.1 Power contact No.2 Signal contact No.3 Th ro ug h 8-Ø1.85 (L ho 18.15 0.4 1.2 0.9 R 7.7 and) le) 27.1 19.2 16.2 14.4 9.7 0.6 R1 .75 8 e) ol EX80-54(50)S-SH(06) 232-0606-5 06 8 27.35 .(H EX80-54(50)S-SH(05) 232-0606-5 05 0.6 in m HRS No. .6 Part No. Ø1 20.2 21.1 27.35 31.2 33.6 (7.1) (0.6) ( 1.5 ) 5( 0.9 .4 5.6 9.6 8Ø1 5.2(Shutter height) Recommended PCB mounting pattern (PCB thickness : 1 mm min.) 0.2 0.8 7.7 Shell ground tab (4) No conducive traces Contact plating (contact area/termination) Shell plating (Body / termination) Gold / Tinned copper Nickel / Tinned copper Shutter color Packaging RoHS Silver Black 500 pcs/reel 5 EX80 Series●0.6 mm Pitch, Docking Station Connectors Connector mounting condition Receptacle EX80-*S-SH PCB 5.2 7.5 0.8 1 1 5.5 1.5 3.5 2 3.6 (4.9) 4.5 13 7.5 5.5 3.5 2 2 2 3.5 (4.9) 4.5 13 3.6 1 1 1.1 PCB Receptacle EX80-*S 1.6 Type with shutters Housing mounting condition (Shown for reference only) Type without shutters Housing mounting condition (Shown for reference only) EX80-*P Plug PCB EX80-*P Plug PCB Note: The stacking length between boards of this connector is 13 mm. Precautions • Make the stacking height design value of the set 13.0 to 13.7 mm. Establish the setting so that the stacking height is 14.5 mm or less including the accumulative tolerance of the set. • Use a floating structure (of 1.2 mm or less) to mount this product. (Within 0.7 mm for the type with shutters) • Be sure to also establish a guide structure on the set side. • For set designs in which the connector rotates and mates, make the radius of the rotation axis 100 mm or greater. Personal computer mm 100 r eate or gr EX80-**P Docking station side ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 10/2014. Contents are subject to change without notice for the purpose of improvements.
EX80-54P(01)
物料型号:EX80系列
器件简介:EX80系列是用于笔记本电脑对接站和其他需要高可靠性、高速数据传输、顺序配对连接的应用的连接器。
引脚分配:文档中提供了100针和54针的引脚分配图,包括电源接触点和信号接触点。
参数特性: - 信号接触点:0.5A电流额定值,3A的高电导率专用电源接触点。 - 接触电阻:信号接触点最大70毫欧,电源接触点最大40毫欧。 - 绝缘电阻:最小300兆欧。 - 耐电压:350V AC,1分钟无闪络或绝缘击穿。
功能详解: - 确保电气和机械连接的安全性。 - 插头设计确保正确的接触接合顺序:地-信号-电源。 - 金属壳体上的导引片确保了与板的正确接地顺序和高接地连接可靠性。 - 可传输2.5Gbps的信号(PCIe)。 - 防止助焊剂渗透到接触区域。 - X/Y轴1.2mm内自动对齐。 - 波纹接触配置确保5000次(配对/未配对)的电气和机械连接可靠性。
应用信息:适用于笔记本电脑对接站和其他需要高可靠性、高速数据传输顺序配对连接的应用。
封装信息:包括插座和插头的组件材料、镀层、订购信息和推荐PCB安装图案。所有连接器设计用于安装在至少1mm厚的PCB上。
EX80-54P(01) 价格&库存
很抱歉,暂时无法提供与“EX80-54P(01)”相匹配的价格&库存,您可以联系我们找货
