ASP-132424-01
ASP-132424-01
    SAMTEC(申泰)
    VITA42SOCKETASSEMBLY
ASP-132424-01 数据手册
ASP-132424-01 REVISION NOTES: 1. 64 POSITION QTH IS NON-STANDARD. 2. USE ASP-125450-03-B & ASP-132421-01-B. 3. C REPRESENTS A CRITICAL DIMENSION. 4. MINIMUM PUSHOUT FORCE: .5 LB. 5. MINIMUM GROUND PLANE RETENTION: 1 LB. 6. PARTS TO BE MOLDED TO POSITION. 7. MAXIMUM VARIANCE OF .002[.05]. APPLIES TO SIGNAL OR GROUNDS INDEPENDENT OF THE GROUND OR SIGNAL PINS RESPECTIVELY. 8. GROUND PLANE PRESS HEIGHT MUST BE .003 [.07] LESS THAN THE MAXIMUM HEIGHT OR .002[.03] GREATER THAN THE MINIMUM HEIGHT OF SIGNAL PIN. 9. PARTS TO BE PACKAGED IN TRAYS. 1.575 40.01 REF .788 20.00 REF 01 31 EQ SPACES @ .0197 [.500] F 127 5 .020 0.51 .235 5.97 REF .155 3.94 REF ACCEPTANCE OF DRAWING ACCEPTED WITH DEVIATIONS LISTED 02 .276 7.01 .027 0.69 REF .644 16.36 REF (TYP) 128 .008 0.20 REF (TYP) .276 7.01 REF "A" .650±.020 16.50±0.508 2 1 .038 0.95 REF .098 2.49 REF .278 7.07 REF .409 10.40 +.0030 .004 [0.10] (SEE NOTE 8) .015 0.38 REF 4 .037 0.94 REF .745 18.92 REF (TYP) .281 7.14 REF SECTION "A"-"A" .265 6.73 REF FAX No: PHONE No: PRINTED NAME CUSTOMER SIGNATURE COMPANY: DATE: "A" .035 0.89 REF +0.076 .4043 - .0010 10.269 - 0.025 (SEE NOTES 7 & 8) C2 .118 3.00 REF 3 .053 1.33 REF C1 1.515 38.48 REF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. ITEM NO. PART NUMBER QUANTITY MATERIAL 1 ASP-125450-03-B 1.0000 VECTRA E130i, COLOR: BLACK 2 T-1S60-03-L 128.00 PHOS BRONZE, 510 SPRING TEMPER 3 ASP-132421-01-B 1.0000 VECTRA E130i, COLOR: BLACK 4 T-1G1-03-L 2.0000 PHOS BRONZE, 510 HALF HARD TEMPER 5 K-DOT-.276-.375-.005 1.0000 POLYIMIDE FILM (KAPTON) 6 TRAY-QXX002-PR-03-AP-T-A 1.0000 ANTI-STATIC BLACK HIPS TOLERANCES ARE: DECIMALS .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] ANGLES 2 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 PLATING: TERMINAL & GROUND PLANE CONTACT AREA: .000010 GOLD OVER .000050 NICKEL REMAINDER: .000150 MATTE TIN OVER .000050 NICKEL F:\DWG\SW\ASP\132000\ASP-132424-01.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: DWG. NO. MODIFIED QTH ASSEMBLY ASP-132424-01 BY: B. COOPER 5/7/2007 SHEET 1 OF 2 ASP-132424-01 REVISION F RECOMMENDED PCB LAYOUT 1.515 38.48 .7875 20.00 (TYP) CL .0586 1.49 .6104 15.50 (TYP) .0273 0.69 (TYP) .0400 1.02 (NPTH TYP) .0415 1.05 (TYP) .0800 2.03 (TYP) 01 02 .2500 6.35 (TYP) 127 .0250 0.64 (TYP) .2075 5.27 (TYP) .1215 3.09 (TYP) 128 .0120 0.30 (TYP) .0570 1.45 (TYP) .0197 0.50 (TYP) .1850 4.70 (TYP) (TYP-2 PLCS PER BANK) .6650 16.89 (TYP) .1000 2.54 (TYP) (TYP-2 PLCS PER BANK) .7875 20.00 (TYP) ALL DIMENSIONS ARE SYMMETRIC ABOUT THE CENTERLINE PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: DWG. NO. F:\DWG\SW\ASP\132000\ASP-132424-01.SLDDRW MODIFIED QTH ASSEMBLY ASP-132424-01 BY: B. COOPER 5/7/2007 SHEET 2 OF 2
ASP-132424-01 价格&库存
很抱歉,暂时无法提供与“ASP-132424-01”相匹配的价格&库存,您可以联系我们找货
