ASP-103612-08
REVISION
NOTES:
1. ASP-103597-01-B BODY FOR NON-STANDARD 19 POSITION.
2. CX-XX-XX REPRESENTS A CRITICAL DIMENSION.
3. MAXIMUM BURR ALLOWANCE: .0005[0.013].
4. MINIMUM PUSHOUT FORCE: .5 LB.
5. CONTACT TO BE FLUSH TO ±.002[0.05] RECESSED. C2-B-DG
6. ONE REEL MINIMUM PLATING REQUIREMENT (85,000 CONTACTS PER REEL).
7. ALL DIMS TO BE SYMMETRICAL ABOUT THE CENTERLINE WITHIN ±.001[0.03].
8. .0025[0.064] MAX VARIATION BETWEEN SOLDERBALLS.
9. REFER TO VISUAL INSPECTION BOARD FOR SOLDERBALL APPEARANCE CHECKS.
10. THE DISTANCE FROM THE CENTER OF ANY SOLDERBALL TO THE
CENTER OF ANY ADJACENT INNER PEG SHALL BE .025±.005[0.64±0.13].
11. SOLDER JOINTS TO BE INSPECTED PER IPC SPECIFICATION 12.2.12 (IPC-A-610C).
F 12. PARTS TO BE PACKAGED IN TRAYS.
IN-PROCESS WITHOUT SOLDERBALLS
CRITICAL DIMENSION INSPECTION INSTRUCTION TABLE
1.0700 27.178 REF
ASSEMBLY OPERATION
.9700 24.638 REF
19
C1-A,I-MV
BY SIGNING THIS DOCUMENT
YOU ARE ACCEPTING THE
CONDITIONS SET WITHIN.
YOUR REQUIREMENTS MUST BE
LISTED WITHIN THIS DRAWING.
WHERE NO DIRECTION FROM THE
CUSTOMER IS IDENTIFIED
SAMTEC'S PROCESS
REQUIREMENTS WILL BE USED.
.017±.010 0.43±0.25
FILL C-226-03-H
FINISHED GOOD
INSPECTION
01
.9000±.0020 22.860±0.051
(18 POS x .0500 [1.270])
IN-PROCESS INSPECTION
.320 8.13 REF
C1, C2
C1
A
B
C .145 3.68
REF
D
.095 2.41
REF
.250 6.35
E
F
.354 8.99
4
.035 0.89 REF
.308±.020 7.82±0.51
2
.134±.003 3.41±0.08
EXCEPTIONS:
PHONE No:
1
PRINTED NAME:
CUSTOMER SIGNATURE:
COMPANY:
DATE:
.139 3.54
.012 0.31
(SEE NOTE 8)
"A"
NON STANDARD
COMPONENT
ITEM NO.
PART NUMBER
QUANTITY
MATERIAL
1
ASP-103597-01-B
1.0000
LCP,UL 94 V0, COLOR: BLACK
2
C-226-03-H
114.00
PHOS BRONZE, 521 HARD TEMPER
3
SDB-030-6337
114.00
63% TIN / 37% LEAD
4
K-850-650
1.0000
POLYIMIDE FILM
5
SEE NOTE 5
.104 2.64
"A"
TY-YFS004-19-3-6
.01539
HIPS
ASSEMBLY
TOOLING
PROCESS
X
SECTION "A"-"A"
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
.XX: .01
.XXX: .005
.XXXX: .0020
ANGLES
2
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
OTHER
SHEET SCALE: 3:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
email: info @SAMTEC.COM
DESCRIPTION:
VITA 42 (LEADED) SOCKET ASSEMBLY
PLATING:
CONTACT AREA: .000030 GOLD OVER .000050 NICKEL
REMAINDER: .000003 FLASH GOLD OVER .000050 NICKEL
DWG. NO.
F:\DWG\SW\ASP\103000\asp-103612-08.slddrw
BY: G. PURVIS
PACKAGING
F
3
ASP-103612-08
5/4/2007
SHEET 1 OF 2
ASP-103612-08
REVISION F
.9000 22.860
CL
19
01
A
B
CL
.2500 6.350
C
D
E
F
'B'
RECOMMENDED BOARD LAYOUT
RECOMMENDED STENCIL LAYOUT
STENCIL TO BE .0060[.152] THICK
NOTE:
OUTER ROWS MAY NOT NEED VIAS - THIS IS LEFT TO
THE DISCRETION OF THE BOARD DESIGNER.
.900 22.86
19
.050 1.27
(TYP)
01
A
.0250 0.635
B
C
.250 6.35
D
E
.0100 0.254
TRACE
F
.050 1.27
(TYP)
.0310 0.787
FREE OF SOLDER MASK
.0250 0.635
(TYP)
45°
.0250 0.64
PAD
PROPRIETARY NOTE
.0100 0.254
VIA (PLATED)
DETAIL 'B'
SCALE 12 : 1
.0200 0.51
PAD
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
email:info @SAMTEC.com
DESCRIPTION:
DWG. NO.
ASP-103612-08
BY: G. PURVIS
5/4/2007
SHEET 2 OF 2
很抱歉,暂时无法提供与“ASP-103612-08”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+395.28000
- 100+363.65760
